Passat B7 kessy retrofit CCM coding
siLc
Tallinn, Estonia
C?ID=330192
I'm in progress of retrofitting kessy to my euro Passat B7 2011. I've already fitted everything needed except for the rear bumper antenna.
Yesteday I finally wired up the rear doors and fitted the kessy door handles. Using golfi_vend's custom label file for 0x46, one can enable the left/right rear door handle sensors individually, I first completed the right side and tried to enable it. The result - all door handles inop and fault code logged in 0x46 along the lines of rear right door handle no communication. After unticking the bit for the rear right handle everything was back to normal.
Not wanting to get bogged down with verifying wire continuity between the door connector and handle connector on the right side, I wired up the left side as well. Then I ticked the bits for both rear handles. Lo and behold, no more fault codes besides the rear bumper antenna but the rear door handles still won't lock or unlock the car while the front handles do.
My coding with rear handle bits ticked:
0091020052830E763004941570084FCE705801100435BC
Example car with factory fitted kessy Passat B7 1.4 TSI EcoFuel CDGA 2013 (same model as mine):
01900A00D2C30E76340494157200CFCE705801030434B8
Example car with factory fitted kessy Passat B7 2.0 TDI CFGC 2014 Alltrack
01900A00D2C30E76340C94157E00CFCE705800030424B8
Example car with factory fitted kessy Passat B7 2.0 TDI CFGC 2013
1891020052C34E76300A143DFE00CFCE705841030434B8
Example car with factory fitted kessy Passat B7 2.0 TDI CFFB 2011 (this one's a sedan)
01910A0002C60E76300494157E004FCE70780103242498
I tried coding to:
0091020052830E763004941570084FCE705801100434B8
Coding was accepted but rear handles still inop.
What codings could I try?
With rear doors does it matter whether the rear bumper antenna is connected or not?
A bit out of date autoscan of my car. All the faults in 0x46 except for 00181 are gone.
Thursday,19,July,2018,16:05:16:46309
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVWZZZ3CZCE0xxxxx   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 36 42 44 46 47 4F 52 53
          55 5F 61 62 65 69 72 A5
VIN: WVWZZZ3CZCE0xxxxx   Mileage: 117230km-72843miles
Address 01: Engine (CDG)       Labels: 03C-906-021-CDG.clb
   Part No SW: 03C 906 021 Q    HW: 03C 907 309 D
   Component: 4414 CNG 14K31      6368
   Revision: E8H06---    Serial number: VWZCZ000000000
   Coding: 0000077
   Shop #: WSC 30382 001 1048576
   VCID: 290F0014A5F26C1F069-807C
   Part No SW: 0AM 300 058 P    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5279
   Revision: 00043014    Serial number: CU501109246351
   Shop #: WSC 51156 001 1048576
   VCID: 3E25C3484C7CFBA743B-806A
   Part No SW: 3AA 614 109 AJ    HW: 3AA 614 109 AG
   Component: J104   C2 450M VE60 0023
   Revision: --H07---    Serial number: 00000005519400
   Coding: 0246129
   Shop #: WSC 00046 000 00000
   VCID: 75B71C6439CA78FF521-8020
   Part No SW: 1K8 907 044 T    HW: 1K8 907 044 T
   Component: Climatronic   H05 0304
   Revision: 00001K04
   Coding: 0019004802
   Shop #: WSC 35110 790 50316
   VCID: 40D9BDB03A088D57317-8014
Address 09: Cent. Elect. (J519)       Labels:. User\3AA-937-087.lbl
   Part No SW: 3AA 937 087 E    HW: 3AA 937 087 E
   Component: BCM PQ47 H+   413 0455
   Revision: BC413001
   Coding: 0008000000000000001C0288740029F423DD008863618F60E48046240041
   Shop #: WSC 05311 123 12345
   VCID: 3C21C9405660E9B76DF-8068
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 02091  10  0603
   Coding: 00B795
   Component: RLS 240911 05  54  0403
   Coding: 0650CD
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39431407800539
   Coding: 0031063211
   Shop #: WSC 06792 128 28888
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00_VW36.rod
   VCID: 3B23CA5C53EEEE8F645-806E
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000666298
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 3829D5506E58C597897-806C
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PDDP8WA
   Coding: 0012337
   Shop #: WSC 05311 000 00000
   VCID: 4CC199800AC05937DDF-8018
   Subsystem 1 - Serial number: 6332MTS660882451
   Subsystem 2 - Serial number: 6342MTS650762441
   Subsystem 3 - Serial number: 6351HTS6L728GAKJ
   Subsystem 4 - Serial number: 6361HTS6CMQGFAKJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110916100545
   Coding: 3982A50001
   Shop #: WSC 00015 115 12345
   VCID: 6FBB2E0C5716422F98D-803A
   Coding: E20000
   Part No SW: 3AA 920 881 X    HW: 3AA 920 881 X
   Component: KOMBI         H03 0705
   Coding: 161F01
   VCID: 49CFA09409324C1FE69-801C
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 26041600F10905
   Coding: 462006
   Shop #: WSC 00046 123 12345
   VCID: 7BA30A5C13EE2E8F245-802E
   Part No SW: 3AA 959 799 C    HW: 3AA 959 799 C
   Component:    IMMO         043 0404
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 48C9A5901EB8B517F97-801C
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2601
   Revision: 00H05000
   Coding: 000039
   VCID: 3333E27C7B3E26CFBC5-8066
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0003531640
   Coding: 0000FF
   Shop #: WSC 05311 115 12345
   VCID: 3537DC6475CA38FF921-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000001579121
   Coding: 0000D8
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.308 1002
   Revision: 1AH03734    Serial number: 00112640139601
   Coding: 0000258
   VCID: 3C21C9405A60E9B76DF-8068
Address 46: Central Conv.        Labels:. User\3C0-959-799-46.lbl
   Component:    KESSY PQ47   043 0359
   Coding: 0091020052830E763004941570084FCE705801100435BC
   Shop #: WSC 01581 666 28888
   Component: Neigungssensor  004 0611
   Subsystem 4 - Component:       ViP n.mounted
7 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
                    Reset counter: 83
                    Mileage: 117001 km
                    Date: 2018.07.16
                    Time: 11:02:41
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Reset counter: 83
                    Mileage: 117001 km
                    Date: 2018.07.16
                    Time: 11:02:41
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Reset counter: 83
                    Mileage: 117001 km
                    Date: 2018.07.16
                    Time: 11:02:41
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 83
                    Mileage: 117001 km
                    Date: 2018.07.16
                    Time: 11:02:41
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
                    Fault Status: 01101100
                    Fault Frequency: 24
                    Reset counter: 83
                    Mileage: 117001 km
                    Date: 2018.07.16
                    Time: 11:04:26
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
                    Fault Frequency: 24
                    Reset counter: 83
                    Mileage: 117001 km
                    Date: 2018.07.16
                    Time: 11:04:26
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
                    Fault Frequency: 24
                    Reset counter: 83
                    Mileage: 117001 km
                    Date: 2018.07.16
                    Time: 11:04:26
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218119856626
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst8KanalBNO2.rod
   VCID: 678B462C7FE69A6FD0D-8032
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1682
   Coding: 00000008
   VCID: 6FBB2E0C5796422F98D-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0003559798
   Coding: 0000FE
   VCID: 3635DB6868CC33E79BB-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002312513
   Coding: 0000D8
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000255785
   Coding: 0022157
   VCID: 3537DC64794A38FF921-8060
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0105
   Coding: 021200000B000200
   Shop #: WSC 05311 115 00000
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0011
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0011
   Coding: 230000
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H20 0252
   Serial number: VWZAZ2R0221946
   Coding: 02740401AA00000011110003000908001F0100C400200100CC
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 20191D30DA48AD57517-8074
   Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Component: Batt.regelung H56 1682
   Coding: 03220864
   VCID: 71BF287441A254DF8E9-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900563909
   Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 40000000050185
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD66C6FC6CAEF80D-8062
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00000158723392
   Coding: 4106040000000000
   Shop #: WSC 05314 000 00000
   VCID: 73B3227C3BBE66CF7C5-8026
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0220
   Serial number: 25021511P10526
   Coding: 000407020000040100221355C180880090000E100020
   Shop #: WSC 28257 001 104857
   ROD: EV_MFKBoschMQBB_VW36.rod
   VCID: 3A2DCF585CD4D7877F3-806E
End----------(Elapsed Time: 01:53, VBatt start/end: 12.1V/12.1V)-----------
Spacewalker
Poland
C?ID=159607
as far as I know rear bumper antena is only for Rear Lid open feedback
is too far to look key near rear door
but simple check MB for rear touch sensor and antenas if they visible or not
did KEY "wake up" when you touch it ?
if sensor not response, antena will not wake up key to be detecting
siLc
Tallinn, Estonia
C?ID=330192
Thanks!
I connected the bumper antenna but it did not make a difference. I checked MVB (20-something) on 0x46 and all door handle sensors report their status OK.
If you meant there could be antenna reception trouble, I know the antenna for doors is in the front door handles and while standing in front of the back door, I can lock the car from the front doors just fine.
siLc
Tallinn, Estonia
C?ID=330192
I took it upon myself to compile a bigger comparison between different kessy-equipped estate/station wagon B7 CCM codings...
00 91 02 00 52 C3 0E 76 30 04 94 15 70 00 4F CE 70 58 01 00 04 34 B8		B7 2011 CNG retrofitted 3AA959799C (my car)
01 91 02 00 52 C3 0E 76 34 04 94 15 72 00 CF CE 70 58 00 03 04 24 B8		B7 2014 CNG 3AA959799E with RVC, panoramic sunroof, electric hatch
01 90 0A 00 D2 C3 0E 76 34 04 94 15 72 00 CF CE 70 58 01 03 04 34 B8		B7 2013 CNG 3AA959799A with RVC, electric hatch
00 90 0A 00 D2 C3 0E 76 34 04 94 15 7E 00 4F CE 70 58 00 03 04 24 B8		B7 2014 2.0 TDI 3AA959799C with RVC, electric hatch
00 90 0A 00 D2 C3 0E 76 34 04 94 15 7E 00 4F CE 70 58 00 03 04 26 B8		B7 2014 2.0 TDI 3AA959799C with RVC, electric hatch and Easy Open
01 90 0A 00 D2 C3 0E 76 34 0C 94 15 7E 00 CF CE 70 58 00 03 04 24 B8		B7 2014 2.0 TDI 3AA959799E with RVC, electric hatch
01 90 0A 00 D2 C3 0E 76 34 0C 94 15 7E 00 CF CE 70 58 00 03 04 24 B8		B7 Alltrack 2015 2.0 TDI 3AA959799E with RVC, electric hatch
18 90 0A 00 D1 43 4E 74 30 00 94 15 70 00 CF CE 50 58 40 03 04 24 B8		B6 2008 3.2 with retrofitted 3AA959799C
01 90 0A 00 01 C6 0E 76 36 04 94 15 72 00 4F CE 70 58 01 13 24 37 9C		CC 2012 3AA959799A with RVC
01 91 0A 00 02 C6 0E 76 30 04 94 15 7E 00 4F CE 70 78 01 03 24 24 98		B7 2011 2.0 TDI 3AA959799 sedan with cam
I think my CCM coding should be 99% correct, no? Even if it is, rear door handles are still inop.
siLc
Tallinn, Estonia
C?ID=330192
I went to golfi_vend and we figured it out - when I first checked the function via MVB 22, I didn't see correctly which side sensors were responding to touch. It turned out I had mixed up the rear sensor connectors on the CCM. I switched the pins on the CCM and rear door handle sensors are now operational.
Solved!
