Hi, I am looking for some advice on my current situation
As you can probably tell from the title, it's a worrying time and im looking for some reassurance from all you knowledgeable people out there
I will start by giving a background story to my woes;
-One day my car decided to throw up a 'Gearbox malfunction: You can continue to drive" (or similiar)
-It did this over and over, with about 2 minutes between each warning (not a set time)
-I then realised that the lights on the gear indicator were going on an off, eg. When driving, the D would illuminate as normal but then the light would go out. At this point, the car would give the gearbox malfunction message.
I must add i was around 200 miles from home on this day..
-I just kept driving and then out of nowhere, a red Gearbox malfunction warning came up and told me to park up immediately and place in P. Naturally, i continued driving due to being over 100 miles from my house
-20 miles or so later.. *CLUNK* and the gearbox seemed to momentarily go into neutral and back into gear... followed by Engine Management, TPMS, ABS, Steering fault and Coil light.
-At this point, the car was stuttering and didn't feel or sound healthy. I pulled up to a stop and the engine was racing to around 1200rpm and wanting to pull away. I stopped the car, let it rest and started it again.
-I only had the engine management light left on and i managed to drive 80 Miles home with no further issues, gearbox changing perfectly with no untoward noises etc.
I then took it on a 10 miles drive later that evening to test whether i would make it to work the following day.
-Doing mixed driving for the first 7-8 miles, the car drove as it should with no sign that anything had gone wrong.
-I then decided to drive it harder and that is when the gearbox was playing up - Foot to the floor, It seemed to have no power then out of nowhere all the power spiked at once.. then it lost the power... then spiked.. etc
Parked up and alternate route to work organised.
I drove it to Audi the following evening without any issues at all (5 miles or so). Booked it in to Audi and only today did they manage to get it in to the workshop.
I received a phonecall at 4pm telling me that they couldn't get the car to communicate with their system, but they would require 5 more hours of testing - £570 please
After swiftly refusing to pay that, I told them that i would collect the car after i finished work and would have a rethink about my options.
I arrive at Audi and i am handed my keys - no fees to be paid. I'm told that my car awaits me outside..
Outside i go, get in the car and it is in drive... Strange.
Ignition on, into park and push start... "Please engage N or P to start engine". NOT GOOD.
This is where i am left... there are no lights showing on the PRNDS gear indicator and the car thinks its out of park, hence i cant start or drive the car.
I wen't back to audi tonight (they had closed by this time) with my VCDS cable and laptop and have since scanned the car.
It would be much appreciated if you guys can have a look at the scan and tell me the likely cause of this issue!
Most modules do seem to be relating back to the lack of communication with the TCM or a fault in the powertrain bus.
Is there anything that Audi could have done when carrying out the basic diagnostic session that would cause there to be no communication with the TCM at all. Bearing in mind that i did drive the car into Audi, yet now i can't drive it away after a basic diagnostic session..
Thanks in advance,
Greg
Thanks in advance,
Greg
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 56 5F 62
72
VIN: WAUZZZ4G6CN033226 Mileage: 128836km-80054miles
02-Auto Trans -- Status: Cannot be reached 0100
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0004
Revision: 53H37---
Coding: 0A254012052601020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 2616FFDE786357172BB-8072
4718 - No Communication with Transmission Control Module
U0101 00 [039] - -
Mileage: 128836 km
Date: 2018.08.13
Time: 00:35:04
Engine speed: 0.00 /min
Coolant temperature: 23 °C
Intake air temperature: 18 °C
Voltage terminal 30: 12.060 V
Cruise Control System (CCS): status-Bits 0-7: 44
selected gear-Bits 0-7: 9
Address 02: Auto Trans
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 F HW: 4G0 907 379 F
Component: ESP PREMIUM H09 0250
Coding: 27A68701E465E180CB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004017
VCID: 34321596BEBF3587A5F-8060
0058 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Getriebe_01_Timeout]
Reset counter: 189
Mileage: 128836 km
Date: 2018.08.13
Time: 00:29:22
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: BB
Uz: 9C
0060 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Getriebe_03_Timeout]
Reset counter: 189
Mileage: 128836 km
Date: 2018.08.13
Time: 00:29:22
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: BE
Uz: 9C
0061 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_Getriebe_04_Timeout]
Reset counter: 189
Mileage: 128836 km
Date: 2018.08.13
Time: 00:29:22
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: C8
Uz: 9C
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Ldm_ApbFailureState]
Reset counter: 189
Mileage: 128836 km
Date: 2018.08.13
Time: 00:29:22
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 01
Uz: 9C
Part No SW: 4H0 907 064 BG HW: 4H0 907 064 BG
Component: BCM2 2.0 H31 0330
Coding: 01B83006000000000000
VCID: 6FB8DAFA9799565F98D-803A
Component: J764 ELV MLB H39 0046
Serial number: 2311000136281016
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 189
Mileage: 128836 km
Date: 2018.08.13
Time: 00:29:27
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 G HW: 4G0 820 043 G
Component: KLIMA 2 ZONEN H10 0056
Serial number: 21071100040895
Coding: 3621000820
ASAM Dataset: EV_AirCondiBasisUDS 002033
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 2310E6CA0B51A23F4C5-8076
0276 - Engine Off Timer Performance
P150A 00 [009] - -
Reset counter: 189
Mileage: 128836 km
Date: 2018.08.13
Time: 00:29:29
Voltage terminal 30: 12.21 V
Terminal 15 status: Terminal 15 on
Part No SW: 4H0 907 063 BA HW: 4H0 907 063 A
Component: BCM1 2.0 H12 0100
Revision: 12012002 Serial number: 00000000957887
Coding: 690000118034A7E00105008000005F5F4F9DC20827080101000004402000
VCID: 688AB1E6B2778167D97-803C
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 110627 H35 0051
Serial number: 110703235627
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11563052
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - LDS H07 0044
Serial number: 08 07 2011 00001002
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: 81088BB5000000000001
Reset counter: 189
Mileage: 128836 km
Date: 2018.08.13
Time: 00:32:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901120000244
Coding: 080305
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B203EAA93E1FAFF645-806E
12658704 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:39
12648720 - Databus
[Getriebesteuergerät - Getriebe_03 - kein Signal/keine Kommunikation]
Reset counter: 189
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:39
12648448 - Databus
[Motorsteuergerät - Motor_K_02 - kein Signal/keine Kommunikation]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:39
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG003CAM%
Coding: 30323436313330303537554A305234473053
VCID: 36362F9EA8C327979BB-8062
Serial number: 3575HRB405R0ISD66HSC
Serial number: 3585HRB405V0ISD6705L
Serial number: 3515JRB40570LCOQI1GX
Serial number: 3525JRB40630JE3GG8VK
Serial number: 3554VRB404P0JL5IIGFG
Serial number: 3564VRB404P0JL5I48I+
9 Faults Found:
1048576 - Databus
[CAN: 0x5F0 Dimmung_01 Timeout]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.08
Time: 07:57:35
1048832 - Databus
[CAN: 0x100 ESP_01 Timeout]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.08
Time: 07:57:35
1049088 - Databus
[CAN: 0x101 ESP_02 Timeout]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.08
Time: 07:57:35
1049344 - Databus
[CAN: 0x103 ESP_03 Timeout]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.08
Time: 07:57:35
1049600 - Databus
[CAN: 0x084 ESP_06 Timeout]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.08
Time: 07:57:35
1049856 - Databus
[CAN: 0x39C Gateway_05 Timeout]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.08
Time: 07:57:35
1050112 - Databus
[CAN: 0x086 LWI_01 Timeout]
Reset counter: 229
1051136 - Databus
U1121 00 [136] - Missing Message
[CAN: 0x6B4 VIN_01 Timeout]
Reset counter: 229
12583168 - Powertrain Databus
U0001 00 [008] - Unspecified Malfunction
[High Speed CAN Communication Bus defect]
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110722000552
Coding: 000034
VCID: 303A19864A2709A7C17-8064
Subsystem 1 - Part No SW: 4G0 951 528 E HW: 4G0 951 528 E
Component: E221 - MFL H07 0009
01312 - Powertrain Data Bus
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:38
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:38
02085 - Incorrect Control Module Installed
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:38
Voltage: 14.60 V
Hex Value: 0x0000
Steering Angle: -1.88°
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:38
Fault Status: 00101110
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:20:34
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 981 S HW: 4G8 920 981 S
Component: TDieGb H71 0375
Revision: 26181114 Serial number: 658230711592056
Coding: 23A7080003012600010000
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K.rod
VCID: 43D0464AEB11823F2C5-8016
16776962 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Airbag_01 keine Kommunikation]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:37
16776967 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[EPB_02 keine Kommunikation]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:37
16776971 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Motor_03 keine Kommunikation]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:37
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 D HW: 4G0 907 468
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000196832
Coding: 00CD077D00
ROD: EV_GatewUDS_AU57.rod
VCID: 313C1C8241AD00AFCE9-8064
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650991491
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11202000907011200181
4226 - No Communication with Transmission Control Module
U0101 00 [009] - -
Reset counter: 189
Mileage: 128836 km
Date: 2018.08.13
Time: 00:36:15
Voltage terminal 30: 12.0 V
Voltage terminal 15: 12.0 V
Control Module temperature: 27 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0004
Revision: -------- Serial number: EJ1BPA3200CUYW0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6B80CEEAA301AA7FB45-803E
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C16204001620002080002
VCID: 42DE434EF48B8B37273-8016
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:39
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:39
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0017120273
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323E138E44AB3BB7B73-8066
3158274 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Ausfall Botschaft "PDU_Motor_03"]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:38
valid
3158276 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Ausfall Botschaft "PDU_LWI_01"]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:38
valid
4205828 - Steering angle sensor
B1168 54 [008] - Missing Calibration / Basic Setting
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:04:54
valid
4208000 - Steering Angle Sensor
B1168 F1 [008] - Synchronization Failed
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:38
valid
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
[Lenkungsendanschläge nicht angelernt]
Fault Frequency: 57
Reset counter: 189
Mileage: 128837 km
Date: 2018.08.13
Time: 10:04:53
valid
Revision: 00002001 Serial number: 0154356756
Coding: 011B062200B9040083200804000100000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:40
Reset counter: 189
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:40
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:40
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:40
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:40
Fault Frequency: 30
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:20:46
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 41DC4C42F18D902F3E9-8014
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:39
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:39
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000111337
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0E0BEE6C7B73770F3-807E
7 Faults Found:
333568 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_TSK_05_MESSAGE_TIMEOUT]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.08
Time: 15:56:45
Voltage terminal 30: 13.3 V
Internal Fault ID: 49
Vehicle speed: 6 km/h
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: static
Status ParkingBrake left: Open
Status ParkingBrake right: Open
13644288 - Powertrain Databus
U0002 00 [008] - No Communications
[FC_CAN_GLOBAL_TIMEOUT]
Reset counter: 229
Voltage terminal 30: 11.0 V
Internal Fault ID: 58
Vehicle speed: 510 km/h
Terminal 15 status: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: Emergency running mode
13641472 - Powertrain Databus
[FC_CAN_BUSOFF]
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 09:27:12
Voltage terminal 30: 11.8 V
Internal Fault ID: 59
RWU: not active
DSD: not active
HTR: not active
ECD: not active
329728 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FC_GETRIEBE_03_MESSAGE_TIMEOUT]
Reset counter: 189
Mileage: 128837 km
Date: 2018.08.13
Time: 17:48:35
Voltage terminal 30: 11.6 V
Internal Fault ID: 94
Function light in parking brake button: On
Red operating lamp: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Status ParkingBrake left: Set
Status ParkingBrake right: Set
329984 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FC_GETRIEBE_04_MESSAGE_TIMEOUT]
Reset counter: 189
Mileage: 128837 km
Date: 2018.08.13
Time: 17:48:35
Internal Fault ID: 95
RWU: not active
DSD: not active
HTR: not active
ECD: not active
397568 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[FC_GETRIEBE_03_MESSAGE_COUNTER]
Fault Frequency: 136
Reset counter: 229
Mileage: 128836 km
Date: 2018.08.06
Time: 17:48:13
Voltage terminal 30: 14.6 V
Internal Fault ID: 118
Vehicle speed: 54 km/h
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: Dynamic
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Reset counter: 229
Voltage terminal 30: 14.7 V
Internal Fault ID: 188
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Part No SW: 4G0 035 056 C HW: 4G0 035 056
Component: Radio U STD H52 0079
Revision: AB001007 Serial number: 051GO0B7525212
Coding: 010003020100000001
VCID: 211CECC211CDB02F5E9-8074
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:45
Bin. Bits: 00000000 00001000
Part No SW: 4G0 035 670 C HW: 4G0 035 670
Component: H-BNT-EU H47 0406
Revision: -------- Serial number: 428F/0B7517482
Coding: 050101000003E1ED05008B3E00000003000001000000000000
VCID: 2310E6CA0BD1A23F4C5-8076
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB13017R9I
Subsystem 3 - Part No SW: 4G2 919 610 A HW: 4G2 919 610 A
Component: E380 BDT C7 H08 0203
Serial number: 90349KGL0001G
Component: CD-Database 3371
Reset counter: 229
Mileage: 128837 km
Date: 2018.08.13
Time: 10:03:49
Bin. Bits: 00010000 00000000
Bin. Bits: 00000000 00010000
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010814204001620002080002
VCID: 44D24556EE9F850715F-8010
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
End----------(Elapsed Time: 01:52, VBatt start/end: 12.1V/12.1V)-----------
