Audi A3 8V Airbags error - after swap gateway and central elect.
XPepino
Czech Republic
C?ID=91614
Hello
i swaped gateway due ACC and Central elect. due heated seats.
Now this airbag have errors (i also swapped panel with parking button).
What i have to do ?
Here is scan:
Monday,06,August,2018,08:32:22:12448
VCDS Version: 18.7.1.1 (x64)  HEX-NET CB: 0.4427.4
Data version: 20180731 DS293.0
VIN: WAUZZZ8V4DA016040   License Plate:
Mileage: 69294km-43057mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V4DA016040   Mileage: 69294km-43057miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H21 4793
   Revision: 84H21---
   Coding: 0A250012030401092000
   Shop #: WSC 45343 001 104857
   ASAM Dataset: EV_ECM16TDI01104L906021N 002006
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 302CE44E6B13F3CAA4-8064
   Part No SW: 0CW 300 047 R    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5210
   Revision: 00043014    Serial number: CU501210105926
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 4AD896A6ED8FA91A8A-801E
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 10F162A220210A720177060401C32508460450806080A4F20059000805
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008.rod
   VCID: 7DB20D7AECC1CEA27F-8028
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000942221
   Coding: 00000104002000011000000000001100
   Shop #: WSC 06385 790 00016
   VCID: 3326EB429A05C8D2D9-8066
   Serial number: C2580456000000000001
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011415001096
   Coding: 04001846C20100DD03044000001407A80016000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 004C748E9B33A34A14-8054
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 120916  041 0580
   Serial number:         120928192046
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8V0 941 531 N    HW: 8V0 941 531 N
   Serial number: 07 08 2012  00000364
   Subsystem 3 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20188473
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert->Keine Anzeige]
                    Reset counter: 94
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:44
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0048
   Revision: --------    Serial number: 39231518200419
   Coding: 0001050011
   Shop #: WSC 03569 010 02200
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_002_VW27.rod
   VCID: 3A38C666BD6F399A1A-806E
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H03 0304
   Serial number: 20061376510137
   Coding: 000C1301FE033B
   Shop #: WSC 66666 123 28888
   VCID: 383CDC6E83632B8AEC-806C
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 94
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:44
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 14.4 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s˛
1807 - No Enable Indentifications Active
          B2032 00 [009] -  -
          [FAULT_SWAP_NO_FSID_ACTIVE]
                    Reset counter: 94
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:44
                    Voltage terminal 15: 14.3 V
   Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
   Component: AirbagVW20    009 0349
   Serial number: 003GER00CZN1
   Coding: 98CCC0000C0000005C540000004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 49DAA9AAE889A20283-801C
   Subsystem 1 - Part No SW: -----------    HW: 480 001 210 12
   Serial number: 3576700000003561FB0Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 210 12
   Serial number: 358670000005F561FB01
   Subsystem 3 - Part No SW: -----------    HW: 480 401 610 12
   Serial number: 3516502A70D63B34B105
   Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
   Serial number: 3526502AD0D19C322136
   Subsystem 5 - Part No SW: -----------    HW: 480 401 109 12
   Serial number: 3556502A10CD5EB570CU
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 210 12
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502B30CD5EB591AX
   Subsystem 7 - Part No SW: -----------    HW: 480 401 109 12
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502A70CD5EB0627R
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 210 12
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C70D0E4721260
9442816 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 00 [137] -  -
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:46
10487296 - Control Module Does Not Match Vehicle
          B2006 00 [137] -  -
          [ECU does not fit to vehicle configuration]
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:46
   Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
   Revision: --------    Serial number: 1710120003012N
   Coding: E408
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 77BE1F52CEFDE4F225-8022
   Part No SW: 8V0 920 870 B    HW: 8V0 920 870 B
   Component: KOMBI         H23 0490
   Coding: 038402082690000808008800000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 94
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:44
   Part No SW: 5Q0 907 530 C    HW: 5Q0 907 530 C
   Component: GW MQB High   109 1072
   Revision: --------    Serial number: 0000060099
   Coding: 030100F40B0876005B0002481C0B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 005010
   ROD: EV_GatewLear_005.rod
   VCID: 312AE14A6019FAC2AB-8064
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 05 10 2012  C0120978
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 8435508401
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393 A
   Component: TSG FS        H12 0006
   Serial number: 14081200010634
   Coding: 005F0E204000040100001002
   VCID: 3D32CD7AAC410EA23F-8068
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 83
   ROD: EV_SteerAssisMQB_008.rod
16387 - Steering End Stops Not Learned
          C10AC F0 [009] - Unknown Error Elaboration
          [Endanschläge nicht korrekt eingelernt Beide Endanschläge nicht eingelernt]
                    Reset counter: 94
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:44
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.25 V
                    Temperature: 33.0 °C
                    KFC: 40
                    KFA: 00 03
                    Environmental conditions: 5F
                    Rotorlagesensorspannung AMR Sinus: 0.676 V
                    Rotorlagesensorspannung AMR Kosinus: 9.657 V
                    Rotorlagesensorspannung AMR Sinus 2: 0.779 V
                    Rotorlagesensorspannung AMR Cosinus 2: 10.513 V
                    Rotorlagesensorspannung Hall 1: 0.0 V
                    Rotorlagesensorspannung Hall 2: 0.0 V
                    Aktueller Sinus-Offset für ASIC: 0.1 mV
                    Aktueller Cosinus-Offset für ASIC: 0.1 mV
                    aktuelle Sinusverstärkung für ASIC: 0.161
23552 - Databus
          [PLA_01 Botschaft - CAN-Timeout]
                    Reset counter: 94
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:48
                    Motor status: 01
                    KFC: 5C
                    KFA: 00 00
                    uAdSensI_U5VFiltered_xdu16: 5.07820 V
                    uioUdNotFilt_xdu16: 14.52 V
                    uAdSensI_SwitchedKl30_xdu16: 14.51 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392 A
   Component: TSG BFS       H12 0006
   Serial number: 26091200010525
   Coding: 005F06204000040100001002
   VCID: 3C34C07EB75B07AA08-8068
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-ENT1.clb
   Part No SW: 8V0 035 889 A    HW: 8V0 035 889
   Component: MU-E--ER      160 0107
   Revision: --------    Serial number: 000031092915000
   Coding: 01730000FF00000010110001000A0000000001040100010000
   ASAM Dataset: EV_MUEnt4CCONT 004052
   ROD: EV_MUEnt4CCONT.rod
   VCID: 40CCB48EDBB3634A54-8014
   Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H47 0013
   Serial number: AUZ8Z9CG20017H
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614     HW: 8V0 919 614
   Component: ControlUnit_B  H33 0037
   Serial number: C1000006061200010149
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 94
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:50
                    Voltage terminal 30: 14.3 V
                    BAP-BAP_Function_ID: 02
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 94
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:47
                    Voltage terminal 30: 14.4 V
downtime
Finland
C?ID=280813
Swap back the original panel. The airbag light is on that panel and that is one part of the airbag system.
After swapping back the original panel, clear all DTCs and check if the airbag error is gone.
Then regarding ACC. You do see this on your autoscan :
          B2032 00 [009] -  -
                    Reset counter: 94
                    Mileage: 69294 km
                    Date: 2018.08.04
                    Time: 09:33:44
You do know that you cannot get the codes at least any official way?
XPepino
Czech Republic
C?ID=91614
Ok, i will try!
Let you know!
And yes, i know it is SWAP function, but someone here in forum can activate it... I am waiting for him now.
downtime
Finland
C?ID=280813
Ok, i will try!
Let you know!
I would not count on it.
There's two ways that I know of :
1. Needs physical alteration of ACC radar boot loader and certain type of ACC radar. 100% reliable as long as you don't update the radar software. This is how it was done on my car a year ago and everything still works as from factory and no problems after service either.
2. Fake FSID codes and some way to online activate them to the car. Don't know in detail how this happens but there's one Chinese guy who's also advertising remote activation of MQB functions in Facebook, but I know that VAG is already done some things to prevent this. So not sure how long this will work and what happens when you take the car in for a service. Does it detect from factory that the car should not have these codes and it wipes them from gateway?
XPepino
Czech Republic
C?ID=91614
Hello
I swapped panel and it works !!! Thank you!
About SWAP:
I mean 2. - it makes one Chinese Guy.
I have there Drive select but after i swapped gateway there is it not available :-/
I need only add Cruise Control activation, but is very hard to find him.
Do you know how to activate remotely ?
downtime
Finland
C?ID=280813
Good to hear that. Probably the panel you bought is not correct for your car. The airbag light, as I mentioned, is part of safety systems and if it does not match the one in the car, it gives that error.
You will get drive select back by going back to the dealer who did the component protection removal and ask them to return the Feature enablement codes to the gateway. After that drive select will work again. They clearly did not do it even it's in the procedure when swapping gateway. You're not the first one to miss features when swapping gateway, there's another thread about this same thing and all was well after dealer returned the features back. They know how to do it. There's even a guided function for that on their diagnostic software.
And about the ACC activation. Let me explain this to you, I did this in other thread but I try to explain it here as well.
You CANNOT just add the activation code to the car. It does not work that way. All the FeC's, codes that enable certain features in the modules, are installed to the car during manufacturing phase. The codes are stored to factory database and are tied against your cars VIN number.
Now when you add a module that needs a FeC, like ACC radar. The module makes a challenge check to gateway, which works as a master, to verify that the FeC is activated. If it is not, the challenge fails and the module is immediately disconnected. The only exception is media system which AFAIK, internally checks the codes. It doesn't check them against gateway.
Normal cruise control you can retrofit IF you buy the package from manufacturer aftersales. The reason is that the package comes with an one-use enablement code, called also as SWaP (SoftWare As a Product) that will enable the FeC for the cruise control on the target car and at the same time it will store the FeC to factory database, again tied to the target car's VIN number. This enablement needs to be done at dealers as they have online connection to factory.
ACC is not sold as retrofit or aftermarket package, so you cannot get the SWaP codes for it. At least not officially.
How this Chinese guy does the enablement, I do not know. What I do know that VAG is aware of this and they've already put some countermeasures in to battle this. I do not know what these countermeasures are, so don't ask :)
Again, what I know that only way to surely have working ACC is the hacked radar. You can join MQB coding group in Facebook and ask help from there about ACC retrofit. They can help you on this one.
Like mentioned in the other thread as well, VAG is making our lives much more difficult on retrofit's with the introduction of SWaP. However, they could utilize it a lot better in my opinion by offering more aftermarket packages like ACC. The ACC could easily be sold as a retrofit part. Radar, stalk set, depending on equipment ABS block, new ABS sensors and possibly new instrument cluster. Of course pricey, but hey, that's life :) But it would provide more money to the company's back pocket because there would always be people who would buy this package.
XPepino
Czech Republic
C?ID=91614
Thank you for explanation!
It is very interesting.
Do you mean MQB-Coding & Retrofit ?
Regards
martinlop
Argentina
C?ID=303160
One little "electrical" comment from my side.
if your new panel has no light indicator (led) for "passenger airbag off", then you can simply "cheat" it with a led between the correct pinouts of the T20 connector of the new panel.
connecting an orange led, and hiding it inside the hole would be an idea, that can cheat the system, making it think system is working as normal.
8v0925301-new-jpg.127597
XPepino
Czech Republic
C?ID=91614
Hello guys
i have not reply from this Chinese Guy about enable ACC radar - after i tried more than 1 month to contact him :-/
Do you have any other solution ?
MQB-Coding & Retrofit did not reply me on 2 messages on facebook and there is no other contact email.
I have no Cruise Control installed originaly in my car :-/
Thank you!
myounus
Northwest UK
C?ID=321059
Your only solution is the Facebook group. Keep trying
XPepino
Czech Republic
C?ID=91614
So, now i swapped rear speed ESP/ABS sensors (i see i bought non original :-( ) and ABS was with errors. Then i tried to repair it and because it was late, i click for clear all adaptions and now i have tons of error in every unit. My stupidity :-(
Is there coding needed if i swap speed sensors in ABS ? In VCDS is not txt for it :-(
Also i tried made basic adaption and nothing worked.
Did someone tried basic adaption of new ABS Golf 7 or A3 8V ?
Here are errors:
Tuesday,09,October,2018,03:05:41:12448
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
Mileage: 69311km-43067mi   Repair Order:
VIN: WAUZZZ8V4DA016040   Mileage: 69311km-43067miles
   Revision: 84H21---
   VCID: 302CE44E6B13F3CA65-8064
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:46
                    Engine speed: 980.00 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 83 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 13.460 V
                    Longitudinal acceleration: raw value: 32.767 m/s˛
                    Vehicle inclination acceleration angle: raw value: -12.557 m/s˛
                    Status: incline angle-Bits 0-7: 1
                    Longitudinal acceleration: 0.000 m/s˛
                    Longitudinal acceleration sensor: status-Bits 0-7: 1
                    Vehicle lateral acceleration: raw value: 0.00 g
                    Vehicle lateral acceleration: 0.00 g
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4AD896A6ED8FA91A4B-801E
10759 - Implausible Data Received from ABS Control Module
          U0415 00 [011] - -
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:47
                    Engine speed: 5382.00 /min
                    Engine torque: -96 Nm
                    Vehicle speed: 65 km/h
                    Control Module temperature: 74 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_4
                    Driving position: N
                    Accelerator position: 0.0 %
                    DTC memory status: 32768
   VCID: 7DB20D7AECC1CEA2BE-8028
15 Faults Found:
0071 - Rear Left Wheel Speed Sensor
          C101C 4A [137] - Incorrect component(s) installed
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:47
0087 - Rear Right Wheel Speed Sensor
          C101D 4A [137] - Incorrect component(s) installed
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:45
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:45
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:45
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:45
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:45
0338 - ABS/ESP Control Module
          U10C5 00 [137] - No or Incorrect Basic Setting
          [inlet valve calibration data missing]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:45
8299 - Databus
          [FCAN: Anhaenger_01_alt veraltet bit is set]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:45
32821 - Hydraulic Assistance Not Possible
          C1100 F0 [009] - Unknown Error Elaboration
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:59:37
32950 - Brake pad replacement mode active
          C1011 00 [008] -  -
                    Reset counter: 100
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 14:01:18
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 139
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:59:36
32976 - Function Restriction
          C10C2 F0 [009] - Emergency Brakes not Available
          [IPB-Miscellaneous: DDBF not available]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:53
32992 - Control Module for Electric Parking Brake
          C10E2 F0 [137] - RPM Sensor Implausble Signal
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:47
32994 - Control Module for Electric Parking Brake
          C10E2 F0 [009] - RPM Sensor Implausble Signal
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:47
33000 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
          [IPB-Sensor: Longitudinal acceleration sensor failure]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:45
   VCID: 3326EB429A05C8D218-8066
   VCID: 004C748E9B33A34AD5-8054
   Coding: 0A47F7
16650 - Bulb 2 for Rear Left Turn Signal
          B12CE 15 [009] - Open or Short to Plus
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:54:30
16906 - Bulb 2 for Rear Right Turn Signal
          B12CF 15 [009] - Open or Short to Plus
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:54:30
          U1014 00 [009] - -
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
   Coding: 0001050011
   VCID: 3A38C666BD6F399ADB-806E
13637426 - Databus
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
   VCID: 383CDC6E83632B8A2D-806C
9 Faults Found:
1070 - Databus
          [FAULT_CIS_AXV_FAIL]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 13.2 V
1067 - Brake Temperature
          C10DF 00 [009] -  -
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
1058 - Databus
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
1544 - Function restriction
          C10C2 00 [008] -  -
          [FAULT_REFERENCE_VELOCITY_NOT_AVAILABLE]
                    Reset counter: 139
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:45
                    Vehicle speed: 0.77 m/s
                    Acceleration: 2.15 m/s˛
          B2032 00 [009] -  -
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
1083 - Databus
          [FAULT_CIS_WHEEL_DIR_INVALID]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
1118 - Databus
          [FAULT_CIS_WHEEL_PULSE_FAIL]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
1081 - Databus
          [FAULT_CIS_WHEEL_RPM_FAIL]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
   VCID: 49DAA9AAE889A20242-801C
          B13BC F2 [136] - No function
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
   Coding: E408
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 77BE1F52CEFDE4F2E4-8022
16776980 - Databus
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
   VCID: 312AE14A6019FAC26A-8064
   VCID: 3D32CD7AAC410EA2FE-8068
   Coding: 83
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
                    Motor status: 02
                    Supply voltage: 13.25 V
                    Temperature: 35.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 13.31 V
                    uAdSensI_SwitchedKl30_xdu16: 13.31 V
20228 - Databus
          [ESP_19 Botschaft - SNA-Check]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
                    Motor status: 02
                    KFC: 4F
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 13.19 V
                    uAdSensI_SwitchedKl30_xdu16: 13.19 V
19716 - Databus
          [ESP_10 Botschaft - SNA-Check]
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:44
                    Motor status: 02
                    KFC: 4D
                    KFA: 00 04
23552 - Databus
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:46
                    Motor status: 02
                    KFC: 5C
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 13.34 V
                    uAdSensI_SwitchedKl30_xdu16: 13.34 V
   VCID: 3C34C07EB75B07AAC9-8068
   VCID: 40CCB48EDBB3634A95-8014
          U1111 00 [009] - -
                    Reset counter: 99
                    Mileage: 69311 km
                    Date: 2018.10.06
                    Time: 13:50:48
                    Voltage terminal 30: 13.2 V
End----------(Elapsed Time: 01:14, VBatt start/end: 13.3V/13.3V)-----------
downtime
Finland
C?ID=280813
The abs sensors need coding change to abs. One moment I’ll whip it up for you
XPepino
Czech Republic
C?ID=91614
Great !!! Where you got these info ? I have no label in VCDS nor Vag Can Pro :-(
downtime
Finland
C?ID=280813
Ok, two options to try.
Byte 26 set to hex 50 :
10F162A220210A720177060401C32508460450806080A4F20059500805
Or if that gives any errors after a while, then byte 26 set to hex F0 :
10F162A220210A720177060401C32508460450806080A4F20059F00805
I'm not really sure what exactly is the difference. In my case hex value 50 gave an error to ABS module every time the car was driven over 80km/h. F0 works perfectly.
So try 50 first, if that gives the same error after driving over 80km/h then change the byte 26 value to F0.
And there is one label file for 3Q0 AB pump which is totally unofficial. You can find it by googling, but if you don't know what your doing exactly, don't use it. There's a risk that you'll screw the ABS coding completely.
XPepino
Czech Republic
C?ID=91614
So, Audi service guy told me, that coding help for these speed sensors error. He is going to enable Cruise Control SWAP code for use with ACC in gateway. Did you have to change some coding in ABS for ACC ?
darkchina811
ITALY
C?ID=333184
when I upgraded from Park Pilot 8K to Park Assist 12K I also had to replace rear wheel sensors. there was indeed some ABS coding involved. I don't know if it's the same, if you need that info dig up the instructions from the famous spanish guy.
downtime
Finland
C?ID=280813
Yes, ACC needs a coding change to ABS. I can modify the coding for you.
But tell me, how the Audi service is going to enable the SWAP code for ACC? They can't do it. The only way for them to do it is to do it through factory database and that will reject it as your car never had ACC.
There are options to mock against the factory database to get the swap codes to the car, but that will need some trickery. Also if it's an authorized Audi service, the guy is risking it for himself as well.
Which one of the ABS coding changes worked for you? value 50 or value F0? I need to know this so I can use the correct base code for ACC changes.
downtime
Finland
C?ID=280813
ABS coding with ACC and emergency brake enabled with byte 26 value 50 :
10F162A220210A720177060401C32508460450806080A4F21659500805
and with byte 26 value F0 :
10F162A220210A720177060401C32508460450806080A4F21659F00805
Choose which one you need.
Byte 24 controls ACC amongst other things. Bit 1,2 and 3 are ACC settings. Those are selected depending what PR code ACC you can set. 8T3, 8T5 or 8T8. Bit 4 controls AWV = Anhaltewegverkürzung or more familiar Stopping distance reduction or emergency automatic brake.
In this coding the byte 24 value is set to hex 16, means that bit 1 and 2 and 4 enabled. 1 and 2 enabled is follow-to-stop/stop-and-go ACC, 8T3/8T8. The other combinations I can't remember, I would need to check.
