2018 Audi A3 quattro - Can you enable ACC?
Mattias Ekström
C?ID=345241
I have a car with the front radar sensor but ACC is not enabled. Can you enable this in VCDS?
my car looks exactly like this. I believe all the hardware is already there. Please help.
D-Dub
C?ID=272151
not without an auto-scan to see what components your vehicle actually does have.
iichel
Eindhoven, NB, NL
C?ID=284912
See below on how to post an autoscan.
Mattias Ekström
C?ID=345241
ok sorry, I actually don't have my car yet as I pick it up in 2 weeks.
But generally speaking can this be done via software if I already have the front radar sensor?
I am skeptical. I suspect this is one of those features that VW/Audi considers "Software as a Product". They do that now even for normal (not Adaptive) cruise in Europe.
Mattias Ekström
C?ID=345241
Does anyone know for sure?? I believe there is an ACC module somewhere in VCDS but I can't find any information on this. I figured this would be the best place to find out!
Sure, VCDS can talk to the radar/ACC module. Take a look at address 13 in this scan for example.
But that doesn't tell us whether ACC functionality can be enabled. ACC functionality isn't just in the radar module; it also requires cooperation from other modules such as the ECU and the ABS brakes (at an absolute minimum).
Mattias Ekström
C?ID=345241
Thanks. I will definitely run a scan and post it once I get my car in just over a week.
That being said I am dying to find out if I can turn this on.
Here is my exact car (below) It says it has the following features. Has anyone done this on a new A3 or know if it can be done?
- ABS w/ Brake Assist
- Audi pre sense basic (preventative occupant protection)
- Audi pre sense front (low speed collision assist)
https://imgur.com/a/8TQBBt4
downtime
Finland
C?ID=280813
For sure, not possible to enable with VCDS. Like Uwe already mentioned, it’s a SWaP function which unfortunately you cannot buy separately. So no way to enable ACC with VCDS and no way to enable it afterwards by any normal way.
Oh and you would need a need stalk set as well because you don’t have CC stalk with distance setting.
Mattias Ekström
C?ID=345241
So there is no possible way to enable this on my car in any way shape or form? just not possible? I get that you would need a new stalk.
Does anyone have access to buy this SwAP function? I just find this hard to believe as the car comes with all the hardware (minus the stalk)
downtime
Finland
C?ID=280813
You cannot buy the SWaP. There's no catalogue item for it. FeC codes you need for ACC are installed to the car from factory and are bound to the cars VIN number. So whenever you need to replace a module that requires FeC (feature enable code) they are automatically installed to the car again from factory database via dealer online connection.
If your car NEVER had the codes, you will NEVER be able to get them unless you hack the factory database. Dealer is not able to change the codes.
However, there's another way. You can buy a hacked radar, install that and have the CP removed from it. And of course buy the new stalk set which you will need naturally as well.
Search Facebook for MQB coding and ask about the ACC retrofit from there. You should get help through there.
I know it's hard to believe but that's how difficult the retrofit scene is becoming.
Oh, and to say for sure if you need something else as well, we need the autoscan. It could be that new ABS pump is also required. Even your current one supports Front assist, it might not support ACC. And you need to change the rear ABS sensors to different ones unless your car has PLA which means there's also correct ABS sensors with that.
The fact that I clicked LIKE on the post above should not be taken to mean I like the situation, but rather as a "thanks" to downtime for posting the explanation.
D-Dub
C?ID=272151
unfortunately I think the way of the future of automotive is locking everything down and making it difficult for any type of non-factory-equipped retrofits.
like apple, they only want you to have, what you bought from them, and not to modify it.
manaterski
Poland
I tested the quattro this car has a good kick. Big power, it's nice to dive him.
Mattias Ekström
C?ID=345241
Thanks guys, here is my scan..
Thursday,30,August,2018,11:26:34:22572
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WAUB8GFF9J1050538   License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 42 44 52 5F 6C BB BC
VIN: WAUB8GFF9J1050538   Mileage: 935km-580miles
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A1D00124426010F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 372B289A8FC8067F80E-8062
   Part No SW: 0D9 300 018 A    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01712051417
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1A6DD12E1C1A3B179F0-804E
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 60208000000109
   Coding: 13FF6A923425226C897C0B03A0CB29C8562C4491D0059476124150548208420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
   VCID: 78A9EBA6C256C907494-802C
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0466534908
   Coding: 030C0C
   VCID: 3C2137B6B6EE25276DC-8068
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001455766
   Coding: 03000014010000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40D94346DA0641C7314-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 74329C0900PAG0MUFU03
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001801600048
   ROD: EV_BCMCONTI.rod
   VCID: 0655955EB8A2AFF74B8-8052
   Component: WWS371 171214  043 0585
   Serial number:         171218131241
   Coding: 0A47F7
   Serial number: 21153841X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 16 09 2017  00001257
   Serial number: 00000000000000125165
   Sun Roof:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST001XGL2100000
   Coding: 101F00
11274 - Bulb for Center Brake Light
          B12C6 15 [008] - Open or Short to Plus
                    Reset counter: 80
                    Mileage: 876 km
                    Date: 2018.08.28
                    Time: 15:03:33
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: B500008111F78428949C8055000024
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   VCID: 3B2334AAB3E0221F646-806E
   Serial number: 003GCR09UKC0
   VCID: 47CB585AFF2876FFF0E-8012
   Belt Pretensioner left:
   Serial number: 34230167A17011841189
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A18011840138
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001PPNEL
   Coding: 303334
   Subsystem 4 - Part No SW: -----------    HW: 480 000 701 18
   Serial number: 35700000000F9858BA2/
   Subsystem 5 - Part No SW: -----------    HW: 480 000 701 18
   Serial number: 358000000005A858BA2W
   Subsystem 6 - Part No SW: -----------    HW: 480 400 801 18
   Serial number: 35100019F287908173F8
   Subsystem 7 - Part No SW: -----------    HW: 480 400 801 18
   Serial number: 3520001B728DFC75828N
   Subsystem 8 - Part No SW: -----------    HW: 480 400 301 18
   Serial number: 3550002A725325B3F2B5
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3560002B1252D872409.
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 20011804220487
   Coding: 2018
   VCID: 0D47AA72DDD4DCAF0A2-8058
   Part No SW: 8V0 920 961 C    HW: 8V0 920 961 C
   Component: KOMBI         H01 0311
   Coding: 0BE418192380CF050280A8001800000000000000
   Component: GW MQB High   518 5323
   Serial number: 16011810804226
   Coding: 030100043F085A005B00004C180B00000001010000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 38292BA682D60907894-806C
   Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
   Component: J453 MFL  H04 0003
   Serial number: 20180110132209 20666
   Serial number: 7588600000180119106A
   Serial number: HA1-00016.10.17
   Coding: 0001
   VCID: 4CC16776E64E95A7DDC-8018
   Revision: 00000000    Serial number: 17000401988006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311F969EBEED67A5C-8060
   Serial number: 020118ELU03672
   Coding: 001C1B204000048000000002
   VCID: 43D34C4ACB105ADF2C6-8016
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B3DC8ADB30AA5F7C6-8026
   Serial number: 171217ELH02244
   Coding: 001C13204400048000000002
   VCID: 42DD494ED40A53D7270-8016
   Part No SW: 8V1 035 652 E    HW: 8V1 035 652
   Component: MU-HS-S-US    050 0160
   Coding: 01730100FF0A000011220001061A00002F002DC401F001040A
   ROD: EV_MUHigScl6C3DELP_AU37.rod
   VCID: 392F2EA2B9DC100F76A-806C
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y080YL
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 BF    HW: 8V0 919 614 BF
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL118101700050476
   Coding: 0273010100002001000040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 211117EKL00909
   Coding: 000C13204000048000000002
   Serial number: 211117EKL0090C
End----------(Elapsed Time: 01:33, VBatt start/end: 13.8V/13.8V)-----------
downtime
Finland
C?ID=280813
So you got ACC installed. Did you get help from MQB Coding or from China?
You have a newer ACC radar so I presume the latter.
Since the OP is Verified now, moving this to Tweaks as well.
MasterTommy
Amsterdam
C?ID=295586
You know module 13 is in all MQB cars with a radar, right? Regardless of it only providing front assist functionality or also ACC...
downtime
Finland
C?ID=280813
Hmmm.. maybe in newer ones, but older don’t have it :(
That explains it.
Did you try MQB Coding Facebook group?
Mattias Ekström
C?ID=345241
No its brand new A3, are you saying I have the hardware to do this?
