Golf MK7 rear PDC retrofit
XPepino
Czech Republic
C?ID=91614
Hello
I made retrofit of rear PDC on Golf MK7 Variant and used there unit what can operate with 8K sensor.
Now i have 2 problems:
- it write error that there is no front sensors + speaker
- not show PDC OPS display on headunit
Is there any way to get working only 4 rear sensors with this 8K PDC unit without errors and OPS on display? (ie flash via ODIS or VCP or something like this).
Thank you!
Here is complete scan:
Thursday,30,August,2018,10:00:46:12448
VCDS Version: 18.7.1.1 (x64)  HEX-NET CB: 0.4427.4
Data version: 20180731 DS293.0
VIN: WVWZZZAUZHP543743   License Plate:
Mileage: 42854km-26628mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZHP543743   Mileage: 42854km-26628miles
Address 01: Engine (J623-CPWA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 N    HW: 04E 907 309 E
   Component: R4 1.4l CSI   H15 9105
   Revision: WIH15---
   Coding: 01250012232405082000
   Shop #: WSC 00028 028 00072
   ASAM Dataset: EV_ECM14CSI01104E906016N 002009
   ROD: EV_ECM14CSI_VW37.rod
   VCID: 2D12FD3A7C219E228F-8078
   CAN Converter 01:
Readiness: 1110 0001
   Part No SW: 0CW 300 049 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0915
   Revision: 00005026    Serial number: CU501609217053
   Shop #: WSC 00028 028 00067
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 44C4B89ECFAB7F6A70-8010
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 62686000001336
   Coding: 48FA6AA12424116F477E060441C62512562488E26082A47300220078C20203
   ROD: EV_Brake1UDSContiMK100IPB_035.rod
   VCID: 7AB80666FDEFF99A5A-802E
   Part No SW: 5G0 907 044 BK    HW: 5G0 907 044 BK
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 02020004200110011005000000101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 71AA214AA099BAC2EB-8024
   Air quality sensor:
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Revision: --------    Serial number: 8658260916000B
   Coding: 00001842C24102FB4BE44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 004C748E9B33A34A14-8054
   Component: WWS    160909  043 0551
   Serial number:         160919152353
   Component: RLHS  042 0105
   Serial number: S4Y16M10D04H05M22S40
   Coding: 00A8DD
   Component: PARKHILFE 7K  H03 0054
   Revision: --------    Serial number: 39391609200538
   Coding: 0031051051
   Shop #: WSC 73430 790 12345
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 43C6BB82CAA5785249-8016
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Reset counter: 42
                    Mileage: 42854 km
                    Date: 2018.08.30
                    Time: 09:52:35
1111316 - Speaker for Front Parking Aid
          B10F5 14 [009] - Open or Short to Ground
                    Reset counter: 42
                    Mileage: 42854 km
                    Date: 2018.08.30
                    Time: 09:52:27
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R25HXL0
   Shop #: WSC 00028 028 00059
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41CAB18AD0B96A425B-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 709 16
   Serial number: 35767000000B17702F1T
   Subsystem 2 - Part No SW: -----------    HW: 480 002 709 16
   Serial number: 3586700000082625ED1.
   Subsystem 3 - Part No SW: -----------    HW: 480 401 709 16
   Serial number: 3516502BF21A37159101
   Subsystem 4 - Part No SW: -----------    HW: 480 401 709 16
   Serial number: 3526502AD229A2E4B17M
   Subsystem 5 - Part No SW: -----------    HW: 480 401 709 16
   Serial number: 3556502A921A372200C+
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20160930200034
   Coding: 0410
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FCEB772A64D1CB22D-806A
   Part No SW: 5G1 920 742 B    HW: 5G1 920 742 B
   Component: KOMBI         204 8311
   Coding: 03A412082380000801082A001400000000000000
   VCID: 271E0F125EDDB47275-8072
   Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2265
   Revision: --------    Serial number: 22091610800106
   Coding: 030100043F085700FB0402481C0F00010001050000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7BB60362F2D5C09241-802E
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29160001848880066377
   Coding: 28FFFF
   Serial number: 5935111604
   Component: TSG FS        010 0031
   Serial number: 0000220129912
   Coding: 003A03208000020000001000
   VCID: 47DEAF92FE9D547295-8012
   Serial number: 00000000000004624407
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45C2A59AC491466267-8010
   Component: TSG BFS       010 0031
   Serial number: 0000219901772
   Coding: 003A01208000020000801000
   VCID: 46C0A296F9974D7A6E-8012
   Serial number: 00000000000004626663
   Coding: 090000
   Part No SW: 3Q0 035 819 B    HW: 3Q0 035 819 B
   Component: MU-S--ER      H30 0359
   Serial number: VWZAZ2S0541326
   Coding: 02730200FF0000005111000100080A001F0100C40120010001
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 302CE44E6B13F3CAA4-8064
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H50 4065
   Serial number: VWZ6Z9S2801668
End----------(Elapsed Time: 01:32, VBatt start/end: 14.7V/14.7V)-----------
downtime
Finland
C?ID=280813
No. You need 4 sensor unit or you need to install the missing 4 front sensors, front speaker + PDC switch.
XPepino
Czech Republic
C?ID=91614
And is it not solution to flash with 4k PDC unit firmware ?
