ACC radar adjustment on 2017 A3
audigroovin
C?ID=30089
Anyone know the meaning of these 5 measured values in attached pic? For example, does "misalignment angle" mean the angle the ECU has measured as an offset error? The 3rd line states "performed adjustment...". Does that mean that was the adjustment made at the factory that the ECU recorded?
I ask because my ACC stopped working. I get the yellow triangle warning symbol in the dash and I get the below error code C110300. I did a rough alignment check of the radar alignment mirror that's bonded to the radar surface (square block unit in center, front, lower grill) and I calculate the mirror to be near perfect normal to the geometric vertical plane of the car and pointing .33 degrees too high to the earth level horizontal plane. I measured the mirror to be near perfect normal to the vertical car plane. I'll post the procedure separately if it makes sense to do so - if my measured offset of .33 deg is correctable and ACC starts back up.
13 Adaptive Cruise Control
System description: ACC BOSCH MQB
Software number: 5Q0907572G
Software version: 0571
Hardware number: 5Q0907572G
Hardware version: H10
ODX name: EV_ACCBOSCHVW416
ODX version: 001005
Long coding: D50087C219FFC428949C8055000026
Trouble codes:
C110300 - Adaptive cruise control sensor misadjusted
static
static
U112300 - Databus error value received
Intermittent
myounus
Northwest UK
C?ID=321059
Could you please post a full autoscan - thanks.
If the ACC has lost its alignment and needs recalibration then the dealers or a specialist ADAS garage with the kit would need to do it.
audigroovin
C?ID=30089
Uh, I was not subscribed to this thread so I never go notified. Anyway, I'll post a scan tomorrow. It appears there is no calibration possible in VCDS. It provides measured values only. Is that correct? I understand that the VAS6430 aligns itself to the driving axis of the car so that the radar puck can be then aligned to the tool. This person did this... http://www.audi4ever.com/v2/blog/de...ruise-Control--A4-A5-Q5--Distronic/index.html and I've been able to a similar alignment but with a cross-hair laser. I can post that procedure but even I adjust the radar unit perfectly to spec how do I tell the car it's aligned? And what is the spec? Normal to driving axis? I imagine horizontally it should be but vertically it might be off normal per design. There's a lot of data but no spec for it it seems.
downtime
Finland
C?ID=280813
Doesn't the basic setting -> Reset misadjustment angle do just that?
You calibrate the radar to correct angle and the run that basic setting. It should take the new values as reference.
What has happened for the radar to lose it's adjustment? Have you done something with the bumper? Lowered the car etc.? It does not lose that without being physically moved.
There was another similar issue on different thread and there the reason was that the radar unit was knocked out from one of the fixings. OP from that thread just clicked the fixings in place and voila, misadjustment issue gone. So check those first before doing any adjustments.
Here's how it's done properly:
audigroovin
C?ID=30089
I removed the bumper and removed the radar unit from it's attachment to the bumper. The same bumper was put back on. Radar unit mounts to a pin-slot repeatable arrangement on the bumper. The bumper was installed at the same elevation (markings where bolts attach were used to verify).
Also, I do not see anything in basic settings except checking the heating function.
audigroovin
C?ID=30089
That's how Audi provides a low risk and robust procedure to get repeatable calibration results from users who purchase and are trained on that system. It is not the only way to do it "properly". ....IMO. At the risk of making an inaccurate assumption the radar mirror can be aligned orthogonaly to the geometric center of the car. If you assume the center of the mirror, the center of the front facing camera, and a 3rd point that is plumb to earth define the vertical plane of the car the mirror can be aligned to that to establish its horizontal spec. Level earth can be used to align vertically. Using a cross-hair laser I found the horizontal alignment near perfect and the vertical alignment pointing down a few tenths of a degree.
What is the software tree required for that alignment system in the video? It's not ODIS, or is it?
MasterTommy
Amsterdam
C?ID=295586
Provided you have adjustment screws on the radar base to physically change its alignment. I just swapped the front bumper on my tiguan (which involved removing the radar unit behind the VW emblem) and it clicks into the grille without any alignment screws present (the seat of the radar is part of the grille). Aligning is done with the same setup as in the video, but purely involves changing parameters of the radar. No static alignment possible. And if I remember correctly, a radar unit that does have alignment screws to change the physical position of the radar also needs to be calibrated afterwards just like the non-adjustable units like in my tiguan. So IMO, you’re still half-assing it by only doing a static adjustment.
I would consider "low-risk, robust, and repeatable" to be essential when it comes to a system that can fully control the car's throttle and brakes.
I've driven thousands of miles with ACC engaged in two different cars and have always been amazed at the system's ability to differentiate between vehicles that are in my lane vs. vehicles that are not in my lane, even on very curvy stretches of highway. This has also made me aware of the potential consequences if the system did not do that correctly. Personally, I would be very reluctant to use ACC on a car that had been calibrated willy-nilly, i.e. without following the correct procedures using the correct equipment.
One of the things people seem to miss is that the centerline of the car is not what matters to here, but rather the centerline of the car's thrust angle. This is why a wheel alignment is considered a mandatory part of the procedure. We know the car you're working on has been crashed. Has the wheel alignment even been checked post-repair?
myounus
Northwest UK
C?ID=321059
If you wanna play with human lives then get a backstreet job.
As Uwe has said the system is integrated into the car's throttle and brakes. This is why you won't find 3rd party aftermarket ACC or similar ADAS products and I don't think you ever will.
I don't think any 3rd party company could take the risk of a software error and manslaughter charges. Some things you can't avoid paying through the nose!
audigroovin
C?ID=30089
Your response is unhelpful. I've never stated I want to change the alignment parameters of the ACC system. I want to align the radar unit to the parameters of the ACC system. That has nothing to do with car throttle or brakes - that is embedded in the system parameters. If it works it works. If the radar is out of alignment it stops working. ...like mine. I want to find what the alignment spec is, what my out-of-alignment is, and then turn the tip/tilt screws on the radar unit to get it working again.
For example, if I can determine which measured value is telling me how far out the horizontal angle is I can easily find how many degrees of screw turn gives so many degrees of angle change. Same with vertical.
audigroovin
C?ID=30089
My car has tip/tilt adjustment screws on the center radar unit. It is attached to the reinforcement bar, not the grill. If there are only 2 adjustment screws how am I "half-assing" it?
audigroovin
C?ID=30089
Here's an auto scan...
Also if you're interested in seeing the damaged car prior to repair just google image search the VIN.
Friday,31,August,2018,09:22:51:59265
VCDS Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
VIN: WAUSPBFF9HA039569   License Plate:
Mileage: 26568km-16508mi   Repair Order:
Chassis Type  FF-AU37 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 3C 42 44 47 51 52
          55 5F 6C 75 8C A5 BB BC C0 C6 CF
VIN: WAUSPBFF9HA039569   Mileage: 26568km-16508miles
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CXUA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AN    HW: 04E 907 309 F
   Component: R4 1.4l TFS   H22 3695
   Revision: X3H22---
   Coding: 021D0012636401083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906023AN 008005
   ROD: EV_ECM14TFS01104E906023AN_008.rod
   VCID: 6CD73866876C7624E8-8038
17156 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 148
                    Mileage: 23880 km
                    Date: 2018.08.04
                    Time: 12:50:10
                    Engine speed: 0.00 /min
                    Coolant temperature: 32 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 13.200 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 6
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 2
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
   Part No SW: 0DD 300 046 A    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 1602
   Revision: 00032056    Serial number: TFK01607270293
   Shop #: WSC 00099 780 00200
   ROD: EV_TCMDQ400021.rod
   VCID: 26430A4E59008C747E-8072
30097 - Transmission Fluid Pressure
          P0867 00 [040] - Function Restriction due to Low Pressure
                    Fault Frequency: 9
                    Mileage: 25467 km
                    Date: 2018.08.20
                    Time: 20:54:03
                    Engine speed: 18.75 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 71 km/h
                    Control Module temperature: 24 °C
                    CURRENT pressure: -10.0 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 12032
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 62216000000155
   Coding: 12FF409238232275897C0A0681CC2948021C44915081947218A1505482A802
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
   VCID: 7CF70826F70CE6A478-8028
16401 - Tire Pressure Warning
          C102D 00 [032] -  -
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0414425711
   Coding: 030C0C
   VCID: 3B75CB3AB282219C31-806E
   Part No SW: 8V0 820 043 S    HW: 8V0 820 043 S
   Component: AC Automat    H03 0610
   Revision: 20001000    Serial number: 00000001022918
   Coding: 0300001001000000080000000000140001000000
   ASAM Dataset: EV_AirCondiFrontNARAU37X 001019
   ROD: EV_AirCondiFrontNARAU37X.rod
   VCID: 428BB6DED568505472-8016
   Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G395 pT-Sens1  H61 0006
   Subsystem 2 - Part No SW: 3Q0 963 231 D    HW: 3Q0 963 231 D
   Serial number: -00103.2T.4C20340003
   Subsystem 3 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 1F58034800PAG0MUFU02
   Air Conditioning Compressor Sub:
   Subsystem 4 - Part No SW: 5QE 816 803 C    HW: 5QE 816 803 C
   Component: J842 eKK  H02 0006
   Serial number: IABB00000K0000000117
   Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H34 0236
   Serial number: 02001620400089
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EF3022EE110F4B456-802A
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160804  043 0580
   Serial number:         160809190108
   Coding: 0A47F7
   Serial number: 62141365
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Serial number: 23 06 2016  00001032
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066799941
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0014BIZX00000
   Coding: 101F00
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 92
                    Mileage: 25982 km
                    Date: 2018.08.25
                    Time: 13:37:18
   Part No SW: 5QA 919 294     HW: 5QA 919 294
   Component: PDC 8 KanalH07 0031
   Serial number: 000308418616214
   Coding: 0470155811
   ASAM Dataset: EV_EPHVA18AU3700000 009027
   VCID: 091961F2A8DEC30C73-805C
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: D51087C219FFC428949C8055000026
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] -  -
                    Reset counter: 102
                    Mileage: 26568 km
                    Date: 2018.08.30
                    Time: 22:23:42
                    Control Module temperature: 62 °C
                    Voltage terminal 15: 12.8 V
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] -  -
                    Reset counter: 102
                    Mileage: 26568 km
                    Date: 2018.08.30
                    Time: 22:23:42
   Serial number: 003GCR09J8S-
   Coding: 9DFCFCC0002000009000001AC24800000065
   Shop #: WSC 29326 002 1048576
   VCID: 479DA7CAFE4A757CA5-8012
   Belt Pretensioner left:
   Serial number: 34230167A12081651157
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A13081650032
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001HX9E7
   Coding: 303334
   Subsystem 4 - Part No SW: -----------    HW: 480 001 708 16
   Serial number: 35700000000A7194BD1S
   Subsystem 5 - Part No SW: -----------    HW: 480 001 708 16
   Serial number: 3580000000009194BD1L
   Subsystem 6 - Part No SW: -----------    HW: 480 401 708 16
   Serial number: 3510001B92205C32145N
   Subsystem 7 - Part No SW: -----------    HW: 480 401 708 16
   Serial number: 3520001B92205C33156R
   Subsystem 8 - Part No SW: -----------    HW: 480 402 607 16
   Serial number: 3550002A92095071916V
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 407 16
   Serial number: 3560002BF21160D161F2
   Part No SW: 8V0 953 521 KF    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 14081608490079
   Coding: EC18
   VCID: 081F64F6B3D4BA046C-805C
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 894     HW: 8V0 920 894
   Component: FBenUSA       H13 0045
   Coding: 08440C516F98CF050283E8101B00000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 F    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3265
   Revision: --------    Serial number: 10081610520163
   Coding: 0201001726F200005B00121C581000000001010100010000000300000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 4999A1F2E85E830CB3-801C
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20160803112839 01417
   Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
   Serial number: 0190810604
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
   Component: EBKV          H14 0200
   Serial number:   085430010337
   Coding: 03720100331A00030002050500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
   ROD: EV_BrakeBoostBoschMQBOMG_004.rod
   VCID: 50AF8C960B04B2C4F4-8004
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861230716072612
   Revision: 00000000    Serial number: 16000142422010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3467E0069FDCEEE4F0-8060
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------
   Coding: 04C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   VCID: 3979D132B8BE138C23-806C
   Serial number: 080816EH725934
   Coding: 005D1F205C00048000000003
   VCID: 4385B3DACA72595C79-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: D106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4581ADC2C446676C57-8010
   Part No SW: 81A 035 466     HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0100
   Revision: 00000001    Serial number: AUZ8ZAGHX004YQ0
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 62CB565E75A8305452-8036
   Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
   Component: LE Gen 3.3H11 1032
   Revision: 00H11000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM08530115G0907080E 001008
   ROD: EV_DMCM08530115G0907080E.rod
   VCID: 29590172481EA30C53-807C
   Serial number: 150716EGE3465A
   Coding: 005D17205E00048000000003
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0E5A001123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E73C22EA19034B416-806A
   Part No SW: 8V1 035 880     HW: 8V1 035 880
   Component: MU-P-LNS-US   052 0694
   Serial number: A702H0G7510874
   Coding: 017393020000000011220002041A00102F0029E5017001047E
   VCID: 77FD170ACE2AC5FC15-8022
   Subsystem 1 - Part No SW: V03 959 801 GF    HW: -----------
   Component: NAR 2016/2017  --- 0054
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY20752D
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL108081600010557
   Compact Disc Database:
   Component: Gracenote2---  --- 3009
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 47
                    Mileage: 23880 km
                    Date: 2018.08.04
                    Time: 08:49:07
                    Voltage terminal 30: 13.3 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [008] - No Communication
                    Reset counter: 126
                    Mileage: 25459 km
                    Date: 2018.08.18
                    Time: 20:13:27
                    Voltage terminal 30: 13.4 V
   Coding: 0273100102002001400040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
   Component: OCULowMQBUS   007 0568
   Coding: 017393011080BA0100F800000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
   Component: BECM          H05 0911
   Serial number: U3010028
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006040
   ROD: EV_BECM06020115C6915182_VW37.rod
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
   Component: BJB  H28 0240
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D1  H14 0481
   Serial number: V013C1622530948
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D2  H14 0481
   Serial number: V013C1622530951
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D3  H14 0481
   Serial number: V013C1622531067
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D4  H14 0481
   Serial number: V013C1622530946
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D5  H14 0481
   Serial number: V013C1622531055
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D6  H14 0481
   Serial number: V013C1622531056
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D7  H14 0481
   Serial number: V013C1622531066
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D8  H14 0481
   Serial number: V013C1622530947
26701 - Battery Charger Input
          P0D81 00 [096] - Implausible Signal
                    Mileage: 25095 km
                    Date: 2018.08.16
                    Time: 09:19:04
                    Pack Voltage: 351.3 V
                    Pack Current: -0.00 A
                    Isolation Resistance: 5080 kOhm
                    Maxumum charge current limit: 126 A
                    Maximum discharge current limit: 295.5 A
                    Contactor Voltage: 0 V
                    OBD unlearned counter: 14
                    Crash status: 00
                    Pilot Line Status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 00
                    (Plus) Contactor Status: 00
                    Terminal 15 status: 00
                    Max Cell Temperature: 28 °C
                    Min Cell Temperature: 27 °C
                    Air inlet temperature: 27 °C
                    Air outlet temperature: 26 °C
                    LV Battery Voltage: 12.5 V
                    Min.cell voltage: 3.655 V
                    Max.cell Voltage: 3.659 V
                    Max.cell SOC: 42 %
                    Min.cell SOC: 41 %
                    Hybrid Battery Pack Remaining Life: 40.8 %
                    Max Charge Pack Current(10s duration): 0 A
                    Max Discharge Pack Current(10s duration): 0.0 A
                    Max Pack Voltage(10s duration): 350 V
                    Min Pack Voltage(10s duration): 350 V
                    Max.cell Voltage(10s duration): 3.661 V
                    Min.cell Voltage(10s duration): 3.655 V
                    Accelerator Pedal Position D: 14.5 %
                    Calculated LOAD Value: 0.0 %
                    Engine coolant temperature: 51 °C
                    Engine RPM: 0.00 /min
                    Vehicle Speed Sensor: 0 km/h
                    Ambient Air Temperature: 215 °C
                    Hybrid Battery Pack Remaining Life: 40.78 %
                    control module system voltage: 12.547 V
                    absolute load: 0.0 %
                    Time After Engine Start: 0 s
   Serial number: 02081611K10671
   Coding: 0403070300000201012223468048490080000E200020
   ROD: EV_MFKBoschMQBB_VW36.rod
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 200716EGK09733
   Coding: 000C17204000048000000002
   Serial number: 200716EGK09732
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 L    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H09 0212
   Serial number: EN163117810000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 006013
   ROD: EV_ENoiseS1NNVW3707_006.rod
   VCID: 4A9B9EFEED588814BA-801E
   Part No SW: 5QE 915 682 AG    HW: 5QE 915 682 AG
   Component: OBC KOSTAL    H31 4013
   Revision: --------    Serial number: 2107160GD0007I
   Coding: 105168023000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
   ROD: EV_OBCSinglPhaseKLOMQB12P.rod
   VCID: 122B469EC58800D482-8046
2097696 - Charging Socket A for AC Connection
          P31C7 00 [008] - Open Circuit
                    Reset counter: 118
                    Mileage: 25095 km
                    Date: 2018.08.16
                    Time: 09:19:04
Address CF: Lane Chge Asst 2
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
End-------------------------(Elapsed Time: 06:33)--------------------------
myounus
Northwest UK
C?ID=321059
Audigroovin, I think we are all saying the same thing that it is not possible to accurately re-align the radar without re-calibrating it. This cannot be correctly/accurately done without the use of specialist equipment. Due to the safety nature of the unit's purpose, i.e. Accelerating and braking when a vehicle is in front of you, the parameters have to be set/aligned by proper equipment.
MasterTommy
Amsterdam
C?ID=295586
I clearly stated that if there are adjustment screws, its still only one step in the 2-part calibration proccess. The second part is what you’re completely ignoring if you only align it using the screws.
audigroovin
C?ID=30089
Perhaps you are right but that conflicts with what I've read online of other people's similar issue wherein they make an adjustment to the tip/tilt and the system turns back on. Maybe VAG has changed the design for this model year and changed that wherein the system shuts down and losses its alignment completely. If that latter is correct that also conflicts with measured values that show measured angles. I think that if the system can measure itself, output alignment parameters, and turn itself off when it measures something that is out of alignment, then it must know what the alignment needs to be.
Address 13: Auto Dist. Reg (5Q0 907 572 G)
22:09:21
IDE08768 Mirror deviation: horizontal 0.260 °
IDE08769 Mirror deviation: vertical -0.484 °
IDE08936 Misalignment angle: horiz 0.014 °
IDE08937 Misalignment angle: horiz: fast algorithm -0.044 °
IDE09380-IDE01784 Performed adjustment-Misalignment angle 0.01 °
IDE09380-MAS08804 Performed adjustment-Horizontal offset angle 5.08 °
IDE09380-MAS08805 Performed adjustment-Vertical offset angle -2.40 °
IDE09906 Vertical deadjustment -0.113 °
ENG00935 Status_ACC_System ACC_irreversible error
Trowbridge, UK
But doesn't "irreversible error" suggest that even when the alignment is corrected some further action may be required?
audigroovin
C?ID=30089
Yes, the line in the measured values, "ENG00935 Status_ACC_System ACC_irreversible error" makes little sense. Does something require replacement? It's also shown in the auto-scan, copied below...
C1103 00 [009] - -
Reset counter: 102
Mileage: 26568 km
Date: 2018.08.30
Time: 22:23:42
connector
Lafayette, CO
C?ID=57065
What about non OEM targets and racks?
Is there liability to anyone other than the driver of the car?
Is the driver tasked with paying attention and not relying on the ADAS in the operations manual?
Does that relieve equipment manufacturers and repair facilities from prosecution?
We have been trying to wrap our heads around ADAS for awhile now.
The market interest is keen, yet it seems like most all are rushing down a path that we are not convinced is the best way forward.
People are spending thousands of dollars on systems that we think are highly questionable.
Shops are using systems that are not OEM for these calibrations.
Aftermarket companies are resizing the targets and moving them closer!
They are proposing new locations, putting them on the windshield to align these systems!
We think you are borderline crazy doing this with anything other than OEM systems and targets, legally acquired from Bosch.
I am not a lawyer, but I have heard others question if there is any legal co-operation between USA and China.
The company that I see is selling more of this then anyone is based in Shenzhen, China.
I think the Hella Guttman choice is a better one, at least they are an OEM supplier.
I watched a dealer technician setting the lane assist on a Subaru last month.
The target was located carefully with instructions from the Subaru Select Monitor 4.
The car was in the learning mode. I did not see him put it into learning mode.
It did not acquire the target where it was set.
The tech went to the target and bumped it with his hand!
Now the car was happy.
That left me wondering.
What are you all thinking?
audigroovin
C?ID=30089
Wow, so much ignorance. I got my ACC working over a year ago, soon after I posted here. The design intent of the system is that the puck up front is aligned to the thrust axis of the vehicle. All anyone has to do is put a 4 foot x 2 foot sheet metal target bonded to a flat particle board panel a few feet in front of the vehicle and geometrically align it to the car. The ekta manual describes set up. Then run Odis to calibrate. Unless your vehicle is grossly out of alignment this is not an issue. The whole $10k alignment rig is ridiculous. Home Depot rig does same thing for $10. Use firewall for datum reference, measure angle car is resting on, etc... your adjusting in tip tilt the target to be normal to the thrust axis of the car.
