B8 A4 led tail lamp euro coding
matteo.panciroli
Italy
HC485763 (2nd hand?)
hi,
I am new in this forum and I tried to replay in a same thread (called B8 A4 led tail lamp euro coding ) but with no success (I think I have no access to it yet).
Basically I have almost the same situation of this guy (Tonymk6).
I have a 2013 Audi b8 A4 (American version) and I am trying to convert the rear lights in the European version (such as: turn signal/fog light).
Basically I tried to compare our channels values with the ones provided by rlarsen (table NA and RoW values) , however it seams that this vehicle has a completely different set of values.
Can somebody help me to understand what are the new values for the European version?
just to summarize, these are my values:
Channel - Value
195 51201
196 51233
197 6
198 38
199 0
200 32
201 51201
202 51233
203 73
204 105
205 13
206 45
207 134
208 166
209 51219
210 51251
I have also the auto scan from the VCDS (but it will be a too long message) I give you just the first lines
(plz forget about all these malfunctions since we are working on this car and it is almost completely disassembled)
Thursday,02,August,2018,12:07:05:15741
VCDS Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
VIN: WAUEFAFL4DN015487 License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 44 46 47 52 53 56 62
72 77
VIN: WAUEFAFL4DN015487 Mileage: 13000km-8077miles
44-Steering Assist -- Status: Sporadic communication error 1000
matteo.panciroli
Italy
Sorry. This is the full auto-scan
          72 77
Address 01: Engine (DET-CAEB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 C    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0003
   Revision: ECH09---
   Coding: 4A030013242400062000
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM20TFS0118K5907115C 001004
   ROD: EV_ECM20TFS0118K5907115C.rod
   VCID: 3260F04865121CD4E2-8066
4367 - Powertrain Databus
          U0001 00 [032] - Unspecified Malfunction
4451 - Powertrain Databus
          U0002 00 [032] - No Communications
4629 - ECM Power Relay Load Circuit
          P068A 00 [096] - Opens Too Early
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 4 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 7.327 V
                    Unlearning counter according OBD: 33
                    Median injection timing: 0.000 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
2838 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K2 927 155 E    HW: 0AW 927 156 K
   Component: 0AW 20TAVSUSA H04 0002
   Revision: --H04---    Serial number: 0000000244
   ASAM Dataset: EV_TCMVL381 A02431
   ROD: EV_TCMVL381.rod
   VCID: 3776C15C8E70F9FCD5-8062
   Part No SW: 8K0 907 379 CH    HW: 8K0 907 379 CH
   Component: ESP8 front    H09 0100
   Coding: 081D18
   Shop #: WSC 02391 823 56573
   VCID: 01026F849834774C2B-8054
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
                    Reset counter: 131
                    Mileage: 12591 km
                    Date: 2017.03.20
                    Time: 18:51:07
                    Hex Value: 0x1800
                    Hex Value: 0x4006
                    Hex Value: 0x1F21
                    Hex Value: 0x1FB2
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GL    HW: 8K0 907 064 FL
   Component: BCM2 2.0      H11 0621
   Coding: 09814000000000000000
   Shop #: WSC 02399 823 56573
   VCID: 00046A80933E7E4424-8054
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0812000124513003
   Serial number: 2312000145066003
                    Reset counter: 153
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:35
                    Fault Status: 00101101
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:12:20
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 153
                    Mileage: 13008 km
                    Date: 2018.05.10
                    Time: 00:50:11
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01100720120446
   Coding: 6400208000
   VCID: 3972C764B064EF8C23-806C
03037 - Rear Temperature Selection Potentiometer (G538)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 73
                    Mileage: 644 km
                    Date: 2014.05.01
                    Time: 20:58:33
                    Voltage: 13.30 V
                    Voltage: 4.90 V
00457 - Control Module for Network (J519)
                    Reset counter: 113
                    Mileage: 644 km
                    Date: 2014.05.01
                    Time: 20:58:38
                    Reset counter: 153
                    Mileage: 13008 km
                    Date: 2018.05.10
                    Time: 00:51:50
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000447358902
   Coding: 26008091863CAFC00000400300003D0D0F1C520822090221000008004000020100000000000000
   VCID: 76E80C58C1FA40F40E-8022
   Component: WWS 090712  H07 0080
   Serial number: SWF12070095996
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002306121037
   Subsystem 3 - Part No SW: 4G0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R27GM02
   Serial number: 4A08C836000000000001
                    Reset counter: 208
                    Mileage: 1795 km
                    Date: 2015.07.28
                    Time: 23:30:38
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 208
                    Mileage: 1795 km
                    Date: 2015.07.28
                    Time: 23:30:38
                    Fault Status: 01101100
                    Reset counter: 164
                    Mileage: 7594 km
                    Date: 2016.06.03
                    Time: 21:49:29
                    Fault Status: 01101101
                    Reset counter: 113
                    Mileage: 13009 km
                    Date: 2018.05.10
                    Time: 22:24:38
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:13:03
                    Reset counter: 153
                    Mileage: 13008 km
                    Date: 2018.05.10
                    Time: 00:51:58
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD90EJNY
   Coding: 303842354730303030304A55304C384B3053
   VCID: 4A9088A8ED827414BA-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1200009ZAF
   Serial number: 6334MSME6E327702E
   Serial number: 6344MSME6F00257EN
   Serial number: 6352QSME641C335CN
   Serial number: 6362QSME601B154CI
   Serial number: 63732SME6D1B4D74F
   Serial number: 63832SME641C1164Z
13635840 - Supply voltage
                    Reset counter: 153
                    Mileage: 13008 km
                    Date: 2018.05.10
                    Time: 00:50:57
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 153
                    Mileage: 13008 km
                    Date: 2018.05.10
                    Time: 00:50:13
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Component: Lenks.Modul   H03 0004
   Revision: --------    Serial number: 90372LG4000HO
   Coding: 000016
   VCID: 438EA58CC2A8A55C79-8016
   Component: E221 - MFL  H03 0003
00886 - Turn Signal Switch (E2)
                    Fault Frequency: 20
                    Reset counter: 128
                    Mileage: 11383 km
                    Date: 2017.01.20
                    Time: 01:24:18
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:33
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:33
   Part No SW: 8K0 920 950 R    HW: 8K0 920 950 R
   Component: KOMBIINSTR.   H09 0553
   Revision: 00200000    Serial number: RB957A27D
   Coding: 8B9609000301D705020000
   VCID: 3E78D478A94AC8B416-806A
   Part No SW: 8R0 907 468 F    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0051
   Revision: 1V060024    Serial number: 2441V126168054
   Coding: 80C303FF00
   VCID: 4280A088DDB2AC5472-8016
   Serial number: 7154457701
                    Reset counter: 153
                    Mileage: 12967 km
                    Date: 2018.02.06
                    Time: 19:58:07
                    Bin. Bits:    00000
                    Voltage: 11.20 V
                    Count: 7
                    Reset counter: 153
                    Mileage: 13009 km
                    Date: 2018.05.08
                    Time: 00:16:29
                    Bin. Bits:    00000
                    Voltage: 12.90 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.70 s
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:34
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:34
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000032349645
   Coding: 00581300000000000000
   VCID: 3B7EDD6CBA58DD9C31-806E
                    Reset counter: 145
                    Reset counter: 153
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:12:33
03319 - Switch for Cushion Angle: Down
                    Fault Status: 00100011
                    Reset counter: 153
                    Mileage: 13009 km
                    Date: 2018.05.07
                    Time: 06:47:19
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C03204E00410001
   VCID: 56A86CD8213A20F42E-8002
02111 - Motor for Window Regulator
                    Fault Status: 00100101
                    Reset counter: 129
                    Mileage: 12764 km
                    Date: 2017.03.23
                    Time: 09:18:51
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:38
                    Fault Status: 00101100
                    Reset counter: 27
                    Mileage: 1112 km
                    Date: 2014.08.10
                    Time: 06:17:23
00109 - Left Mirror Turn Signal Lamp (L131)
                    Reset counter: 153
                    Mileage: 1090 km
                    Date: 2014.08.10
                    Time: 05:56:23
   Part No SW: 8K0 909 144 E    HW: 8K0 909 144 B
   Component: RCEPS         H37 0506
   Revision: 00001000    Serial number: 0026682433
   Coding: 100000000001
   Shop #: WSC 01116 444 108813
   ASAM Dataset: EV_RCEPSAU48X 006012
   ROD: EV_RCEPSAU48X_006.rod
   VCID: 336EF54C9A0815DCE9-8066
   Revision: 00002001    Serial number: 0179686913
   Coding: 0106023A00FA400480B0013200000000
   Subsystem 2 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
03128 - Switch 1 for Sunroof
                    Fault Frequency: 55
                    Reset counter: 113
                    Mileage: 13009 km
                    Date: 2018.05.07
                    Time: 05:57:59
01514 - Regulator for Roof
                    Fault Frequency: 48
                    Reset counter: 113
                    Mileage: 13009 km
                    Date: 2018.05.07
                    Time: 05:57:59
                    Reset counter: 153
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:12:20
03233 - Controls for Garage Door Opener (E284)
                    Reset counter: 113
                    Mileage: 13009 km
                    Date: 2018.05.10
                    Time: 22:24:35
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T1 035 223     HW: 8T1 035 223
   Component: DSP Prem      H05 0040
   Revision: 00005001    Serial number: 94803004294301
   Coding: 0203010302
   VCID: 6CDC2E308FB68A24E8-8038
02753 - Inside Microphone (R74)
                    Reset counter: 113
                    Mileage: 13009 km
                    Date: 2018.05.10
                    Time: 22:24:41
                    Voltage: 13.40 V
                    Temperature: 22.0°C
                    Temperature: 27.0°C
                    Bin. Bits: 00000010
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55AA6BD43C3C2BEC27-8000
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:38
00110 - Right Mirror Turn Signal Lamp (L132)
                    Reset counter: 103
                    Mileage: 1112 km
                    Date: 2014.08.10
                    Time: 06:17:49
                    Reset counter: 131
                    Mileage: 1130 km
                    Date: 2014.08.10
                    Time: 06:32:26
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000069292
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3874C260836EF684DC-806C
463360 - Function Restriction due to Faults in Other Modules
          U1113 00 [000] - -
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 H    HW: 8R1 035 186 H
   Component: Con3 Sirius   H08 0461
   Revision: 00000001    Serial number: AUZ5Z6L1768748
   Coding: 040300020101850043D9070800
   VCID: 3A70D868B562E4942A-806E
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Reset counter: 153
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:44
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C03204000210001
   VCID: 59B267E450240F8C03-800C
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:38
   Component: TSG HR        H07 0304
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:11:38
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005277108
   Coding: 0010370
   Shop #: WSC 02335 785 00200
   VCID: 3E78D478694AC8B416-806A
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:18:44
                    Reset counter: 145
                    Mileage: 12967 km
                    Date: 2018.02.12
                    Time: 09:18:44
01523 - Microphone for Telephone (R38)
                    Reset counter: 113
                    Mileage: 13009 km
                    Date: 2018.05.07
                    Time: 05:58:07
End-------------------------(Elapsed Time: 03:36)--------------------------
matteo.panciroli
Italy
I am still investigating how to reprogrammed our A4 rear lights from North American to Euro spec.
We have already exchanged the tail lights (with the European standard version)
Now I am trying to code it properly .
I found something interesting (but not so helpful) here
http://ankk-vagcom.com/a5-8t-activer-les-clignotants-en-mode-us/
Can anybody help? or give any advice?
(PS: If I am posting in the wrong place Plz let me know and I'll post correctly next time)
Thx
herbol
Poland
Hi everyone,
I own A4 B8 MY 2013 sedan (US market) and I struggle with tail lights coding too. I have the same channels value like @matteo.panciroli who opened this thread. Does anyone could help me with proper coding to EU? Lights stayed US but with orange diods and separated turnlight path in tailgates lights. Thanks in advance for any help.
Saturday,09,November,2019,08:31:19:26307
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUBFAFL5EN030097   License Plate:
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
          77
VIN: WAUBFAFL5EN030097   Mileage: 169220km-105148miles
62-Door, Rear Left -- Status: Malfunction 1010
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 4A2A0013242600062000
   Shop #: WSC 46117 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
   ROD: EV_ECM20TFS0118K5907115N.rod
   VCID: 3D3235B8AC176DA78C-8068
   Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1005
   Revision: --H16---
   Coding: 000002
   VCID: 47DE5750FECB377726-8012
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 2D1D1801
   Shop #: WSC 02391 785 00200
   VCID: 095A9168A05F8107F0-805C
                    Reset counter: 235
                    Mileage: 168868 km
                    Date: 2019.03.27
                    Time: 17:01:45
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x001A
                    Hex Value: 0x02A6
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 JL    HW: 8K0 907 064 JL
   Component: BCM2 2.0      H14 0650
   Coding: 09814040000000000000
   VCID: 034683408273DB57BA-8056
   Serial number: 0514000002489005
   Serial number: 0213000403373006
                    Reset counter: 233
                    Mileage: 168868 km
                    Date: 2019.02.05
                    Time: 17:27:52
                    Reset counter: 0
                    Mileage: 169220 km
                    Date: 2019.11.08
                    Time: 21:09:47
   Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
   Component: KLIMA 1 ZONE  H02 0123
   Revision: A1000000    Serial number: 01230120140138
   Coding: 6480208000
   VCID: 373E2790862B47F756-8062
   Revision: 06016001    Serial number: 00000057317302
   Coding: 26000091863CAFC00000480300003D0D0F1C530822090221000004004000030100000000000000
   VCID: 76A0EA94C1A1FEFF8D-8022
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA101213  H18 0461
   Serial number: 1312060701162
   Coding: 004577
   Serial number: 22152502
   Coding: 02005D
   Serial number: 00000000001301140453
   Serial number: 0000002274555R9QY403
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: D339C907000000000001
                    Reset counter: 0
                    Mileage: 169220 km
                    Date: 2019.11.08
                    Time: 21:09:49
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KJDB0YYZ/
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 44060 001 1048576
   VCID: 4AD86E64EDD9CA1F39-801E
   Serial number: 5810000R140000HUQ3
   Serial number: 6334MSME416A4643B
   Serial number: 6344MSME430A7000+
   Serial number: 6352QSME4C3C1C56W
   Serial number: 6362QSME353D387EY
   Serial number: 63732SME3B3D306C7
   Serial number: 63832SME3B3D0B4AC
          [Bladder Mat: functional restriction because of low voltage]
                    Reset counter: 0
                    Mileage: 169220 km
                    Date: 2019.11.08
                    Time: 21:09:11
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NAJ000MI
   Coding: 000016
   VCID: 48DC546CFBD5380F2F-801C
   Part No SW: 8K0 920 951 E    HW: 8K0 920 951 E
   Component: KOMBIINSTR.   H09 0564
   Revision: 00200000    Serial number: ZA172AM1F
   Coding: 8B97090003010009020000
   VCID: 322816846D49A2DF61-8066
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0060
   Revision: 1V090029    Serial number: 2941V141140A1C
   Coding: 80C303FF00
   Serial number: 5328082203
                    Reset counter: 233
                    Mileage: 168868 km
                    Date: 2019.02.05
                    Time: 17:27:53
                    Bin. Bits:    00000
                    Voltage: 11.90 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.90 s
                    Fault Frequency: 29
                    Reset counter: 0
                    Mileage: 168868 km
                    Date: 2019.03.03
                    Time: 03:00:47
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 17
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 235
                    Mileage: 168868 km
                    Date: 2019.03.26
                    Time: 21:34:01
   Revision: 00000000
   Coding: 020302
   VCID: 393A21A8B03F5187A0-806C
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 21:17:22
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 21:17:22
03272 - Control Module for Audio Interface
                    Reset counter: 245
                    Mileage: 169039 km
                    Date: 2019.11.05
                    Time: 17:18:44
   Component: TSG FA        H09 0305
   Coding: 011C03204000410001
   VCID: 56E08A1421619EFFAD-8002
                    Reset counter: 230
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 21:17:25
                    Reset counter: 233
                    Mileage: 168868 km
                    Date: 2019.02.05
                    Time: 17:27:56
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0020595550
   Shop #: WSC 00399 211 09590
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3424109C9F5DACEF73-8060
16387 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Keine Freigabe der Lenkunterstützung aufgrund Unterspannung der Versorgungsspannung]
                    Reset counter: 230
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 21:17:30
                    Write only channel
18689 - Terminal 30
          U140A 00 [008] - Open Circuit
          [Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
                    Reset counter: 230
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 00:28:25
                    Write only channel
   Revision: 00002001    Serial number: 0325190074
   Component: GTO BF  H01 0080
   Serial number: 00000000000000782949
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 190
                    Mileage: 168862 km
                    Date: 2018.11.27
                    Time: 14:21:49
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 196
                    Mileage: 168862 km
                    Date: 2018.11.27
                    Time: 14:23:43
02615 - Fuel Tank Cap; Lock
                    Reset counter: 189
                    Mileage: 168862 km
                    Date: 2018.11.27
                    Time: 14:29:38
   Part No SW: 8R1 035 223 A    HW: 8R1 035 223
   Component: DSP STD       H08 0230
   Revision: 26S00000
   Coding: 0203010102
   VCID: 2B160BE04A63F31722-807E
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Fault Status: 00101011
                    Reset counter: 233
                    Mileage: 168862 km
                    Date: 2019.01.07
                    Time: 19:17:33
                    Voltage: 11.70 V
                    Temperature: 26.0°C
                    Bin. Bits: 00000001
                    Reset counter: 0
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 21:18:19
                    Voltage: 6.40 V
                    Temperature: 25.0°C
                    Bin. Bits: 00000010
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
   Component: TSG BF        H09 0305
   VCID: 55E28D183C6795E7A4-8000
                    Reset counter: 230
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 21:17:25
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 00000001426649
   VCID: 393A21A8B83F5187A0-806C
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000003    Serial number: AUZ5Z6N1991898
   Coding: 04020002010185004159070800
   VCID: 43C64340C2F31B57FA-8016
   Component: Display
                    Fault Frequency: 22
                    Reset counter: 0
                    Mileage: 168862 km
                    Date: 2018.11.06
                    Time: 01:47:53
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 230
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 21:17:31
   Component: TSG HL        H07 0305
   VCID: 59FA8128507FB18780-800C
02123 - Door Warning Light / Entry Light
                    Reset counter: 234
                    Mileage: 168862 km
                    Date: 2018.12.28
                    Time: 23:10:45
                    Reset counter: 230
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 21:17:25
                    Fault Status: 01101000
                    Reset counter: 194
                    Mileage: 168868 km
                    Date: 2019.02.10
                    Time: 19:17:02
   Component: TSG HR        H07 0305
                    Reset counter: 230
                    Mileage: 168862 km
                    Date: 2019.01.23
                    Time: 21:17:26
   Revision: 00000000    Serial number: 00000005332933
   Coding: 0010370
   VCID: 3E3032B4691176BF95-806A
End----------(Elapsed Time: 01:53, VBatt start/end: 12.6V/12.4V)-----------
