Fault reading on Intake Manifold Flap
Fitzie
Ireland
C?ID=143884
Hi, I'm new to the forum - Based in Ireland, I drive an B8 A4 2.0ltr with a CVT box. I have had 4.5 years of virtually trouble free driving with this great car but, but engine management lights just came on out of the blue the other day when I started the car. The car is driving fine but, I'm getting fault readings on the scan with the intake manifold flap and an rpm ECU unit.
I removed the hosepipe on the EGR unit to have a look at the condition/coking of the unit as I thought this may be something to do with it but, although oily the unit was quiet clean withvirtually no coking build up.
Any idea's on what the issue is and how I can resolve the faults? Is it OK to continue driving as I have a 400mile round trip to do in the next week and don't want to come a cropper on same. I read on a thread of another forum that the engine could go into limp mode with this error?
Thanks in advance for any advice!
VCDS Version: Release 12.12.3 (x64)
Data version: 20140822
Monday,20,October,2014,14:18:06:53769
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 56 62 72 77
VIN: WAUZZZ8KX9A205269   Mileage: 173470km/107789miles
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H01 4379
   Revision: 11H01---
   Coding: 0104002C02072118
   Shop #: WSC 00694 210 91850
   ASAM Dataset: EV_ECM20TDI03L906022MK A01006
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: 7AF08555FD0D50CED59-802F
5340 - Intake Manifold Flap; Bank 1
          P2008 00 [096] - Electrical Malfunction
5346 - Intake Manifold Flap; Bank 1
          P2009 00 [175] - Short to Ground
                    Fault Frequency: 13
                    Mileage: 173381 km
                    Date: 2014.10.19
                    Time: 15:34:06
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 H
   Component: 0AW 20TDI RdW H01 0006
   Revision: --H01---    Serial number: 0000000166
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02005
   ROD: EV_TCMVL381.rod
   VCID: 77F69C61CE1F4DA6AA7-8022
2225 - RPM Signal from ECU
          P0727 00 [032] - No Signal
                    Fault Frequency: 0
                    Reset counter: 0
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
   Component: ESP8 front    H04 0240
   Coding: 170500
   VCID: 7CFC834DFF396EFEC75-8029
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H80 0145
   Coding: 011100
   VCID: 3064677D63F15A9E2BD-8065
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: ELVAUDIB8  H36 0041
   Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
   Component: KLIMA 3 ZONEN H06 0150
   Revision: D0000000    Serial number: 01040220091437
   Coding: 34040000
   VCID: 42803DB5DD5DD80ECD9-8017
   Part No SW: 8K0 907 063     HW: 8K0 907 063
   Component: BCM1 1.0      H22 0253
   Revision: 01022001    Serial number: 00000000197652
   Coding: 6900C0B10034A7000001000000005F5F001D420800000141000000
   VCID: ECDC330D0F597E7ED75-80B9
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 020209  H05 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0080
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 F    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0040
   Revision: 11001001    Serial number: 40140904100379
   Coding: 000103
   VCID: 3C7C434DBFB9AEFE875-8069
02070 - Rear Parking Aid Sensors
                    Reset counter: 210
                    Mileage: 158451 km
                    Date: 2014.05.10
                    Time: 12:57:06
                    Temperature: 17.0°C
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1E1YLS
   Coding: 30363435363030303030554A3052384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 3C7C434DB7B9AEFE875-8069
   Serial number: 6334MSME450346140
   Serial number: 6344MSME45754578J
   Serial number: 6352QSME121C0102$
   Serial number: 6362QSME46214B26E
   Serial number: 63732SME511B1E3C4
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME641B1902Y
   Component: Lenks.Modul   H15 0013
   Revision: --------    Serial number: 90304IB40008X
   Coding: 000016
   VCID: 3D7A4E49A4A3A7F6B0B-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
   Component: KOMBIINSTR.   H18 0224
   Revision: 00200000    Serial number: 9E363R929
   Coding: 031F080002002600010000
   VCID: 3162627968FB5396243-8064
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 210
                    Mileage: 158451 km
                    Date: 2014.05.10
                    Time: 12:48:03
   Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0095
   Revision: GB300043    Serial number: 4300G0912801E4
   Coding: 000303
   VCID: 4B9E1091EA1719463EF-801E
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 E    HW: 8K0 959 793 E
   Revision:             Serial number: 0000008466220
   Coding: 011002204001410001
   Revision: 00002001    Serial number: 0116716740
   Coding: 011F062200390400012001
                    Fault Status: 11101100
                    Reset counter: 210
                    Mileage: 158451 km
                    Date: 2014.05.10
                    Time: 12:48:01
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 210
                    Mileage: 158461 km
                    Date: 2014.05.10
                    Time: 13:37:35
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 10
                    Mileage: 158461 km
                    Date: 2014.05.10
                    Time: 13:49:59
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: 6ED8B905B9450C6E791-803B
   Part No SW: 8K0 959 792 E    HW: 8K0 959 792 E
   Revision:             Serial number: 0000008435326
   Coding: 011002204401410001
   Shop #: WSC 06325 123 12345
   VCID: 418232B9D85BC316D43-8014
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 10000000177261
   VCID: 336E687192E7618656F-8066
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
   Component: Concert3      H01 0300
   Revision: 00000003    Serial number: AUZ5Z6I1176957
   Coding: 0502008201018D00437B070900
   VCID: 458A26A9CC73EF36E8B-8010
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
                    Reset counter: 138
                    Mileage: 158451 km
                    Date: 2014.05.10
                    Time: 12:48:02
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000008434141
   Coding: 010002204001210001
   VCID: 448C3BADC749D63EFF5-8011
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000008434161
   Part No SW: 8T0 862 335 D    HW: 8T0 862 335 C
   Component: FSE_256x BT     H33 0600
   Revision: 00000000    Serial number: 00000005057525
   Coding: 0010320
   VCID: 3B7E40517AB7A9C68EF-806E
Gone But Not Forgotten
Two things
Change flap motor since common issue and get the update programming done since firmware update is needed.
If fault returns test he harness via WD in repair manual.
I agree with Jack, several TPIs/flash updates exist for EDC software issues and the earlier 2.0L CR TDI was noted for intake manifold runner issues.
I however do not believe that alone would cause you a serious issue on the upcoming trip ... my only thoughts (without digging for the SSP) would be the DPF and/or EGR behavior. When one system fails, other systems may not operate properly so you could end up with a DPF and EGR system that isn't functional for a few hundred miles.
Fitzie
Ireland
C?ID=143884
Two things
Thanks for your response. Apologies, but when you say 'get the update programming done since firmware update is needed' do you mean after the flap motor is fitted?
Fitzie
Ireland
C?ID=143884
Hi Dana.. Again, thanks for your response... I'm new to a lot of these acronyms i.e. TPI's, EDC and SSP? The DPF & EGR I'm fine with you'll be glad to know:o
Maybe I need to do a regen on the DPF which I could do on the run... Would that be of any benefit?
I just added definitions for a number of those acronyms. TPI was already there, but the software doesn't pick it up when it's pluralized.
Fitzie
Ireland
C?ID=143884
Thanks Uwe...;)
If the MIL was on for a while prior to this inquiry you could certainly try to force a Standing Regen using the UDS instructions here but that shouldn't be necessary if you are fixing the flap motor soon.
