2010 Audi A6 Quattro(Fault Codes)
Cobie90
C?ID=311736
I have an issue with my ABS system. I recently changed my driver front wheel and hub bearing, outter tie end rod and driver side wheel speed sensor. Since i have did that my Traction light, TPMS light, and ABS light come on soons i crank my car. If i erase the codes they come back on soons i reach about 5 mph.( Also my cars wobbles only on driver front side and also when i start slowing down it also wobbles.(Image of lights that shows up and VCDS fault codes)
Lights that come on when car is cranked
https://imgur.com/a/ymqmZb7
Tuesday,14,August,2018,17:23:50:05661
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WAUKGAFB7AN036515   License Plate:
Mileage: 159350km-99015mi   Repair Order:
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
          56 5F 62 6C 72
VIN: WAUKGAFB7AN036515   Mileage: 159350km-99015miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CCA)       Labels: Redir Fail!
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0050
   Revision: --H06---    Serial number:
   Coding: 0105000A190F0120
   Shop #: WSC 08175 444 103843
   VCID: 2412E4F0D2DA9EF735C-8070
               U1017 - 000 -
                    Fault Status: 01101000
                    Fault Frequency: 164
                    Mileage: 156754 km
                    Date: 2018.07.11
                    Time: 12:03:27
                    RPM: 1248 /min
                    Mass Air / Rev.: 125.4 mg/str
                    Temperature: 79.5°C
                    Bin. Bits: 00000010
                    Load: 9.0 %
009523 - Ignition Switch; Run/Start Position Circuit
               P2533 - 000 - Open or Short to Ground - Intermittent
                    Fault Status: 00100001
                    Mileage: 158623 km
                    Date: 2018.08.02
                    Time: 17:47:22
                    RPM: 1344 /min
                    Mass Air / Rev.: 190.8 mg/str
                    Temperature: 76.5°C
                    Bin. Bits: 00000010
                    Voltage: 11.63 V
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0010
   Revision: --H04---    Serial number:        4539555
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 2A0E0AC8B0FE48870F0-807E
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: 6E86C6D84C9664A7938-803A
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Reset counter: 225
                    Mileage: 159333 km
                    Date: 2018.08.14
                    Time: 16:27:42
                    Hex Value: 0x1100
                    Hex Value: 0x4012
                    Hex Value: 0x0006
                    Hex Value: 0x37A7
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602501421794
   Coding: 0000007
   Shop #: WSC 02324 785 00200
   VCID: 2514F9F4D9E067FF222-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000076    Serial number: 00000030563599
   Coding: 0524326
   Shop #: WSC 02335 785 00200
   VCID: 1D64D114F1B0AF3F7A2-8048
   Part No SW: 4F0 910 279 Q    HW: 4F0 907 279 A
   Component: ILM Fahrer      H24 0340
   Coding: 0139123
   VCID: 372823BC734CE56F80E-8062
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
            010 - Open or Short to Plus
                    Fault Status: 01111010
                    Reset counter: 225
                    Mileage: 150448 km
                    Date: 2018.04.28
                    Time: 21:27:00
                    Reset counter: 225
                    Mileage: 152148 km
                    Date: 2018.05.12
                    Time: 21:29:00
01494 - Bulb for Parking Lamps; Left (M1)
                    Fault Frequency: 11
                    Reset counter: 225
                    Mileage: 144320 km
                    Date: 2018.03.13
                    Time: 01:20:00
01498 - Bulb for Parking Lamps; Right (M3)
                    Reset counter: 225
                    Mileage: 144300 km
                    Date: 2018.03.12
                    Time: 20:40:00
00156 - Control Circuit for Windshield Washer Pump
                    Reset counter: 225
                    Mileage: 142128 km
                    Date: 2017.12.18
                    Time: 19:00:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1574C9340580F77FB22-8040
Address 15: Airbags (J234)       Labels:| 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FA0012RDS
   Coding: 303142373034303030314A55304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 36362EB878C61C679B8-8062
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03 0060
   Serial number: 5810000R0000003W4J
   Serial number: 3574SRB400009FDD0ABV
   Serial number: 3584SRB400009F94E27L
   Serial number: 3516HRB402VC0AS50SV6
   Serial number: 3526HRB402VC0AS4OKNE
   Serial number: 3554NRB40000517EBB79
   Serial number: 3564NRB4000051197E1Z
12583424 - Powertrain Databus
          U0002 00 [008] - No Communications
          [High Speed CAN Communication Bus no signal/communication]
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026092900003
   Coding: 0012141
   VCID: 2708F3FCA3EC75EF10E-8072
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
   Component: KOMBIINSTR.   H08 0144
   Revision: 00000000    Serial number: CN450YEA9
   Coding: 8BD60A050B00CF05020201
   Shop #: WSC 02391 823 56573
   VCID: 313C1DA491283B5FCEA-8064
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L09A1700BA
   Coding: 000303
   VCID: 392C25844958F31F76A-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790718207
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010017085
   Coding: 00581B00004011110000
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000102168472
   Coding: 011F57204E40410001
   VCID: 46D65E7808A68CE70B8-8012
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01229654010000
   Coding: 4618269
   VCID: 353429B46940177F922-8060
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000041814
   Coding: 05000000
   VCID: 290CF5C4B9F8439F06A-807C
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 A    HW: 4F0 907 274
   Component: J793  RKA+      H02 0100
   Revision: 00000506    Serial number: 00005061074829
   Coding: 0623301
   VCID: 221EE2E8C8CE90C7470-8076
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
                    Reset counter: 250
                    Mileage: 158330 km
                    Date: 2018.07.30
                    Time: 22:55:35
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 13.70 V
                    Temperature: 37.0°C
                    (no units): 98.0
                    Fault Status: 11101101
                    Reset counter: 225
                    Mileage: 156754 km
                    Date: 2018.07.11
                    Time: 12:03:29
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 13.70 V
                    Temperature: 33.0°C
                    (no units): 83.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000509539
   Coding: 0002014
   VCID: 5EE69618BC36F427238-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000102131826
   VCID: 45D4597435A087FF022-8010
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: 211CEDE4CDC88BDF5EA-8074
                    Fault Status: 00101101
                    Fault Frequency: 51
                    Reset counter: 9
                    Mileage: 159312 km
                    Date: 2018.08.14
                    Time: 13:28:34
                    Voltage: 12.63 V
                    Count: 236
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0060
   Coding: 0000026
   VCID: 698CB5C47578839FC6A-803C
   Subsystem 1 - Part No: -----------
   Component: AFS-Modul links
   Subsystem 2 - Part No: -----------
   Component: AFS-Modul rechts
02071 - Local Databus
                    Fault Status: 11100100
                    Reset counter: 94
                    Mileage: 142129 km
                    Date: 2017.12.08
                    Time: 22:37:28
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335J-097535137
   Coding: 020000010000000000
   VCID: 1D64D114FDB0AF3F7A2-8048
   Part No SW: 4E0 035 664 A    HW: 4E0 035 664 A
   Component: H-BN-NA       H45 0042
   Revision: --------    Serial number: 488J/097520192
   Coding: 010200000002E1FE41000304EF6300030000
   VCID: 221EE2E8C4CE90C7470-8076
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356JX091091752
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 T
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001422512
   Component: CD-Database  1293
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000009496373
   Coding: 010E57204040220001
   VCID: 43D0476C3B94B9CF2C6-8016
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J9925BW
   Coding: 1000304
   Revision:             Serial number: 0000009496374
End----------(Elapsed Time: 01:52, VBatt start/end: 13.4V/13.4V)-----------
Address 03: DTCs cleared
NostraJackAss
Do your work over and check parts plus seek professional help if above your skill level, right?
Induced FOD..........
JPPSG & RTFB are a must no?
Cobie90
C?ID=311736
I mean it still drives it just wobble when i drive and start braking. I was wondering if it could be that the abs system lost memory are if my rotor warped just wanted opinions before i start replacing parts.
Cobie90
C?ID=311736
Im confused at what you are saying
South Molton, UK
I would check the wheel is OK, that the hub bearing has been properly fitted and the brake disc correctly re-fitted.
It sounds like something is out of true causing the woble when you brake.
Cobie90
C?ID=311736
Ok thanks ill check back over my work but have you ever heard of rotors warping
NostraJackAss
Rotors show warpage typically when you apply the brake & due to uneven braking surface as a result of overheating ,incorrect camber/toe settings, warn pads, stuck/faulty caliper/brake carrier slider or corrosion.
Your statements imply you should not be doing these repairs or you are unsafe as a result is my opinion.
Cobie90
C?ID=311736
I mean i changed everything properly because i did the passenger side and my car drove fine but when i changed the driver side my car started shaking and its just on my driver side...and the only fault code is
Abs front left wheel speed sensor "Implausible signal" (G47) which is sending fault codes to my Abs module and is making my parking brake, Tpms, traction and abs light come on
HMC
C?ID=28246
Brake disk distortion will cause a vibration when braking, it will not cause a 00283 DTC. Did you use new parts or used? I am with Jack, you have introduced your problem. Recheck what you have done and if you used old parts change them for good quality new parts.
Regards HMC
