Hello there,
I try to solve a Skoda Scout coding issue after the person tried to code with a chinese clone VCDS.
In order to solve all the coding issue i had to modify byte 18 to make the parking light on.
I add there a value witch i found it on a forum 1B but i still receive some bulb errror warning.
I attached you the autoscan if anyone can provide me a good value for this byte in order to test it.
Thanks!
Thanks!
Monday,30,July,2018,21:23:00:32554
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: TMBKE61Z3D2100453 License Plate: PH999
Mileage: 403770km-250891mi Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 62 69 72
VIN: TMBKE61Z3D2100453 Mileage: 403770km-250891miles
Address 01: Engine (J623-CFHC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 DA HW: 03L 906 018 BR
Component: R4 2.0l TDI H25 9977
Revision: 42H25--- Serial number:
Coding: 00190012042600080000
Shop #: WSC 54844 107 00000
ASAM Dataset: EV_ECM20TDI01103L906018DA 003006
ROD: EV_ECM20TDI01103L906018C.rod
VCID: 6C94315687F4DD24EB-8038
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 113B401C0A2200FA880F02E9501C0042310000
Shop #: WSC 73430 790 00064
VCID: 7DB20C12E48E44AC4C-8028
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: ----------- HW: -----------
Component: Climatronic 0607
Revision: --------
Coding: 0010000002
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 6FAE265AB6E2263CCE-803A
Part No SW: 1K0 937 087 AD HW: 1K0 937 087 AD
Component: BCM PQ35 H 111 0709
Revision: AC111709
Coding: 40100AB8E00508C000080084510091A447701B1E726D85601E8540000040
VCID: 73A62A2AD2CA02DC2A-8026
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 14111 26 0601
Coding: 00D7B7
Component: RLS 151112 05 54 0403
Coding: 0630ED
00984 - Left Tail Light (M4)
014 - Defective
Fault Status: 01101110
Reset counter: 38
Mileage: 403777 km
Date: 2018.07.30
Time: 21:15:14
Voltage: 13.60 V
Term 50 Off
00985 - Right Tail Light (M2)
Fault Status: 00101110
Reset counter: 78
Mileage: 403777 km
Date: 2018.07.30
Time: 21:15:14
Voltage: 13.60 V
Term 50 Off
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 38
Mileage: 403777 km
Date: 2018.07.30
Time: 21:21:36
Voltage: 12.55 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:| 1Z0-919-475-V2.clb
Part No SW: 1Z0 919 475 E HW: 7N0 919 475
Component: PARKHILFE 8K H06 0005
Revision: --H06--- Serial number: 28261231800799
Coding: 110003
Shop #: WSC 13765 790 00064
ASAM Dataset: EV_EPHVA18SKxxx0000 001001
ROD: EV_EPHVA18SKxxx0000_001.rod
VCID: 43C6BAEACAEAF25C7A-8016
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2YEKWM
Coding: 0020790
VCID: 3D32CC12640E84AC0C-8068
Subsystem 1 - Serial number: 6332MSME732049376
Subsystem 2 - Serial number: 6342MSME74254967G
Subsystem 3 - Serial number: 6351HSME2E664B5CR
Subsystem 4 - Serial number: 6361HSME2E7214446
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440LKG000AS
Coding: 5080140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 70AC2526ABDC39C4D7-8024
Part No SW: 1Z0 920 843 S HW: 1Z0 920 843 S
Component: KOMBI H06 0608
Coding: 120E00
Shop #: WSC 73430 031 00064
ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
VCID: 48DCADC6F3CCD104AF-801C
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 151112F1000434
Coding: 352302
VCID: 74A42936D7C405E433-8020
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: 45C2A4F20CDECC6C54-8010
Component: IMMO H06 0608
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A98374E8D00C31499-803E
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2119
Coding: 0000246
VCID: 76A0133E01B817F40D-8022
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
VCID: 373EDE3A4632AEFCD6-8062
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0000246
VCID: 48DCADC63BCCD104AF-801C
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0148
Coding: 1507354
VCID: 3424E936574445E4F3-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000023
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000023
Address 56: Radio
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 3228EF2EAD504BD4E1-8066
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030322943
Coding: 410D000100000000
VCID: 302CE526635C79C497-8064
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3326EA2A524A42DCEA-8066
End----------(Elapsed Time: 01:03, VBatt start/end: 12.5V/12.4V)-----------
