Cylinder Misfire, help needed...
Bojole
C?ID=27403
Hi guys,
Recently I started getting Cylinder 5 misfire, which can be seen under higher load on the engine (above 3500 rpms and under load/acceleration).
I thought, that was a failed coil, and replaced it, together with the spark plug (which looked in great shape), but that didn't solve the problem.
I am suspecting that something might be wrong with the injector, or fuel pressure or delivery. Any ideas on how to diagnose further are welcome.
I'm planning to try and see what are the Injectors measuring blocks, and also check the Fuel Rail values.
Cheers, and thanks!
P.S. I'm on US market built 2012 Audi Q5 3.2
Bojole
C?ID=27403
Just to add to the description. When misfire count increases, eventually the cylinder get's turned off, and 'EPC' and 'check engine' lights come On.
reet
C?ID=57674
scope the secondary on the coil pack and the injector on that cylinder mvbs no good for injector switch times also confirm misfire with cylinder misfire counter and carry out compression and leak dow test.
Bojole
C?ID=27403
Thanks reet. I will run these later today and post the results.
Bojole
C?ID=27403
Here are some of the logs that I pulled. Hopefully helps to figure the problem for someone that can make more sense than myself :)
Error Log from Engine:
Friday,24,August,2018,19:55:14:02041
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 18.2.1.5 (x64)
Data version: 20180518 DS287.2
Dealer/Shop Name: BV
VIN: WA1WKBFP9CA....
Mileage: 82870   Repair Order:
                Address 01: Engine       Labels: 06E-907-559-CAL.clb
Control Module Part Number: 8R0 907 559 G    HW: 8F0 907 559 A
  Component and/or Version: 3.2 SIMOS8.2  H08 0004
           Software Coding: 0121000A190F0A21
            Work Shop Code: WSC 12345 123 12345
              ASAM Dataset: EV_ECM32FSI0218R0907559G 001004 (AU48)
                       ROD: EV_ECM32FSI.rod
                      VCID: 448D34EFCF9C266440-8011
6354 - Cylinder 5
          P0305 00 [168] - Misfire Detected
                    Mileage: 133042 km
                    Date: 2018.08.20
                    Time: 18:46:09
                    Engine speed: 3220.00 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 44 km/h
                    Coolant temperature: 84 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 13.710 V
                    Engine speed: actual: 3328 /min
                    MAF_ENVD: 648.19998 mg/stroke
                    Coolant temperature (unfiltered): 90.0 °C
                    Engine: operating status: PL
                    T_AST_ENVD: 179.90 s
                    Vehicle speed: actual: 45 km/h
6130 - Fuel/Air Mixture Cylinder 5
          P21A0 00 [237] - Unbalanced
                    Mileage: 133093 km
                    Date: 2018.08.21
                    Time: 10:21:22
                    Engine speed: 2519.00 /min
                    Normed load value: 38.8 %
                    Vehicle speed: 116 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.015 V
                    Engine speed: actual: 2560 /min
                    MAF_ENVD: 359.50587 mg/stroke
                    Coolant temperature (unfiltered): 97.5 °C
                    Engine load: 59.765625 %
                    Vehicle speed: actual: 118 km/h
7948 - Cylinder Disabling
          P130A 00 [040] - -
                    Mileage: 133042 km
                    Date: 2018.08.20
                    Time: 18:46:10
                    Engine speed: 3062.00 /min
                    Normed load value: 86.3 %
                    Vehicle speed: 87 km/h
                    Coolant temperature: 97 °C
                    Intake air temperature: 28 °C
                    Engine speed: actual: 3488 /min
                    Vehicle speed: actual: 46 km/h
Bojole
C?ID=27403
And here are some reading from the Fuel Pressure:
Friday,24,August,2018,20:11:26:02041-VCID:448D34EFCF9C266440-8011,VCDS Version: Release 18.2.1 (x64),Data version: 20180518 DS287.2
8R0 907 559 G,ADVMB,3.2 SIMOS8.2  H08 0004,
,,G003,F0,G035,F0,G296,F0,G299,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Loc. IDE00025,TIME,Loc. IDE00589,TIME,Loc. ENG100489,TIME,Loc. ENG100409,,,,,,,,,,,,,,,,,
,STAMP,Coolant temperature,STAMP,Fuel pressure,STAMP,Fuel pump: actual fuel pressure,STAMP,Fuel rail pressure: specified,,,,,,,,,,,,,,,,,
,, °C,, kPa rel,, hPa,, hPa,,,,,,,,,,,,,,,,,
,0.57,102,0.78,5170,0.15,7121.62,0.36,45998.7,,,,,,,,,,,,,,,,,
,1.39,102,1.60,5170,0.99,7121.62,1.19,45998.7,,,,,,,,,,,,,,,,,
,2.22,102,2.42,5170,1.81,7121.62,2.02,45998.7,,,,,,,,,,,,,,,,,
,3.03,101,3.23,5170,2.62,7121.62,2.83,45998.7,,,,,,,,,,,,,,,,,
,3.86,101,4.06,5170,3.45,7121.62,3.65,45998.7,,,,,,,,,,,,,,,,,
,4.68,101,4.89,5170,4.27,7121.62,4.48,45998.7,,,,,,,,,,,,,,,,,
,5.50,101,5.71,5170,5.09,7121.62,5.29,45998.7,,,,,,,,,,,,,,,,,
,6.34,101,6.54,5190,5.92,7121.62,6.13,45998.7,,,,,,,,,,,,,,,,,
,7.16,101,7.37,5170,6.74,7121.62,6.95,45998.7,,,,,,,,,,,,,,,,,
,7.98,101,8.19,5170,7.57,7121.62,7.77,45998.7,,,,,,,,,,,,,,,,,
,8.80,101,9.01,5190,8.40,7121.62,8.60,45998.7,,,,,,,,,,,,,,,,,
Bojole
C?ID=27403
And finally a log from a short drive on which the load and misfire forced cylinder 5 to get shut off.
It easier to read in spreadsheet, here is it as raw csv.
Friday,24,August,2018,20:26:16:02041-VCID:448D34EFCF9C266440-8011,VCDS Version: Release 18.2.1 (x64),Data version: 20180518 DS287.2
,,G035,F0,G486,F0,G488,F0,G489,F0,G490,F0,G491,F0,G492,F0,G493,F0,G502,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Loc. IDE00589,TIME,Loc. ENG100203,TIME,Loc. ENG103747,TIME,Loc. ENG101859,TIME,Loc. ENG103818,TIME,Loc. ENG104229,TIME,Loc. ENG101360,TIME,Loc. ENG102335,TIME,Loc. ENG100222,,,,,,,
,STAMP,Fuel pressure,STAMP,MFF_ADD_LAM_CYL_SEL_ADJ_H_RES[0],STAMP,MFF_ADD_LAM_CYL_SEL_ADJ_H_RES[2],STAMP,MFF_ADD_LAM_CYL_SEL_ADJ_H_RES[3],STAMP,MFF_ADD_LAM_CYL_SEL_ADJ_H_RES[4],STAMP,MFF_ADD_LAM_CYL_SEL_ADJ_H_RES[5],STAMP,Misfire detection active,STAMP,Misfires all cylinders per 1000 rpm,STAMP,Misfires cylinder 5 from engine start to engine stop,,,,,,,
,, kPa rel,, mg/stroke,, mg/stroke,, mg/stroke,, mg/stroke,, mg/stroke,, ,, ,, ,,,,,,,
,0.56,3580,0.76,-0.403,0.96,0.041,1.16,0.091,1.37,0.362,1.57,-0.141,1.77,00000000 ,0.15,0,0.36,0,,,,,,,
,2.41,3560,2.62,-0.402,2.83,0.041,3.04,0.092,3.25,0.362,3.46,-0.141,3.66,00000000 ,1.98,0,2.20,0,,,,,,,
,4.27,3560,4.47,-0.402,4.67,0.041,4.88,0.092,5.09,0.361,5.30,-0.141,5.50,00000000 ,3.86,0,4.06,0,,,,,,,
,6.11,3560,6.31,-0.402,6.51,0.041,6.72,0.092,6.92,0.361,7.13,-0.141,7.34,00000000 ,5.70,0,5.90,0,,,,,,,
,7.95,3580,8.15,-0.401,8.35,0.041,8.56,0.092,8.76,0.361,8.96,-0.141,9.16,00000000 ,7.54,0,7.74,0,,,,,,,
,9.78,3750,10.00,-0.401,10.21,0.041,10.41,0.092,10.62,0.361,10.82,-0.141,11.03,00000000 ,9.37,0,9.57,0,,,,,,,
,11.65,4420,11.86,-0.400,12.07,0.041,12.27,0.093,12.47,0.360,12.67,-0.141,12.88,00000000 ,11.24,0,11.44,0,,,,,,,
,13.48,4490,13.69,-0.400,13.89,0.041,14.10,0.094,14.30,0.359,14.50,-0.141,14.70,00000000 ,13.08,0,13.28,0,,,,,,,
,15.31,4430,15.52,-0.400,15.72,0.041,15.92,0.094,16.12,0.359,16.33,-0.141,16.53,00000000 ,14.91,0,15.11,0,,,,,,,
,17.13,4210,17.34,-0.400,17.54,0.042,17.75,0.095,17.95,0.359,18.15,-0.141,18.36,00000000 ,16.73,0,16.94,0,,,,,,,
,18.96,4950,19.16,-0.400,19.37,0.042,19.57,0.095,19.78,0.359,20.00,-0.141,20.21,00000000 ,18.56,0,18.76,0,,,,,,,
,20.84,5050,21.04,-0.400,21.24,0.042,21.44,0.095,21.64,0.359,21.85,-0.141,22.05,00000000 ,20.42,0,20.63,0,,,,,,,
,22.66,4450,22.86,-0.402,23.06,0.045,23.27,0.097,23.47,0.357,23.68,-0.141,23.88,00000000 ,22.25,0,22.46,0,,,,,,,
,24.50,4380,24.70,-0.402,24.91,0.045,25.11,0.097,25.31,0.357,25.52,-0.141,25.72,00000000 ,24.08,0,24.29,0,,,,,,,
,26.32,5410,26.53,-0.402,26.73,0.045,26.94,0.097,27.14,0.357,27.34,-0.141,27.54,00000000 ,25.92,0,26.12,0,,,,,,,
,28.17,7880,28.37,-0.402,28.57,0.045,28.78,0.097,29.00,0.357,29.21,-0.141,29.41,00000000 ,27.75,0,27.96,0,,,,,,,
,30.02,9160,30.23,-0.402,30.44,0.045,30.65,0.097,30.85,0.357,31.05,-0.141,31.26,00000000 ,29.61,0,29.82,3,,,,,,,
,31.86,6640,32.08,-0.402,32.27,0.045,32.47,0.097,32.67,0.357,32.88,-0.141,33.08,00000000 ,31.46,7,31.66,8,,,,,,,
,33.69,7060,33.89,-0.402,34.10,0.045,34.30,0.097,34.50,0.357,34.70,-0.141,34.91,00000000 ,33.28,8,33.49,8,,,,,,,
,35.53,7080,35.73,-0.402,35.94,0.045,36.15,0.097,36.36,0.357,36.56,-0.141,36.76,00000000 ,35.12,8,35.33,8,,,,,,,
,37.37,3990,37.57,-0.402,37.77,0.045,37.98,0.097,38.18,0.357,38.38,-0.141,38.59,00000000 ,36.96,8,37.17,8,,,,,,,
,39.20,4790,39.41,-0.402,39.62,0.045,39.82,0.097,40.02,0.357,40.22,-0.141,40.43,00000000 ,38.79,8,38.99,8,,,,,,,
,41.03,7520,41.24,-0.402,41.44,0.045,41.65,0.097,41.84,0.357,42.05,-0.141,42.26,00000000 ,40.63,8,40.83,8,,,,,,,
,42.88,4110,43.08,-0.402,43.28,0.045,43.49,0.097,43.69,0.357,43.89,-0.141,44.10,00000000 ,42.47,8,42.67,8,,,,,,,
,44.72,4090,44.92,-0.402,45.12,0.045,45.33,0.097,45.53,0.357,45.73,-0.141,45.93,00000000 ,44.31,0,44.51,8,,,,,,,
,46.54,5170,46.75,-0.402,46.95,0.045,47.16,0.097,47.37,0.357,47.57,-0.141,47.77,00000000 ,46.13,0,46.35,8,,,,,,,
,48.38,8310,48.59,-0.402,48.79,0.045,48.99,0.097,49.19,0.357,49.40,-0.141,49.60,00000000 ,47.98,0,48.18,8,,,,,,,
,50.21,7880,50.41,-0.402,50.62,0.045,50.82,0.097,51.04,0.357,51.24,-0.141,51.44,00000001 ,49.80,0,50.01,8,,,,,,,
,52.05,3320,52.25,-0.402,52.46,0.045,52.66,0.097,52.86,0.357,53.06,-0.141,53.27,00000000 ,51.64,0,51.85,8,,,,,,,
,53.87,4570,54.08,-0.402,54.28,0.045,54.48,0.097,54.69,0.357,54.89,-0.141,55.09,00000001 ,53.47,0,53.67,8,,,,,,,
,55.72,4740,55.92,-0.402,56.12,0.045,56.32,0.097,56.53,0.357,56.73,-0.141,56.93,00000001 ,55.30,0,55.50,8,,,,,,,
,57.55,4860,57.74,-0.402,57.95,0.045,58.19,0.097,58.40,0.357,58.61,-0.141,58.83,00000001 ,57.14,0,57.34,8,,,,,,,
,59.43,3500,59.64,-0.402,59.85,0.045,60.05,0.097,60.26,0.357,60.46,-0.141,60.66,00000000 ,59.02,0,59.23,8,,,,,,,
,61.27,5480,61.48,-0.402,61.70,0.045,61.89,0.097,62.09,0.357,62.30,-0.141,62.51,00000000 ,60.86,0,61.06,8,,,,,,,
,63.13,6550,63.33,-0.402,63.53,0.045,63.73,0.097,63.94,0.357,64.14,-0.141,64.34,00000000 ,62.73,0,62.92,8,,,,,,,
,64.95,6590,65.15,-0.402,65.36,0.045,65.56,0.097,65.76,0.357,65.96,-0.141,66.17,00000000 ,64.54,0,64.75,8,,,,,,,
,66.77,6650,66.98,-0.402,67.18,0.045,67.39,0.097,67.59,0.357,67.79,-0.141,67.99,00000000 ,66.38,0,66.57,8,,,,,,,
,68.60,9300,68.80,-0.402,69.01,0.045,69.21,0.097,69.41,0.357,69.62,-0.141,69.82,00000000 ,68.20,2,68.40,14,,,,,,,
,70.43,8380,70.63,-0.402,70.83,0.045,71.03,0.097,71.24,0.357,71.44,-0.141,71.64,00000000 ,70.02,18,70.22,26,,,,,,,
,72.25,6350,72.46,-0.402,72.66,0.045,72.87,0.097,73.06,0.357,73.27,-0.141,73.47,00000001 ,71.84,21,72.05,29,,,,,,,
,74.09,6160,74.30,-0.402,74.50,0.045,74.70,0.097,74.90,0.357,75.11,-0.141,75.31,00000001 ,73.68,21,73.89,29,,,,,,,
,75.92,5540,76.12,-0.402,76.32,0.045,76.53,0.097,76.73,0.357,76.93,-0.141,77.13,00000000 ,75.51,21,75.72,29,,,,,,,
,77.74,4330,77.95,-0.402,78.17,0.045,78.37,0.097,78.57,0.357,78.77,-0.141,78.98,00000001 ,77.34,21,77.54,29,,,,,,,
,79.58,3850,79.79,-0.402,79.99,0.045,80.19,0.097,80.40,0.357,80.60,-0.141,80.80,00000000 ,79.18,21,79.38,29,,,,,,,
,81.41,8100,81.61,-0.402,81.81,0.045,82.02,0.097,82.22,0.357,82.42,-0.141,82.63,00000000 ,81.00,21,81.21,29,,,,,,,
,83.23,6960,83.43,-0.402,83.64,0.045,83.84,0.097,84.05,0.357,84.25,-0.141,84.45,00000001 ,82.83,22,83.03,30,,,,,,,
,85.06,5630,85.26,-0.402,85.46,0.045,85.67,0.097,85.87,0.357,86.08,-0.141,86.29,00000001 ,84.65,22,84.86,30,,,,,,,
,86.91,5770,87.10,-0.402,87.31,0.045,87.51,0.097,87.72,0.357,87.93,-0.141,88.15,00000001 ,86.49,22,86.70,30,,,,,,,
,88.77,5870,88.98,-0.402,89.18,0.045,89.38,0.097,89.58,0.357,89.79,-0.141,89.99,00000001 ,88.35,22,88.56,30,,,,,,,
,90.60,5970,90.81,-0.402,91.00,0.045,91.21,0.097,91.41,0.357,91.62,-0.141,91.83,00000001 ,90.19,22,90.39,30,,,,,,,
,92.44,5560,92.65,-0.402,92.84,0.045,93.05,0.097,93.25,0.357,93.46,-0.141,93.66,00000000 ,92.04,22,92.24,30,,,,,,,
,94.28,4660,94.48,-0.402,94.69,0.045,94.89,0.097,95.09,0.357,95.29,-0.141,95.51,00000000 ,93.87,22,94.08,30,,,,,,,
,96.12,7180,96.32,-0.402,96.52,0.045,96.73,0.097,96.93,0.357,97.14,-0.141,97.35,00000000 ,95.71,0,95.92,30,,,,,,,
,97.96,8210,98.16,-0.402,98.37,0.045,98.57,0.097,98.77,0.357,98.98,-0.141,99.18,00000000 ,97.56,0,97.76,30,,,,,,,
,99.79,9010,99.99,-0.402,100.20,0.045,100.41,0.097,100.62,0.357,100.83,-0.141,101.04,00000000 ,99.38,4,99.58,35,,,,,,,
,101.66,7150,101.86,-0.402,102.06,0.045,102.27,0.097,102.47,0.357,102.67,-0.141,102.87,00000000 ,101.25,5,101.46,35,,,,,,,
,103.48,3990,103.68,-0.402,103.89,0.045,104.10,0.097,104.30,0.357,104.50,-0.141,104.70,00000001 ,103.08,5,103.28,35,,,,,,,
,105.31,3020,105.51,-0.402,105.71,0.045,105.92,0.097,106.12,0.357,106.32,-0.141,106.52,00000001 ,104.90,5,105.11,35,,,,,,,
,107.14,3190,107.34,-0.402,107.54,0.045,107.74,0.097,107.94,0.357,108.15,-0.141,108.35,00000001 ,106.73,5,106.93,35,,,,,,,
,108.96,3340,109.16,-0.402,109.36,0.045,109.57,0.097,109.77,0.357,109.97,-0.141,110.17,00000001 ,108.55,5,108.76,35,,,,,,,
,110.78,3440,110.99,-0.402,111.19,0.045,111.39,0.097,111.60,0.357,111.80,-0.141,112.00,00000000 ,110.38,5,110.58,35,,,,,,,
,112.61,3550,112.81,-0.402,113.02,0.045,113.22,0.097,113.42,0.357,113.62,-0.141,113.83,00000000 ,112.20,5,112.41,35,,,,,,,
,114.45,4420,114.66,-0.402,114.87,0.045,115.08,0.097,115.28,0.357,115.48,-0.141,115.68,00000000 ,114.03,5,114.24,35,,,,,,,
,116.29,7060,116.50,-0.402,116.70,0.045,116.90,0.097,117.10,0.357,117.30,-0.141,117.51,00000000 ,115.88,5,116.09,35,,,,,,,
,118.12,7800,118.32,-0.402,118.52,0.045,118.72,0.097,118.93,0.357,119.15,-0.141,119.35,00000000 ,117.71,5,117.91,35,,,,,,,
,119.98,8480,120.19,-0.402,120.39,0.045,120.59,0.097,120.80,0.357,121.00,-0.141,121.20,00000000 ,119.56,6,119.77,36,,,,,,,
,121.82,8460,122.04,-0.402,122.26,0.045,122.45,0.097,122.66,0.357,122.86,-0.141,123.07,00000000 ,121.41,29,121.61,59,,,,,,,
,123.69,3440,123.89,-0.402,124.09,0.045,124.30,0.097,124.50,0.357,124.76,-0.141,124.94,00000001 ,123.28,29,123.48,59,,,,,,,
,125.58,2880,125.79,-0.402,125.99,0.045,126.20,0.097,126.40,0.357,126.60,-0.141,126.80,00000001 ,125.16,29,125.36,59,,,,,,,
,127.42,3030,127.63,-0.402,127.84,0.045,128.04,0.097,128.24,0.357,128.44,-0.141,128.65,00000001 ,127.01,29,127.21,59,,,,,,,
,129.27,3220,129.48,-0.402,129.69,0.045,129.90,0.097,130.10,0.357,130.30,-0.141,130.50,00000000 ,128.85,29,129.06,59,,,,,,,
,131.11,4010,131.31,-0.402,131.52,0.045,131.72,0.097,131.92,0.357,132.12,-0.141,132.33,00000000 ,130.71,29,130.91,59,,,,,,,
,132.94,4420,133.14,-0.402,133.34,0.045,133.54,0.097,133.75,0.357,133.95,-0.141,134.16,00000000 ,132.53,29,132.74,59,,,,,,,
,134.76,6960,134.96,-0.402,135.17,0.045,135.37,0.097,135.57,0.357,135.77,-0.141,135.98,00000000 ,134.35,29,134.56,59,,,,,,,
,136.59,5440,136.79,-0.402,136.99,0.045,137.20,0.097,137.40,0.357,137.60,-0.141,137.80,00000001 ,136.18,29,136.38,59,,,,,,,
,138.42,6350,138.63,-0.402,138.83,0.045,139.04,0.097,139.24,0.357,139.44,-0.141,139.64,00000001 ,138.01,29,138.21,59,,,,,,,
,140.25,2830,140.46,-0.402,140.66,0.045,140.86,0.097,141.06,0.357,141.27,-0.141,141.47,00000001 ,139.85,29,140.05,59,,,,,,,
,142.08,2950,142.28,-0.402,142.48,0.045,142.69,0.097,142.89,0.357,143.09,-0.141,143.30,00000001 ,141.67,29,141.87,59,,,,,,,
,143.90,3090,144.10,-0.402,144.31,0.045,144.52,0.097,144.73,0.357,144.93,-0.141,145.14,00000001 ,143.50,29,143.70,59,,,,,,,
,145.74,3200,145.95,-0.402,146.15,0.045,146.35,0.097,146.56,0.357,146.76,-0.141,146.97,00000001 ,145.34,29,145.54,59,,,,,,,
,147.57,3220,147.77,-0.402,147.97,0.045,148.18,0.097,148.38,0.357,148.58,-0.141,148.80,00000001 ,147.16,29,147.37,59,,,,,,,
,149.39,2790,149.60,-0.402,149.80,0.045,150.00,0.097,150.20,0.357,150.41,-0.141,150.61,00000001 ,148.99,29,149.19,59,,,,,,,
,151.22,3140,151.42,-0.402,151.62,0.045,151.83,0.097,152.03,0.357,152.24,-0.141,152.45,00000001 ,150.82,29,151.02,59,,,,,,,
,153.06,3380,153.26,-0.402,153.47,0.045,153.67,0.097,153.87,0.357,154.08,-0.141,154.28,00000000 ,152.66,29,152.86,59,,,,,,,
,154.89,3580,155.09,-0.402,155.29,0.045,155.50,0.097,155.71,0.357,155.92,-0.141,156.12,00000000 ,154.48,29,154.68,59,,,,,,,
,156.73,3430,156.93,-0.402,157.13,0.045,157.33,0.097,157.54,0.357,157.74,-0.141,157.94,00000000 ,156.32,29,156.52,59,,,,,,,
,158.55,6120,158.76,-0.402,158.96,0.045,159.16,0.097,159.36,0.357,159.57,-0.141,159.77,00000001 ,158.15,29,158.35,59,,,,,,,
,160.38,6020,160.58,-0.402,160.78,0.045,160.98,0.097,161.19,0.357,161.39,-0.141,161.60,00000000 ,159.97,0,160.17,59,,,,,,,
,162.20,7930,162.40,-0.402,162.61,0.045,162.82,0.097,163.01,0.357,163.22,-0.141,163.42,00000000 ,161.80,0,162.00,59,,,,,,,
,164.04,6820,164.25,-0.402,164.46,0.045,164.67,0.097,164.87,0.357,165.07,-0.141,165.27,00000000 ,163.62,0,163.83,59,,,,,,,
,165.88,3550,166.09,-0.402,166.29,0.045,166.49,0.097,166.70,0.357,166.90,-0.141,167.10,00000000 ,165.48,0,165.68,59,,,,,,,
,167.71,4110,167.91,-0.402,168.11,0.045,168.32,0.097,168.52,0.357,168.72,-0.141,168.93,00000000 ,167.30,0,167.51,59,,,,,,,
,169.55,4900,169.75,-0.402,169.95,0.045,170.16,0.097,170.36,0.357,170.56,-0.141,170.77,00000000 ,169.13,0,169.34,59,,,,,,,
,171.40,4370,171.60,-0.402,171.82,0.045,172.03,0.097,172.23,0.357,172.44,-0.141,172.64,00000000 ,170.98,0,171.19,59,,,,,,,
,173.24,3940,173.45,-0.402,173.66,0.045,173.87,0.097,174.08,0.357,174.28,-0.141,174.48,00000000 ,172.84,0,173.05,59,,,,,,,
,175.09,4350,175.29,-0.402,175.50,0.045,175.69,0.097,175.90,0.357,176.11,-0.141,176.32,00000001 ,174.68,0,174.89,59,,,,,,,
,176.93,3260,177.14,-0.402,177.35,0.045,177.55,0.097,177.76,0.357,177.96,-0.141,178.16,00000000 ,176.52,0,176.73,59,,,,,,,
,178.77,3410,178.97,-0.402,179.18,0.045,179.38,0.097,179.58,0.357,179.78,-0.141,179.99,00000000 ,178.36,0,178.57,59,,,,,,,
,180.59,5730,180.80,-0.402,181.00,0.045,181.20,0.097,181.41,0.357,181.61,-0.141,181.81,00000000 ,180.19,0,180.39,59,,,,,,,
,182.42,8570,182.62,-0.402,182.83,0.045,183.03,0.097,183.23,0.357,183.43,-0.141,183.64,00000000 ,182.01,0,182.22,59,,,,,,,
,184.25,7630,184.45,-0.402,184.65,0.045,184.85,0.097,185.05,0.357,185.26,-0.141,185.46,00000001 ,183.84,0,184.04,59,,,,,,,
,186.07,7880,186.27,-0.402,186.49,0.045,186.69,0.097,186.89,0.357,187.10,-0.141,187.30,00000000 ,185.67,0,185.87,59,,,,,,,
,187.91,8480,188.11,-0.402,188.32,0.045,188.52,0.097,188.72,0.357,188.93,-0.141,189.13,00000000 ,187.50,0,187.71,59,,,,,,,
,189.73,5490,189.94,-0.402,190.14,0.045,190.34,0.097,190.55,0.357,190.75,-0.141,190.96,00000000 ,189.34,0,189.53,59,,,,,,,
,191.56,4660,191.76,-0.402,191.97,0.045,192.17,0.097,192.37,0.357,192.58,-0.141,192.78,00000000 ,191.15,0,191.36,59,,,,,,,
,193.39,5370,193.59,-0.402,193.79,0.045,193.99,0.097,194.20,0.357,194.40,-0.141,194.61,00000000 ,192.98,0,193.18,59,,,,,,,
,195.23,2860,195.43,-0.402,195.63,0.045,195.83,0.097,196.04,0.357,196.24,-0.141,196.44,00000001 ,194.82,0,195.02,59,,,,,,,
,197.06,2790,197.25,-0.402,197.46,0.045,197.66,0.097,197.86,0.357,198.07,-0.141,198.27,00000000 ,196.65,0,196.85,59,,,,,,,
,198.88,4780,199.08,-0.402,199.28,0.045,199.49,0.097,199.69,0.357,199.89,-0.141,200.09,00000000 ,198.47,0,198.67,59,,,,,,,
,200.70,5220,200.91,-0.402,201.11,0.045,201.31,0.097,201.52,0.357,201.72,-0.141,201.92,00000000 ,200.30,0,200.50,59,,,,,,,
,202.53,5440,202.73,-0.402,202.94,0.045,203.14,0.097,203.34,0.357,203.54,-0.141,203.74,00000000 ,202.12,0,202.33,59,,,,,,,
,204.36,6330,204.56,-0.402,204.76,0.045,204.96,0.097,205.17,0.357,205.37,-0.141,205.57,00000000 ,203.95,0,204.15,59,,,,,,,
,206.18,6600,206.38,-0.402,206.58,0.045,206.79,0.097,206.99,0.357,207.19,-0.141,207.39,00000000 ,205.77,0,205.98,59,,,,,,,
,208.00,5000,208.21,-0.402,208.41,0.045,208.61,0.097,208.82,0.357,209.02,-0.141,209.22,00000000 ,207.60,0,207.80,59,,,,,,,
,209.83,4140,210.03,-0.402,210.24,0.045,210.44,0.097,210.64,0.357,210.84,-0.141,211.04,00000000 ,209.43,0,209.63,59,,,,,,,
,211.67,4260,211.87,-0.402,212.07,0.045,212.28,0.097,212.49,0.357,212.68,-0.141,212.89,00000001 ,211.25,0,211.46,59,,,,,,,
,213.50,3480,213.70,-0.402,213.90,0.045,214.10,0.097,214.31,0.357,214.51,-0.141,214.71,00000001 ,213.09,0,213.29,59,,,,,,,
,215.32,3500,215.52,-0.402,215.72,0.045,215.93,0.097,216.13,0.357,216.34,-0.141,216.54,00000001 ,214.91,0,215.12,59,,,,,,,
,217.15,2830,217.35,-0.402,217.55,0.045,217.76,0.097,217.97,0.357,218.17,-0.141,218.38,00000001 ,216.74,0,216.94,59,,,,,,,
,218.99,2950,219.19,-0.402,219.39,0.045,219.60,0.097,219.80,0.357,220.00,-0.141,220.20,00000001 ,218.58,0,218.78,59,,,,,,,
,220.82,3340,221.01,-0.402,221.21,0.045,221.42,0.097,221.62,0.357,221.83,-0.141,222.03,00000000 ,220.40,0,220.61,59,,,,,,,
,222.66,4020,222.87,-0.402,223.08,0.045,223.28,0.097,223.48,0.357,223.68,-0.141,223.89,00000000 ,222.23,0,222.44,59,,,,,,,
,224.51,3320,224.72,-0.402,224.93,0.045,225.14,0.097,225.35,0.357,225.56,-0.141,225.76,00000000 ,224.10,0,224.31,59,,,,,,,
,226.37,4310,226.57,-0.402,226.77,0.045,226.97,0.097,227.18,0.357,227.38,-0.141,227.58,00000000 ,225.96,0,226.16,59,,,,,,,
,228.19,4040,228.39,-0.402,228.60,0.045,228.80,0.097,229.00,0.357,229.20,-0.141,229.41,00000000 ,227.78,0,227.99,59,,,,,,,
,230.02,4980,230.22,-0.402,230.43,0.045,230.64,0.097,230.84,0.357,231.04,-0.141,231.25,00000000 ,229.61,0,229.81,59,,,,,,,
,231.86,4330,232.06,-0.402,232.26,0.045,232.46,0.097,232.67,0.357,232.87,-0.141,233.08,00000000 ,231.45,0,231.66,59,,,,,,,
,233.68,3840,233.88,-0.402,234.09,0.045,234.29,0.097,234.49,0.357,234.70,-0.141,234.90,00000000 ,233.29,0,233.48,59,,,,,,,
NostraJackAss
Change injectors..............and filter or even HPP check for FOD grenade of fragments causing failure!
Bojole
C?ID=27403
Jack, just the injector for cylinder 5 or all?
Which filter, the fuel line?
And what's HPP? :)
For foreign objects damage inspection do I need to open the cylinder head?
Thanks!
NostraJackAss
Change them all if that deep & HPP is the high pressure fuel pump, or swap to isolate a condition before so, right?
Inspect old injectors under magnifier at inlets and if you see anything change the pump, right?
Always change the fuel filter and inspect for contamination in a fuel system, right?
Bojole
C?ID=27403
Jack, that makes sense and it's clear, now, what I have to do. Thank you and cheers.
Bojole
C?ID=27403
Jack, just replying to follow up on this, if someone else reads it, and to say THANKS. I replaced all injectors and the High pressure pump, and the engine runs smooth like a cat now.
All error codes cleared. I didn't do any special adaptations after the replacement, so not sure, if I had to, and I missed something.
Cheers
P.S. If any amateur, like me, is attempting this repair, have in mind that it took me about 6 hours, and I had to rent an injector extractor tool. In this time I cleaned all around the intake manifold, scraped and vacuumed the intake valves as their stems had some carbon buildup from the lame ethanol fuel here in US, cleaned the injector shafts, examined and cleaned the MAF sensor, washed and oiled the K&N intake filter.
