- Jan 6, 2015
- 686
- 404
- Bosnia and Herzegovina
- C?ID=156900
post latest scan and admap to check again, also did you change anything in right side wiring?
Monday,10,September,2018,18:02:46:62614
VCDS Version: 18.2.1.2 (x64)
Dealer/Shop Name: AUTOSOUND BLACKPOOL
Workshop Code: 123 05026 012345
VIN: WVWZZZAUZEW003961 License Plate: N/A
Mileage: 108473km-67401mi Repair Order: MK7 golf sept 10
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 55 5F
VIN: WVWZZZAUZEW003961 Mileage: 108473km-67401miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC X22 5517
Revision: 84X22---
Coding: 01110012034505092000
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F6D379176E9DA3C8E-807A
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 612630000002CA
Coding: 01FA8AA12420096F0380060641C42580512490C06082A4F3F440F074C002
VCID: 7BF5D3C1F211F69C72-802E
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00120104202100001000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 356105F994B5E0ECC4-8060
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011505500833
Coding: 03000A42424122733FA44080B1040328101E000000000000000000000000
Shop #: WSC 05026 123 12345
ROD: EV_BCMBOSCH_013.rod
VCID: 000FA42D9BF7954427-8054
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130509 042 0551
Serial number: 130511002310
Coding: 0E4DD5
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y13M05D08H16M51S34S1
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150751N31
Serial number: 00000000000056677916
10762 - Bulb for Right Tail Light
B12BF 15 [009] - Open or Short to Plus
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:15
563221 - Databus
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:10
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231312301615
Coding: 0071051001
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 3B7513C1B291369C32-806E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H03 0141
Serial number: 15051376510544
Coding: 00000300FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001013
Part No SW: 5Q0 959 655 M HW: 5Q0 959 655 M
Component: AirbagVW20 011 0361
Serial number: 003M1R02YF9R
VCID: 4A9B4605ED4B9F14B9-801E
Belt Pretensioner left:
Component: BeltPretRevFL H35 0340
Serial number: 34169677B16051350765
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0340
Serial number: 34169676B17051340165
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 005 13
Serial number: 35767000000BAA104D0Y
Subsystem 4 - Part No SW: ----------- HW: 480 000 705 13
Serial number: 35867000000A21A40D0Q
Subsystem 5 - Part No SW: ----------- HW: 480 401 105 13
Serial number: 3516502B11050661516M
Subsystem 6 - Part No SW: ----------- HW: 480 401 105 13
Serial number: 3526502C51050654738-
Subsystem 7 - Part No SW: ----------- HW: 480 401 105 13
Serial number: 3556502B51050664A0A+
Part No SW: 5Q0 953 507 AG HW: 5Q0 953 549 A
Revision: -------- Serial number: 14051304400439
Coding: 0D00
ROD: EV_SMLSKLOMQB_013_AU37.rod
Part No SW: 5G0 920 961 A HW: 5G0 920 961 A
Component: KOMBI 252 2210
Coding: 23AD1A002F80260001896E01000000
VCID: 285FDC8D53078D044F-807C
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000572368
Coding: 030100040B087300FF00005E080F00010001000000000000000000000000
ROD: EV_GatewLear_009_VW37.rod
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H14 0035
Serial number: 23130000575720030291
Coding: 2C0000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 8109540503
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 07031404082028
Coding: 00370220DC01048000001000
Shop #: WSC 05026 000 00000
VCID: 408F642DDB77554467-8014
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001377136
Coding: 0D0000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D711DD9AC8538AC0C-8068
Address 47: Sound System
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 11051301100756
Coding: 003700205C01048000801000
VCID: 3E731AD5A18323B415-806A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001446881
Coding: 050000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 029A010003000400
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 020 D HW: 3G0 035 020
Component: MU-H-ND-EU 043 0814
Serial number: A580X0XX002803
Coding: 02730201FF00000011111201008800002F0100C601200100DF
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
VCID: 183FEC4DE3673D84FF-804C
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H41 8077
Serial number: VWZ6ZDT0692274
Subsystem 2 - Part No SW: V03 959 800 QN HW: -----------
Component: ECE 2016 --- 0134
Compact Disc Database:
Component: Gracenote2--- --- 1011
10 Faults Found:
1586 - invalid data record
B2005 00 [009] - -
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:13
Voltage terminal 30: 12.3 V
1587 - invalid data record
B2005 00 [009] - -
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:13
1588 - invalid data record
B2005 00 [009] - -
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:13
1595 - invalid data record
B2005 00 [009] - -
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:13
1652 - invalid data record
B2005 00 [009] - -
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:13
1597 - Data Set Implausible
B2012 00 [009] - -
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:13
1598 - Data Set Implausible
B2012 00 [009] - -
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:13
1546 - Internal Control Module Memory Check Sum Error
B2000 46 [008] - Calibration/parameter memory failure
Reset counter: 253
Mileage: 1048574 km
Voltage terminal 30: 13.7 V
B201A 00 [009] - -
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:18
Voltage terminal 30: 12.2 V
Status_Software_Version_Management-module_name: MDUV612/Main
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Reset counter: 213
Mileage: 108473 km
Date: 2018.09.10
Time: 17:58:13
End-------------------------(Elapsed Time: 03:53)--------------------------
;SW:5Q0-937-084-S HW:5Q0-937-084-S --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB M H14 0112 Coding:03000842C24102730BA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 11001 EV_BCMBOSCH_011.rod
;Monday 10 September 2018 15:04:18:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 489F7C0DF3476D04AF-801C
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 0 9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 0 ms 9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 0 ms 9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 0 ms 9
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 9
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 9
IDE01550-Service position 170.494336 ° 2
IDE02152-Characteristics in production mode 2000 ms 1
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln No 2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln No 2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn normal 2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 2
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 3
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel not enabled 4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung not enabled 4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset 0.25 ° 13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.0 %/s 13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt both sides 13
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.0 km/h 13
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.0 °C 13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.0 °C 13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.0 °C 13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 80 ° 13
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.0 km/h 13
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 13
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separate 3
IDE04923-ENG115774-Turn signal control-Komfortblinken active 3
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 3
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 3
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 3
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 3
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.10% 3
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 3
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion not active 14
IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren not active 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 116 5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 2 5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 5
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 5
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 5
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung 35.0 °C 8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung 35.0 °C 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH time value 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 1
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 1
IDE04928-ENG148904-Anti-theft device-Überwachung Innenentriegelungshebel not active 1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 4
IDE05142-ENG116621-Access control-automatisches Entriegeln active 4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 4
IDE05142-ENG116706-Access control-Autounlock NAR not active 4
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 4
IDE05142-ENG115722-Access control-Electrical rear lid not active 4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 4
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 4
IDE05142-ENG115755-Access control-Notschließfunktion active 4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 4
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 4
IDE05142-ENG115758-Access control-Valet Parking not active 4
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 4
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 4
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 0 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 0 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 0 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 0 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 0 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0A 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 1A 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 0 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 0 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 48 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 4C 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 37 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 41 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 minimize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 minimize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 maximize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 maximize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 0 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 0 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 0 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 0 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 0 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 0 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 0 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 28 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 28 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 100 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 0 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 100 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 100 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 0 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 0 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 100 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 100 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 100 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 100 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 100 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 100 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 0 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 28 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 28 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 0 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 0 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 0 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 31 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 31 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 0 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 0 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 0 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 0 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 0 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 0 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 0 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 29 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 2A 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 0 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 0 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 0 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 43 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 44 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 1C 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 1D 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 not active 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 not active 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 not active 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 not active 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 not active 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 not active 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 12 - Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 12 - Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 not active 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 13 - Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 13 - Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 18 - 2* 5W 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 not active 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 not active 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 not active 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 11 - Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 11 - Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 10 - allgemeine Scheinwerfer 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 10 - allgemeine Scheinwerfer 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 Always 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 Always 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 only_if_closed 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 only_if_closed 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 Always 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 0 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 0 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 0 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 0 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 0 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 0 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 0 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 8 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 8 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 0 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 0 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 0 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 13 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 14 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 0 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 0 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 0 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 0 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 15 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 15 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 0 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 0 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 6 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 7 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 0 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 0 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 0 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 0 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 0 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 0 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 0 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 0 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 31 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 31 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 9 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 10 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 14
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 14
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 14
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 14
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 14
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 14
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 14
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 14
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 14
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 14
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 14
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 14
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 14
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 14
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung not active 6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 6
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active 2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 2
IDE07007-ENG148891-A/C heater function via remote control-Anzahl zulaessiger Remotestarts 2 2
IDE07007-ENG148876-A/C heater function via remote control-RemoteStart Betrieb Dauer 10 min 2
IDE07356-Position during interval mode 31.494474 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs not active 5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 1 min 5
IDE08542-IDE02021-Access control 2-Comfort closing active 6
IDE08542-IDE02022-Access control 2-Comfort opening active 6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 6
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen No 6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen Yes 6
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung No 6
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 6
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 6
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 6
IDE08542-ENG115671-Access control 2-Regenschließen Permanent 6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 6
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 6
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 1
IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner not active 1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 1
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 1
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE10298-Alternating park position 1 7.494498 ° 2
IDE10299-Alternating park position 2 29.494476 ° 2
MAS00194---no display-- 5 s 1
MAS00194-ENG123004---no display---p_lx_regenlichtschwelle 6000 lx 2
MAS00194-ENG123002---no display---p_n_regenlichtschwelle_high 12 s 2
MAS00194-ENG123003---no display---p_n_regenlichtschwelle_low 6 2
MAS00194-ENG123005---no display---p_t_regenlicht 30 s 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.494474 ° 2
MAS05056-upper turn position 170.494336 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 3
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 3
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 3
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 3
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 3
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 3
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 3
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 3
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 3
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 3
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 3
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 3
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 3
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 5570560 3
ENG122933-error_mask 0 2
ENG117283-Frontwaschfunktion 10 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -3 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 lx 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 lx 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 lx 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16.00% 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16.00% 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100.00% 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100.00% 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100.00% 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6.00% 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6.00% 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100.00% 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100.00% 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100.00% 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100.00% 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100.00% 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100.00% 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100.00% 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100.00% 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100.00% 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100.00% 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100.00% 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6.00% 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6.00% 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100.00% 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100.00% 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0 0 lx 8
ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1 8 lx 8
ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2 50 lx 8
ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3 500 lx 8
ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0 6.00% 8
ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1 6.00% 8
ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2 100.00% 8
ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3 100.00% 8
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 0 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 0 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 0 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 not active 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 not active 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 not active 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 0 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 0 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 0 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 not active 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 not active 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 not active 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 0 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 0 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 0 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 not active 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 not active 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 0 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 0 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 0 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 not active 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 not active 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 0 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 0 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 not active 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 Always 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 not active 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 0 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 0 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 not active 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 Always 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 not active 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 12 - Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 12 - Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 28 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 13 - Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 28 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 13 - Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 maximize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 28 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 29 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 only_if_closed 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 not active 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 not active 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 maximize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 28 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 2A 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 only_if_closed 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 not active 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 not active 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 100 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 18 - 2* 5W 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 0 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 0 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 0 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 not active 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 not active 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 100 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 100 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 0 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 0 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 0 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 0 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 not active 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 not active 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 not active 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 not active 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 0 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 0 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 not active 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 not active 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 0 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 0 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 0 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 0 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 not active 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 not active 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 not active 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 not active 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 minimize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 100 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 0 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 31 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 43 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 48 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Blinken links aktiv (beide Phasen) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 not active 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 Standlicht vorn (Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 minimize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 100 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 0 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 31 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 44 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 4C 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Blinken rechts aktiv (beide Phasen) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 not active 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 Standlicht vorn (Positionslicht: Begrenzungslicht) 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 Parking light right 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 100 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 11 - Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 not active 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 100 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 11 - Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 not active 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 100 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 1C 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 37 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 10 - allgemeine Scheinwerfer 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Left high beam 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Lichthupe generell 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 100 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 1D 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 41 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 10 - allgemeine Scheinwerfer 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Right high beam 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Lichthupe generell 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 10 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 100 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 150 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 220 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 253 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG122927-RLS_close_glazing 2.0 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 9 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG122996-Wischgeschwindigkeiten-Dauerwischen Stufe 1 Zyklen pro Minute 40 3
ENG116832-ENG122997-Wischgeschwindigkeiten-Dauerwischen Stufe 2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 01:47
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42C24122733FA44080B10403281002000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Thursday 23 August 2018 10:16:35:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 10 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 10 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 34 - LED Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 8 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 8 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen not active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art once 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus not active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 34 - LED Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 10 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 10 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:12
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Wednesday 29 August 2018 16:33:39:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 34 - LED Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 34 - LED Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 01:59
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Saturday 1 September 2018 17:43:55:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:07
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Saturday 1 September 2018 17:46:55:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:07
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Saturday 1 September 2018 17:54:04:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:08
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Monday 10 September 2018 18:03:41:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0A 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 1A 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 maximize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 maximize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 28 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 28 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 28 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 28 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 29 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 2A 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 13 - Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 37 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 only_if_closed 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 only_if_closed 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 0 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 8 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 8 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 0 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 0 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 0 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 0 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 not active 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 28 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 28 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 13 - Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 maximize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 28 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 29 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 only_if_closed 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 not active 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 not active 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 maximize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 28 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 2A 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 only_if_closed 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 not active 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 not active 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 37 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:15
post latest scan and admap to check again, also did you change anything in right side wiring?
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42C24122733FA44080B10403281002000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Thursday 23 August 2018 10:16:35:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 10 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 10 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 34 - LED Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 8 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 8 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen not active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art once 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus not active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 34 - LED Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 10 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 10 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:12
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Wednesday 29 August 2018 16:33:39:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 34 - LED Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 34 - LED Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 01:59
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Saturday 1 September 2018 17:43:55:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:07
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Saturday 1 September 2018 17:46:55:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:07
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Saturday 1 September 2018 17:54:04:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 0 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 minimize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 minimize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 10 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 10 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 0 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 0 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 34 - LED Bremsleuchten 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 34 - LED Bremsleuchten 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 2 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 24 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 24 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 9 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 10 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 6 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 7 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 10 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 10 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 minimize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 0 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 34 - LED Bremsleuchten 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Brake light 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 minimize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 0 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 0 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 34 - LED Bremsleuchten 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Brake light 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Parking light right 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:08
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122733FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Monday 10 September 2018 18:03:41:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0A 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 1A 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 maximize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 maximize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 28 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 28 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 10 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 28 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 28 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 29 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 2A 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 2A 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 13 - Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 37 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 only_if_closed 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 only_if_closed 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 only_if_closed 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 0 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 8 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 8 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 28 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 0 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 0 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 0 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 0 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht not active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 31.49 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art Permanent 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not active 8
IDE08542-ENG154261-Access control 2-Reserved_4 not active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen not active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen not active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal not active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar not active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset not active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe not active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09595-ENG115658-Characteristic curve-x0 0 lx 18
IDE09595-ENG101574-Characteristic curve-X1 2000 lx 18
IDE09595-ENG99557-Characteristic curve-X2 4000 lx 18
IDE09595-ENG102140-Characteristic curve-X3 6000 lx 18
IDE09595-ENG102936-Characteristic curve-X4 8000 lx 18
IDE09595-ENG103548-Characteristic curve-X5 10200 lx 18
IDE09595-ENG148955-Characteristic curve-y1_0 0 18
IDE09595-ENG148956-Characteristic curve-y1_1 40 18
IDE09595-ENG148957-Characteristic curve-y1_2 90 18
IDE09595-ENG148958-Characteristic curve-y1_3 140 18
IDE09595-ENG148959-Characteristic curve-y1_4 190 18
IDE09595-ENG148960-Characteristic curve-y1_5 245 18
IDE09595-ENG148961-Characteristic curve-y2_0 0 18
IDE09595-ENG148962-Characteristic curve-y2_1 60 18
IDE09595-ENG148963-Characteristic curve-y2_2 110 18
IDE09595-ENG148964-Characteristic curve-y2_3 160 18
IDE09595-ENG148965-Characteristic curve-y2_4 210 18
IDE09595-ENG148966-Characteristic curve-y2_5 255 18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.10 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 2 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 3 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 1 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 2 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen not active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen not active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen not active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung 3000 ms 10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit 1000 ms 10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige 0 s 10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz 25 10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor 0 10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS 393210 lx 10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS 393210 lx 10
IDE09733-ENG147405-LED bar setting values-Sperrzeit 0 s 10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 25% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 25% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 58% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 53% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 58% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 53% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 85% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 80% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 85% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 7.49 ° 2
IDE10299-Alternating park position 2 29.49 ° 2
MAS01490-Energy management active 1
MAS05055-lower turn position 31.49 ° 2
MAS05056-upper turn position 170.49 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen not active 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein not active 8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG122925-DWA_Interior_Monitoring_Data_Set_Development FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 150
ENG122934-erase_error_table 55 00 00 3
ENG122933-error_mask 0 bit 2
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay 10 2
ENG117283-ENG108451-Frontwaschfunktion-reserve 0 2
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 8 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 6 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 100 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 100 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 100 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 100 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 12 - Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 127 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 1E 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 37 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 Left high beam 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 Lichthupe generell 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 127 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 1F 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 41 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 Right high beam 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 Lichthupe generell 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 127 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 6 - LED Lichtmodul 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 127 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 6 - LED Lichtmodul 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 0 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 41 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 0 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 only_if_closed 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 not active 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 not active 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 not active 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 0 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 42 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 0 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 only_if_closed 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 not active 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 not active 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 100 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 12 - Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 28 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 39 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 10 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 28 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 3A 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 20 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 13 - Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 Parking light right 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 not active 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 maximize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 maximize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 28 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 100 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 29 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 only_if_closed 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 not active 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Brake light 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 not active 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 not active 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 maximize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 maximize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 28 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 100 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 2A 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 only_if_closed 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 not active 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Brake light 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 not active 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 not active 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 100 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2F 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 1C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 maximize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 10 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 0 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 2A 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 37 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 only_if_closed 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 not active 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 not active 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 maximize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 86 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 31 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 0B 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 only_if_closed 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Rueckfahrlicht 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 not active 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 86 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 only_if_closed 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 26 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 89 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 maximize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 maximize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 26 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 0 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 0 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 Parking light right 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 not active 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 not active 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 not active 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 127 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 0 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 not active 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 not active 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 127 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 0 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 Parking light right 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 not active 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 not active 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 3 - Xenon Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 3 - Xenon Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 127 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 26 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 35 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 36 - LED Kleinleistung 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 127 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 27 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 3F 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 36 - LED Kleinleistung 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 Parking light right 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske 63 1
ENG126648-ENG148864-LIN-Mirrormode-Stage 0 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar not active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv not active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar not active 16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts 2 8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer 10 min 8
ENG122927-RLS_close_glazing 2.00 s 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off 120 s 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on 10 s 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off 65 km/h 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on 140 km/h 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle 6000 lx 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high 12 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low 6 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht 30 s 2
ENG122929-RLS_LIN_Communication 4 s 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn 200 lx 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day 500 lx 1
ENG122930-RLS_tunel_gateway_recognize 5 s 1
ENG122935-RLS_Washer_Front 15 s 1
ENG122926-RLS_wiper_position_parking 15 s 1
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute 40 3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute 60 3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute 30 3
Elapsed Time: 02:15
;SW:5Q0-937-084-AJ HW:5Q0-937-084-AJ --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H H18 0137 Coding:03000A42424122533FA44080B1040328101E000000000000000000000000
;EV_BCMCONTI 13000 EV_BCMBOSCH_013.rod
;Tuesday 11 September 2018 17:10:49:62614
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 000FA42D9BF7954427-8054
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2000 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 320 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 320 ms 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 170.49 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln not active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global not active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn not active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln not active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn short 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung not active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte not active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 50% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 50% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 50% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung Enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset -63.75 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt double sided 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 180 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 600 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH not active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn not active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm keine verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung Always 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Globale Entriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05144-Read parameter address 00 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 37 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 41 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 0 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 0 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 10 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 20 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0A 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 1A 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 1C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 0 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 0B 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 35 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 3F 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 maximize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 maximize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 maximize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 maximize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 maximize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 maximize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 maximize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 maximize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 maximize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 maximize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 100 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 100 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 127 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 127 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 127 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 127 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 28 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 28 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 100 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 0 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 86 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 86 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 89 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 127 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 127 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 0 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 0 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 26 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 28 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 28 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 100 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 100 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 26 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 127 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 127 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 0 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 0 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 0 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 0 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 0 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 0 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 0 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 1E 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 1F 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 41 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 42 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 39 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 3A 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 29 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 2A 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2F 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 0 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 31 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 26 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 27 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 12 - Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 12 - Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 2 - Shutter: Diagnosesensierung für 'LED low' 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 6 - LED Lichtmodul 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 6 - LED Lichtmodul 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 13 - Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 not active 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 9 - allgemeine Glühlampe 27W: auch H15 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 3 - Xenon Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 3 - Xenon Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 36 - LED Kleinleistung 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 36 - LED Kleinleistung 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 only_if_closed 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 only_if_closed 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 only_if_closed 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 only_if_closed 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 Always 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 only_if_closed 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 only_if_closed 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 0 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 13 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 14 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 0 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 4 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 8 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 8 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 32 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 0 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 25 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 8 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 8 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 15 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 15 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 0 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 0 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 0 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 0 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 9 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 10 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 0 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 0 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 8 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 8 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 8 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 24 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 24 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 0 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 0 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 8 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 8 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 8 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 9 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 9 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 10 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 0 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 0 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 10 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 9 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 10 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 0 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 0 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 0 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 0 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 0 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 0 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 0 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 0 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 0 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 0 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 0 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 0 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 0 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.00 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 52.50 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 53.50 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 52.50 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 100% 8
IDE06
