Getting original DSG Coding for my vehicle.
Leospeedworks
Philippines
C?ID=64222
While programming my dsg I accidentally pressed CLONE instead of program. So Now my car wont shift since it copied a different car’s
Transmission. I dont know the original coding. Is there a way to access this? Thanks very much!
South Molton, UK
If you have done a previous Auto-Scan then the result will have been saved in the folder C:\Ross-Tech\VCDS\Scans as a text file. Open that and see what the DSG coding was.
Leospeedworks
Philippines
C?ID=64222
Problem is inwas able to do the autoscan after the cloning. :(
Fredrick Awuor
Kenya
C?ID=309834
Hello,it would help a great deal to post even the current autoscan to help those who want to help you
Leospeedworks
Philippines
C?ID=64222
Good morning Sadly no. here is the Autoscan after though.
Friday,24,August,2018,14:25:12:56504
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
VIN: 3VWCA7AU8GM501758   License Plate: DOCJEFF
Mileage: 7996km-4968mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
          75 A5
VIN: 3VWCA7AU8GM501758   Mileage: 7996km-4968miles
Address 01: Engine (J623-DEJA)       Labels: None
   Part No SW: 04L 906 021 HH    HW: 04L 907 309 S
   Component: R4 2.0l TDI   X23 4449
   Revision: 85X23---
   Coding: 011D0112036410081000
   Shop #: WSC 20200 993 00000
   ASAM Dataset: EV_ECM20TDI01104L906021HH 004002
   ROD: EV_ECM20TDI01104L906021HH.rod
   VCID: 72A838B3A57399D421-8026
4718 - No Communication with Transmission Control Module
          U0101 00 [032] - -
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:20
                    Engine speed: 0.00 /min
                    Coolant temperature: 53 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 12.300 V
                    Requested transmission torque: 1000.0 Nm
                    Limitation: accelerator pedal: 140.0 Nm
                    selected gear-Bits 0-7: 0
                    Transmission torque intervention status-Bits 0-7: 0
                    Calculated reducing transmission intervention torque: 1000.0 Nm
   Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4903
   Revision: 06253104    Serial number: TFK01504200181
   Shop #: WSC 00066 790 00221
   ROD: EV_TCMDQ250021.rod
   VCID: 1D723B0F0C6D76AC2C-8048
10677 - Powertrain Databus
          U0002 00 [008] - No Communications
21192 - No Communication with Diagnostic Gateway
          U0146 00 [008] - -
10683 - No Communication with Instrument Cluster
          U0155 00 [008] - -
21197 - Transmission Control Unit
          P1701 00 [011] - Locked
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:35:42
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Revision: 00000000    Serial number: 61255000000491
   Coding: 04FA6AA12420096D007E020581CB2520562490004081A4B21663F052C082
   Shop #: WSC 01383 790 50316
   VCID: 7AB81093FD03E19469-802E
8222 - Databus
          [FCAN : Getriebe_11 message is not received]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:26
8226 - Databus
          [FCAN : Getriebe_14 message is not received]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:26
16416 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:57
   Revision: 00021000    Serial number: 0369561303
   Coding: 030C0C
   VCID: 3A38D093BD83219429-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 02020124202100000105000012111402
   VCID: 42C8A873D553695471-8016
   Air quality sensor:
459526 - Databus
          [Feuchtesensor innen - Fehlerspeicher auslesen]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:13
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86581605150987
   Coding: 00511A464041A2E969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 00058
   ROD: EV_BCMBOSCH_015.rod
   Component: WWS    150424  043 0581
   Serial number:         150628122231
   Component: RLHS  037 0059
   Serial number: S4Y15M05D12H14M07S02
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000AGJKT00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST000AGJHQ00000
   Coding: 191800
555797 - Databus
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:26
939534 - Humidity sensor
          B1281 04 [008] - Internal System Fault
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:17
                    Reset counter: 7
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:22:09
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39431513200885
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 47DEB967FE714C7CA6-8012
13637426 - Databus
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:14
12648721 - Databus
          [Getriebesteuergerät - Getriebe_11 - kein Signal/keine Kommunikation]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:21
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0400
   Serial number: 03041503210436
   Coding: 01045400FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
9 Faults Found:
1066 - Databus
          [FAULT_CIS_BPRESS_DRIVER_INVALID]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:13
                    Control Module temperature: 44 °C
                    Voltage terminal 15: 12.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1056 - Databus
          [FAULT_CIS_ECD_FAIL]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:13
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:13
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:13
0284 - Databus
          [FAULT_CIM_TIMEOUT_Getriebe_11]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:25
                    Control Module temperature: 35 °C
1027 - Databus
          [FAULT_CIS_TIMEOUT_Getriebe_13_alt]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:25
1028 - Databus
          [FAULT_CIS_TIMEOUT_Getriebe_14_alt]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:26
1050 - Transmission in Limp Mode
          P305B 00 [008] - -
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:13
1043 - Automatic Distance Control
          B10E7 F0 [008] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:13
   Serial number: 003GCR020SHJ
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J1500031T5M02
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 002 305 15
   Serial number: 3570000000095360A41A
   Subsystem 3 - Part No SW: -----------    HW: 480 002 305 15
   Serial number: 35800000000C2750A41E
   Subsystem 4 - Part No SW: -----------    HW: 480 402 204 15
   Serial number: 3510002B31A91E748351
   Subsystem 5 - Part No SW: -----------    HW: 480 400 705 15
   Serial number: 3520002C71A878748211
   Subsystem 6 - Part No SW: -----------    HW: 480 401 205 15
   Serial number: 3550002C31A878716260
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 205 15
   Serial number: 3560002C11A87870417$
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150328500557
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73A63DB7DA6990DC2A-8026
   Part No SW: 5G1 920 841 A    HW: 5G1 920 841 A
   Component: KOMBI         242 6420
   Coding: 0BA4121AAD98CF0502886A095000000000000000
   Shop #: WSC 26341 002 1048576
   VCID: 260014E3593BB5747D-8072
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 221
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:17
16776983 - Databus
          [WBA_03 keine Kommunikation]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 13:28:25
9634288 - Transmission Control Module
          B1301 F0 [009] - Not Authorized
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 11:59:07
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 22051510000972
   Coding: 0901000810087300FB00021A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07025
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 75A203AFD41D8EEC04-8020
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150000640000025136
   Coding: 35FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0059191
131703 - No Communication with Transmission Control Module
          U0101 00 [008] - -
          [Timeout Knoten 0x77 / 02 - Steuergerät für Getriebe]
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:32:03
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
   Revision: 00000000    Serial number: 15000127253004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424FEAB9FE7D7E4F3-8060
   Component: HRE_Master    H11 0071
   Serial number: 0368973987
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C34D68BB7B71FA43B-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0362366473
   Coding: 020111
   Serial number: 1506150605076Q
   Coding: 003A13200000040000000000
   VCID: 43C6AD77CA49605C7A-8016
   Serial number: 00000000000001409257
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0302
19460 - Databus
          [ESP_05 Botschaft - SNA-Check]
                    Fault Frequency: 50
                    Reset counter: 6
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:13
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 61.0 °C
                    KFC: 4C
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.17 V
                    uAdSensI_SwitchedKl30_xdu16: 12.16 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA00B9H0
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D922BCFBC4D462CFC-8038
   Serial number: 0506150605070E
   Serial number: 00000000000001321709
   Coding: 091000
   Coding: 060A00010B000400
   VCID: 40CCA27BDB5F7B4467-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0245
   Serial number: VWZAZ2R0154807
   Coding: 027302020000000051510002001808001F0100F401200105C2
   Shop #: WSC 63336 002 1048576
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 71AA37BFA075A2CCD8-8024
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H52 1028
   Serial number: VWZ8Z9RFC0013W
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 221
                    Mileage: 7996 km
                    Date: 2018.08.24
                    Time: 12:21:17
                    Voltage terminal 30: 12.2 V
                    BAP-BAP_Function_ID: 02
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C0823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000355517
   Coding: 0000000000020306000400010100000100
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:54, VBatt start/end: 13.3V/13.2V)-----------
Leospeedworks
Philippines
C?ID=64222
Thanks For all the help. If there is a fee to get the code I can paypal. good morning to all.
This isn't a coding problem. Every TCU with your part number on the web is coded 0014, just like yours.
I suggest you seek help from whomever made the tool that has a "CLONE" function in it, 'cause VCDS doesn't. ;)
Gone But Not Forgotten
I reiterate sir no cloning!
Ever hear of the term BACKUP?
https://forums.ross-tech.com/showth...uot-JPPSG-quot&p=138957&viewfull=1#post138957
https://en.wikipedia.org/wiki/Clone_(computing)
http://www.computerhistory.org/revolution/personal-computers/17/302
Leospeedworks
Philippines
C?ID=64222
Thank you sir. Is there a way to code with vcds to make the modules compatible again?
You don't have a coding problem.
Install correct transmission based on Pr-String in trunk by VIN number, fix fault codes if any using RTFB and WD, further SVM Config CP GeKo/FaZit & adapt Transmission at dealer with Odis.
JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Leospeedworks
Philippines
C?ID=64222
Thank you Sir.
Leospeedworks
Philippines
C?ID=64222
JPPSG
Thank you Sir Jake. You really are the forum God here. By the way maybe your shop can help me with another concern? I have a used untuned ecu that i want to replace my ecu with because it has reached a maximum number of flashes thru obd. Can I avail of your services for this? This is for our own shop car.
Thank you Sir Jake. You really are the forum God here. By the way maybe your shop can help me with another concern? I have a used untuned ecu that i want to replace my ecuwith because it has reached a maximum number of flashes thru obd. Can I avail of your services for this? This is for our own shop car.
No sir...........
I am not interested in doing business with you, thank you anyway.
Indeed you are set to ignore and please don't contact me further as a resource with requests like this.
Thank you
Leospeedworks
Philippines
C?ID=64222
Thanks too. Update on the post Guys My dealer got it done in 5 monutes and under warranty.
Leospeedworks
Philippines
C?ID=64222
Sorry about the Post it sounds wrong. I just want to clear things because by the Tone of Jack it might give people the impression that I do illegal stuff. Anyway just to explain things. I tune cars. I have a personal VW 2 month old Golf which is tuned engine and DSG. A friend wanted his car tuned as well and instead of writting the tuned file into the his DSG I made a mistake and pressed a different option. I was asking for coding help to avoid going to the dealer and getting a record. Anyway It's solved now. You can check my facebook page speedworksengineering and see what we do.
