2012 NMS Passat Discover Media/MIB2 retrofit attempt and issues
mmgc123
C?ID=201092
Hello Everyone! I recently took on a retrofitting project to get an MIB2 unit into my passat. I've been running into a couple issues and I hope you all can help me out in some way. I followed the necessary steps to ensure all new components would work, including upgrading my canbus gateway from 7N0 907 530 P to 7N0 907 530 BD as I read that I would not be able to access the 5F module to code the MIB2 head unit with the old one. Upon hooking everything up, I lost functioning of my sunroof and dashboard analog clock. I contacted the folks at Ross-tech and they read through my scans and saw that 4F was no longer able to be accessed with the new gateway. They inferred that this could be the reason my sunroof stopped working. Now, as far as I'm aware, I need a gateway ending is at least -AN or above to have access to 5F. I installed a -BD version and lost access to 4F. Any recommendations on whether I should try an -AN gateway? Will I still have access to bother 5F and 4F? I am seeing plenty of -AP models for sale for a reasonable price, but the folks at Ross-Tech indicated that per my VIN, 7N0-907-530-AN-Z00 is the version that is listed as a part number for my car. Any reason a -AP unit wouldn't work? I have attached scans before the swap and right after the swap for reference. The head unit works great, except for an issue where the RVC screen does not activate on reverse. It happens almost everyday and I have to restart the unit before the image returns when I place the car in reverse. I have an OEM retrofitted camera installed with an RGB-composite signal converter. I'll be working on fixing that as soon as I figure out what is wrong with the gateway. Thoughts? Thanks! :D
Thursday,19,July,2018,17:46:11:64180
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 46 4C 4F 52 56 62 72
          77
01-Engine -- Status: Sporadic communication error 1000
4C-Tire Pressure II -- Status: Not registered 0001
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 DD    HW: 07K 907 309 A
   Component: 2,5l R5/4V       01 5685
   Revision: T6H02---    Serial number:
   Coding: 0000075
   Shop #: WSC 56460 002 1048576
   VCID: 73CB3A0B124F9CDC2A-8026
   Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
   Component: AQ 250 6F           1916
   Revision: 00H90000    Serial number:
   Coding: 0000328
   Shop #: WSC 09003 957 00200
   VCID: 02256FCF5DF5A55431-8056
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: C54BC0F5492808FAA31003EB921C1061A61C00
   VCID: 7CD91137FF11D3A47B-8028
   Part No SW: 561 907 044 H    HW: 561 907 044 H
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 0010001002
   VCID: 1C1931B7175173A4DB-8048
   Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
   Component: BCM PQ35 B+   021 0064
   Revision: BH021001
   Coding: 6F200EBBF02B28D48888000116000CE800F5000040A00D60858460040C70
   VCID: 43ABAACBC26F6C5C7A-8016
   Component: RLS 040112 05  54  0403
   Coding: 1030BB
                    Fault Status: 01101100
                    Reset counter: 166
                        Term 15 Off
                    Voltage: 12.55 V
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 82
                    Mileage: 54753 km
                    Date: 2016.02.01
                    Time: 00:00:04
                        Term 15 Off
                    Voltage: 12.25 V
                    Fault Status: 00101010
                    Reset counter: 246
                    Mileage: 127896 km
                    Date: 2012.11.27
                    Time: 13:35:21
                    Voltage: 13.95 V
02742 - Bulb for Brake/Turn Signal Light; Left
                    Reset counter: 248
                    Mileage: 127935 km
                    Date: 2012.11.27
                    Time: 17:26:25
                    Voltage: 14.00 V
02743 - Bulb for Brake/Turn Signal Light; Right
                    Reset counter: 6
                    Mileage: 128873 km
                    Date: 2012.12.06
                    Time: 13:23:02
                    Voltage: 13.65 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM01ETAU
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FC3367BB667B83CCE-803A
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000BB8X0X
   Coding: 303044
   Serial number: 3572MSME52072265ZZZM
   Serial number: 3582MSME75522165ZZZR
   Serial number: 3516KSME25622317ZZZH
   Serial number: 3526KSME06404216ZZZD
   Serial number: 3556LSME17037B14ZZZS
   Serial number: 3566LSME3A567E14ZZZ2
   Part No SW: 1K5 953 501 Q    HW: 5K0 953 569 H
   Revision: FF010040    Serial number: 20120109101260
   Coding: 0982100000
   VCID: 3957C823B8A3268C20-806C
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 B    HW: 561 920 970 B
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 191728A31863068CC0-804C
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 07021201290792
   Coding: 461000
   VCID: 3D5FDC33A48B1AAC0C-8068
                    Fault Status: 00110100
                    Reset counter: 246
                    Mileage: 127896 km
                    Date: 2012.11.27
                    Time: 12:51:41
02649 - Digital Radio Tuner
                    Fault Status: 01110100
                    Reset counter: 82
                    Mileage: 54753 km
                    Date: 2016.02.01
                    Time: 16:34:06
            000 -  -
                    Mileage: 57007 km
                    Date: 2016.04.24
                    Time: 18:36:55
03753 - Control Module for Microphone
                    Reset counter: 82
                    Mileage: 54753 km
                    Date: 2016.02.01
                    Time: 16:34:06
   Component: IMMO          H07 0507
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AF5276F8D855D1499-803E
   Revision: A1001003    Serial number: 7661542874
   Coding: 020000
   VCID: 297718634003960C50-807C
   Part No SW: 3C0 035 684 J    HW: 3C8 035 684 E
   Component: RNS-MID       H65 4366
   Revision: AB001001    Serial number: VWZ6Z7M7113033
   Coding: 06000042010000A4000B
   VCID: 2A75E76F45059D1459-807E
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V10  8246
00857 - CD Changer Unit (R41)
                    Reset counter: 221
                    Mileage: 54800 km
            000 -  -
                    Reset counter: 221
                    Mileage: 69552 km
            000 -  -
                    Reset counter: 221
                    Mileage: 123240 km
01523 - Microphone for Telephone (R38)
                    Reset counter: 221
                    Mileage: 54801 km
                    Date: 2016.02.04
                    Time: 09:52:45
   Revision: 13110009    Serial number: 0003989481
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5B9B72AB52DF349C12-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Component: EZE_2         H40 1623
   Coding: 01030108
   VCID: 6FC3367BBE67B83CCE-803A
   Serial number: 53388786011133302086
   Coding: 181100
   Component: Analoguhr  008 0004
   Revision: 15110009    Serial number: 0003975172
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5C9971B757D133A41B-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [008] - Electrical Failure
                    Fault Frequency: 35
                    Reset counter: 6
                    Mileage: 127896 km
                    Date: 2018.07.07
                    Time: 13:23:49
Address 56: Radio
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661254495
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 27731E5B5E17A07C46-8072
End-------------------------(Elapsed Time: 02:07)--------------------------
Monday,23,July,2018,18:16:52:64180
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 46 4C 4F 52 56 5F 62
          72 77
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
5F-Information Electr. -- Status: Not registered 0011
77-Telephone -- Status: Not registered 1001
   Coding: 0000075
   Coding: 0000328
   Revision: 00H31001
   Revision: 00001001
   Coding: 0010001002
   Revision: BH021001
   Coding: 6F200EBBF02B28D48008000116000CE800F5000040A00D60858460040C70
   Coding: 1030BB
   Coding: 00003548
   Coding: 303044
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [137] - Open or Short to Ground
                    Mileage: 129155 km
                    Date: 2018.07.23
                    Time: 16:52:17
   Coding: 0982100000
   Coding: E20000
   Coding: 231E01
   Part No SW: 7N0 907 530 BD    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1673
   Revision:   H57       Serial number: 120116F1001904
   Coding: 351000
   VCID: 73CB3A0BD24F9CDC2A-8026
                    Reset counter: 41
                    Mileage: 129127 km
                    Date: 2012.12.10
                    Time: 08:28:18
01304 - Radio
                    Reset counter: 41
                    Mileage: 129127 km
                    Date: 2012.12.10
                    Time: 08:28:18
                    Reset counter: 41
                    Mileage: 129155 km
                    Date: 2012.12.13
                    Time: 16:39:36
            000 -  -
                    Fault Frequency: 41
                    Mileage: 129127 km
                    Date: 2012.12.09
                    Time: 18:30:35
02103 - Control Module 2 for Vehicle Electrical System (J520)
                    Reset counter: 0
                    Mileage: 129127 km
                    Date: 2012.12.09
                    Time: 19:29:55
   Coding: 020000
   Coding: 0404F5
   Slave Driver:
   Coding: 800000
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
                    Fault Frequency: 36
                    Mileage: 127896 km
                    Date: 2018.07.07
                    Time: 13:23:49
Address 56: Radio
   Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
   Component: MU-S-NS-US    H31 0359
   Serial number: VWZAZ2T1004614
   Coding: 02630102AA00000051220003001808009F0100D400200105C6
   Shop #: WSC 00066 790 00011
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 246909572F214B6463-8070
   Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
22 Faults Found:
1537 - Supply voltage
                    Reset counter: 144
                    Mileage: 9376 km
                    Date: 2012.10.19
                    Time: 04:10:08
                    Voltage terminal 30: 9.1 V
          U1400 00 [008] - -
                    Reset counter: 144
                    Mileage: 9376 km
                    Date: 2012.10.19
                    Time: 04:19:52
                    Voltage terminal 30: 8.5 V
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 227
                    Mileage: 6985 km
                    Date: 2012.08.05
                    Time: 08:17:50
                    Voltage terminal 30: 14.0 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: Not available
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: FF
0542 - Audio signal output 1
          B14F1 13 [009] - Open Circuit
                    Reset counter: 0
                    Voltage terminal 30: 12.6 V
0546 - Audio signal output 2
          B14F2 13 [009] - Open Circuit
                    Reset counter: 0
0553 - Audio signal output 3
          B14F3 01 [009] - Electrical Failure
                    Reset counter: 0
0554 - Audio signal output 4
          B14F4 13 [009] - Open Circuit
                    Reset counter: 0
0009 - Antenna for Satelite Radio
          B10F4 13 [008] - Open Circuit
                    Voltage terminal 30: 12.8 V
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
2565 - GPS Antenna
          B1054 13 [008] - Open Circuit
                    Voltage terminal 30: 12.7 V
6720 - Rear View Camera
          B1102 31 [009] - No Signal
                    Reset counter: 1
                    Mileage: 129155 km
                    Date: 2018.07.23
                    Time: 16:57:47
                    Voltage terminal 30: 13.6 V
1564 - Microphone 1
          B129B 13 [008] - Open Circuit
6700 - Databus
                    Network diagnosis-Status: Enabled
6702 - Databus
6705 - Databus
                    Voltage terminal 30: 11.5 V
6706 - Databus
6714 - Databus
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 0
                    BAP-BAP_Function_ID: 02
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 0
0001 - Antenna 1 for Radio
          B1119 13 [008] - Open Circuit
                    Mileage: 9376 km
                    Date: 2012.10.15
                    Time: 01:38:25
                    Voltage terminal 30: 13.0 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
0003 - Antenna 2 for radio
          B111A 13 [008] - Open Circuit
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
                    Interface for external media: status-Status: Open circuit
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 0
End-------------------------(Elapsed Time: 02:06)--------------------------
rhinopower
C?ID=58979
Just use the original gateway, and to access the discover media put 5F in the bottom left box to access it on vcds.
siLc
Tallinn, Estonia
C?ID=330192
I think 7N0907530AN in its original form does not bring the support for 5F but it is the version that can be software upgraded to at least 7N0907530BC (and including BG, BL) to gain 5F support. Just buy the BC version and you should be good to go.
If you have Discover Media, you can remove the MDI box (address 2E) and Bluetooth (address 77). I'm unsure if MDI messes with 5F but in my experience the Bluetooth does.
rhinopower
C?ID=58979
I’m still using original 3c0 gateway no issue. You don’t need to change to a gateway that supports 5F
mmgc123
C?ID=201092
I'll give putting the old gateway back into the car and see if that helps return 4F functionality. I currently have a -BD gateway installed as I mentioned before. I'm unsure why I would lose 4F access with that version in the first place. I was under the impression that anything above -BC would work in my car...maybe -BD is different than BC/BG/BL etc.
mmgc123
C?ID=201092
UPDATE: changed back to the old gateway and everything that was lost is working again. I can confirm that I can access the 5F module by searching for it in the bottom left area. Still having the issue with the RVC. Will change it to a composite aftermarket one sometime this week to see if that resolves the issue. Thanks
golfi_vend
Tartu, Estonia
C?ID=195131
Different CAN-gw have different connections. There are LIN1, LIN2 and Can-Extended. There also might be more. Be safe and use one with HW:530AN(SW: AN,BC BG BL).
Been there, done that.
mmgc123
C?ID=201092
Update: Changed the RVC to an aftermarket composite one with a digital relay...issue still persists. Not sure what to do next. I have read on other threads that a possible software update may be required as a bug fix. Not sure how I can do that with a retrofitted unit with component protection removed. I have to reset the unit every time I start the car now to get it to change to the RVC screen. Not great. :cry:
