UK discover media - Tmc help
rhinopower
C?ID=58979
Just ironing out the creases now. Retrofitted the unit all ok, but I do not get anything on traffic, just a line through the Tmc icon. Does anyone have an adaption map from a working unit in the UK, or know what needs changing to make it work?
myounus
Northwest UK
C?ID=321059
Hi
Can you please post an autoscan first and then let us know what vehicle you retrofitted what into. Your post is a little vague ����
rhinopower
C?ID=58979
Let’s do this a different way, does anyone at Ross tech have an adaption map for a 5C0035680B, from a UK vehicle, so I can compare adaption channels relating to TMC?
South Molton, UK
An Auto-Scan would still be helpful, so we know which adaptation map is relevant to the modules fitted to your car.
rhinopower
C?ID=58979
I can do, but as the 5F unit isn’t installed or available on my gateway, the unit has to be access directly, which is why I included my part number
^^^ the "standard" technique for enabling TMC is to enter the correct code into the channel IDE05111-Fee-based traffic information (TMC) in the hex5F module.
Here are the codes that I'm aware-of for various TMC systems:
65535 - TMC OFF
1024 - SUNA Traffic (Intelematics)
0 - dev options
32771 online traffic + VW TMCPro
I'm not sure which system UK uses, but if it's the same data transmission mechanism as in Australia (i.e. a harmonic frequency on an FM band radio station via mobile data transmission),then you will need to ensure that RDS is activated in the code-string of the hex5F module as per the screen-shot below (enable bit 1 & bit 3):
After this, "TP" and "RDS" need to be activated in the set-up menu for the radio
rhinopower
C?ID=58979
Mine was set to 32768 when I checked. 1024 didn’t bring any results. I will check these coding options and report back. Gut feeling is it’s going to be a code that nobody has listed so far, but I can try all of the above. Many thanks.
South Molton, UK
65535 - TMC OFF
0 - dev options
On my UK based Skoda Octavia the value in this channel is 1023.
rhinopower
C?ID=58979
Thanks for everyone’s help
3 was the magic number to make it work. Full traffic information now, although it didn’t kick in until 24 hours after
Jeromeo
Australia
C?ID=335683
65535 - TMC OFF
0 - dev options
It still doesn't work for me.
in both my cars MY 2018 Amarok and MY2018 Tiguan
TMC icon stay always crossed.
I'm wondering if they disabled another bit somewhere.
Tiguan
Thursday,11,April,2019,16:09:26:46987
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
VIN: WVGZZZ5NZJM135223   License Plate:
Mileage:    Repair Order: tmc on
UDS Adaptation Channel (2B): IDE05111-Fee-based traffic information (TMC)
Stored value 1024
Address 5F,3Q0 035 846 B,recoded (Long Coding-exp),from,02730608FF00000051510001000808001F0500C601200100CF,to,02730608FF00000051510001000908001F0500C601200100CF,(00066/790/00441),
Amarok
Wednesday,10,April,2019,15:32:00:46987
VIN: WV1ZZZ2HZJA020643   License Plate:
Mileage:    Repair Order: TMC
Stored value 1024
Address 5F,5C0 035 680 F,channel IDE02122-Developer mode,adapted from,not activated ,to,activated ,
Mari
C?ID=150535
65535 - TMC OFF
0 - dev options
Add to your list ;)
3 - VW TMCPro MIB1
1537 - Canada
32768 - VW TMCPro MIB2
I coded "3" in my device to get traffic-information
kamold
Australia
C?ID=241363
Won't work in the Amarok, the PQ platform MIB firmware doesn't work with TMC in Aus (nothing is impossible, but so far no luck).
Likewise with certain other firmware versions on MQB MIB2s. As usual please post full autoscans when looking for assistance, providing snippets only elongates the process.
Jeromeo
Australia
C?ID=335683
Oh OK Thanks @Kamold. That is a shame for the Amarok I already missed on DAB+ on delivery and now I cannot even Have TMC... :(
Here is the scan for the Tiguan
Monday,22,April,2019,16:02:17:46987
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 36 39 3C 42 44
          4B 52 5F 6C 6D A5 CA CF D6 D7
VIN: WVGZZZ5NZJM135223   Mileage: 6106km-3794miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HT    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 4075
   Revision: B4H24---
   Coding: 0125003204661D083000
   Shop #: WSC 00066 790 00454
   ASAM Dataset: EV_ECM20TDI01104L906026HT 004005
   ROD: EV_ECM20TDI01104L906026GP_004.rod
   VCID: 034675158AA29352C0-8056
   Part No SW: 0DL 300 012 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2110
   Revision: 00H06V07
   ROD: EV_TCMDQ500021.rod
   VCID: 3424E6C99F8CE4EA09-8060
   Revision: 00000000    Serial number: 50418000001167
   Coding: 0BEE939A44231B714779070262C649D0C922D8E2E046927D38625038C2AA4200002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   VCID: 77BE11C5CE7ACFF2EC-8022
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0467890898
   Coding: 132C2C0723
   VCID: 3E30C4E1A1C03EBAEF-806A
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: >90047:4
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NA 907 044 R    HW: 5NA 907 044 R
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00118238
   Coding: 0012012420010000110510001210142A
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   VCID: 4ED094211160AE3A1F-801A
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C86421021800PK
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06406C01B990A67AE7-8052
   Subsystem 1 - Part No SW: 5NN 955 119 A    HW: 5NN 955 119 A  Labels: 1KX-955-119.CLB
   Component: 326 RL 180217  034 0373
   Serial number: 18021221028320
   Component: RLHS  047 0105
   Serial number: S6Y18M03D01H20M21S25
   Coding: 00A8DD
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000116644R18036
   Coding: 0371567851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 50EC8A590B54B8CA0D-8004
   Component: ACCCONTIMQB   H02 0233
   Coding: 320547C354FF8728749C8145304087
   Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
   Component: AirbagVW21    005 0336
   Serial number: 003VVM05MLRX
   Coding: 98CCC0C0000000005C545000008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 075E6105BE9ABF729C-8052
   Subsystem 1 - Part No SW: -----------    HW: 480 002 112 17
   Serial number: 357000000004A3DC0A2Q
   Subsystem 2 - Part No SW: -----------    HW: 480 002 312 17
   Serial number: 358000000006600DD92M
   Subsystem 3 - Part No SW: -----------    HW: 480 401 901 18
   Serial number: 3510001A9285E66263A5
   Subsystem 4 - Part No SW: -----------    HW: 480 401 901 18
   Serial number: 3520001C7288860412F+
   Subsystem 5 - Part No SW: -----------    HW: 480 401 302 18
   Serial number: 3550001B92948592A6FI
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18011808491556
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 095A673DA88EC9028A-805C
   Part No SW: 5NA 920 751 B    HW: 5NA 920 751 B
   Component: KOMBI         380 0310
   Coding: 27A40818EF88000801886B0B1401000000000000
   Component: GW MQB High   518 5323
   Serial number: 23011800841741
   Coding: 030500345F087300FB07225A1E0F00010001070000000000000000000000
   Shop #: WSC 00066 790 00441
   ROD: EV_GatewNF_VW37.rod
   VCID: 383CD2F983E4008A25-806C
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 3341704254530257AT3B
   Coding: 2C0000
   Serial number: 9237205600
   Serial number: HA1-00021.11.17
   Coding: 0101
   VCID: 4CD49E29E77C9C2A71-8018
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C2AB0DC4166D62AE-8010
   Serial number: 18000012805018
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3326E5D59A82E3D210-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0023
   Serial number: Y0006RAU21000
   Coding: 0014000000000500018280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   VCID: 3D32C3EDACC625A2F6-8068
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------
   Coding: 44C002
   VCID: 3A38C8F1BDE8129AD3-806E
   Serial number: 5038805400908
   Coding: 00311B20D201028000000000
   VCID: 47DEA105FE1A7F725C-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000201295
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: 93170000
   Shop #: WSC 00066 790 00446
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73A625D5DA02A3D2D0-8026
   Serial number: 11021800840782
   Coding: 0000000501001D5600104F010A0000000000000000000000000000000000
   VCID: 72A820D1A518AADADB-8026
   Serial number: 6038805600066
   Coding: 00311320DE01028000000000
   VCID: 46C0AC01F910667AA7-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000203670
   Coding: 050000
   Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846 B
   Component: MU-S-N-ER     851 0867
   Coding: 02730608FF00000051510001000908001F0500C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 302CEAD96B94D8CA6D-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHV0322004
   Subsystem 2 - Part No SW: 3G0 919 866 BM    HW: -----------
   Component: MRM2 2018  --- 0915
   Coding: 0123060122002017000040
   VCID: 393AD7FDB8EE1982DA-806C
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: A2-C758-8700-0
   Coding: 0A28
   VCID: 42C8B011D5385A5A8B-8016
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
   Serial number: 27101741P20988
   Coding: 000307060102010100021346C150A90098000E300040
   VCID: 085C6239B384B00A95-805C
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 10804073260C
   ROD: EV_SunRoofCONTIAU736_006.rod
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   VCID: 373ED1C58EFA0FF22C-8062
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16603C41E93016FA17-8042
   Component: LED1R         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:01, VBatt start/end: 12.1V/12.1V)-----------
Adpmap 5F
;SW:3Q0-035-846-B   HW:3Q0-035-846-B ---  Information Electr.,,,,
;Component:MU-S-N-ER     851 0867, Coding:02730608FF00000051510001000908001F0500C601200100CF,,,
;EV_MUStd4CDELP,1001,EV_MUStd4CDELP_VW26.rod,,
;Monday,22,April,2019,11:44:44:46987
;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0,,,,
;VCID: 302CEAD96B94D8CA6D-8064,,,,
IDE00001-Production mode,00 00 00 ,3,,
IDE00346-Summertime-automatic,manual ,1,,
IDE00758-Base volume of telephone,50%,1,,
IDE00759-Base volume of speech output,50%,1,,
IDE00760-Microphone sensitivity,0 dB,1,,
IDE00769-Number 1 for Info call,5E 05 A1 81 00 60 90 63 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23,,
IDE00770-Number 1 for roadside assistance,5E 05 A1 81 00 06 87 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23,,
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1,,
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1,,
IDE00845-Wheel circ.,0 mm,2,,
IDE02121-CD eject button,Enabled ,1,,
IDE02122-Developer mode,not activated ,1,,
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23,,
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23,,
IDE02332-Deactivate production mode,0,3,,
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic ,49,,
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27,49,,
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27,49,,
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27,49,,
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27,49,,
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27,49,,
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27,49,,
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27,49,,
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27,49,,
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27,49,,
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27,49,,
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27,49,,
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27,49,,
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27,49,,
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27,49,,
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27,49,,
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49,,
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27,49,,
IDE02502-Confirmation of installation change,36 2D ,2,,
IDE02607-Wheel pulse,0,2,,
IDE02699-Number 1 for roadside assistance,5E 02 A1 00 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23,,
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 00 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23,,
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30,,
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30,,
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30,,
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30,,
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30,,
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30,,
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30,,
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30,,
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30,,
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0,30,,
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30,,
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30,,
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30,,
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30,,
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30,,
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30,,
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30,,
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30,,
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30,,
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30,,
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30,,
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30,,
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30,,
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30,,
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30,,
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30,,
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30,,
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30,,
IDE03471-ENG142152-Vehicle configuration-Map_Style,0,30,,
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30,,
IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30,,
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_AUS ,30,,
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30,,
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30,,
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30,,
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30,,
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30,,
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30,,
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30,,
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30,,
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30,,
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30,,
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30,,
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,0,30,,
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,0,30,,
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0,30,,
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30,,
IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30,,
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30,,
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30,,
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0,30,,
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30,,
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30,,
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30,,
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30,,
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30,,
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30,,
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30,,
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30,,
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30,,
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30,,
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30,,
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30,,
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30,,
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present ,30,,
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30,,
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30,,
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0,30,,
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30,,
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30,,
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30,,
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30,,
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30,,
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30,,
IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30,,
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30,,
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30,,
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30,,
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30,,
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30,,
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30,,
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30,,
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30,,
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30,,
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30,,
IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1,,
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF ,4,,
IDE04550-Bluetooth: Sniff mode,OFF ,1,,
IDE05111-Fee-based traffic information (TMC),1024,2,,
IDE05113-Infotainment Recorder,activated ,1,,
IDE06425-Roller test bench mode: functional,not activated ,1,,
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1,,
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1,,
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1,,
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1,,
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1,,
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1,,
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1,,
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128,40,,
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5,40,,
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128,40,,
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128,40,,
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128,40,,
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128,40,,
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128,40,,
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128,40,,
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128,40,,
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128,40,,
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128,40,,
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128,40,,
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128,40,,
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128,40,,
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128,40,,
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128,40,,
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128,40,,
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128,40,,
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128,40,,
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128,40,,
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3,40,,
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128,40,,
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128,40,,
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128,40,,
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128,40,,
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6,40,,
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128,40,,
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128,40,,
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128,40,,
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128,40,,
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128,40,,
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128,40,,
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128,40,,
IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated ,4,,
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4,,
IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated ,4,,
IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated ,4,,
IDE10604-Menu entries for mobile online services,not activated ,1,,
IDE11122-Country identification: country of sale HMI,AU ,2,,
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21,,
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,21,,
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,21,,
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21,,
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21,,
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,21,,
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,21,,
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,21,,
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,21,,
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,21,,
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,21,,
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,21,,
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21,,
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,21,,
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,21,,
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,21,,
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,21,,
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21,,
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,21,,
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,21,,
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,21,,
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21,,
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,21,,
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,21,,
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21,,
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21,,
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21,,
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21,,
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21,,
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21,,
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,21,,
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21,,
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,21,,
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,21,,
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,21,,
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,21,,
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,21,,
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,21,,
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,21,,
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,21,,
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,21,,
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21,,
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21,,
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21,,
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,21,,
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,21,,
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21,,
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21,,
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21,,
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,21,,
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21,,
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21,,
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21,,
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21,,
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21,,
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,21,,
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,21,,
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,21,,
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21,,
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21,,
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21,,
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21,,
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,21,,
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21,,
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21,,
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,21,,
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,21,,
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,21,,
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,21,,
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21,,
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,21,,
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21,,
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21,,
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,21,,
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,21,,
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,21,,
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,21,,
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,21,,
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,21,,
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,21,,
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,21,,
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,21,,
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,21,,
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,21,,
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,21,,
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,21,,
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,21,,
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21,,
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21,,
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21,,
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21,,
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21,,
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,21,,
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,21,,
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,21,,
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21,,
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21,,
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,21,,
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,21,,
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,21,,
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,21,,
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,21,,
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,21,,
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,21,,
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,21,,
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,21,,
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,21,,
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,21,,
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,21,,
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,21,,
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21,,
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,21,,
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,21,,
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,21,,
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,21,,
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,21,,
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,21,,
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,21,,
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,21,,
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21,,
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,21,,
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,21,,
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,21,,
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,21,,
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,21,,
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,21,,
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,21,,
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,21,,
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,21,,
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,21,,
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21,,
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,21,,
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21,,
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,21,,
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,21,,
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21,,
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21,,
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,21,,
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,21,,
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,21,,
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,21,,
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,21,,
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,21,,
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,21,,
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,21,,
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,21,,
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21,,
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21,,
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21,,
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21,,
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,21,,
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,21,,
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,21,,
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,21,,
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,21,,
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,21,,
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,21,,
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,21,,
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,21,,
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,21,,
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,21,,
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21,,
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21,,
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21,,
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21,,
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21,,
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,21,,
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,21,,
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192,,
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192,,
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192,,
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192,,
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192,,
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192,,
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192,,
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192,,
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192,,
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,not activated ,192,,
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192,,
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192,,
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192,,
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192,,
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192,,
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192,,
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192,,
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,not activated ,192,,
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192,,
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192,,
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192,,
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192,,
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192,,
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192,,
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192,,
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192,,
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192,,
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192,,
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192,,
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192,,
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192,,
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192,,
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192,,
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192,,
IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4,,
MAS00951-Bluetooth,On ,1,,
MAS01968-Fan,normal ,1,,
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6,,
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6,,
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6,,
MAS03782-WLAN,On ,1,,
ENG117917-BAP_Debug_Mode_Release,not_released ,1,,
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60,,
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60,,
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60,,
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60,,
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60,,
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60,,
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60,,
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60,,
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60,,
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60,,
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60,,
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60,,
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60,,
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60,,
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60,,
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60,,
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60,,
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60,,
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60,,
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60,,
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60,,
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60,,
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60,,
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60,,
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60,,
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60,,
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60,,
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60,,
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60,,
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60,,
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60,,
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60,,
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60,,
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60,,
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60,,
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ,60,,
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60,,
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60,,
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60,,
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60,,
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60,,
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60,,
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60,,
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60,,
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60,,
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60,,
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60,,
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60,,
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60,,
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60,,
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60,,
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60,,
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60,,
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60,,
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60,,
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60,,
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60,,
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60,,
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60,,
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60,,
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60,,
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60,,
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60,,
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60,,
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60,,
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60,,
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60,,
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60,,
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60,,
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60,,
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60,,
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60,,
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60,,
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60,,
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60,,
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60,,
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60,,
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60,,
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60,,
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60,,
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60,,
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60,,
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60,,
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60,,
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60,,
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ,60,,
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60,,
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60,,
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ,60,,
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60,,
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ,60,,
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60,,
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60,,
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ,60,,
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60,,
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60,,
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60,,
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60,,
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60,,
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60,,
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60,,
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60,,
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60,,
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60,,
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60,,
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60,,
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60,,
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60,,
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60,,
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60,,
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60,,
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60,,
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60,,
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated ,60,,
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60,,
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60,,
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60,,
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60,,
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60,,
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60,,
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60,,
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60,,
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60,,
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60,,
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60,,
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ,60,,
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60,,
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60,,
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60,,
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60,,
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60,,
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60,,
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60,,
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60,,
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60,,
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60,,
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60,,
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60,,
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60,,
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60,,
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60,,
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60,,
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60,,
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60,,
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60,,
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ,60,,
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60,,
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60,,
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ,60,,
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60,,
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60,,
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60,,
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60,,
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60,,
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60,,
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60,,
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60,,
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60,,
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60,,
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60,,
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60,,
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60,,
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60,,
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60,,
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60,,
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60,,
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60,,
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60,,
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60,,
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60,,
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60,,
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60,,
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60,,
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60,,
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60,,
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60,,
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60,,
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60,,
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60,,
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60,,
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60,,
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60,,
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60,,
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60,,
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60,,
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60,,
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60,,
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60,,
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60,,
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60,,
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60,,
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60,,
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60,,
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60,,
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60,,
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60,,
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60,,
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60,,
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60,,
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60,,
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60,,
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60,,
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60,,
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60,,
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60,,
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60,,
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60,,
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60,,
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60,,
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60,,
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60,,
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60,,
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60,,
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60,,
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60,,
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60,,
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60,,
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60,,
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60,,
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60,,
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60,,
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60,,
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60,,
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60,,
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60,,
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60,,
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60,,
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60,,
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60,,
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60,,
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60,,
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60,,
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60,,
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60,,
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60,,
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60,,
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60,,
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60,,
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60,,
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60,,
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60,,
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60,,
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60,,
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60,,
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60,,
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60,,
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60,,
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60,,
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60,,
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60,,
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60,,
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60,,
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60,,
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60,,
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60,,
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60,,
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60,,
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60,,
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60,,
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60,,
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60,,
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60,,
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60,,
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60,,
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60,,
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60,,
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60,,
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60,,
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60,,
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60,,
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60,,
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60,,
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60,,
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60,,
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60,,
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ,60,,
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60,,
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60,,
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ,60,,
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60,,
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60,,
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60,,
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60,,
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60,,
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60,,
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60,,
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60,,
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60,,
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60,,
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60,,
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ,60,,
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60,,
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60,,
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ,60,,
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60,,
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60,,
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60,,
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60,,
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60,,
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60,,
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64,,
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64,,
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64,,
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64,,
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64,,
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64,,
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64,,
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64,,
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64,,
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64,,
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64,,
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ,64,,
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64,,
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64,,
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64,,
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64,,
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64,,
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64,,
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ,64,,
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64,,
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64,,
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64,,
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64,,
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64,,
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64,,
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64,,
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64,,
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64,,
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64,,
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64,,
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64,,
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64,,
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64,,
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64,,
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64,,
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64,,
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64,,
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ,64,,
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64,,
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64,,
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64,,
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64,,
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64,,
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64,,
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64,,
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64,,
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64,,
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64,,
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64,,
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64,,
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64,,
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64,,
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64,,
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64,,
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated ,64,,
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64,,
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64,,
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64,,
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64,,
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64,,
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64,,
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64,,
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64,,
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64,,
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64,,
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64,,
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ,64,,
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64,,
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ,64,,
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64,,
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64,,
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64,,
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64,,
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64,,
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64,,
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64,,
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64,,
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64,,
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64,,
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64,,
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64,,
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64,,
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64,,
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64,,
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64,,
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64,,
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64,,
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64,,
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64,,
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64,,
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64,,
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8,,
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8,,
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8,,
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8,,
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8,,
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8,,
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available ,8,,
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8,,
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8,,
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8,,
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8,,
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8,,
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8,,
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8,,
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8,,
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8,,
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0,6,,
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50,6,,
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100,6,,
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0,6,,
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50,6,,
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100,6,,
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0,6,,
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50,6,,
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100,6,,
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0,6,,
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50,6,,
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100,6,,
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0,12,,
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10,12,,
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50,12,,
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100,12,,
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150,12,,
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253,12,,
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1%,12,,
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1%,12,,
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3%,12,,
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6%,12,,
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44%,12,,
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100%,12,,
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,FF ,32,,
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,FF ,32,,
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,FF ,32,,
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,FF ,32,,
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,FF ,32,,
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,FF ,32,,
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,FF ,32,,
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,FF ,32,,
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,FF ,32,,
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,FF ,32,,
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,FF ,32,,
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,FF ,32,,
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,FF ,32,,
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,FF ,32,,
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,FF ,32,,
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,FF ,32,,
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,FF ,32,,
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,FF ,32,,
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,FF ,32,,
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,FF ,32,,
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,FF ,32,,
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,FF ,32,,
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,FF ,32,,
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,FF ,32,,
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,FF ,32,,
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,FF ,32,,
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,FF ,32,,
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,FF ,32,,
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,FF ,32,,
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,FF ,32,,
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,FF ,32,,
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,FF ,32,,
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5,,
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5,,
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5,,
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5,,
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5,,
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5,,
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5,,
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5,,
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5,,
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5,,
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5,,
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40,,
ENG117809-p_damping_Display,5 ms,1,,
ENG117808-p_HMI_Display,13%,1,,
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0,2,,
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0,2,,
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2,,
Elapsed Time: 00:34,,,,
Blockmap 5F
;SW:3Q0-035-846-B   HW:3Q0-035-846-B ---  Information Electr.
;Component:MU-S-N-ER     851 0867, Coding:02730608FF00000051510001000908001F0500C601200100CF
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW26.rod
;Monday,22,April,2019,15:55:39:46987
;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
;VCID: 302CEAD96B94D8CA6D-8064
Group,Description,Actual
IDE00019,Voltage terminal 30,12.0, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0.00, /min
IDE00668-MAS03231,Microphone current consumption-Microphone 1,5.20, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,0, counts
IDE00916-IDE02127,Speaker status-Left front speaker,OK,
IDE00916-IDE02128,Speaker status-Right front speaker,OK,
IDE00916-IDE02129,Speaker status-Left rear speaker,OK,
IDE00916-IDE02130,Speaker status-Right rear speaker,OK,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measured value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,OFF,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measured value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measured value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measured value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measured value not available,
IDE01712-MAS01779,GPS Position-Length,153°11'09.10"E,
IDE01712-MAS01780,GPS Position-Width,027°55'31.81"S,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,13,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,13,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,67, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,50, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,55, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Electrical OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,50, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,Electrical OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,24, mA
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,Yes,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,31,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,18,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,26,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,1,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,49, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,48, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,47, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,45, dBµV
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth partially visible: connection possible,
IDE03477-MAS00106,GPS time-Year,2019,
IDE03477-MAS00107,GPS time-Month,4,
IDE03477-MAS00108,GPS time-Day,22,
IDE03477-MAS00109,GPS time-Hours,5,
IDE03477-MAS00110,GPS time-Minutes,56,
IDE03477-MAS00111,GPS time-Seconds,24,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,17, min
IDE04317-MAS00108,Total system run time-Day,10, d
IDE04317-MAS00109,Total system run time-Hours,4, H
IDE04317-MAS00110,Total system run time-Minutes,45, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 03 00 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04544,Media type in optical drive,Not available,
IDE04545-IDE01588,Vehicle state-Driving direction,Measured value not available,
IDE04545-IDE01714,Vehicle state-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle state-Distance impulses,0,
IDE04545-IDE03684,Vehicle state-Vehicle stopped,Yes,
IDE04546-IDE00301,Navigation calibration-Distance,0.510, mm
IDE04546-MAS03647,Navigation calibration-Calibration condition,complete,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,153°11'09.02"E,
IDE04605-MAS01780,Navigation: Corrected position-Width,027°55'32.14"S,
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,6.6, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,Yes,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.3, dB
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 2,
IDE04649-MAS06857,Activation for housing fan-Speed,5340, /min
IDE04748,Microphone override meter,0,
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,74 95 EC 39 EC 78,
IDE05040-MAS01632,Video input status-Status,valid,
IDE05040-MAS04390,Video input status-Active source,Rearview camera,
IDE05536-MAS01632,GPS almanac-Status,valid,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2019,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,4,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,22,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,4,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,41,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,31,
IDE05596-MAS00106,Last time GPS position outside map-Year,2000,
IDE05596-MAS00107,Last time GPS position outside map-Month,0,
IDE05596-MAS00108,Last time GPS position outside map-Day,0,
IDE05596-MAS00109,Last time GPS position outside map-Hours,0,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,0,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,0,
IDE05597-IDE03615,Bluetooth: Paired device 1-Version,Á#óSam’s iPhone
Apple Inc.
iPhone10,3Version 12.2 (Build 16E227)ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,B8 C1 11 10 23 F3,
IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,Á#óSam’s iPhone
Apple Inc.
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),B8 C1,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),B8 C1,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,Á#óSam’s iPhone
Apple Inc.
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,Sam’s iPhone
Apple Inc.
iPhone10,3
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,B8 C1,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,B8 C1,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,B8 C1,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,B8 C1,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,B8 C1,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,B8 C1,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,B8 C1,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,B8 C1,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,B8 C1,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,B8 C1,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,B8 C1,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,B8 C1,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,B8 C1,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,B8 C1,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,B8 C1,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,B8 C1,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,B8 C1,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,u˜Ñ¾�
Galaxy S9+samsungSM-G965F--ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,88 75 98 D1 BE 90,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,u˜Ñ¾�
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),88 75,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),88 75,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,u˜Ñ¾�
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,Galaxy S9+
samsung
SM-G965F
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,88 75,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,88 75,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,88 75,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,88 75,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,88 75,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,88 75,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,88 75,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,88 75,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,88 75,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,88 75,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,88 75,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,88 75,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,88 75,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,88 75,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,88 75,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,88 75,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,88 75,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,¸7|ôVXperia Z5 Compact------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿ,
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,40 B8 37 7C F4 56,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,¸7|ôVXperia Z5 Compact------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿ,
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),40 B8,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),40 B8,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,¸7|ôVXperia Z5 Compact------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿ,
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,Xperia Z5 Compact
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,40 B8,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,40 B8,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,40 B8,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,40 B8,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,40 B8,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,40 B8,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,40 B8,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,40 B8,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,40 B8,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,40 B8,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,40 B8,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,40 B8,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,40 B8,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,40 B8,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,40 B8,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,40 B8,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,40 B8,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,0,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,OK,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Terminal 58xs dimmer,0, %
IDE05726,Terminal 58xd dimmer,27.65, %
IDE05814,Individualization characteristic,74 07 30 B9 29,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,1,
IDE06425,Roller test bench mode: functional,not activated,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE08530-MAS00106,Connection status online basic services-Year,2000.0, yr
IDE08530-MAS00107,Connection status online basic services-Month,0, mon
IDE08530-MAS00108,Connection status online basic services-Day,0, d
IDE08530-MAS00109,Connection status online basic services-Hours,0, H
IDE08530-MAS00110,Connection status online basic services-Minutes,0, min
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,0,
IDE08530-ENG20907,Connection status online basic services-Server_HTTP_Status_Code_Textual,Service deactivated,
IDE08531-MAS00106,Connection status online license services-Year,2000.0, yr
IDE08531-MAS00107,Connection status online license services-Month,0, mon
IDE08531-MAS00108,Connection status online license services-Day,0, d
IDE08531-MAS00109,Connection status online license services-Hours,0, H
IDE08531-MAS00110,Connection status online license services-Minutes,0, min
IDE08531-MAS07132,Connection status online license services-Code status,0,
IDE08531-MAS07134,Connection status online license services-ID services,0,
IDE08531-MAS07135,Connection status online license services-Activation status,No expiry,
IDE08531-MAS07136,Connection status online license services-Exp. year,0, yr
IDE08531-MAS07137,Connection status online license services-Exp. month,0, mon
IDE08531-MAS07138,Connection status online license services-Exp. day,0, d
IDE08531-ENG20907,Connection status online license services-Server_HTTP_Status_Code_Textual,not defined,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardwareversion,---,
IDE10479-MAS01483,Interface for external media: identification-Softwareversion,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10843-MAS01482,Function module: identification-Hardwareversion,1,
IDE10843-MAS04326,Function module: identification-Device name,AP_FLASH,
IDE10843-MAS11354,Function module: identification-Bootloader version,60,
IDE10843-MAS11355,Function module: identification-Application version,0,
IDE10843-MAS11356,Function module: identification-Module Name,IPL,
IDE10857-MAS02476,Touchless loading of mobile phone: status-install,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-charge,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,22,
MAS00464-MAS00109,Standard - ambient data 1-Hours,15,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,56,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,35,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,155,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,6106, km
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia display unit 1-System status,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,188, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,39, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,12.2, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,73, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,33, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,3,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,106.9, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,51, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,52, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,no tuned IBOC Audio Service,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,52, dBµV
MAS01991-IDE00010,Card reader-Serial number,13 C3 87 B8,
MAS01991-IDE01001,Card reader-Application,AP,
MAS01991-MAS01632,Card reader-Status,connected,
MAS01991-MAS03159,Card reader-Manufacturer,09,
MAS01991-MAS03375,Card reader-Major version,2,
MAS01991-MAS03376,Card reader-Minor version,0,
MAS01991-MAS03959,Card reader-Write-protection,activated,
MAS01991-MAS04388,Card reader-Card type,MIBST,
MAS01991-MAS13476,Card reader-Manufacturing date: month,11, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2017, yr
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS03782-ENG117422,WLAN-IP_Address,192.168.255.1,
MAS03782-ENG117423,WLAN-IP_Subnetmask,255.255.255.0,
MAS03782-ENG117421,WLAN-MAC_Address,74 95 EC 39 EC 79,
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,23469547646392691,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,SPP,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,11,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,12,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,19, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,4, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,22, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,15, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,36, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,40, s
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,99, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,not activated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,45570,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,34560,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
ENG117858-MAS01424,System_Temperature_Sensor_2-max.value,61, °C
ENG117858-MAS01425,System_Temperature_Sensor_2-min.value,0, °C
ENG117858-MAS02238,System_Temperature_Sensor_2-Current,46, °C
ENG117860-MAS01424,System_Temperature_Sensor_4-max.value,56, °C
ENG117860-MAS01425,System_Temperature_Sensor_4-min.value,0, °C
ENG117860-MAS02238,System_Temperature_Sensor_4-Current,38, °C
ENG117862-MAS01424,System_Temperature_Sensor_6-max.value,205, °C
ENG117862-MAS01425,System_Temperature_Sensor_6-min.value,205, °C
ENG117862-MAS02238,System_Temperature_Sensor_6-Current,205, °C
Elapsed Time: 00:24
Jeromeo
Australia
C?ID=335683
in Blockmap
Could this be why it doesn't Work?
How can i change this value to ON?
Thanks.
