Golf 7 lost AIR CARE after swapping Climatronic panel
darkchina811
ITALY
C?ID=333184
Hello all,
I am in the process of retrofitting heated seats and the auxiliary heater, so I replaced the Climatronic panel in order to obtain the missing buttons. Since I did the swap, everything works fine (after I did basic settings / first AC compressor run-in), but I have lost the AIR CARE function that was under setting in the Climatronic menu.
I have looked everywhere in the coding and adaptations but could not find any related entry.
I suppose the Climatronic panel I installed is older and has an older firmware. I asked the dealer to update it, they tried but ODIS refused to update because ODIS is online and it says that particular panel should not be in my car.
Does anybody know if the AIR CARE function is actually related to the panel firmware?
Does anybody know if ODIS can be forced to update the firmware?
I attach the details: top is car's original panel (AIR CARE ok but no aux heat / heated seats buttons) and bottom is current panel (all buttons but no AIR CARE).
[b]Removed.  Data from a clone/pirate copy of VCDS is not welcome here.[/b]
darkchina811
ITALY
C?ID=333184
Here you go, this is with the original panel. I don't have one at hand with the current panel but nothing changes except module 08 details. Of course coding and adaptations were matched after replacing the panel.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
It's not full AS file. Missing something like:
Saturday,01,October,2016,16:03:46:09030
VCDS Version: 16.8.2.3  HEX-V2 CB: 0.4324.4
Data version: 20160926 DS261.0
VIN: TMBPH16Y013252230   License Plate: AR005HD
Mileage: 88830km-55196mi   Repair Order:
I'm sorry, I have to thread lock, based on e-mail report.
Please wait for Admin decision. Thread lock until further notice.
Posts edited and thread unlocked.
The OP (darkchina811) has a legitimate VCDS system. There is no excuse for him to be using a cloned/pirate one.
darkchina811
ITALY
C?ID=333184
Here's a recent scan, all the errors are just because I disconnected battery/airbags. Normally, zero errors.
Monday,27,August,2018,19:05:50:06888
VCDS Version: 18.2.1.5  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WVWZZZAUZHW0xxxxx   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZHW0xxxxx   Mileage: 20502km-12739miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2833
   Revision: R7H25---
   Coding: 0119003223241D082000
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B833BBF03045EDFB46-803E
   CAN Converter 01:
17158 - Databus
                    Mileage: 20458 km
                    Date: 2018.08.26
                    Time: 00:22:28
                    Engine speed: 0.00 /min
                    Coolant temperature: 21 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.133 V
                    Unlearning counter according OBD: 36
                    Acceleration: 0.000 m/s²
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 131
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
          U0428 00 [032] - -
                    Mileage: 20458 km
                    Date: 2018.08.26
                    Time: 00:22:27
                    Voltage terminal 30: 12.180 V
                    Outside air temperature: 215 °C
                    Absolute intake pressure: 99 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 47.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
   Component: ESC           H62 0637
   Revision: 00000000    Serial number: 91596000011507
   Coding: 01FA6AA1242219704779060841C62980562498E26082947300200078C00203
   ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
   VCID: 74B120C35E3A812765C-8020
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 165
                    Mileage: 20458 km
                    Date: 2018.08.26
                    Time: 00:22:28
16412 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 165
                    Mileage: 20458 km
                    Date: 2018.08.26
                    Time: 00:22:38
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 165
                    Mileage: 20458 km
                    Date: 2018.08.26
                    Time: 00:22:38
   Part No SW: 5G0 907 044 BE    HW: 5G0 907 044 BE
   Revision: 00001K08
   Coding: 00020004100110011005004000101022
   Air quality sensor:
   Part No SW: 5Q0 937 084 CJ    HW: 5Q0 937 084 AL
   Component: BCM MQBAB M   H24 0175
   Serial number: 01061616601135
   Coding: 00000842C20102FB4B644080B11403281000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 025D761B148EBF97670-8056
   Component: WWS    160522  043 0551
   Serial number:         160601172917
   Coding: 0E4DFD
   Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 90482146
   Coding: 02006C
   Serial number: 000000000ZY15028208R
   Serial number: 00000000000030139763
   Revision: --------    Serial number: 39331616902729
   Coding: 0031151001
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 43D3B31F4B14769F2C6-8016
13637426 - Databus
                    Reset counter: 165
                    Mileage: 20458 km
                    Date: 2018.08.26
                    Time: 00:22:28
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1V1W4Y
   VCID: 41DFB9175108648F3EA-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 35767000000432B44C1Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
   Serial number: 358670000008B4C4DB17
   Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3516502BB205729313D3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3526502AF2076340F201
   Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
   Serial number: 35565029B21160C1025X
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 13061608490829
   Coding: 0400
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0D4755275DD0F0EF0A2-8058
   Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
   Component: KOMBI         303 8311
   Coding: 07A501002380000801083B001400000000000000
   VCID: 26150A8BD866A3B72B8-8072
   Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1265
   Revision: --------    Serial number: 0005024934
   Coding: 030100043F085700FB000248080F00010001050000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 7BA30BFF7364CE5F246-802E
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001142480026234
   Coding: 28FFFF
   Serial number: 8442320304
   Serial number: 300516EEU02971
   Coding: 003B0320D000040100001000
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCEFB3CDE37577F0-806E
16272 - Steering Angle Sensor
                    Reset counter: 130
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 12.25 V
                    Temperature: 20.0 °C
                    KFC: 3F
                    KFA: 00 90
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.30 V
                    uAdSensI_SwitchedKl30_xdu16: 12.31 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
   Serial number: 280516EER24731
   Coding: 003B0120DE00040100801000
   VCID: 42DDB61B540E7F97270-8016
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0744
   Coding: 02730000AA0000005111000100080A001F0206D40120010003
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 2C01F8A3C68A99E7FDC-8078
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJT00QNA
1564 - Microphone 1
          B129B 13 [008] - Open Circuit
                    Reset counter: 168
                    Mileage: 20458 km
                    Date: 2018.08.26
                    Time: 01:49:29
                    Voltage terminal 30: 14.5 V
End----------(Elapsed Time: 01:59, VBatt start/end: 12.3V/12.3V)-----------
myounus
Northwest UK
C?ID=321059
Can you please delete all DTC's and post a new scan.
Did you car have AC Manuel and you upgraded to a climatronic?
downtime
Finland
C?ID=280813
No, he retrofitted aux heater and heated seats which means you need to swap the climatronic panel as well as his old one did not have buttons for heated seats and no button for aux heater start / stop.
SW update can be done with ODIS-E. But OP needs to obtain the flash file by himself from Erwin. Unfortunately for OPs Climatronic panel, there's no sw update available :(
What was OPs previous climatronic part number?
I don't know exactly which clima versions have Aircare but if I would need to guess based on ETKA, I would guess either 5GE907044AE, 5GE907044AH or 5GE907044AP. All of these three have seat heating and aux heater buttons as well. There were not PR numbers in ETKA describing AirCare, so it's just a guess.
darkchina811
ITALY
C?ID=333184
Here is a clean auto scan, not that it makes any difference for module 08 anyway.
The Climatronic that came with the car is 5G0 907 044 BK (H04 1601).
Wednesday,29,August,2018,14:39:45:06888
VIN: WVWZZZAUZHW0xxxxx   Mileage: 20504km-12740miles
   Revision: R7H25---
   CAN Converter 01:
Readiness: 1110 0001
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DFD
   Coding: 02006C
   Coding: 0031151001
   Coding: 0400
   Coding: 28FFFF
   Coding: 8107
End----------(Elapsed Time: 01:58, VBatt start/end: 12.0V/12.0V)-----------
myounus
Northwest UK
C?ID=321059
It's not required for the electric aux heater that's usually present in most diesel models in the uk. If retrofitting the webasto aux heater then I'm not sure what's the part numbers would be of compatible climatronic panels. I've never retrofitted it but have seen it on a friend's Golf R factory fitted where he switched it on/off through the screen.
I think the easiest way (in the absence of a flashing tool) would be to purchase an updated panel.
darkchina811
ITALY
C?ID=333184
I had to swap the panel mainly for heated seats buttons, then I thought, since I have to swap, I'll get one with the Webasto button as well. you know, just because.
I think the easiest solution is that I live without the AIR CARE feature. I can breathe just fine while driving :)
thank you all.
downtime
Finland
C?ID=280813
Jep. I agree. One of the most unneeded functions in my opinion. It needs the double priced air filter as well.
I have it in my own car (Volvo V90, called CleanAir) and don’t have it in my wife’s Seat Leon. I haven’t had a single problem in breathing in either one and accidental gas leaks from passengers smell as bad in both :)
darkchina811
ITALY
C?ID=333184
mmm, how does it NEED the more expensive cabin filter, the car doesn't know what filter gets installed.
anyway, who cares. it's just that I am not completely satisfied until I discover what made the feature disappear.
downtime
Finland
C?ID=280813
Technically it does not know that in any way, it is just the requirement dictated by VW in line with AirCare climatronic.
Maybe the whole idea of AirCare is the biofilter. Climatronic panel does not have any difference. I have air quality sensor in our Seat and it changes the airflow from fresh air to circulation if there’s bad air quality.
VAG just has invented a name for the absurdly priced filter.
What was the part number of your old climatronic panel?
darkchina811
ITALY
C?ID=333184
I am not home so can't answer everything, but there must be a difference somewhere. with the original panel I see AIR CARE on the screen, it can be activated, while with the new panel I don't see it.
South Molton, UK
Not all climate control panels support auto-recirculation (AirCare), on my previous Audi I ordered it as an option and the climate control panel had different buttons and a different part number.
Knowing the part number of both you previous and retrofitted climate control panel is IMHO key to understanding why the feature has disappeared.
It may be that either:
- the new panel doesn't support AirCare and you need a different one; OR
- you need to make coding and/or adaptation changes.
darkchina811
ITALY
C?ID=333184
the auto-recirculation option is still present in the menu, while the AIR CARE is gone, so I think AIR CARE is something else.
if you go scroll the thread up I already pointed out the part number for the original panel :)
golfi_vend
Tartu, Estonia
C?ID=195131
Firmware may be flashable to aupport AirCare. It also may not. We need p/n-s.
darkchina811
ITALY
C?ID=333184
Climatronic that came with the car is 5G0 907 044 BK (H04 1601), no heated seats and no Webasto buttons. AIR CARE present.
the one installed now, with all buttons, is 5G0 907 044 BE (H03 1001). I have the buttons I need but AIR CARE is gone.
downtime
Finland
C?ID=280813
Hardware is different. Old has H04, new one H03. Also new one has lower software version than old one.
Like Golfi_vend wrote, the sw might be flashable to newer version supporting AirCare, maybe. Erwin unfortunately did not contain upgrade file for the climatronic, but I know that they are not obtainable that easy from there.
And no need to have such pointy attitude. People here try to help, and to be able to do that, as nobody else has access to your car and there are no telepathic skills obtained yet, we need as much information as possible. Your latest post provided the info what takes things forward now.
And about AirCare. As far as I know it's just a brand for the biofilter VAG introduced couple of years ago. The air ducts are exactly the same, the flap motors are the same and air recirculation is the same.
