B7 RS4 rough idle nightmare - HELP PLEASE (reward offered!)
DPNW
Washington State, near Portland, OR
C?ID=345651
Hey, all! So...bought my dream car in November. :thumbs: A mugello blue 2007 RS4 with KW V3 coilovers, millitek downpipes and full exhaust, and only 75k on the ticker. I'd only waited 12 years...worth every moment of the wait, though!
By May, however, I was getting DTCs that pointed back to carbon buildup and intake manifold runner flaps sticking. :cry: Took it all down, did a carbon cleaning (via soda blasting) which was DIRELY needed, and installed JHM-refurbished injectors at the same time. Ran like poopy. :mad: Started researching and eventually replaced the knock sensors, camshaft position sensors, the actuator valve for the IMRFs, the PCV/oil separator, the evap canister purge valve, then finally plugs and coil packs to rule out ALL of the idled-so-rough-it-choked-and-died suspects (in my own defense, things did get progressively better, and this took several months to get all of these parts thrown at it...). I also kept telling myself that with almost 80k on it I am just buying time that I won't need to worry about any of that stuff again. Because, let's face it, with brake rotors that are $400ea up front, 9 quarts of oil capacity, and all of the other finicky stuff that makes this machine so great, some extra sensors didn't seem like a big deal. Except, well, they didn't completely fix the issues.
So, what was it doing. Right? Bet you're curious. Well, it normally idles around 850, but kept gagging down to 520 or so, bouncing up, choking down, and eventually would just sputter and die. (No, I didn't let that happen more than once between changing something). Finally got to where the throttle body adaptation was all it needed to at least keep running, but continued to throw more missfire codes, along with some other bizarre ones that may have had to do with trying to do a few adaptions that I didn't know the right procedure for (engine on or off, mostly).
Anyway, this morning, I decided to really document the issue so I can ask for help. Cleared the DTCs, then re-did the TBA and did the IMRF adaptations (which did not happen the first attempts...or the first 5 attempts...but finally they happened - is that normal?) and it actually holds a steady RPM around 850, but it still sounds rough and is throwing random missfire and specific missfire codes. It's been misfiring since I first got it all back together. I'm at my wits end. :banghead:
Help!?!? What am I missing!?!?
Here is the auto-scan from this morning, then I cleared the DTCs and re-did the TBA and tried the IMRF adaptations for - both banks - numerous times until I got an "ADP OK" for both, then drove a good while (30 miles or so) before the second scan I've posted below, although the MIL came back on within a mile of my house. Any ideas? THANK YOU FOR READING THIS FAR!! :) Beers on me AND a test drive if you can help me get through this - you just gotta come to me in the PNW (near Portland)! This is the most fun to drive car I've ever driven, let alone owned. And I've been very promiscuous in the car department...well, driving many of them, anyway...I've only owned 5 VWs, 1 Audi, 3 Fords, 1 Jeep, 2 Subarus, a Honda (carburated!) and a Chevy...that's kinda a lot, too... :eek:
Scan one - beginning of my time with the beast today (the DTCs being cleared is included, watch for the bold heading above the later scan further down)
Saturday,18,August,2018,12:02:27:39739
VCDS Version: 18.2.1.2 (x64)
VIN: WUARU78E57N904981   License Plate: ILOVEANDHATETHISCARALLATTHESAMETIME
Mileage: 126040km-78317mi   Repair Order: 081818a
          67 69 75 76 77
VIN: WUARU78E57N904981   Mileage: 126040km-78317miles
Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
   Part No SW: 8E1 910 560 A    HW: 8E1 907 560
   Component: 4.2L V8/4V FSI     ª0060
   Revision: 57H13---    Serial number: XXXXXXXXXXXXXX
   Coding: 01040009180F0160
   Shop #: WSC 06412 444 58801
   VCID: 2447042EE740C46463-8070
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Fault Status: 01101000
                    Mileage: 126044 km
                    Temperature: 14.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.430 V
Readiness: 0010 1101
   Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
   Component: ESP8 quattro    H06 0150
   Coding: 0004533
   Shop #: WSC 06335 000 00000
   VCID: 2B55EF128A9E0B1CA2-807E
                    Fault Status: 00101101
                    Reset counter: 37
                    Hex Value: 0x0000
                    Hex Value: 0x4022
                    Hex Value: 0x0025
                    Hex Value: 0x01A7
                    Hex Value: 0x0001
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Reset counter: 37
                    Hex Value: 0x0000
                    Hex Value: 0x6222
                    Hex Value: 0x0028
                    Hex Value: 0x01A4
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 6DD1210A270AC52CFC-5124
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 01031
   Shop #: WSC 65536
   VCID: 3D71D14A37EA95AC0C-4AEC
Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
               P0300 - 001 -  - MIL ON
                    Fault Status: 11100001
                    Mileage: 126023 km
                    RPM: 720 /min
                    Load: 37.2 %
                    Temperature: 57.0°C
                    Temperature: 41.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.208 V
000772 - Cylinder 4
               P0304 - 001 - Misfire Detected - MIL ON
                    Mileage: 126023 km
                    RPM: 720 /min
                    Load: 37.2 %
                    Temperature: 57.0°C
                    Temperature: 41.0°C
                    Voltage: 13.208 V
000771 - Cylinder 3
               P0303 - 001 - Misfire Detected - MIL ON
                    Mileage: 126023 km
                    RPM: 720 /min
                    Load: 37.2 %
                    Temperature: 57.0°C
                    Temperature: 41.0°C
                    Voltage: 13.208 V
000773 - Cylinder 5
               P0305 - 001 - Misfire Detected - MIL ON
                    Mileage: 126023 km
                    RPM: 776 /min
                    Load: 35.7 %
                    Temperature: 57.0°C
                    Temperature: 40.0°C
                    Voltage: 13.843 V
000775 - Cylinder 7
               P0307 - 001 - Misfire Detected - MIL ON
                    Mileage: 126023 km
                    RPM: 1378 /min
                    Load: 29.4 %
                    Temperature: 57.0°C
                    Temperature: 40.0°C
                    Voltage: 13.716 V
000774 - Cylinder 6
               P0306 - 001 - Misfire Detected
                    Fault Status: 01100001
                    Mileage: 126044 km
                    RPM: 848 /min
                    Load: 47.4 %
                    Temperature: 33.0°C
                    Temperature: 32.0°C
                    Voltage: 13.462 V
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0G0M08Z
   Coding: 0432607
   VCID: 3C77DC4E7FF09CA43B-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3HR5T
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB4043A0A8EWÿ†63
   Subsystem 5 - Serial number: A0A8EWÿ†6342DRB404210BACOÿ†63
   Subsystem 6 - Serial number: 10BACOÿ†6352ARB401D6AEA92ÿ†63
   Subsystem 7 - Serial number: 6AEA92ÿ†6362ARB4018C6C6C/ÿ†63
   Subsystem 8 - Serial number: C6C6C/ÿ†63729RB401D81B99Zÿ†63
   Subsystem 9 - Serial number: 81B99Zÿ†63829RB401D81BC0Uÿ
   Subsystem 10 - Serial number: 81BC0Uÿ
Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
   Part No: 8E0 953 549 T
   Component: Lenksáulenmodul     0301
   Coding: 04441
   Shop #: WSC 06335
   VCID: 4487A4AE5400E46443-4AEC
   Part No SW: 8E0 920 982 R    HW: 8E0 920 982 R
   Component: KOMBI+WFS 4     H14 0100
   Revision: 0100        Serial number: 00000000000000
   Coding: 0023208
   Shop #: WSC 00002 512 00000
   VCID: 3D71D14A67EA95AC0C-5124
   Coding: 0023208
   VCID: 3D71D14A67EA95AC0C-5142
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71E93D7A3B3221CCD8-4B06
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4135
   Coding: 11880
   Shop #: WSC 06335
   VCID: 78FF005E584870841F-4AEC
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
00955 - Key 1
            35-00 -  -
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: 2959151A8062190C50-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H04 0020
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH03 0020
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0062523
   Shop #: WSC 02197 785 00200
   VCID: 2A5BEA168664121459-5124
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802030631
   Coding: 0000304
   VCID: 3169FD7AABB261CC98-5124
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005014280
   Coding: 0011877
End-------------------------(Elapsed Time: 05:56)--------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 11: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 25: DTCs cleared
Address 36: DTCs cleared
Address 46: DTCs cleared
Address 55: DTCs cleared
Address 65: DTCs cleared
Address 76: DTCs cleared
Address 77: DTCs cleared
          67 69 75 76 77
               P1923 - 008 -
                    Mileage: 126044 km
                    Temperature: 15.0°C
                    Temperature: 24.0°C
                    Voltage: 11.811 V
Readiness: 0110 1101
   Coding: 0004533
   Coding: 00000
   Coding: 01031
   Shop #: WSC 65536
   Coding: 0432607
   Coding: 04441
   Shop #: WSC 06335
   Coding: 0023208
   Coding: 0023208
   Coding: 00002
   VCID: 71E93D7A3B3221CCD8-4AEC
   Coding: 11880
   Shop #: WSC 06335
No Faults Found
   Coding: 0000019
   Coding: 0062523
   VCID: 2A5BEA168664121459-5142
   Coding: 0000304
   Coding: 0011877
End-------------------------(Elapsed Time: 06:14)-------------------------
SCAN FROM THE END OF TODAY (after clearing the DTCs, re-adapting as described above, and driving around 30 miles)
Saturday,18,August,2018,20:26:58:39739
VIN: WUARU78E57N904981   License Plate: IJUSTWANTITTOWORKRIGHTAGAINAAARRGHH
Mileage: 126090km-78348mi   Repair Order: 81818eod
          67 69 75 76 77
VIN: WUARU78E57N904981   Mileage: 126090km-78348miles
               P1923 - 008 -
                    Mileage: 126096 km
                    Temperature: 80.0°C
                    Temperature: 73.0°C
                    Voltage: 11.557 V
   Coding: 0004533
   Coding: 00000
   Coding: 01031
   Shop #: WSC 65536
            30-00 - Open or Short to Plus
8 Faults Found:
                    Mileage: 126044 km
                    RPM: 1336 /min
                    Load: 41.2 %
                    Temperature: 15.0°C
                    Temperature: 22.0°C
                    Voltage: 13.081 V
000772 - Cylinder 4
                    Mileage: 126044 km
                    RPM: 1336 /min
                    Load: 41.2 %
                    Temperature: 15.0°C
                    Temperature: 22.0°C
                    Voltage: 13.081 V
000771 - Cylinder 3
                    Mileage: 126044 km
                    RPM: 1336 /min
                    Load: 41.2 %
                    Temperature: 15.0°C
                    Temperature: 22.0°C
                    Voltage: 13.081 V
000773 - Cylinder 5
                    Mileage: 126044 km
                    RPM: 1357 /min
                    Load: 45.1 %
                    Temperature: 15.0°C
                    Temperature: 21.0°C
                    Voltage: 13.335 V
000775 - Cylinder 7
                    Mileage: 126044 km
                    RPM: 1133 /min
                    Load: 36.8 %
                    Temperature: 33.0°C
                    Temperature: 25.0°C
                    Voltage: 13.970 V
000769 - Cylinder 1
               P0301 - 001 - Misfire Detected - MIL ON
                    Mileage: 126044 km
                    RPM: 736 /min
                    Load: 54.5 %
                    Speed: 2.0 km/h
                    Temperature: 35.0°C
                    Temperature: 33.0°C
                    Voltage: 12.700 V
000774 - Cylinder 6
               P0306 - 001 - Misfire Detected - MIL ON
                    Mileage: 126044 km
                    RPM: 779 /min
                    Load: 53.7 %
                    Speed: 2.0 km/h
                    Temperature: 36.0°C
                    Temperature: 33.0°C
                    Voltage: 13.208 V
000776 - Cylinder 8
               P0308 - 001 - Misfire Detected
                    Mileage: 126088 km
                    RPM: 869 /min
                    Load: 26.7 %
                    Temperature: 99.0°C
                    Temperature: 73.0°C
                    Voltage: 12.573 V
   Coding: 0432607
   Coding: 04441
   Shop #: WSC 06335
   Coding: 0023208
   Coding: 0023208
   Coding: 00002
   Coding: 11880
   Shop #: WSC 06335
00955 - Key 1
            35-10 -  -  - Intermittent
   Coding: 0000019
   Coding: 0062523
   Coding: 0000304
   VCID: 3169FD7AABB261CC98-5142
   Coding: 0011877
_Val
Latvia
C?ID=356659
What are your MAF reading (002) and Fuel trim at idle (032, 033)?
South Molton, UK
Couple of thoughts from a long-term former B7 RS4 owner (owned one from new for 10 years until 2016):
1) The B7 RS4 has a complex vacuum system operating both intake flaps and airbox power flap, leaks in that can cause all sorts of running/power problems. Have you checked ALL the many pipes in that system?
2) Have you done a compression check on all cylinders?
DPNW
C?ID=345651
Idle Log File
All - thanks for the interest and help!!!! I couldn't work out a good way to post a spreadsheet on here without it being even more overwhelming than the auto-scans I already posted. So....here's a dropbox folder with the log files. I cleaned up the one from this morning (the idle is definitely worse when it's cold) - I logged start through a good bit of idling after warmup was complete, but had to switch controllers to grab lambda and flap info for bank 2, so note that the data is not aligned horizontally in terms of being at the same precise point in time (I bolded the start time at the top as a flag). Side note, it's annoying that controller 31 (which SHOULD grab from both ECUs) won't show bank 2 data on lamdas and some other stuff. SO inconvenient...just kidding. Wouldn't be able to do anything with VCDS, so I'm NOT complaining!!
I also included some other data points that seemed potentially relevant (might as well log 12 at a time, right?). I also included in the folder a few raw logs from yesterday that include some revs and other information.
I can't see an obvious issue, but I'm also at the :banghead::cry: stage, which may be clouding my judgement.
https://www.dropbox.com/sh/hv6buc4oaclp2e9/AADatvMar7re9TPOzjPVQPeGa?dl=0
DPNW
C?ID=345651
Dave,
Thanks for looking this over! Sounds like you got to see a whole spread of behaviors from these machines. I wish I could have bought one new...just wasn't possible at the time, but I obviously never lost the dream!
I've checked everything I can think of on the vacuum system, including visually, with smoke (not pressurizing the system, using a "smoke pen" around all the vacuum lines I can - the only thing that "sucks" is the open port at the top of the neck of the IM. Early on I thought maybe I had reassembled things wrong, but, despite not having ever found a picture or gotten confirmation, everything I found indicated that port is meant to be open. Do you know what I'm talking about? This guy right here...is this my problem? I couldn't find a hose that had the right shape to put back here without leaving something far more logically needed open.
Beyond the open port, regarding vacuum, I tried replacing the check valve directly under the intake manifold and putting a hand vacuum pump in place of the "vacuum supply" line and the system held vacuum under all conditions.
I have not done a compression check. Do you think that's something I should do? I am going to need some self education and probably a tool or two as I haven't done that before.
My name's David, too!
Thanks again!
_Val
Latvia
C?ID=356659
Long term fuel trim adaptation (partial) is rocket high.
Short term isn't changing at all (stays steady at 0) - lambda control haven't turned on yet (099. group or needs even longer log file) or something is really off spec.
Mine simos3 do that somewhere in 30-40sec after cold start.
Engine load is 30-40-50% at idle (autoscan freeze frames). That's just consequences because of misfires?
I would ask someone how to really test maf signal at idle, except pedal to metal test in 3rd or 4th gear while logging (http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info)
South Molton, UK
There should not be ANY open ports around the IM, there's definitely something missing there.
I think you need to step through this logically, following JPPSG would be a good start.
BTW see how JPPSG is bold green? That's a feature on here which if you hover over it will give more information.
DPNW
C?ID=345651
Thanks, Dave (and _Val!). Sounds like my issue may be simpler than I’ve made it. However, I have scoured every manual and the internet only to come up empty for what goes there. I also posted on the two big Audi forums asking if another owner can possibly post a picture of the top of their IM or help me, but nobody responded (it’s been several week). I’ve tried plugging it and the idle smooths out momentarily, but obviously it’s meant to have air moving through it as it goes rough again. As I said, I don’t see a hose that could possibly fit or anything disconnected. I will get out my inspection camera and search down along the firewall (and everywhere else). Any suggestions on where I can find the answer to what is supposed to go there? Maybe I can find one for sale near me and go check it out? Unfortunately I’m now traveling for work and won’t be able to look at the car until Friday, but I’ll let you know if I find any open hoses hiding in the engine bay.
If I do indeed have something disconnected, I suspect resolving that will go a long way toward getting the fuel trim and other issues resolved, so I assume focusing on the physical disconnection should be my primary focus for now. Let me know if anyone feels otherwise.
Thank you!! And thanks for the tip on hovering over the green - good to know. And thanks to Ewe for the code tags in my initial post. Obviously am learning my way around forums.
If it's open, why not start by closing it off or plugging somehow just to see what happens? Install a short piece of tubing that fits and clamp it shut?
DPNW
C?ID=345651
Dang auto correct. Sorry, ‘Uwe’! Bad-A pet sheep, though!
I did try plugging it and it smoothed the idle out momentarily, but then ran poorly when I brought the rpms up and continued to be rough when I dropped back to idle. I haven’t tried it since I did the TBA and IMRF adaptations but will do that also on Friday.
Just theoretically, what would get piped in after the throttle body - EGR? As I recall it (not looking at it right now), there are two ports before the throttle body and two after (one is on the bottom, the other on the firewall side). One of each of them is inlet/outlet of the suction pump (a Venturi valve that draws in from...I forget where).
_Val
Latvia
C?ID=356659
Are you able to set Readiness for EVAP and SAI? Are they actually working?
btw, what is IMRF? Intake Manifold Runner Flaps ... Google didn't help.
DPNW
C?ID=345651
Hey, all. Well, I've been all over N America and am finally back home and able to tinker some more. Yes, I meant Intake Manifold Runner Flaps (although incredibly, massively, really fast would be more fun to talk about).
I just finished educating myself on setting readiness and will do that in the morning when it's sexy roar won't wake the neighborhood. Planning to follow the procedure here http://http://www.ross-tech.com/vcds/tour/readiness.php but let me know if you think the road-test process is necessary instead or in addition (detailed in post #5 here): http://https://www.audizine.com/forum/showthread.php/479620-Help-running-quot-Set-Readiness-quot-on-Ross-Tech-VCDS
Also, Dave, looking at several other diagrams of the engine bay in the audi service manual, all of them show that same port open on the IM. Maybe it's a North American thing? It has me very perplexed, either way.
Any chance this could be a Lambda Probe issue, without any codes in that regard? Misfire codes seem to be my primary issue (both specific and multiple random missfire). Maybe the pre-cat probe on one bank is bad or something? Laying awake at night thinking about this I came up with a theory that maybe an issue with one of those probes would be causing the crazy high adaptation and the other issues. However, it seems the car only runs roughly at idle (I did a road test - wanted to get the thing rolling at least a little), which I'm not knowledgeable enough to know whether that impacts the likelihood of my Lambda probe theory. Thoughts?
DPNW
C?ID=345651
Realizing I still have a lot to learn about using the VCDS properly to set readiness for the systems to identify what actually can be readied through the proper procedures vs that which is actually having issues. I'll post again when I have completed that education plus the JPPSG process. Realizing that in some ways I've been a complete idiot about this and I'd like to remedy that before posting any more. Thanks!
colin c
Southampton UK
C?ID=308923
Does the vacuum operated sports exhaust flaps work? If there's an air leak in the system they are normally the first thing that stop working.
As well as a cylinder compression check a cylinder leakage check is more informative, I have come across an S6 with the V10 engine so badly coked up that the inlet valves were not closing fully causing a missfire at idle. I know you said you have decoked the intake did you do the inlet valves as well?
DPNW
C?ID=345651
Thanks, Colin! The vehicle has an aftermarket Millitek exhaust that deleted the flaps, so I can't go off of that. However, I have tested the vacuum system and it held consistent vacuum pressure, so I have come to the conclusion that the vacuum system is connected properly. How I did this was to unplug the vacuum system draw port (on the bottom of the intake manifold), which is where the check valve is, and instead connected a hand vacuum pump with a gauge. When I applied vacuum to that line (which I believe is testing the entire vacuum system since this is the primary vacuum supply line), it held vacuum pressure firmly and indefinitely. Is there another way to test this?
The primary reason I did the carbon clean at all was the intake valves. Sorry, I didn't expound on that earlier. I took off the intake manifold to deal with the runner flaps sticking (wasn't sure if I needed new position sensors or actuators or what), but when I saw the intake valves I realized I was in for a lot more work. Both the runner flaps and the intake valves were really gunked up - I soda blasted (with everything masked off and using a vacuum setup to minimize excess dust) the intake valves when the valves were closed (to minimize dust getting into the cylinder), then carefully vacuumed out the cylinders before scrubbing the gunk from around the edge of the valve using solvent and verifying that each valve had a tight seal. I then also cleaned the intake manifold, including removing each of the flaps to be able to clean the shaft and flaps completely. I then lubricated the runner flap shafts until they were moving freely before reassembling. Of course, once I had it all re-assembled the first time I realized that the vacuum line that runs out from under the intake manifold and the throttle body valve had gotten unplugged while I was reassembling, so had to disassemble everything one more time to reconnect that. :banghead:
I'm wondering if the solvent phase of my valve cleaning resulted in some gunk getting burned off and clogging the lambda valves (which are of unknown age). So, in addition to continuing my vag-com self study, I'm going to remove those and clean them with gasoline.
OP Verified. Moving to Car Repair Support.
NostraJackAss
I need no reward....
Tear back down and install new factory injectors, with all new gaskets, provided you qualify a compression check.
You don't install used rebuilt injectors in an RS4!
Please post a fresh auto-scan and anither scan immediately after clearing fault memory, in addition please post the OBD2 Mode 9 data.
Is car modified?
Prepare to qualify the JPPSG!
NostraJackAss
DPNW
C?ID=345651
REWARD: Beers anytime in the PNW. Seemed like a good idea when I started the thread...would love to delete that from the heading now. But the offer stands if any of you do find yourself out this way (specifically the Portland, OR area).
Jack - thanks for wading in. I've spent a lot of hours reading any post related to my issue, including learning about CAN and the JPPSG. I'll post my JPPSG below in another post, but I mention this as I very much appreciate that you give your input so freely and want you to know that I absolutely do not want to waste your time (or anyone else's) with my ignorance. However, I'm reaching the limits of what I believe I can figure out using youtube, google, and the forum...so be prepared for me to still ask some dumb questions, but I've truly invested in avoiding that. That said, NostraJackAss away...
You are absolutely right that EVAP has been an issue for a while, but foolishly was focused on the missfires and blindly replacing potential problem parts first. Yes, I've learned my lesson, and yes, I will post shortly parts and sources, along with an auto-scan from before I did the carbon clean and set off this nightmare.
My most recent effort has been multiple attempts to set readiness using both VCDS-initiated and drive readiness setting procedures. The "end of line check" will not initiate, despite the vehicle running and then pushing brake and gas immediately after enabling basic settings. The ECU does take over the throttle control, but the test does not begin and count down (held the petals for over a minute and no change). So, I've done two clear-DTCs and road test procedures to set readiness and have reached the same results each time: O2 sensors, SAI, EVAP and Catalytic Converters will not set readiness. Running individual sequences, the EVAP, Bank 2 SAI, and Bank 2 Intake manifold runner flaps will not test via basic settings (engine on, brake and gas for the first two, engine off for the IMRFs - right procedure?). Bank 1 SAI and Bank 1 IMRF sequences will run under basic settings. Does this tell anything about where the vacuum leak may be?
I picked up the tools to do a compression test and will do that ASAP (probably tomorrow as I am away from the vehicle for the evening, but did bring my laptop to be able to post the latest scan and feedback on the readiness attempts of the last two days. I will round up the materials for the modified oil cap for the measuring of crankcase vacuum in the meantime. Not familiar with isolated crimp test procedure. Have you written that up somewhere or are you aware of where I can educate myself on that?
The seller I purchased from was the second owner, and he did not tell me all of the mods the vehicle had - only that it had a millitek full exhaust including downpipes and KW V3 adjustable coilovers. Those were installed by the original owner. The seller did say he had a carbon clean done and had hooked the front bumper on a parking stop and tore the bumper off, but that was it. Oh yeah, and he got a MAACO paint job that looks like shit on the whole front clip and is rock chipped to hell, and the ambient temp sensor was faulty, so I don't assume that anything damaged was properly addressed. Back to modifications: I've since discovered JHM intake manifold spacers and billet aluminum actuator linkages for the intake manifold runner flaps. The airbox, ECU, etc are unmodified, to the best of my knowledge.
Through the course of my disassembly and carbon clean I installed/replaced the following: injectors and seals as previously mentioned, new IM gaskets (obvious, but done none the less), new oil separator/PCV valve (as assumed the old one was allowing a lot through the system based on the extreme carbon buildup in only about 25k - seller said he had it professionally carbon cleaned at around 50k), new IMRF position sensors (potentiometers) and new IMRF control valve (as stated earlier, my issue was with the runner flaps, so I wanted to cover my bases while I had it all accessible).
I previously had replaced the plugs and coil packs with aftermarket but OEM similar products (bosch plugs and I forget which packs off the top of my head).
After initial re-assembly post-carbon clean, the vehicle idled absolutely terribly (it was actually choking and dying at times), despite the vacuum test I mentioned previously. So I began to read up on potential causes - assuming, probably wrongly, that I had another part that failed through the course of the work I had done or because I had disturbed its slumber. I don't think I yet grasped just how much was involved in the machine's controllers and how much I could actually dig in with the VCDS that the prior owner had included with the car. For that reason, I installed a new vacuum check valve off (bottom of intake manifold) (OEM), new knock sensors ("OEM supplier" but not in VAG box), new OEM camshaft position sensors and new EVAP purge valve (OEM) - as these were all potential issue for misfires and didn't want to pull the IM yet again later, or the replacement was ruling things out for others. Then I replaced the coil packs and plugs - again - this time with OEM for both. After all of these changes, things got A LOT better. Somewhere during this the battery died, so when I got it back to life I finally discovered the various initial adaptations (such as the throttle valve) that should be done after a disconnect from power like that. With that done, it ran the best yet, but still "hunts" for a healthy idle when cold (and sounds abnormally "chuggy"), but only sounds a little off after it's warmed up.
Now I am seeing voltage drop DTCs on top of everything else. I first assumed the battery was bad, had it tested at Autozone, and they said it was good. I monitored the central electrical controller block 1 and it didn't drop below 13.3V under heavy load. Once the vehicle was off, that dropped to within a few thousandths of 12V, but I'm not sure if that indicates anything.
RE: the injectors. That's a pricey prescription you've written. Not arguing, just want to clarify. These were cleaned and re-flowed by JPM and were installed with new seals. You still think the chances are good enough that they are my issue to justify the cost and effort to replace these refurbished ones with new? If it must be done, so be it...just want to confirm prior to spending the $1-2k and a full day on it. Where do you recommend I source them from to try to keep the cost down? I've obviously now put quite a bit into this (admittedly, some of it foolishly)...
Here is a scan from April, before I was even having the original IMRF issues (although this did lead to a new OEM ambient temp sensor):
Sunday,08,April,2018,19:56:50:39739
VCDS Version: 18.2.0.3 (x64)
VIN: WUARU78E57N904981   License Plate: 575F WSU
Mileage: 123060km-76465mi   Repair Order: 030818
          67 69 75 76 77
VIN: WUARU78E57N904981   Mileage: 123060km-76465miles
   VCID: 2447042EE740C4645C-8070
001057 - Warm Up Catalyst; Bank 1
               P0421 - 002 - Efficiency Below Threshold - Intermittent
                    Mileage: 122569 km
                    RPM: 2131 /min
                    Load: 21.6 %
                    Speed: 42.0 km/h
                    Temperature: 94.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
012424 - Starter Relay
               P3088 - 001 - Electrical Malfunction - Intermittent
                    Fault Status: 00100001
                    Mileage: 122656 km
                    Temperature: 9.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 10.668 V
   Coding: 0004533
   VCID: 2B55EF128A9E0B1C9D-807E
   Coding: 00000
   VCID: 6DD1210A270AC52CC3-5124
   Coding: 01031
   Shop #: WSC 65536
   VCID: 3D71D14A37EA95AC33-4AEC
   Coding: 0432607
   VCID: 3C77DC4E7FF09CA404-8068
   Coding: 04441
   Shop #: WSC 06335
   VCID: 4487A4AE5400E4647C-4AEC
   Coding: 0023208
   VCID: 3D71D14A67EA95AC33-5142
   Coding: 0023208
   Coding: 00002
   VCID: 71E93D7A3B3221CCE7-4B06
   Coding: 11880
   Shop #: WSC 06335
   VCID: 78FF005E5848708420-4AEC
00962 - Alarm via. Tilt Sensor
            35-00 -  -
   Coding: 0000019
   VCID: 2959151A8062190C6F-807C
                    Reset counter: 0
   Coding: 0062523
   VCID: 2A5BEA168664121466-5124
   Coding: 0000304
   VCID: 3169FD7AABB261CCA7-5142
   Coding: 0011877
End-------------------------(Elapsed Time: 05:57)--------------------------
Here is when I had the runner flap issue that led me to the carbon clean (I disassembled to access the IMRFs on the intake manifold, but the intake valves were so gummed up that I couldn't avoid doing a complete carbon clean).
Monday,23,April,2018,20:54:53:39739
VIN: WUARU78E57N904981   License Plate: 575FWSU
Mileage: 124530km-77379mi   Repair Order: 042318
          67 69 75 76 77
VIN: WUARU78E57N904981   Mileage: 124530km-77379miles
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 008 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10101000
                    Mileage: 124221 km
                    RPM: 3397 /min
                    Load: 18.0 %
                    Speed: 28.0 km/h
                    Temperature: 79.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.589 V
               P1923 - 008 -
                    Mileage: 124531 km
                    Temperature: 30.0°C
                    Temperature: 21.0°C
                    Voltage: 11.430 V
   Coding: 0004533
   Coding: 00000
   Coding: 01031
   Shop #: WSC 65536
   VCID: 3D71D14A37EA95AC33-4B06
008224 - Intake Manifold Flap Position Sensor (Bank 2)
               P2020 - 008 - Implausible Signal - Intermittent - MIL ON
                    Fault Frequency: 9
                    Mileage: 124098 km
                    RPM: 1098 /min
                    Load: 18.8 %
                    Speed: 122.0 km/h
                    Temperature: 96.0°C
                    Temperature: 44.0°C
                    Voltage: 13.335 V
   Coding: 0432607
   Coding: 04441
   Shop #: WSC 06335
   Coding: 0023208
   Coding: 0023208
   Coding: 00002
   Coding: 11880
   Shop #: WSC 06335
   VCID: 78FF005E5848708420-4B06
            35-00 -  -
   Coding: 0000019
   Coding: 0062523
   Coding: 0000304
   VCID: 3169FD7AABB261CCA7-5124
   Coding: 0011877
   VCID: 3D71D14A67EA95AC33-5124
End-------------------------(Elapsed Time: 05:59)--------------------------
Here was post completion of the carbon clean (after getting all of these I cleared the DTCs again and only some returned, but I assume this has the most useful info for you)
Sunday,03,June,2018,17:40:17:39739
Mileage: 125990km-78286mi   Repair Order: 06032018
          67 69 75 76 77
VIN: WUARU78E57N904981   Mileage: 125990km-78286miles
9 Faults Found:
                    Fault Frequency: 17
                    Mileage: 124864 km
                    RPM: 3833 /min
                    Load: 50.2 %
                    Speed: 100.0 km/h
                    Temperature: 33.0°C
                    Temperature: 12.0°C
                    Voltage: 13.462 V
012425 - Signal Line for Fuel Pump Electronics
               P3089 - 002 - Electrical Malfunction - Intermittent
                    Mileage: 125993 km
                    RPM: 773 /min
                    Load: 27.8 %
                    Temperature: 40.0°C
                    Temperature: 23.0°C
                    Voltage: 13.970 V
000290 - Throttle Position Sensor (G69)
               P0122 - 002 - Signal too Low - Intermittent
                    Mileage: 125993 km
                    Temperature: 17.0°C
                    Temperature: -40.0°C
                    Voltage: 11.557 V
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 002 - Signal Too Low - Intermittent
                    Mileage: 125993 km
                    Temperature: 17.0°C
                    Voltage: 11.557 V
008212 - Intake Manifold Flap Position Sensor (Bank 1)
               P2014 - 002 - Electrical Malfunction - Intermittent
                    Mileage: 125993 km
                    Temperature: 17.0°C
                    Voltage: 11.557 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High - Intermittent
                    Mileage: 125993 km
                    Temperature: 17.0°C
                    Voltage: 11.557 V
009529 - Low Pressure Fuel Sensor (G410)
               P2539 - 001 - Open Circuit - Intermittent
                    Mileage: 125993 km
                    Temperature: 18.0°C
                    Voltage: 11.557 V
005416 - Camshaft Timing Adj. Bank1 (N205)
               P1528 - 004 - Open Circuit
                    Mileage: 125993 km
                    RPM: 164 /min
                    Load: 94.1 %
                    Temperature: 18.0°C
                    Temperature: 21.0°C
                    Voltage: 9.652 V
               P1923 - 008 -
                    Mileage: 125993 km
                    Temperature: 36.0°C
                    Temperature: 27.0°C
                    Voltage: 11.430 V
   Coding: 0004533
18265 - Load Signal
                    Hex Value: 0x00C0
                    Hex Value: 0x6202
                    Hex Value: 0x0028
                    Hex Value: 0x018E
                    Hex Value: 0x0001
                    Hex Value: 0x00C0
                    Hex Value: 0x6202
                    Hex Value: 0x0025
                    Hex Value: 0x018E
                    Hex Value: 0x0001
   Coding: 00000
   Coding: 01031
   Shop #: WSC 65536
   VCID: 3D71D14A37EA95AC0C-4B06
                    Fault Frequency: 18
                    Mileage: 124752 km
                    RPM: 3754 /min
                    Load: 46.6 %
                    Speed: 73.0 km/h
                    Temperature: 38.0°C
                    Temperature: 14.0°C
                    Voltage: 13.716 V
008217 - Intake Manifold Flap Position Sensor (Bank 2)
               P2019 - 002 - Electrical Malfunction - Intermittent
                    Mileage: 125993 km
                    Temperature: 17.0°C
                    Voltage: 11.557 V
               P0300 - 001 -
                    Mileage: 125993 km
                    RPM: 2424 /min
                    Load: 23.1 %
                    Temperature: 19.0°C
                    Temperature: 21.0°C
                    Voltage: 13.462 V
000776 - Cylinder 8
                    Mileage: 125993 km
                    RPM: 2424 /min
                    Load: 23.1 %
                    Temperature: 19.0°C
                    Temperature: 21.0°C
                    Voltage: 13.462 V
000769 - Cylinder 1
                    Mileage: 125993 km
                    RPM: 2659 /min
                    Load: 23.1 %
                    Temperature: 20.0°C
                    Temperature: 21.0°C
                    Voltage: 13.589 V
   Coding: 0432607
                    Reset counter: 39
   Coding: 04441
   Shop #: WSC 06335
   VCID: 4487A4AE5400E46443-4B06
   Coding: 0023208
   Coding: 0023208
   Coding: 00002
   Coding: 11880
   Shop #: WSC 06335
   Coding: 0000019
   Coding: 0062523
   Coding: 0000304
   Coding: 0011877
Cleared DTCs, then got this:
Monday,04,June,2018,09:22:20:39739
Mileage: 125990km-78286mi   Repair Order: 06032018b
          67 69 75 76 77
                    Mileage: 125993 km
                    RPM: 1622 /min
                    Load: 37.2 %
                    Temperature: 35.0°C
                    Temperature: 30.0°C
                    Voltage: 10.033 V
008198 - Intake Manifold Flap; Bank 1
               P2006 - 008 - Stuck Closed - Intermittent
                    Mileage: 125993 km
                    RPM: 819 /min
                    Load: 38.4 %
                    Temperature: 35.0°C
                    Temperature: 25.0°C
                    Voltage: 13.335 V
                    Mileage: 125993 km
                    RPM: 729 /min
                    Load: 42.3 %
                    Temperature: 35.0°C
                    Temperature: 25.0°C
                    Voltage: 13.462 V
               P1923 - 008 -
                    Mileage: 125993 km
                    Temperature: 37.0°C
                    Temperature: 27.0°C
                    Voltage: 12.192 V
   Coding: 0004533
18265 - Load Signal
                    Hex Value: 0x00C0
                    Hex Value: 0x6202
                    Hex Value: 0x0028
                    Hex Value: 0x018E
                    Hex Value: 0x0001
                    Hex Value: 0x00C0
                    Hex Value: 0x6202
                    Hex Value: 0x0025
                    Hex Value: 0x018E
                    Hex Value: 0x0001
   Coding: 00000
   Coding: 01031
   Shop #: WSC 65536
8 Faults Found:
                    Fault Frequency: 18
                    Mileage: 124752 km
                    RPM: 3754 /min
                    Load: 46.6 %
                    Speed: 73.0 km/h
                    Temperature: 38.0°C
                    Temperature: 14.0°C
                    Voltage: 13.716 V
                    Mileage: 125993 km
                    Temperature: 17.0°C
                    Voltage: 11.557 V
                    Mileage: 125993 km
                    RPM: 2424 /min
                    Load: 23.1 %
                    Temperature: 19.0°C
                    Temperature: 21.0°C
                    Voltage: 13.462 V
000776 - Cylinder 8
                    Mileage: 125993 km
                    RPM: 2424 /min
                    Load: 23.1 %
                    Temperature: 19.0°C
                    Temperature: 21.0°C
                    Voltage: 13.462 V
000769 - Cylinder 1
                    Mileage: 125993 km
                    RPM: 2659 /min
                    Load: 23.1 %
                    Temperature: 20.0°C
                    Temperature: 21.0°C
                    Voltage: 13.589 V
000770 - Cylinder 2
               P0302 - 001 - Misfire Detected
                    Mileage: 125993 km
                    RPM: 1137 /min
                    Load: 49.0 %
                    Temperature: 35.0°C
                    Temperature: 26.0°C
                    Voltage: 12.827 V
008199 - Intake Manifold Flap; Bank 2
               P2007 - 008 - Stuck Closed - Intermittent
                    Mileage: 125993 km
                    RPM: 814 /min
                    Load: 38.8 %
                    Temperature: 35.0°C
                    Temperature: 25.0°C
                    Voltage: 13.335 V
000772 - Cylinder 4
                    Mileage: 125993 km
                    RPM: 692 /min
                    Load: 42.3 %
                    Temperature: 36.0°C
                    Temperature: 25.0°C
                    Voltage: 13.335 V
   Coding: 0432607
                    Reset counter: 39
   Coding: 04441
   Shop #: WSC 06335
   Coding: 0023208
   Coding: 0023208
   Coding: 00002
   Coding: 11880
   Shop #: WSC 06335
   Coding: 0000019
   Coding: 0062523
   Coding: 0000304
I then realized that the vacuum line running toward the firewall from under the IM had been unplugged. Fixed that. Reassembled. Got this:
Wednesday,13,June,2018,18:10:40:39739
Mileage: 125990km-78286mi   Repair Order: 06132018b
          67 69 75 76 77
               P1923 - 008 -
                    Mileage: 125992 km
                    Temperature: 17.0°C
                    Temperature: 26.0°C
                    Voltage: 11.557 V
   Coding: 0004533
            000 -  -
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x0024
                    Hex Value: 0x019C
                    Hex Value: 0x0001
   Coding: 00000
   Coding: 01031
   Shop #: WSC 65536
                    Mileage: 125993 km
                    RPM: 1292 /min
                    Load: 45.1 %
                    Temperature: 18.0°C
                    Temperature: 15.0°C
                    Voltage: 13.335 V
000769 - Cylinder 1
                    Mileage: 125993 km
                    RPM: 1292 /min
                    Load: 45.1 %
                    Temperature: 18.0°C
                    Temperature: 15.0°C
                    Voltage: 13.335 V
000776 - Cylinder 8
               P0308 - 001 - Misfire Detected - MIL ON
                    Mileage: 125993 km
                    RPM: 702 /min
                    Load: 46.6 %
                    Temperature: 24.0°C
                    Temperature: 15.0°C
                    Voltage: 12.954 V
000775 - Cylinder 7
                    Mileage: 125993 km
                    RPM: 702 /min
                    Load: 46.6 %
                    Temperature: 24.0°C
                    Temperature: 15.0°C
                    Voltage: 12.954 V
000770 - Cylinder 2
               P0302 - 001 - Misfire Detected - MIL ON
                    Mileage: 125993 km
                    RPM: 1370 /min
                    Load: 38.0 %
                    Temperature: 17.0°C
                    Temperature: 25.0°C
                    Voltage: 13.081 V
000771 - Cylinder 3
                    Mileage: 125992 km
                    RPM: 1231 /min
                    Load: 40.4 %
                    Temperature: 12.0°C
                    Temperature: 15.0°C
                    Voltage: 13.208 V
   Coding: 0432607
   Coding: 04441
   Shop #: WSC 06335
   Coding: 0023208
   Coding: 0023208
   Coding: 00002
   Coding: 11880
   Shop #: WSC 06335
   Coding: 0000019
   Coding: 0062523
   Coding: 0000304
   Coding: 0011877
End-------------------------(Elapsed Time: 05:55)--------------------------
Anyway, I have more historic logs, but here is the most recent auto-scan:
Sunday,30,September,2018,10:20:52:39739
Mileage: 126180km-78404mi   Repair Order: 093018
          67 69 75 76 77
VIN: WUARU78E57N904981   Mileage: 126180km-78404miles
               P1923 - 008 -
                    Mileage: 126187 km
                    Temperature: 97.0°C
                    Temperature: 36.0°C
                    Voltage: 12.192 V
   Coding: 0004533
   Coding: 00000
   Coding: 01031
   Shop #: WSC 65536
9 Faults Found:
                    Mileage: 126129 km
                    RPM: 1328 /min
                    Load: 43.5 %
                    Temperature: 15.0°C
                    Temperature: 19.0°C
                    Voltage: 13.462 V
000771 - Cylinder 3
                    Mileage: 126129 km
                    RPM: 1328 /min
                    Load: 43.5 %
                    Temperature: 15.0°C
                    Temperature: 19.0°C
                    Voltage: 13.462 V
000772 - Cylinder 4
                    Mileage: 126129 km
                    RPM: 1358 /min
                    Load: 44.7 %
                    Temperature: 15.0°C
                    Temperature: 18.0°C
                    Voltage: 13.462 V
000773 - Cylinder 5
                    Mileage: 126129 km
                    RPM: 1392 /min
                    Load: 44.7 %
                    Temperature: 15.0°C
                    Temperature: 18.0°C
                    Voltage: 13.335 V
000770 - Cylinder 2
                    Mileage: 126145 km
                    RPM: 765 /min
                    Load: 18.4 %
                    Temperature: 97.0°C
                    Temperature: 33.0°C
                    Voltage: 13.589 V
000769 - Cylinder 1
                    Mileage: 126145 km
                    RPM: 814 /min
                    Load: 19.2 %
                    Temperature: 97.0°C
                    Temperature: 36.0°C
                    Voltage: 13.462 V
001281 - Vehicle Speed Sensor
               P0501 - 002 - Implausible Signal - Intermittent
                    Mileage: 126145 km
                    RPM: 2366 /min
                    Load: 18.8 %
                    Temperature: 97.0°C
                    Temperature: 43.0°C
                    Voltage: 13.462 V
000775 - Cylinder 7
                    Mileage: 126145 km
                    RPM: 782 /min
                    Load: 25.1 %
                    Temperature: 96.0°C
                    Temperature: 45.0°C
                    Voltage: 13.716 V
                    Mileage: 126180 km
                    RPM: 1018 /min
                    Load: 23.9 %
                    Temperature: 96.0°C
                    Temperature: 42.0°C
                    Voltage: 11.684 V
   Coding: 0432607
                    Reset counter: 39
   Coding: 04441
   Shop #: WSC 06335
   Coding: 0023208
   Coding: 0023208
   Coding: 00002
   Coding: 11880
   Shop #: WSC 06335
00955 - Key 1
   Coding: 0000019
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 33
02233 - Left Headlight Power Output Stage (J667)
                    Reset counter: 33
   Coding: 0062523
   Coding: 0000304
   Coding: 0011877
End-------------------------(Elapsed Time: 05:54)--------------------------
Complete JPPSG to be delivered very soon. The only thing I haven't been able to do is ensure the controllers are up to date. However, at the rate things are going, a trip to the dealer is eminent... Thanks!
