Can't get switch to work on B9 Audi A4 towbar trailer
paul
C?ID=80508
Before I trawl for another module, welcome any advice from those in the know!
Installed a factory swivel bar and coded up and all seems well apart from not being able to get the switch to work to release the bar so pretty stuck. Even tried manually releasing in output test so suspect the module I have been sold is not compatible (despite being advertised as correct).
I have tried all variations of button codes in the module on byte 2 but may have missed elements elsewhere. Included is a before and after scan:
Before stupidly after installing trailer module) :
Saturday,25,August,2018,20:12:30:38198
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WAUZZZF40JA124225   License Plate: PAULA4
Mileage: 3115km-1935mi   Repair Order:
Chassis Type: F4-AU49 (8W7)
Scan: 01 02 03 08 09 13 15 16 17 19 29 2B 39 42 44 46 47 52 5F 69
          6C 6D 81 82 8B A5 AC BB BC D6 D7
VIN: WAUZZZF40JA124225   Mileage: 3115km-1935miles
69-Trailer -- Status: Not registered 0011
Address 01: Engine (J623-CRTC)       Labels: None
   Part No SW: 8W0 907 401 E    HW: 059 907 309 F
   Component: 3.0TDI MD1    H24 0004
   Revision: C7H24---
   Coding: 122A40320566050324080000000000000000000000000000
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ECM30TDI0118W0907401E 001004
   ROD: EV_ECM30TDI0118W0907401E.rod
   VCID: 392F2EF8E9D0C1AF76A-806C
17156 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 20:08:58
                    Engine speed: 0.00 /min
                    Coolant temperature: 50 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 12.060 V
                    Engine status: COENG_READY
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 8W0 927 158     HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H05 1010
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 7F5B00E0B7742F9F08E-802A
Address 03: ABS Brakes (J104)       Labels:. 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 M    HW: 8W0 907 379 D
   Component: ESP9 Premium  H13 0767
   Coding: 14AA309930A40A9A11A04893008252A2E4A5D2280C0C508812004A4527A54B
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 4FFB702047547F1FB8E-801A
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0210
   Coding: 2618002D5544450D02000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44D14F0C9E128C4715C-8010
   Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002043849
   Serial number: 1AB1190900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501143E17900CD054D51195BAE80F9110B3108000000000000000020001A810A45012B025605
   Shop #: WSC 06325 790 00001
   VCID: 025D8914C4864277670-8056
   Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 171122  043 0813
   Serial number: 89425300401732600688
   Coding: 5BC7F7
   Serial number: 21025295X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
   Component: E1 - LDS  H06 0008
   Serial number: 22 08 2017  01102510
   Serial number: GX1CE115111723611409
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00641630
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000195697005
   Part No SW: 8W0 907 561 C    HW: 8W0 907 561
   Component: LRR4          H10 0340
   Coding: 3473FFE258FFEC0A959A81A0
   ASAM Dataset: EV_ACCBOSCHAU49X 003022
   ROD: EV_ACCBOSCHAU49X.rod
   VCID: 3E253DE4F0FEE697438-806A
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 20:08:58
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 12.0 V
                    Status_ACC_System: ACC_Init
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 20:08:58
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0107
   Serial number: 003UP00BT9G.
   Coding: AACCF0C00C800000985400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 4CC1672CB6424407DDC-8018
   Subsystem 1 - Part No SW: -----------    HW: 442 062 811 17
   Serial number: 3577Y00C126D2BC2D304
   Subsystem 2 - Part No SW: -----------    HW: 442 062 911 17
   Serial number: 3587Y00C926068A152A%
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 511 17
   Serial number: 3517700B127DA976339I
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 712 17
   Serial number: 3527700B728B79E4613L
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 507 17
   Serial number: 3557500AF275CB2631BO
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 507 17
   Serial number: 3567500AF275CB2520CN
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 507 17
   Serial number: 23075009F2772296E27D
   Subsystem 8 - Part No SW: -----------    HW: 442 430 212 17
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00B92532143E0B7
   Subsystem 9 - Part No SW: -----------    HW: 442 430 212 17
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00B9253214341D1
1060613 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Objektstatus]
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 20:08:59
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 20:08:59
1060615 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_v_rel]
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 20:08:59
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 20:08:59
   Part No SW: 4M0 907 129 ME    HW: 4M0 907 129 ME
   ROD: EV_SMLSKLOAU736_006.rod
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0373
   Coding: 258469D06C80060001A3E9601000400000000000
   VCID: 43D34C109B1C8B7F2C6-8016
          U1014 00 [009] - -
          [ECU incorrectly coded]
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 20:08:58
   Part No SW: 8W7 907 468 F    HW: 8W7 907 468 E
   Component: Gateway       H42 0123
   Revision: 7C000001    Serial number: 0187C027718109
   Coding: 03010001000086407F07000000590012D8180007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   ROD: EV_CGateCONTIAU491.rod
   VCID: 4EC56D24405E7617B38-801A
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20180108184828 21851
   Serial number: 5191156004
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
          [Data_Bus_Commponent_List_detected]
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 19:42:28
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: 78A9EBFC925A18A7494-802C
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000379963004
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323D19D434A632F7B70-8066
   Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
   Component: TSG FS        005 0129
   Serial number: 0000295268633
   Coding: 005D9A215001000000001082
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 0D008380008080
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42DD491484068277270-8016
   Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
   Component: BCM2 MLBevo   025 0387
   Coding: 013500002FB100406309A0000E00080233024010804706502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   VCID: 015F8618C180596F7EA-8054
   Ignition key:
   Subsystem 1 - Part No SW: 4M0 959 754 AJ    HW: 4M0 959 754 AJ
   Component: ID-Geber  H40 0105
   Serial number: 3617000216094006
   Serial number: 000000000ZY173384HQP
   Serial number: 00000000000099906688
7 Faults Found:
647169 - Bulb for Left Tail Light
          B12BE 13 [009] - Open Circuit
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 19:53:29
                    Supply voltages-Supply voltage: Terminal 30: 12.528 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.528 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.514 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 12 04 98
                    light_freeze_frame: 11111111 11111111 11111111 11111111
647425 - Bulb for Right Tail Light
          B12BF 13 [009] - Open Circuit
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 19:53:29
65610 - Databus
          U1201 00 [008] - No Communications
                    Reset counter: 108
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 18:42:17
                    Supply voltages-Supply voltage: Terminal 30: 12.813 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.827 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.827 V
                    general_additional_freeze_frame-Stall_current_cutoff_level: Not available
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: Not available
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 02 10 04 80
                    general_additional_freeze_frame-Transport_Mode: Not available
                    general_additional_freeze_frame-Vehicle speed: Not available
65612 - Grass Breakage Sensor
          B145F 13 [008] - Open Circuit
                    Reset counter: 108
131160 - Databus
          [Electronic steering column lock control module: ELV_01: no signal/communication]
                    Reset counter: 108
                    Supply voltages-Supply voltage: Terminal 30: 12.827 V
65896 - Databus
          [Climatronic control module: Klima_03: no signal/communication]
                    Fault Frequency: 73
                    Reset counter: 108
                    Mileage: 2574 km
                    Date: 2018.08.16
                    Time: 10:43:14
                    Supply voltages-Supply voltage: Terminal 30: 12.609 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.636 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
                    general_additional_freeze_frame-terminal_control_intern_status: 91 04 02 10 04 80
65915 - Local Data Bus 3
          U10C8 00 [009] - No Communications
                    Reset counter: 68
                    Mileage: 3115 km
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 80
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAHJA03BZEM
   Coding: 0194020800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 76B5E5C4984E6ED75B8-8022
   Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
   Component: TSG BFS       005 0129
   Serial number: 0000278938534
   Coding: 005D9A215C01000000001080
   ROD: EV_DCU2PasseSideMAXHCONT.rod
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 035 B    HW: 8W5 035 035
   Component: MU-P-LND-EU   034 1177
   Serial number: A829A0JB050759
   Coding: 019402010000000053111102000A00332F0002E7017001009E
   VCID: 363525C4D8CE2ED79B8-8062
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 8W8 919 605     HW: 8W8 919 605
   Component: DU High AU49x  H32 0170
   Serial number: TPO00106091700820864
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK129111700020827
   Compact Disc Database:
   Component: Gracenote2  --- 1016
3086 - Antenna for Telephone Mount
          B1564 01 [009] - Electrical Failure
                    Reset counter: 59
                    Mileage: 2658 km
                    Date: 2018.08.18
                    Time: 20:49:57
                    Voltage terminal 30: 12.4 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
   Part No SW: 4M0 907 383 B    HW: 4M0 907 383 B
   Component: Anhaenger     H18 0172
   Revision: 9A001001    Serial number: 0000532948
   Coding: 0100010202000000
   Shop #: WSC 02387 128 28888
   VCID: 313F16D831A009EFCEA-8064
136203 - Supply Voltage
          P1757 00 [009] - Open Circuit
                    Reset counter: 68
                    Mileage: 3115 km
                    Date: 2018.08.25
                    Time: 19:53:03
Address 6C: Back-up Cam. (J772)       Labels:* None
   Component: RVC Compact   H12 0250
   Coding: 0294020102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 33331CD0CBBC3BFFBC6-8066
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31709534400000
   Coding: 0570
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   ROD: EV_DeckLidCONTIAU736_AU49.rod
   Part No SW: 8W2 713 041 F    HW: 4M2 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 17121145195270
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 372B28C0DFC4D7DF80E-8062
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 8W5 919 617 C    HW: 8W5 919 617 C
   Component: HeadUpDisplay H18 1640
   Coding: 4F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 48C95B3CA23AA827F94-801C
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 C    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 003022
   ROD: EV_ACC2BOSCHAU49X.rod
   VCID: 3C2137ECE6E2F4876DC-8068
   Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
   Component: BVS           H17 0050
   Coding: 0404090200000403024023A4A50000FCB0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736.rod
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Variant_coding_failure]
                    Mileage: 3115 km
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 12.10 V
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736.rod
   Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
   Component: TSG HFS       005 0129
   Serial number: 0000297723583
   Coding: 000D98200001000000001080
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 51FF7658516069EFAEA-8004
   Component: TSG HBFS      005 0129
   Serial number: 0000297723312
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C544B80ECED7BB8-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:42, VBatt start/end: 12.1V/12.2V)-----------
Address 69: DTCs cleared
Address 19,8W7 907 468 F,recoded (Installation List),from,01503C0808040200,to,01503C0808040200,,
Address 69,4M0 907 383 B,recoded (Long Coding),from,0100010202000000,to,0110000202000000,(02387/128/28888),
Address 01: DTCs cleared
Address 01,8W0 907 401 E,recoded (Long Coding),from,122A40320566050324080000000000000000000000000000,to,122A40320576050324080000000000000000000000000000,(06324/790/00001),
Address 09,8W0 907 063 CG,recoded (Long Coding-exp),from,07501143E17900CD054D51195BAE80F9110B3108000000000000000020001A810A45012B025605,to,07501143E17900CD054D51195BBE80F9110B3108000000000000000020001A810A45012B025605,(06325/790/00001),
Address 13,8W0 907 561 C,recoded (Long Coding-exp),from,3473FFE258FFEC0A959A81A0,to,3473FFEA58FFEC0A959A81A0,(06325/790/00001),
Address 13: DTCs cleared
Address 17,8W5 920 790 D,recoded (Long Coding-exp),from,258469D06C80060001A3E9601000400000000000,to,258469D06C80060001A3E9603000600000000000,(06335/790/00001),
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 44,8W0 909 144 H,recoded (Long Coding-exp),from,0D008380008080,to,0D208380008080,(06324/790/00001),
Address 44: DTCs cleared
Address 46,8W0 907 064 EC,recoded (Long Coding-exp),from,013500002FB100406309A0000E00080233024010804706502F0400000504803F001F0001000000,to,01350000AFB100406309A0000E00480233024010804706502F0400000504803F001F0001000000,(06335/790/00001),
Address 46: DTCs cleared
Address 69,4M0 907 383 B,recoded (Long Coding-exp),from,0110000202000000,to,0110010202000000,(02387/128/28888),
Address 69,4M0 907 383 B,recoded (Long Coding-exp),from,0110010202000000,to,0110020202000000,(02387/128/28888),
Address 69,4M0 907 383 B,recoded (Long Coding-exp),from,0110020202000000,to,0110030202000000,(02387/128/28888),
Address 69,4M0 907 383 B,recoded (Long Coding-exp),from,0110030202000000,to,0110010202000000,(02387/128/28888),
Address 15: DTCs cleared
Address 17,8W5 920 790 D,recoded (Long Coding-exp),from,258469D06C80060001A3E9603000600000000000,to,258469D06C80060001A3E9601000600000000000,(06335/790/00001),
Address 44,8W0 909 144 H,recoded (Long Coding-exp),from,0D208380008080,to,0D008380008080,(06324/790/00001),
Address 69,4M0 907 383 B,recoded (Long Coding-exp),from,0110010202000000,to,0110000202000000,(02387/128/28888),
Address 69,4M0 907 383 B,channel IDE00001-Production mode,adapted from,not active ,to,active ,
Address 69,4M0 907 383 B,recoded (Long Coding-exp),from,0110000202000000,to,0100010202000000,(02387/128/28888),
Address A5: DTCs cleared
Address A5,8W0 907 217 C,recoded (Long Coding-exp),from,0404090200000403024023A4A50000FCB0F0C020C020,to,0404090200000403024023A5A50000FCB0F0C020C020,(06335/790/00001),
After:
Sunday,26,August,2018,10:52:39:38198
Dealer/Shop Name: PAW
VIN: WAUZZZF40JA124225   License Plate: TOWA4
Mileage: 3119km-1938mi   Repair Order:
VIN: WAUZZZF40JA124225   Mileage: 3119km-1938miles
   Revision: C7H24---
   Coding: 122A40320576050324080000000000000000000000000000
   Revision: --H05---
   Coding: 100000
   Coding: 07501143E17900CD054D51195BBE80F9110B3108000000000000000020001A810A45012B025605
   Coding: 5BC7F7
   Coding: 02005D
   Coding: 230000
   Coding: 3473FFEA58FFEC0A959A81A0
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 68
                    Mileage: 3119 km
                    Date: 2018.08.26
                    Time: 10:47:49
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 12.7 V
   Coding: 258469D06C80060001A3E9601000600000000000
   Coding: 013500002FB100406309A0000E00480233024010804706502F0400000504803F001F0001000000
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Serial number: >1194400
                    Reset counter: 59
                    Mileage: 2658 km
                    Date: 2018.08.18
                    Time: 20:49:57
   Coding: 0110010202000000
   Coding: 0570
   Coding: 4F01C0
   Coding: 0404090200000403024023A5A50000FCB0F0C020C020
End----------(Elapsed Time: 02:16, VBatt start/end: 12.8V/12.9V)-----------
   Revision: C7H24---
   Revision: --H05---
   Coding: 100000
   Coding: 5BC7F7
   Coding: 02005D
   Coding: 230000
                    Reset counter: 59
                    Mileage: 2658 km
                    Date: 2018.08.18
                    Time: 20:49:57
   Trailer Articulation Angle Sensor:
   Coding: 0570
   Coding: 4F01C0
End----------(Elapsed Time: 02:50, VBatt start/end: 12.4V/12.3V)-----------
   Revision: C7H24---
   Revision: --H05---
   Coding: 100000
   Coding: 5BC7F7
   Coding: 02005D
   Coding: 230000
                    Reset counter: 59
                    Mileage: 2658 km
                    Date: 2018.08.18
                    Time: 20:49:57
   Coding: 0570
   Coding: 4F01C0
End----------(Elapsed Time: 02:09, VBatt start/end: 12.2V/12.2V)-----------
Address 5F,8W5 035 035 B,channel IDE02506-MAS03230-Copy multimedia data-Optical drive,adapted from,OFF ,to,On ,
paul
C?ID=80508
Turns out the module I had was wrong for the trailer. Now replaced with a version with part number ending in D and all is well. When I get chance will post a full autoscan for reference.
