Adaptation after ATF change in rear differential
Filou96
France
C?ID=258992
Hello , I try to explain in english
I want to change ATF oil and axle oil in rear diff OBF/MKX type, Audi S5 V6 quattro
Workshop manuals said that I need to purge ATF line after refilling with ATF, VAS Audi has an option to purge ATF lines via ATF pump
I dont find same option in VCDS , or perhaps not with the same name, I have found
In output tests : all wheel drive pump ? pressure test or fill or bleed ?
And this in basic settings, did I have to do reset oil aging adaptation value with new ATF oil ? and/or reset transmission adaptation value ?
I also have option to do nothing , just refill new ATF , drive slowly the car for some km , there is an auto purge function for air bubbles in ATF , it is explain in Geott doc, and after some km , I check ATF level .
But perhaps it is necessary to do reset oil aging adaptation value
If somebody knows about this, thanks a lot
Regards
Philippe
Please post an Auto-Scan so people can see exactly what this car is made of.
Filou96
France
C?ID=258992
Hi , autoscan below, adress 22: AWD, J492 is concerned
Sunday,05,August,2018,10:18:13:14784
VCDS Version: 18.2.1.5
Data version: 20180518 DS287.2
VIN: WAUZZZ8T2CA047557   License Plate:
Mileage: 83590km-51940mi   Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 14 15 16 17 19 1B 22 36 3C 42 44 46 52
          53 56 5C 5F 69 A9
VIN: WAUZZZ8T2CA047557   Mileage: 83590km-51940miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CGWC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 B    HW: 4H0 907 551
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---
   Coding: 1A250034053601020000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551B 002005
   ROD: EV_ECM30TFS0214H0907551D_002.rod
   VCID: 356179B29478B6ECC7-8060
   Part No SW: 8K1 927 156 R    HW: 0B5 927 156 F
   Component: 0B5 30TFSIRdW H10 0007
   Revision: --H10---    Serial number: 0000000175
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 44871476CFA21F6440-8010
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 29AD4E
   Shop #: WSC 06324 000 00000
   VCID: 0407D4768722DF6400-8050
   Part No SW: 8K0 907 064 FE    HW: 8K0 907 064 FE
   Component: BCM2 2.0      H10 0602
   Coding: 01A00000000000000000
   VCID: 78FFB086CBEA8B841C-802C
   Subsystem 1 - Part No SW: 8T0 959 754 Q    HW: 8T0 959 754 Q
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0512000014697008
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000025359874
   Coding: 09037025002400001000
   VCID: 45810972CC98266C57-8010
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Component: KLIMA 3 ZONEN H04 0036
   Revision: C1000000    Serial number: 01130320120639
   Coding: 6622028080
   VCID: 336547AA920CA8DCE9-8066
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
   Component: BCM1 1.0      H14 0103
   Revision: 08014001    Serial number: 00000389593302
   Coding: 260000108034AFF0398140C300001D0D0F9CE38826090201000008000401070100000024000000
   Shop #: WSC 00872 572 96513
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 090312  H15 0070
   Serial number: SWF12030090007
   Coding: 00FD11
   Serial number: 20193277
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000503121065
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 19088B16000000000001
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 27021205070001
   Coding: 050181
   VCID: 3A7B6A8EB56659942A-806E
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD91PCV0
   Coding: 30513933363030303030554A304C38543053
   VCID: 489F0046F38A3B04AC-801C
   Serial number: 6334MSME6B614C78S
   Serial number: 6344MSME6B64242BK
   Serial number: 6352QSME1B0F1144E
   Serial number: 6362QSME3E0E0F48-
   Serial number: 63732SME210F105E.
   Serial number: 63832SME240F0C5C7
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Component: Lenks.Modul   H03 0004
   Revision: --------    Serial number: 90372LBT0000Z
   Coding: 0000F6
   VCID: 44871476C7A21F6440-8010
   Component: E221 - MFL  H03 0003
   Part No SW: 8T0 920 930 F    HW: 8T0 920 930 F
   Component: KOMBIINSTR.   H35 0540
   Revision: 00000000    Serial number: NSW57JN2D
   Coding: 036F0100F3010008050000
   Shop #: WSC 06325 123 12345
   VCID: 39797582B060528C23-806C
   Part No SW: 8R0 907 468 D    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H10 0025
   Revision: 1Z070014    Serial number: 1441Z122018005
   Coding: 00CF07FF00
   VCID: 408F1866D3BA034464-8014
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790219182
   Serial number: 12066002235021200181
   Part No SW: 8K0 907 144 H    HW: 8K0 907 144 H
   Component: DYNAMIKLENK.  H06 0680
   Revision: 52001005    Serial number: --------------
   Coding: 040100
   VCID: 346744B69702AFE4F0-8060
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 000103120001003
   VCID: 2F6D4BDA76248C3C8D-807A
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000025359020
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H16 0047
   Serial number: 0172056979
   Coding: 010311
   Shop #: WSC 22449 002 1048576
   VCID: 3E73669EA14E75B416-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H16 0047
   Serial number: 0172771029
   Coding: 010311
   Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
   Component: TSG FA        H09 0302
   Coding: 011C02224000120102
   VCID: 4D91315214E8DE2C9F-8018
   Part No SW: 8K0 909 144 Q    HW: 8K0 909 144 L
   Component: RCevo         H53 0702
   Revision: 00000002    Serial number: 0000462391
   Coding: 010001010001
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 3F8D1B9AA6447CBC1D-806A
   Revision: 00002001    Serial number: 0172690846
   Coding: 011E068000B9000083300036A0000000
   Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
   Component: TSG BF        H09 0302
   Coding: 011C02224400120102
   VCID: 4C973C56EFF2D72488-8018
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 30000000029410
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 36637EBE897EBDF4CE-8062
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 230CZ0C7547529
   Coding: 010003020100000001
   VCID: 285FA0C65BCADB044C-807C
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217     HW: 4E0 907 217 C
   Component: J759 HC             0020
   Revision: 00H08003    Serial number: 3002123110000A
   Coding: 0031003
   VCID: 76E3BEBE01FEFDF40E-8022
   Part No SW: 8R1 035 670 K    HW: 8R1 035 670
   Component: H-BNT-EU      H43 0941
   Revision: --------    Serial number: 067C+0C7509646
   Coding: 040100020206A1ED5D80EB5E00000403040000000000000000
   VCID: 3B756F8ABA5C609C31-806E
   Subsystem 1 - Part No: 8R0 060 884 ED
   Component: EUR 2017  2402
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130C 0CS122550
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001094684
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000146620353
   Coding: 0100000000000000
   VCID: 36637EBE817EBDF4CE-8062
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 120215200690
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72EB82AEA596E1D422-8026
End-------------------------(Elapsed Time: 05:05)--------------------------
I imagine the procedure involves the use of the Output Tests:
  • Fill pressure lines
  • Bleed pressure lines
But I have not seen an actual procedure, and personally, I would not run those without a procedure to follow.
embmwtech
C?ID=255258
I am also trying to bleed the system on a 2012 S5 4.2 sport diff and can not get the output tests to initiate. It would be nice to know what parameters it was looking for.
