2105 Skoda Octavia ABS security access/coding required
akersgarage
C?ID=179893
Hello Wondering if anyone can help me.
Just fitted new ABS unit to an Octavia 3 2015. Wrote down the old ABS coding and coded new unit using this long code.
Coding accepted, no issues with that.
I have posted an auto scan below. As you can see there are various faults related to basic setting on various sensors.
Normally I would carry out basic setting on these and all is good, but the security access wont accept any code I try.
Has anyone managed to carry out basic setting on brake pressure sensor etc or coded a ABS unit on the Octavia 3, do you have the security access code required.
I have tried a few access codes 12233, 27971
Thanks in advance
Thursday,26,July,2018,17:03:12:45930
VCDS Version: 18.2.1.2 (x64)
VIN: TMBKK7NE5F0102516   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A5 A9
VIN: TMBKK7NE5F0102516   Mileage: 32640km-20281miles
Address 01: Engine (J623-CUPA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EM    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7543
   Revision: 83H22---
   Coding: 111D0012032501080000
   Shop #: WSC 73430 031 00110
   ASAM Dataset: EV_ECM20TDI01104L906021EM 002008
   ROD: EV_ECM20TDI01104L906021EM.rod
   VCID: 74E00DA5DF0845E433-8020
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 32640 km
                    Date: 2018.07.26
                    Time: 16:06:16
                    Engine speed: 774.00 /min
                    Normed load value: 53.7 %
                    Coolant temperature: 55 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 14.180 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
   Part No SW: 0D9 300 041 Q    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4504
   Revision: 05853104    Serial number: TFK01409162014
   ROD: EV_TCMDQ250021.rod
   VCID: 264427ED595467747D-8072
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 62194000002237
   Coding: 1C0793915420096E007C060141C92938C92A9000608294F400610070C009
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 44809D65CF28B56443-8010
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 39
                    Mileage: 32640 km
                    Date: 2018.07.26
                    Time: 16:19:05
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 39
                    Mileage: 32640 km
                    Date: 2018.07.26
                    Time: 16:19:05
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 39
                    Mileage: 32640 km
                    Date: 2018.07.26
                    Time: 16:19:05
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 39
                    Mileage: 32640 km
                    Date: 2018.07.26
                    Time: 16:19:05
8299 - Databus
                    Reset counter: 39
                    Mileage: 32640 km
                    Date: 2018.07.26
                    Time: 16:19:05
          C1146 02 [137] - Signal Failure
                    Reset counter: 39
                    Mileage: 32640 km
                    Date: 2018.07.26
                    Time: 16:19:14
   Part No SW: 5E0 907 044 K    HW: 5E0 907 044 K
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 02110104000100011005000000101000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_003_SK37.rod
   VCID: 2D56D8C17CA2542CBC-8078
   Air quality sensor:
   Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86580810141849
   Coding: 0F001A42C24722FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 00110
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79FE3C91F86A388C60-802C
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140911  041 0570
   Serial number:         140919225302
   Coding: 065DDD
   Component: RLHS  037 0059
   Serial number: S5Y14M10D08H18M31S01
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY142022VBC
   Serial number: 00000000000060080525
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331427501751
   Coding: 0031051051
   Shop #: WSC 73430 790 00063
   ROD: EV_EPHVA18AU3700000_002_AU37.rod
   VCID: 3D76E881ACC2C4AC0C-8068
13637426 - Databus
                    Reset counter: 38
                    Mileage: 32640 km
                    Date: 2018.07.26
                    Time: 00:52:40
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P4PL2WW5K
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F0AD289E64E16BC5E-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 809 14
   Serial number: 3576U000000B4B490116
   Subsystem 2 - Part No SW: -----------    HW: 454 002 109 14
   Serial number: 3586U00000013859011.
   Subsystem 3 - Part No SW: -----------    HW: 454 802 809 14
   Serial number: 3516R3752DC040000002
   Subsystem 4 - Part No SW: -----------    HW: 454 802 809 14
   Serial number: 3526R4156DC040000002
   Subsystem 5 - Part No SW: -----------    HW: 454 801 209 14
   Serial number: 3556V0ED0A604000000B
   Part No SW: 5Q0 953 507 DF    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 06101404220386
   Coding: 1410
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 7DF62881EC4204AC4C-8028
   Part No SW: 5E0 920 947     HW: 5E0 920 947
   Component: KOMBI         204 4290
   Coding: 27A509086980A60001086A021000000000000000
   VCID: 69DE6CD188CA880C90-803C
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002533164
   Coding: 030100040F087300EF00026A1C0F00010001050000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011_VW37.rod
   VCID: 428C9B7DD53CBB5471-8016
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000A0954190814
   Serial number: 0800644603
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000120650086
   Coding: 001C00208001040000001100
   Serial number: 00000000000003906373
   Coding: 1D0200
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 9103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3566F0A194F21CECC4-8060
19204 - Databus
                    Reset counter: 79
                    Mileage: 32640 km
                    Date: 2018.07.26
                    Time: 00:44:22
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 12.50 V
                    Temperature: 41.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.80 V
                    uAdSensI_SwitchedKl30_xdu16: 12.79 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000120522662
   VCID: 418E9471D03AA04C68-8014
   Serial number: 00000000000003991880
   Coding: 050200
   Coding: 03DE02003F000000
   VCID: 40889175DB30A94467-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 874 A    HW: 5E0 035 874 A
   Component: MU-S-ND-ER    041 0435
   Serial number: S7F00410143538
   Coding: 03735201FF0000001111120100A800002F0001860100010046
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: SKZ8Z9PT300JRR
   Subsystem 2 - Part No SW: 5E0 051 236 G    HW: -----------
   Component:  ECE 2015  --- 0045
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 00000233923
   Coding: 0100000001030304000400000000010100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B72E699B2D6CA9C32-806E
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 140725201897
End-------------------------(Elapsed Time: 04:13)--------------------------
Should be 40168.
But before you try it, check:
IDE00323 -- Security Access: Number of invalid keys
If this is anything other than zero, put a charger on the car and leave the ignition on until it goes to zero.
Gone But Not Forgotten
Should be 40168.
Just an FYI OP:
Some controllers each time booted, go into "wait times", so don't reset the key when it goes to zero or you just did a big circle.
At that point pf zero obtained in clock counts, login as Uwe aforementioned and commence with your function to perform.
akersgarage
C?ID=179893
Uwe. How do you go about checking this IDE00323 you speak of. This is new to me.
Thanks for the replies guys.
[Select]
[03-ABS]
[Advanced Measuring Values]
On this particular module, IDE00323 should be the first item in the list you can select from, but if it's not, you can type the word 'Security' into the search/filter box and it should be the only thing that turns up.
akersgarage
C?ID=179893
Thanks very much again. Ive seen that section of Adv measured values before but didnt know what it was. Thanks
This car is currently 1 when selected. Will try the ignition on.
