LED DRL's MY12 Octavia - bulb check?
langers2k
C?ID=224085
I suspect this might be a byte 18 mystery.
I want to replace the DRLs on a MY12 Octavia Elegance with LEDs but this will cause a blown bulb warning on the dash. As the VRS model came with LED DRLs I hope it's as simple as copying the coding over, assuming Skoda wire the DRLs in both cars identically...
Any suggestions on both the original byte 18 and a VRS byte 18 would be? Non-xenon in both cases.
Thanks!
Tuesday,07,October,2014,17:19:34:12963
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBBE21Z1C2------
Address 01: Engine (J623-CFHC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 C    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H24 7100
   Revision: 42H24---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 73430 031 00097
   ASAM Dataset: EV_ECM20TDI01103L906018C 003005
   ROD: EV_ECM20TDI01103L906018C.rod
   VCID: 2A5B233B4DCD8A4EE59-807F
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0106
   Revision: 00H35001
   Coding: 0001281
   Shop #: WSC 73430 790 00097
   VCID: 7BF5D67F3AD7C3C6CEF-802E
   Part No SW: 3T0 907 044 BL    HW: 3T0 907 044 BL
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 7DF1D867ECC3CDF6F0B-8028
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 48000AB8E05BB1C040080080110001E4437000AE726D85605C8440000040
   Shop #: WSC 26007 576 125000
   VCID: 3F8D626FAE4F1FE6A27-806A
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 29071  26  0601
   Coding: 00D7B7
   Component: RLS 120811 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901122400152
   Coding: 10800E
   Shop #: WSC 13765 790 00097
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000.rod
   VCID: 33653E5F9A07CB8656F-8066
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC26XCCR
   Coding: 0020788
   VCID: 3D71186764430DF6B0B-8068
   Subsystem 1 - Serial number: 6332MSME63154E54D
   Subsystem 2 - Serial number: 6342MSME624625344
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110808201317
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79F9CC77F8EBF1D6DC3-802C
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
   Part No SW: 1Z0 920 943 S    HW: 1Z0 920 943 S
   Component: KOMBI         H05 0607
   Coding: 410E01
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 49997CB7E88BA1560C3-801C
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 310711F1001106
   Coding: 351303
   VCID: 356100479C73D5B678B-8060
   Component: IMMO          H05 0607
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADB633B0D4DCA4EA59-80BF
Address 37: Navigation (J794)       Labels: 3C0-035-270.clb
   Part No SW: 3T0 035 191 A    HW: 3T0 035 191
   Component: RNS310        H19 0353
   Revision: 11000000    Serial number: SKZ1Z2L0693486
   Coding: 000004010401000000000000
   ASAM Dataset: SK_RNS310 A02007
   ROD: EV_SKRNS310UDS.rod
   VCID: 2B55263F423793461EF-807E
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2120
   Coding: 0000758
   VCID: 76E3C74B01F59EAEB11-8023
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 34673D435709CCBE4F5-8061
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000758
   VCID: 489F79B33B81585E13D-801D
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012545
   VCID: 326B3B5BAD1DC28E5D9-8067
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33653E5F5207CB8656F-8066
langers2k
C?ID=224085
Anyone got any ideas? I've only found one post about byte 18 coding on a similar octavia here: http://forums.ross-tech.com/showthr...CM-(1k0-937-087-J)&p=3388&viewfull=1#post3388
Dana states the following codes:
34,Lighting: Skoda Octavia (1Z/SK35) Rest of World / Left Hand Drive / separate DRLs
36,Lighting: Skoda Octavia (1Z/SK35) Rest of World / Left Hand Drive / Scandinavian DRLs
38,Lighting: Skoda Octavia (1Z/SK35) Rest of World / Left Hand Drive / Xenon-Shutter DRLs
Do we also know what they are for RHD vehicles and the VRS versions?
langers2k
C?ID=224085
Anybody got any ideas? I've tried to PM Dana unsuccessfully (full inbox) so is it possible another ross-tech employee can point this in their direction?
Thanks,
Spacewalker
Poland
C?ID=159607
As long as your BCM support LED light, is easy
Hovewer there is a solutuion now to "code" any BCM to support LED light .
Also you can custom adjust light OUTPUT in BCM , so no need any more swap wires for extra light
Unfortunatelly not via VCDS
langers2k
C?ID=224085
Excellent, so do you happen to know if the 1K0 937 087 Q does support LEDs?
I assume I would need access to VAS to change these settings, are you able to provide any extra information as I'm sure I could find a friendly dealer once I know what I need to change.
Spacewalker
Poland
C?ID=159607
087Q not support LED but can be "adjust" to.
VAS will do almost this same as VCDS, but both unit are not strong enaught this time.
golfi_vend
Tartu, Estonia
C?ID=195131
Internal software has to be modified right?
langers2k
C?ID=224085
So if I did want to try modifying the BCM without using VCDS/VAS, what would I need? Are you able to provide more information or should we take this to PM as it's not really a VCDS question anymore.
Thanks!
Enriquez
Poland
C?ID=72075
You have 2 options:
1. Prepare for the visit in the dealership - to restore Your DRL's working again. If Your vehicle is LHD, change the byte 18 bvalue to $33 or $5B. If this will not help You, come back to 35 or 39. If Your's DRL's will not work at all, You need in this case to go to the dealer, to restore the genuine light setup. They know how to do it. They should know... You can purchase the error cancellers e.g. from this shop: http://sklep.motohid.pl/pl/p/Adapter-Kasownik-do-LED-DRL-Octavia-2-FL,-Superb,-Passat/339
2. Find somebody with VAS 5054a head and ODIS Engineering software. It could be VAG CAN Pro software as well. In the CECM module first login to the access and authorization by using 42013 login. Then go to the CECM memory cells and change the value of the following memory cells: 3109, 3110, 3111 from default values $02, $01, $30 to the modified $02, $81, $70 ($ = HEX).
Xpower
C?ID=163029
The wiring for vRS and non vRS is totally different, The LED's on a vRS have 3 wires and you have 2 to your bulb. vRS also doesn't have the seperate wiring for the side light in the headlight (it's not in the harness from the BCM to the headlight)
Pins are:
Current controlled power supply
On / dimming signal to transistor in DRL module
Enriquez
Poland
C?ID=72075
That's correct, but we are talking not about retrofit vrs leds, but just replace existing bulb by led one.
quattrodave
C?ID=133847
Eagerly watching this thread as I desperately want to fit LED DRL's to mine...
Instead of disabling bulb checking on the DRL circuit would it not be possible to get the BCM to re-learn the resistance values?
Edit: The reason I ask is I see it as unlikely the resistance would be hard-coded as it will only accept a rather small resistance window as 'OK'. So if its not hard-coded then it has to be either a single value or between x value and y value. Essentially all we have to do is find these values and, for want of a better expression, move the goal posts. I must admit this is easier said than done... I know I'm new to VCDS but if it works like I think it works the I'd be surprised if it can't be done via VCDS, I do wonder if we just don't know what all the bits actually do...
It's probably not "hard coded", but "parameterized". The dealer's tools that we use as a reference for developing VCDS do not provide access to those parameter tables. VW has no interest in making it easy to do these sorts of upgrades; they would much rather you bought a heavily optioned model to begin with, because those heavily optioned cars are substantially more profitable for them than more basic models are.
quattrodave
C?ID=133847
Hmmmm food for thought.... Let me have a head scratch....
langers2k
C?ID=224085
I've had a look at the wiring diagrams and it looks like the pins on the BCM which are connected to the sidelights and DRL's in the elegance are both connected to the LED modules on the VRS.
Does anyone know what input the LED module is expecting? Assuming that it uses 12v on one wire to do full brightness (DRL mode) and 12v on the other to do dimmed brightness (sidelight mode) then it might be as easy as recoding byte 18 as a VRS.
golfi_vend
Tartu, Estonia
C?ID=195131
Praise our lord Internet. :)
Pin 1: PO (Positionlight) alle 4 LED`s gedimmt (55 mA)
Pin 2: Masse
Pin 3: DRL bedeutet Day Running Light (also alle 4 zu 100% 380 mA)
langers2k
C?ID=224085
Thanks for that golfi_vend - I've also seen reports of pin 1 and 3 being reversed and that one pin is power and the other is dim/full brightness.
In the wiring diagrams I can see that the following pins on the BCM are connected to
VRS (I've made assumptions about what the pins do, namely as 26 and 44 are only on cars without a sidelight fitted in the main cluster)
25 Fog lights
26 Left LED module pin 3 sidelight
44 Right LED module pin 3 sidelight
48 Left LED module pin 1 DRL
49 Right LED module pin 1 DRL
Elegance
25 Fog lights
26 Left sidelight
44 Right sidelight
48 Left DRL
49 Right DRL
Someone must have an idea of what the byte 18 codes should be for RHD VRS and non VRS cars without xenons? I've also been looking for the part number of a VRS BCM but I've not noticed anything yet.
Enriquez
Poland
C?ID=72075
There is no specified value of byte 18 for VRS model. It's parametrized directly by VAS.
Once, I've looking for that by trying all of the 256 f.... combinations with VCDS, and no success.
One more thing. 1K0 937 087 series has different byte 18 pre-coding table than the newest 1K0 937 087 AN...
So, there will be more complex cobinations for non-VAS users to find out correct CECM type and correct coding, if even possible.
The easiest, legal and cheapest way to retrofit the new bumper from VRS model is just do all the hardware work Yourself and ask dealer to parametrise the light configuration using VAS. If they don't know how to do it, just change the dealer or ask here for instructions.
mtl
Slovenia
C?ID=153305
I will start with this and I assume that you do not want to install VRS LEDs, but just put an LED bulb into existing place for DRLs.
Have you tried ticking Byte 27, Bit 2?
I can confirm that it worked on a 2009 Octavia 2 facelift, though it had this BCM installed: 1K0 937 086 F. No bulb warning after coding.
langers2k
C?ID=224085
That's exactly what I want to do, I've tried setting byte 27, bit 2 tonight and I still get 'Open or Short to Plus' for both bulbs. I've found a willing helper with Van Can Pro so I may look at the locations suggested earlier in the thread.
