T5.1 Steering wheel retrofit airbag igniter fault
kamold
Australia
C?ID=241363
Hi All,
I recently retrofitted cruise control to a T5.1 along with a Mk6 Golf R sports steering wheel, brand new airbag and a Discover Media.
Tested everything was working and sent the owner on his way.
He had to drive for a few hours to go and pick some things up, then he said that he was doing a 3 point turn when he noticed the airbag warning light come on.
Checked the fault and we had a driver's airbag igniter short to ground fault (no other faults at that point.)
The next day the ESP fault light came on, which was due to steering angle sensor fault.
Seemed to me the most likely cause would be the slip ring (this was not replaced as part of the cruise retrofit, only the stalks).
So I got a replacement slip ring from a Polo wreck and swapped it over - same faults.
Put the original factory airbag back in and faults cleared.
Ok so problem is with the airbag or harness....
I took the working airbag and harness out of my B6 Passat (also a Mk6 R sports steering wheel, but with paddles) and put the suspect airbag into my car - works perfectly, no airbag igniter fault. Both airbags are newer single stage igniter type.
So now I'm a bit confused...my understanding is that this retrofit is compatible. I have added the required wiring for LIN and + from the steering wheel connector to the BCM in the Transporter and all functions on the multifunction steering wheel work including the horn.
Anyone had a similar issue or suggestion?
Autoscan before any work performed:
Wednesday,18,July,2018,09:32:30:58930
VCDS Version: 18.5.4.2 (x64)  HEX-V2 CB: 0.4427.4
Data version: 20180518 DS291.0
VIN: WV1ZZZ7HZAH25   License Plate:
Mileage: 25130km-15615mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 56 0B
VIN: WV1ZZZ7HZAH25   Mileage: 25130km-15615miles
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CK    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H33 9129
   Revision: 26H33---    Serial number: 00000000000000
   Coding: 01254012230400080000
   Shop #: WSC 34251 000 1048576
   ASAM Dataset: EV_ECM20TDI01103L906022CK 002008
   ROD: EV_ECM20TDI01103L906019DG.rod
   VCID: 70B92E0BAA2D70A775D-8024
Address 02: Auto Trans (J217)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 045 F    HW: 0BH 927 711 B
   Component: DSG DQ500-7F  H02 0711
   Revision: 00H02V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3829D62B82DDE8E77DD-806C
Address 03: ABS Brakes (-----)       Labels:. 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 508724AD89A90A9724A39176A96516
   Shop #: WSC 02736 790 49152
   VCID: 3431E21B9E350C87515-8060
   Part No SW: 7E5 907 047 T    HW: 7E5 907 047 T
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis.rod
   VCID: 40D9BECBDA0DA027C5D-8014
   Part No SW: 7H0 937 087 B    HW: 7H0 937 087 B
   Component: BCM T5GP H+4  H46 0207
   Revision: BO046001    Serial number: 0156 064100038
   Coding: A0A0293A0E21200100200000242B8CD40000430F60040000300000000000
   Shop #: WSC 02736 790 00000
   VCID: 3333E1079B3B0BBF48F-8066
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3310
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3310
   Part No SW: 7E0 919 475     HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0008
   Revision: --------    Serial number: 33031004507265
   Coding: 100102
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K A01003
   ROD: EV_VW75XParkAssis4K_A01.rod
   VCID: 6FBB2D77B7136F5F6C7-803A
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag010 H05 0011
   Revision: --------    Serial number: 003E5001DEJQ
   Coding: 000000000000000000000000000000003130
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   VCID: 3431E21B9EB50C87515-8060
   Part No SW: 7E0 920 860 A    HW: 7E0 920 860 A
   Component: KOMBI         H16 0111
   Coding: 160200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   VCID: 2615085358696E17DF1-8072
   Part No SW: 6N0 909 901     HW: 7H0 937 087 B
   Component: GW-K-CAN TP20 0207
   Coding: 042300
   VCID: 70B92E0BAAAD70A775D-8024
   Component: IMMO          H16 0111
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 7E0 035 156     HW: 7E0 035 156
   Component: Radio         H21 0058
   Revision: R0000000    Serial number: VWZAZ1K9819782
   Coding: 0000020001
   VCID: 60995E4B7A4DC027E5D-8034
End----------(Elapsed Time: 01:13, VBatt start/end: 12.3V/12.3V)-----------
myounus
Northwest UK
C?ID=321059
Can you please provide an autoscan 'as is', ie with faults.
Short to ground is normally the harness. Double check the pins are all touching cleanly with no breaks.
kamold
Australia
C?ID=241363
I don't have access to the vehicle at the moment unfortunately.
I couldn't see any evidence of it but perhaps the harness was crimped or trapped somehow when installed in the Transporter.
I'll test the airbag and harness for a few days in my car and make sure the faults don't recur, then put it back in the Transporter and see how it goes. Will post a scan with it faulted if it gets to that point.
kamold
Australia
C?ID=241363
Sorry I forgot to close this one out.
Issue turned out to be the clockspring (slipring).
After swapping the airbag and harness with a known working set, the fault went away. But eventually it started to log ESP faults due to steering angle sensor. This was intermittent, and then eventually the airpbag fault returned.
After replacing the clockspring (which has steering angle sensor integrated) all faults went away and haven't returned.
