2009 Passat 2.0 TDI (UK):- P2196 - 000 - Signal too High (Rich)
Klaus Ludwig
C?ID=227092
Hi,
New to forum, not an Auto specialist and only just started using VCDS. Currently have one fault which comes up once every 10- 50 miles. Auto-Scan is as follows:-
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 6C
VIN: WVWZZZ3CZ9E0xxxxx
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BT    HW: 03L 907 309
   Component: R4 2,0L EDC 0000SG  6214
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 00363 210 85044
   VCID: 78FFCCFD0B0EB1DEA3D-802D
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 000 - Signal too High (Rich) - MIL ON
                    Fault Status: 11100000
                    Mileage: 224215 km
                    Date: 2000.14.28
                    Time: 18:57:21
                    RPM: 2047 /min
                    Speed: 51.0 km/h
                    Lambda: 48.1 %
                    Mass Air / Rev.: 545.0 mg/str
                    Voltage: 0.675 V
                    (no units): 16.0
                    Voltage: 0.975 V
Readiness: 1 1 0 0 0
   Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
   Component: J104    C4 440 V2   0013
   Revision: --025---    Serial number: 00000786438999
   Coding: 0001286
   Shop #: WSC 05311 000 00000
   VCID: 2F6D37A1BEC0B666327-807A
   Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 6FEDF7A17E40F666727-803A
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000009125181
   Coding: 00880F0700041A00470A00000F000000000859435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 326B3ED5ADF29B8E5D9-8067
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 201108 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Component: J234__00Q VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPQZAV1O
   Coding: 0012369
   VCID: 3B7513F17AB85AC68EF-806E
   Subsystem 1 - Serial number: 6333FTS691633018
   Subsystem 2 - Serial number: 6343FTS635553408
   Subsystem 3 - Serial number: 6353ETS6R6PVVVNR
   Subsystem 4 - Serial number: 6363ETS6RQ45V5KJ
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AT    HW: 3C0 953 549 AT
   Component: J0527               0030
   Revision: 00034000    Serial number: 3C9953507CE
   Coding: 0000004
   Shop #: WSC 05314 000 00000
   VCID: 7EF3DAE5292A8FEEE91-802B
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 971 R    HW: 3C0 920 971 R
   Component: KOMBI         H04 0107
   Coding: 460F00
   Shop #: WSC 05314 115 00000
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 346738CD9FE695BE4F5-8061
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P08C0804AD
   Coding: F9801F06404202002003
   VCID: 2A5B26B58522D34EE59-807F
   Part No SW: 3C0 959 433 AQ    HW: 3C0 959 433 AQ
   Component:    IMMO         044 0383
   Revision: 00044000    Serial number: VWZCZ000000000
   VCID: 79F9C9F93004A8D6DC3-802C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1T0 035 680 B    HW: 1T0 035 680 BX
   Component: RNS-MID       H03 1200
   Revision: AB001001    Serial number: VWZ6Z7H6306026
   Coding: 000004000000000000
   VCID: 2D512DA974CCC47600B-8078
                    Fault Frequency: 9
                    Reset counter: 37
                    Mileage: 224200 km
00878 - Connection to Speaker Front Left
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 9
                    Reset counter: 37
                    Mileage: 224200 km
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1518
   Revision: 72009005    Serial number: 00000628989110
   Coding: 0000565
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 195    2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2C5720AD8FD6CD7E175-8079
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 044 0612
   Coding: 0191020851030E763004941570085BCE103C01
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1518
   Revision: 72009005    Serial number: 00000513489111
   Coding: 0000564
   VCID: 70EFF4DD637EE99E6BD-8025
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000217648
   Coding: 0000057
   VCID: 285FDCBD9B2EE15EF3D-807D
                    Fault Frequency: 9
                    Reset counter: 37
                    Mileage: 224200 km
                    Fault Frequency: 9
                    Reset counter: 37
                    Mileage: 224200 km
   Part No SW: 3C0 907 441     HW: 3C0 907 441
   Component: J772__Rearview      0042
   Revision: 00H05000    Serial number:    PA8 J8X0064
   Coding: 0000007
   VCID: DFCD07610EE0E6E6427-808A
Have taken various logs whilst engine on load and imported into Excel as graphs. Air filter is new. No smoke/pressure tests have been carried out on intake/exhaust. Any pointers on what data to focus on and/or most probable cause would be appreciated. Many "Lambda" readings in VCDS. Don't currently know which of Lambda readings to look at or whether the Lambda sensors are wide band type.
Gone But Not Forgotten
This happens usually from a bad heater or internal issue with the OXS sensor from ash pile up/water causing corrosion on the sensor itself.
There were updates for firmware on this to ignore the threshold some.
I think you are up to date.
You can also try cleaning the sensor by heating with a propane torch to remove impurities.
Run Lubro moly fuel additive and check oil spec/level being to high.
Consider more force regens to heat the system up for burn off.
or
Change sensor.............
Klaus Ludwig
C?ID=227092
If this is the case in this instance (faulty Lambda sensor), I'm not sure which of the two sensors it is most likely to be.
Does anyone know whether there is any way I can confirm a Lambda sensor fault (taking into account my particular fault code) by monitoring with VCDS or from the freeze frame info listed with the fault?
I must admit that I was originally thinking that the fault might be due to almost anything that could influence the air/fuel mix or MAF accuracy if it wasn't a Lambda sensor.
008598 - Oxygen (Lambda) Sensor B1 S1 <<<<<<<<<<<<<<<<<<<<<
Mileage: 224215 km
Date: 2000.14.28
Time: 18:57:21
Ja ja
Sensor B1 S1 = ( Bank 1 Sensor 1)
This means........... most forward OXS sensor closest to engine in front of CAT/Particulate ASH trap.
Things like the repair manual and WD component locators are a great way to get to understand where and what things are for locations and function.
https://erwin.volkswagen.de/erwin/showHome.do;jsessionid=1F78E1AAD4D779451B4CAAAEA97B3EAC
Klaus Ludwig
C?ID=227092
Thanks. Sensor was found with carbon deposits. Not too far off recommended change miles which is 250k. It is a wide-band unit. Car belongs to a friend who now plans to try removing it again and cleaning with vinegar or something similar and will most likely end up fitting a new sensor.
I have had excellent results with taking sodium hydroxide ( Most common oven cleaner ) Then CLR ( calcium lime rust cleaner ) Then rinse in soda ash/distilled water solution followed by being burned with a propane torch.
I have been experimenting with the CBEA for over 5 years! :p
Including with upper ADP channels after login to change the result for the target lambda threshold recently.
Some ecu's I have to change it manually in eeprom then BDM back.
I have also found that using SAE oil to reseal rings and prevent ash is a considerable gain in MPG/Power............ with no issue for turbo chargers since the TDI runs much cooler than the typical gas engines. This includes modified cars..........
Now for guys that think I am crazy............I am............ and will always do what is not the norm to verify on my own.
All ALH/1Z/AHU cars I serviced in my care for every oil change have gone past 275 K on the original turbo. ( every 5K change ) with SAE oil!
Two cars are running to this day with the original oil filter never changed, turbo, nor head gasket. VC was removed to inspect........clean like new!
ATD/BRM/BEW didn't destroy lifters or cams ............go figure.
However............ for PD cars we did mods of spray bath drips on the cam/rocker area............ with a custom spray rail, and cranked up the relief PSI at the pump removing regulation from the oil filter housing.
The best idea we have for a solution so far is removing turbo charger lubrication from the sump with its own cooler, pump and sump.
Then the engine is virtually contamination free in comparison to OEM design.
Synthetic oil for gear boxes and certain applications are superior, however, when it comes to common sense of sealing a combustion chamber for blow by it is not!
Two issues I see with synthetic oil which are stupid and negate the reason for paying up for it.
Contaminates itself by allowing fuel into sump and then shoots vapors into emission required recovery systems causing carbon and ASH/Misfire/CAT damage and the evil domino effect it perpetuates to engine or component DEATH!
This is why I mix it or change very frequently with SAE.
I am convinced I am correct, especially for what I have observed in the 1.8T 2.0T, V8 W12, AND V-VR6 engines........... all the other ones needed chains, none and I mean none have yet to need this in my care with SAE oil.
Klaus Ludwig
C?ID=227092
Not been on forum for a long time. Very late update:- New Lamba sensor was fitted after cleaning original with oven cleaner failed. Perhaps too late to catch it with cleaning in our case. Problem solved. All still OK a year later. All advice was much appreciated.
