01 B5 A4 service interval chane
crazyquik22023
C?ID=206258
I'm not really sure how to change the service interval. I tried changing 17-10-042+043 to 4. This put my service interval at 8200 miles. If I change the number to 3 it changes the service interval to 3800 miles. I would ideally like the service interval to be 4500 miles. But if I can get it to 4k miles or 5k miles I'm fine with that. I have a feeling I am doing this incorrectly. Any help would be appreciated. Thanks.
Please post the Auto-Scan so we can see which cluster is installed.
If you manually tweaked the settings using the Adaptation function from the 17-Instrument Cluster controller, the contents from AdpLog.TXT located in the C:\Ross-Tech\VCDS\Debug would be helpful.
If you used the [SRI Reset] function instead the SRILog.txt file should contain the before and after modifications. It couldn't hurt to post the content from both of those if you aren't sure.
crazyquik22023
C?ID=206258
Sorry, Should have posted scan first
VCDS Version: Release 12.12.3 (x64)
Data version: 20140822
Wednesday,22,October,2014,17:05:34:42504
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 058-906-018-ATW.lbl
Part No: 4B0 906 018 M
Component: 1.8L R4/5VT G01 0003
Coding: 16201
VCID: 2B5527B0D9A338461EF-5140
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C37F46C8C0DCFFE675-5124
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00140
Shop #: WSC 06435
VCID: 2D5129A8E7B7367600B-25A6
7 Faults Found:
00602 - Potentiometer On Positioning Motor for Footwell/Defroster Flap (G114)
30-00 - Open or Short to Plus
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
00797 - Sunlight Photo Sensor (G107)
01297 - Sensor for Vent Temperature; Footwell (G192)
01296 - Sensor for Vent Temperature; Center (G191)
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 K
Component: Airbag Front+Seite 0002
Coding: 00104
Shop #: WSC 06335
VCID: 3E731EE43AD1BDEEA91-5198
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D12
Coding: 00244
Shop #: WSC 40866
VCID: 39790DF823FF9AD69C3-515E
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 15176
Shop #: WSC 06435
VCID: 408F601C4025CB1EDBD-4EEA
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4B0 035 192 K
Component: RNS 4.2 H06 BNO 0140
VCID: 2541D188BF470E36C8B-4ACE
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
VCID: E0CF009C60E52B1E7BD-4B32
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 01320
Shop #: WSC 02325
VCID: 2541D188BF470E36C8B-4AE8
End ---------------------------------------------------------------------
AdpLog.txt file:
Address 17:8D0 920 980 Q  channel 43 adapted from 4 to 0004  Wednesday,27,August,2014,21:22:20:42504
Address 17:8E0 920 950 H  channel 2 adapted from 1 to 00000  Friday,19,September,2014,16:23:24:42504
Address 17:8D0 920 980 Q  channel 42 adapted from 4 to 00003  Tuesday,21,October,2014,21:28:33:42504
Address 17:8D0 920 980 Q  channel 43 adapted from 4 to 3  Tuesday,21,October,2014,21:29:13:42504
Address 17:8D0 920 980 Q  channel 42 adapted from 3 to 00035  Tuesday,21,October,2014,21:30:03:42504
Address 17:8D0 920 980 Q  channel 42 adapted from 35 to 00036  Tuesday,21,October,2014,21:30:42:42504
Address 17:8D0 920 980 Q  channel 43 adapted from 3 to 36  Tuesday,21,October,2014,21:30:53:42504
Address 17:8D0 920 980 Q  channel 42 adapted from 36 to 0008  Tuesday,21,October,2014,21:32:14:42504
Address 17:8D0 920 980 Q  channel 43 adapted from 36 to 8  Tuesday,21,October,2014,21:32:44:42504
Address 17:8D0 920 980 Q  channel 42 adapted from 8 to 4  Tuesday,21,October,2014,21:33:29:42504
Address 17:8D0 920 980 Q  channel 43 adapted from 8 to 4  Tuesday,21,October,2014,21:33:38:42504
Address 17:8D0 920 980 Q  channel 42 adapted from 4 to 3  Tuesday,21,October,2014,21:34:24:42504
Address 17:8D0 920 980 Q  channel 43 adapted from 4 to 3  Tuesday,21,October,2014,21:34:34:42504
Address 17:8D0 920 980 Q  channel 2 adapted from 0 to 00000  Tuesday,21,October,2014,21:35:30:42504
SRILog:
Wednesday,27,August,2014,21:24:11:42504
VCDS Release 12.12.2:  SRI Reset -- Data version: 20140212
Control Module Part Number: 8D0 920 980 Q       Labels:  8D0-920-xxx-17.lbl
Component:B5-KOMBIINSTR. VDO D12 , Coding:00244
Operation: Please select an operation -- 1/2
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	0             	---
40       	Mileage since Service                             	miles x100	0             	---
41       	Time since Service                                	Days      	0             	---
42       	Min Mileage to Service                            	miles x1000	4             	---
43       	Max Mileage to Service                            	miles x1000	4             	---
44       	Max Time to Service                               	Days      	365           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	---       	---           	---
48       	Thermal Load                                      	---       	---           	---
Friday,19,September,2014,16:22:55:42504
VCDS Release 12.12.3:  SRI Reset -- Data version: 20140822
WAULT68E32A170886
Control Module Part Number: 8E0 920 950 H       Labels:  8E0-920-9xx-8E2.lbl
Component:KOMBI+WEGFAHRS. RB4 D26, Coding:03200
02       	Service Reminder Status                           	          	1             	---
40       	Mileage since Service                             	miles x100	409           	---
41       	Time since Service                                	Days      	1348          	---
42       	Min Mileage to Service                            	miles x1000	10            	---
43       	Max Mileage to Service                            	miles x1000	10            	---
46       	Total Consumption                                 	DIST x100 	1812          	---
49       	Min Time to Service                               	---       	---           	---
Friday,19,September,2014,16:23:16:42504
Operation: Service Reset -- 2/2
02       	Service Reminder Status                           	          	1             	0
The new values have been saved successfully, SRI reset complete!
Wednesday,08,October,2014,17:42:52:42504
Control Module Part Number: 8D0 919 035 G       Labels:  8D0-919-0xx-17.lbl
Component:B5-KOMBIINSTRUMENT  D08, Coding:00262
02       	Service Reminder Status                           	---       	---           	---
05       	Distance to Oil Change (OEL)                      	km x1000  	0             	---
06       	Distance to Inspection 1 (IN1)                    	km x1000  	0             	---
07       	Time to Inspection 1 (IN1)                        	Days x10  	0             	---
08       	Time to Inspection 2 (IN2)                        	Days x10  	0             	---
Wednesday,08,October,2014,17:43:04:42504
Operation: Service Reset (INSP) -- 2/2
02       	Service Reminder Status                           	---       	---           	1
Tuesday,21,October,2014,21:35:12:42504
42       	Min Mileage to Service                            	miles x1000	3             	---
43       	Max Mileage to Service                            	miles x1000	3             	---
Tuesday,21,October,2014,21:35:20:42504
Operation: General Service Reset -- 2/2
02       	Service Reminder Status                           	          	0             	0
That makes little sense to me. But you can always cheat it. Set it to some value that produces a longer interval than you want, then compensate for it by putting a non-zero value in 40 (Mileage since service) reduce the mileage remaining.
crazyquik22023
C?ID=206258
Ya it really doesn't make sense to me either. But ya thats a good idea to just add the value in group 40. I would ideally like it to just go back to 4500 miles when I do a service interval reset. But I'm just being too picky. Thanks for the help.
