Is my DPF stuffed?
Crafty345
Australia
C?ID=287816
Is my DPF stuffed?
Monday,20,August,2018,20:28:35:42630
VCDS Version: 18.2.1.2 (x64)
VIN: WAUZZZ8T1AA026759   License Plate:
Mileage: 126490km-78597mi   Repair Order:
Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K2 907 401     HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H16 0006
   Revision: 15H16---
   Coding: 0114002C190F0128
   Shop #: WSC 19618 002 1048576
   ASAM Dataset: EV_ECM30TDI0118K2907401 001006
   ROD: EV_ECM30TDI0118K2907401.rod
   VCID: 6AE250938DD96F1499-803E
5188 - Diesel Particle Filter
          P2463 00 [036] - Excessive Soot Accumulation
                    Mileage: 126474 km
                    Date: 2018.08.20
                    Time: 19:45:07
                    Engine speed: 1747.50 /min
                    Normed load value: 54.1 %
                    Vehicle speed: 27 km/h
                    Coolant temperature: 46 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 13.660 V
                    Crankshaft speed (RPM): 1653.5 /min
                    Vehicle speed: 28.54 km/h
                    Particle filter: soot mass measured: 32.14 g
                    Particle filter: soot mass calculated: 24.62 g
                    Particle filter: kilometers since last regeneration: 99955 m
                    P Flt Rgn st Intr-Bits 0-7: 00000000
                    Particle filter: time since last regeneration: 0 s
5162 - Diesel Particle Filter; Differential Pressure Sensor
          P2453 00 [229] - Implausible Signal
                    Mileage: 126493 km
                    Date: 2018.08.20
                    Time: 20:04:09
                    Engine speed: 0.00 /min
                    Coolant temperature: 91 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 12.720 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Particle filter: difference pressure: 377 hPa
                    Intake air temperature: 11.0 °C
                    Exhaust gas temp.after pre-catalyst: 180.0 °C
                    Particle filter: offset for differential press.: 17 hPa
                    Exhaust gas vol.flow particulate filter: 0.0 m³/h
5189 - Particulate Trap Bank 1
          P2002 00 [036] - Efficiency Below Threshold
                    Mileage: 126474 km
                    Date: 2018.08.20
                    Time: 19:45:07
                    Particle filter: difference pressure: 765 hPa
                    Exh t Adap T Oxi Cat Ds: 151.3 °C
                    Exhaust gas temperature before particulate filter: 140.0 °C
                    Exhaust gas vol.flow particulate filter: 155.1 m³/h
                    Field regeneration status-Bits 0-7: 00000000
iichel
Netherlands, Operation Market Garden
C?ID=284912
Could be, or the sensor is simply broken, the G505.
Could you have a look at the measurement value blocks or advanced measurement values, for your DPF differential pressure values?
Have a look at the engine-off values, there should be hardly any differential pressure, if any at all.
Then you could have a look at the engine idling, and see if these values make sense.
Things to look at:
IDE00427 -- Particle filter: difference pressure
What does it show with the engine not running?
What does it show with the engine at idle?
And then these (doesn't matter if the engine is running or not).
IDE00433 -- Particle filter: oil ash volume
IDE00434 -- Particle filter: soot mass calculated
IDE00435 -- Particle filter: soot mass measured
IDE00436 -- Particle filter: kilometers since last regeneration
Gone But Not Forgotten
[h=2]Is my DPF stuffed?[/h]
Most likely & like a teddy bear that has been left for dead.......... :rolleyes:
It would be advised to clean the DPF, with all conduits or sensors & as regular maintenance in the exhaust, start with a chemical clean.
Crafty345
Australia
C?ID=287816
Tuesday,21,August,2018,17:57:42:42630
Address 01: Engine (8K2 907 401 )
17:57:28
IDE00427 Particle filter: difference pressure 0 hPa
IDE00428 Particle filter: offset for differential press. 21 hPa
IDE00433 Particle filter: oil ash volume 0.30 l
IDE00434 Particle filter: soot mass calculated 15.85 g
IDE00435 Particle filter: soot mass measured 54.21 g
IDE00436 Particle filter: kilometers since last regeneration 138508 m
Crafty345
Australia
C?ID=287816
And with the engine running
Tuesday,21,August,2018,18:18:29:42630
18:18:25
IDE00427 Particle filter: difference pressure 4 hPa
IDE00432 Particle filter: time since last regeneration 11119 s
IDE00434 Particle filter: soot mass calculated 16.00 g
138 km and ~3 hours since last regeneration. Average speed ~45 km/h.
Vehicle has less than 80,000 miles on it. Seems like it shouldn't really need DPF remediation just yet.
I wonder what would happen if he just took this thing out on the highway at 120-130 km/h for a few hours?
Does 21 hPa of offset for the differential pressure sensor strike anyone else as kinda high?
Uwe it is high.....
OP:
It would be a good idea to try chemical cleaning first & so the DPF & CAT can be observed visually during regen with this level versus going on a road trip.
After doing a chemical removal and verifying the PSI sensors work while exhaust has no obstruction using an external vacuum & PSI gauge to further check mechanicals and not rely solely on OBD data.
Safety first!
"Only you can prevent DPF fires!"
Crafty345
Australia
C?ID=287816
Only one problem with that here in the land down under - max speed limit is 110 km/h, could put the trans in sport mode and hold it in 5th gear to keep the revs up
Crafty345
Australia
C?ID=287816
Uwe it is high.....
OP:
Safety first!
So how does one do a "chemical clean"?
Crafty345
Australia
C?ID=287816
I just went and plugged my VCDS in again, (engine off) cleared the codes and within two seconds the fault light came back on, this, I hope, tells me that it's an electrical problem (sensor) that should be a cheap fix, after it's fitted I will take the car for a long drive and keep it in 5th gear so it can do a decent DPF burn.
You could search Youtube on DPF cleaners and methods to extract, right?
You could select a lower gear which revs the engine higher & to avoid speed limit issues to address the law and safety now couldn't you?
Crafty345
Australia
C?ID=287816
Well I just replaced the DPF differential pressure sensor and cleared the codes, however two codes came back - Diesel particulate filter P2463 (excessive soot accumulation) and Particulate filter trap bank 1 P2002 (efficiency below threshold), I'm hoping that I can now take it for a drive have the car do a regen and all should be good.
Crafty345
Australia
C?ID=287816
Tried to do a service DPF regen and kept getting an error, so I reset the learned values of the particulate filter and the difference pressure sensor and all good now.
Trade Member
C?ID=271231
No it sounds a lot but converted to psi = 0.301
If I understand it correctly, this value is a discrepancy in the readings between the two sides of the sensor that the ECU learns and compensates for. Although a three tenths of a PSI doesn't sound like much, I still wonder if there should be that much of a difference. It would be interesting to know what this value is after the OP has told the ECU to re-learn the sensor and has driven the vehicle some.
Crafty345
Australia
C?ID=287816
I'll post the readings this weekend after I have done my usual driving for the week
