Hi,
I ran AutoScan which discovered failure with the G62 sensor.
I refitted a new original sensor original from VAG, cleared all DTC's, but there is stil a problem with the sensor.
I have tried to disconnect the positive cable on the battery to check if that could help.. but no...
Is there anyone that could help me?
Thanks in advance!
Here is the code:
Thanks in advance!
Here is the code:
Monday,20,October,2014,21:45:11:15915
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WVWZZZ1KZ5W050772 License Plate: KH30927
Mileage: 137500km-85438mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72
VIN: WVWZZZ1KZ5W050772 Mileage: 137500km/85438miles
Address 01: Engine Labels: 036-906-032-AXP.lbl
Part No SW: 036 997 032 D HW: xxxxxxxxxxx
Component: BOSCH ME7.5.10 9736
Revision: 00000000 Serial number: VWZ7Z0D0119662
Coding: 0000071
Shop #: WSC 00220 218 16467
VCID: 1B35FCB6DA9BEBC66EF-804E
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 002 - Signal too High - MIL ON
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 N
Component: ASR FRONT MK70 0103
Coding: 0017025
Shop #: WSC 01392 785 00200
VCID: 3D71122E644F85F6B0B-8068
Part No: 1K0 820 047 CS
Component: Climatic PQ35 081 0404
VCID: 77FDC00606F36FA6AA7-8022
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000893085
Coding: 088F8F0600041800001400001400000000
VCID: 3F8D68266E4397E6A27-806A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
Component: 01 AIRBAG VW8 023 0700
Revision: 06023000 Serial number: 00385D0H2AM.
Coding: 0012337
Shop #: WSC 01371 785 00200
VCID: 31693E1EA8177196243-8064
Subsystem 1 - Serial number: 6332MSME35254803
Subsystem 2 - Serial number: 6342MSME224D4903
Subsystem 3 - Serial number: 6351HSME4B483803
Subsystem 4 - Serial number: 6361HSME1C413D03
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 500 0030
Coding: 0000002
VCID: EFED7866FEA3A766F27-80BA
Part No: 1K0 920 851
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0007103
Shop #: WSC 00220 218 96319
VCID: E5C11A4E2C5F6D3688B-80B0
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 27001047060A20
Coding: 3D3F4340070002
VCID: 2959D67E80C70956EC3-807C
Component: IMMO VDD 0814
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0147
Coding: 0000052
VCID: 306F3B1AA31D789E2BD-8065
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.1 1401
VCID: 2F6D3866BE236766327-807A
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 00E802087F2D8404084F0100
Shop #: WSC 00040 218 58589
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Component: Tuersteuergeraet 09 0153
Coding: 0000052
Part No: 1K0 035 186 L
Component: Radio BVX 140 0022
Coding: 0020200
Shop #: WSC 00220 218 89102
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0202
Coding: 0000016
Address 69: Trailer Labels: 8P0-907-383.lbl
Part No SW: 8P0 907 383 HW: 8P0 907 383
Component: ANHAENGERELEKTR H01 0010
Coding: 0000001
VCID: F6E34D0281F996AE311-80A3
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
End ---------------------------------------------------------------------
