2018 VW Golf 1.6 TDI SE
drennie599
Northern Ireland
C?ID=109519
Have this out on hire, thought a scan would be beneficial :)
Thursday,23,August,2018,19:01:39:49196
VCDS Version: 18.2.1.2 (x64)
Workshop Code: 874 00874 000874
VIN: WVWZZZAUZJW219150   License Plate: KG5479
Mileage: 968km-601mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZJW219150   Mileage: 968km-601miles
Address 01: Engine (2D2D2-DDYA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 GT    HW: 04L 907 445 E
   Component: R4 1.6l TDI   H01 3757
   Revision: 22005001
   Coding: 0111401243451D092000
   ASAM Dataset: EV_ECM16TDI03004L906056GT 004004
   ROD: EV_ECM16TDI03004L906056GS_004.rod
   VCID: 0505E9DA84E10A6C14-8050
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
   Component: ESC           H25 0423
   Revision: 00000000    Serial number: 50458000000436
   Coding: 01FA8AA1242109754778060560C32580512490E26006A4733440F078C002430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW27.rod
   VCID: 020FF2C695CF3D5431-8056
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 00120104202110001000000000000002
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 7AFF8A26FD1F759469-802E
   Part No SW: 5Q0 937 084 CN    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H36 0253
   Serial number: 01001805900373
   ROD: EV_BCMCONTI.rod
   VCID: 0607EED6B9E701741D-8052
   Component: WWS    180212  042 0551
   Serial number:         180219170214
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S6Y18M02D26H16M27S46
   Coding: 00A8DD
   Serial number: 000000000ZY1803725XF
   Serial number: 00000000000000090783
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018053
   Coding: 0471051801
   VCID: 4B911FE2E2053C1C82-801E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 2B00608151FFC728949C810560400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E774636A1B799B415-806A
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR3XYBRT
   Coding: 98CCC000000000005C0000CF008800000065
   VCID: 091DE5EAA8F96E0C70-805C
   Belt Pretensioner left:
   Serial number: 34169677E05031810255
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E06031840542
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 303 18
   Serial number: 3570000000069950FB2T
   Subsystem 4 - Part No SW: -----------    HW: 480 000 303 18
   Serial number: 3580000000050AF00C2H
   Subsystem 5 - Part No SW: -----------    HW: 480 400 303 18
   Serial number: 3510001AF28F9E53140A
   Subsystem 6 - Part No SW: -----------    HW: 480 400 303 18
   Serial number: 3520001C12929722D45-
   Subsystem 7 - Part No SW: -----------    HW: 480 402 602 18
   Serial number: 35500019D28F9E55957T
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 04031804221099
   Coding: 0400
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0D15D1FADC91722C5C-8058
   Part No SW: 5G1 920 941 C    HW: 5G1 920 941 C
   Component: KOMBI         202 1440
   Coding: 27A42A002780060001886B011401000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009008
   ROD: EV_DashBoardJCIMQBAB_009.rod
   VCID: 295D856A48390E0C50-807C
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007553605
   Coding: 030100045F086800FB00005C080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW27.rod
   VCID: 387B502E8393A784DF-806C
   Component: E221__MFL-DC1  H17 0040
   Serial number: 39180000324410028085
   Coding: 2CFFFF
   Serial number: 6572576804
   Serial number: 230218EBM28658
   Coding: 00310220D001048000001000
   VCID: 438137C2CA55F45C7A-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000019764399
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 81170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73E1A702DA7504DC2A-8026
   Serial number: 240218EBN25876
   Coding: 00310020DE01048000801000
   VCID: 428F32C6D54FFD5471-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000019638917
   Coding: 150000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Coding: 02731001FF00000051110101008808001F0500C601200100CF
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 326F620665EF4DD4E1-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHV0542295
   Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
   Component: ECE1 2018  --- 0915
End-------------------------(Elapsed Time: 03:39)--------------------------
