V10tdi particulate ash values and forced regen
atomizer
C?ID=325670
VWV10TDI group labels,desc. Particulate filter ash values, please advise?
atomizer
C?ID=325670
when I do an AUTO-Scan there is nothing for engine 1 or II I am not having operational problems except Hvac, I would like to get an idea what status is for soot and ash grams or % of fill,In measuring Block 068 i get 79 units in field 3, I do not know the meaning or if this is relavent, this is a towing unit just purchsed in 2017 and we are planning 3 week trip 5K miles , I have masters degree in fuel systems, ADS pump Shop retired ,3 Benz diesels and other But this is hard to gather info on . Thanks
Boki Ar
Arandjelovac, Serbia
C?ID=57300
People do not mean a lot here with [VWV10TDI group labels,desc]. Auto scan is much better, because we can be seen how the vehicle is equipped and configured.
atomizer
C?ID=325670
I just got off the phone with Peter @ ross tech He explained what you were probably looking for, It will be a couple of days , this is learning curve for me and i'm german.isn't that funny,Thanks
atomizer
C?ID=325670
Tuesday,07,August,2018,20:53:53:24229
VCDS Version: 18.2.1.5  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
Dealer/Shop Name: roberts
VIN: WVGPT77L46D062545   License Plate:
Mileage: 269060km-167186mi   Repair Order: 8-7-18
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L46D062545   Mileage: 269060km-167186miles
   Part No SW: 070 906 016 CQ    HW: 028 101 196 2
   Component: V10 5,0L EDCG000AGMª8472
   Revision: --H02---    Serial number: VWZ3Z0E6443672
   Coding: 0060575
   Shop #: WSC 31414 000 00000
   VCID: 619F58C3AD5C405F1EA-5160
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
   Component: AL 750 6A           0856
   Revision: 00H37000    Serial number:
   Coding: 0004216
   VCID: 7F5BFEBB3BE896AF08E-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D27C4B3716444BF5A2-5160
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137 A    HW: 5WK 485 02
   Component: 29 Kessy            6700
   Revision: 67005915    Serial number: VWZ3Z0E6443672
   Coding: 0147688
   VCID: 313FE883BD3CB0DFCEA-5160
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77AB169B13D8AEEF40E-5160
   Part No: 7L6 907 044 T
   Component: CLIMAtronic 2+2     4222
   Coding: 0021030
   Shop #: WSC 02616 444 178905
   VCID: 45D7AC5319B40C7F022-5160
   Subsystem 1 - Part No: 7L6 907 049 E
   Component: CLIMAtronic FOND    0400
00898 - Control Circuit A/C compressor
02599 - Rear Left Temperature Flap Motor (V313)
            000 -  -  - Intermittent
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3002
   Coding: 0111839
   VCID: 47CBA65B23B81E6FF0E-5160
            000 -  -
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª8472
   Coding: 0060575
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 H
   Coding: 0010032
   VCID: 44D1B157128E357715C-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 R
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0005231
   VCID: 48C9A5672EA61117F94-5160
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 815 071 D
   Component: Standheizung E1MAC
   Coding: 0000100
   VCID: 3333E28B472082CFBC6-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B92D8776B6F9D7814-5160
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   Part No: 0AD 927 755 AT
   Component: TRANSFERCASE        0114
   VCID: 0D4754730144B43F0A2-5160
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  X012
   Coding: 0000003
   VCID: 66954BDF44722767EB8-5184
00492 - Body Pitch Angle from Level Control Module
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 3635DB9F545297E79B8-5160
   Component: Sitzverstellung     0703
Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
   Part No: 7L6 919 887 M
   Component:      Navigation     0047
   Coding: 0000101
   VCID: 50F98D07D6F6D9D7A14-5160
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000003
   Shop #: WSC 02132 444 84388
   VCID: 678B46DB43783E6FD0E-513C
No Faults Found
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 J
   Component:    HSG              5115
   Coding: 0000085
   VCID: 43D3B24B1780324F2C6-4B1E
   Subsystem 1 - Part No: 7L0 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
            000 -  -
Address 47: Sound System        Labels:
   VCID: 55F77C13EC04BCFF722-5160
   Note: Excessive Comm Errors
Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
   Part No: 7L6 035 186 E
   Component:        Radio        0047
   Coding: 0014062
   VCID: 3537DC9349549CFF922-5160
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C21C9B76A7E4DB76DC-5160
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
   Component: J345  Anhaenger     0080
   Revision: 4A009001    Serial number: 00000193524433
   Coding: 0016386
   Shop #: WSC 00512 001 24584
   VCID: 3FDBBEBB7B6856AF48E-5160
   Part No SW: 7L6 907 441     HW: 7L6 907 441
   Component: J772__Rearview      0051
   Revision: 00H07000    Serial number:    PA8 J620411
   Coding: 0000101
   VCID: 72BD278F78BACBC7770-5160
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 T
   Component: DACHDISPLAY         0539
   Revision: 00900539    Serial number: 2009289.07
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 392FD0A3654C789F76A-5160
End----(Elapsed Time: 09:52, VBatt start/end: 12.2V/11.9V. VIgn 12.0V)-----
MVB 067:
1. EGT before turbo'
2. EGT in DPF
3. Differential pressure across DPF
4. Differential pressure sensor offset.
MVB 068:
1. Soot load in %
2. Ash loading in grams.
3. Ask learning value
MVB 073:
1. Fuel consumption since regen
2. Distance since regen
3. Time since regen
atomizer
C?ID=325670
I appreciate your help have a couple of ?? Just for laughs, My neighbor came over from Hungary in 61 as 10yr old with his parents ,he'retired machinist and he jokingly calls me Bushwah capitalistic pig which was a label for people from old country who had benz and all the other well engineered marvels.. Okay 1st)is this in the drivetrain section and am I doing DX for engine i and II seperatly and also if you could send other MVB for engine sensors It would be appreciated, I could send e-mail address if ness. Thanks
atomizer
C?ID=325670
Also on mvb 68 ,block 3 ask learning value what do es this mean if it has 79 in that block?
If I knew, I'd tell you. :)
