Audi A6 C7.5 Massage and Ventilated Seats Retrofit
XPepino
Czech Republic
C?ID=91614
Hello
I put massage and ventilated seats from prefacelift Audi A6 C7 Avant to Facelift Audi A6 Avant C7.5.
There was original textile electric seats with driver memory function, so i have to add only passanger side cables from right door.
I swapped front Climate control:
Original: 4G0 820 043 CD, Coding: 36821178250000 (labels used: 4G0-820-043-4Z.clb)
New one: 4G0 820 043 BM (it was replaced 4G0820043CE in ETKA)
Also swapped rear Climate control: (due rear seats heating + made cables)
Original: 4G0 919 158 Q, coding 20
New One: 4G0 919 158 K
Coding of front clima was not documented in my HEX-CAN so i used from the original one: 36821178250000
There was not working Cooling and seats ventilation worked only 3-5 sec, also massage only shown for while on MMI and does not work. (yes i made CP remove). Clima unit anyway worked optically fine and there was no error in scan.
Then I used HEX-NET cable from my friend and made coding from VCDS experimental Beta - but also without success - cooling, ventilated seats and massage does not work.
I try write here all scan of all units in car (i got car later). I have error on both seats memory units but they are reachable by VCDS and there is also error on instrument cluster after i swap front clima panel.
I tried to coding 09 - central electronics - but there is no label file: (i would like to code, that there is no front heating, because it take care about seats units)
Here is original coding 09 module:
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
   Component: BCM1 2.0      H20 0311
   Revision: 14020001    Serial number: 00001172356502
   Coding: 0105001440349FE2C9014087A0001800CF9CC7082E08020180000894E101170200400009090000
   Shop #: WSC 02391 785 00200
   VCID: 70EBB6F1A32669C4D1-8024
When will you have (experimental) coding of Central El. - V2 ?
Have someone did this retrofit with success ?
Thank you!
P.S. I plan next week to buy new HEX-V2 unlimited, hope it (except Wifi and mobile app) works same way like HEX-NET... (working experimental coding and beta versions i need)
Yes, with VCDS on a PC, it works exactly the same as a HEX-NET plugged in via USB.
XPepino
Czech Republic
C?ID=91614
Perfect!
Due to swap (upgrade) from old HEX-CAN i wait with returning old one after i make this retrofit...
With HEX-NET it can be fine make coding at home but have car outside... but it is much more expensive :-/
XPepino
Czech Republic
C?ID=91614
Hello
Here is my scan from car.
I have Audi A6 Avant 4G C7.5 2015, Engine CRTE 160kW, 3.0 TDI
I tried coding of Central Electric about heating, (from germany VCDS label), it looks ok.
I dont know where is problem but units of Comfort seats does not appear on CAN.
But there was already textile electric seats so this connector looks ok!!!
Another thing is, that i tryied coding of 08 HVAC but there is not still working Cooling :-/ I tried many codes. Ventilation work ok, seats ventilation too. Try also basic settings but not sure if it passed ok.
What do you think ? And why not seats units are not seems on CAN?
Why is not Cooling working?
VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ4G4GNxxxxxxx   License Plate:
Mileage: 80891km-50263mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 28 34 36 3B 3C 42 44
          46 52 53 55 5F 62 6C 6D 72 85 88 89 8B 8E 8F 90 AC
VIN: WAUZZZ4G4GN100931   Mileage: 80891km-50263miles
17-Instruments -- Status: Cannot be reached 0100
88-Multicont. Seat Driver -- Status: Cannot be reached 0100
89-Multicont. Seat Pass. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRTE)       Labels: None
   Part No SW: 4G2 907 311 C    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H34 0002
   Revision: 92H34---
   Coding: 12254012046601030000
   ASAM Dataset: EV_ECM30TDI0114G2907311C 001002
   ROD: EV_ECM30TDI0114G2907311C.rod
   VCID: 254597A524647C6C4B-8070
   Part No SW: 4G0 927 166 A    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0008
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2B51619D42804A1C9D-807E
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 17A6DE49E8657B929B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 418D2335D00CB04C57-8014
   Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
   Component: BCM2 2.0      H37 0572
   Coding: 05A96F0E000000000000
   VCID: 7DF59FC5E47414AC73-8028
   Part No SW: 4G8 959 760 C    HW: 4G8 959 760 C
   Component: MEM-BFS       H04 0154
   Revision: AA000000    Serial number: 00000016109954
   Coding: C018320085006201010001010101112030303333283333
   Shop #: WSC 02311 785 00200
   VCID: 3A7F54D9B5DAE39416-806E
03656 - Control Module for Multicontour Seat; Front Driver-Side
                    Reset counter: 169
                    Mileage: 80891 km
                    Date: 2018.07.25
                    Time: 00:59:33
   Part No SW: 4G0 820 043 BM    HW: 4G0 820 043 BM
   Serial number: 06021500041342
   Coding: 3602007E200000
   Shop #: WSC 06443 128 28888
   VCID: 6BD1A19D82008A1CDD-803E
0272 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 169
                    Mileage: 80891 km
                    Date: 2018.07.25
                    Time: 01:24:32
                    Basic setting of flap motors-Recirculation flap motor: OK
                    Basic setting of flap motors-Flap motor for indirect ventilation: OK
                    Basic setting of flap motors-Left side vent motor: OK
                    Basic setting of flap motors-Right side vent motor: OK
                    Basic setting of flap motors-Left footwell flap motor: OK
                    Basic setting of flap motors-Right footwell flap motor: OK
                    Basic setting of flap motors-Left center vent motor: OK
                    Basic setting of flap motors-Right center vent motor: OK
                    Basic setting of flap motors-Defroster flap motor: OK
                    Basic setting of flap motors-Left temperature flap positioning motor: OK
                    Basic setting of flap motors-Right temperature flap positioning motor: OK
                    Basic setting of flap motors-Left rear temperature door motor: OK
                    Basic setting of flap motors-Right rear temperature door motor: OK
                    Basic setting of flap motors-Fresh air door motor: OK
                    Basic setting of flap motors-Left rear air door motor: OK
                    Basic setting of flap motors-Right rear air door motor: OK
   Coding: 0105001440349FE2C9014084A0001800CF9CC7082E08020180000894E101170200400009090000
   VCID: 70EBB6F1A32669C4E8-8024
   Component: WWS57X 150827  H38 0080
   Serial number:         150920100926
   Coding: 0045F7
   Serial number: 20788606
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 22 10 2015  00000323
   Component: EVLS-SG  H08 0300
   Serial number: WA121418000014967796
   Coding: 020300
   Serial number: 1B1840D7000000000001
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0080
   Revision: --------    Serial number: 56261528901101
   Coding: B82B16
   ASAM Dataset: EV_EPHVA2CAU64X0000 001014
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 366740E989C207F4F2-8062
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 295D9B95487C580C6F-807C
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1006XR7G
   Coding: 30333130313730323539554A304C34473053
   VCID: 3B7151DDB2E0DA9C0D-806E
   Serial number: 3575HRB40553LHKE2PM+
   Serial number: 3585HRB405J3LHKEC1K/
   Serial number: 3515JRB405P3JK6278SQ
   Serial number: 3525JRB405R3K164HG9C
   Serial number: 3554VRB4008553H0D15I
   Serial number: 3564VRB4006553H4CPRN
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372OJQ00077
   Coding: 0004FD
   VCID: 387B4ED18BD6F184E0-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0009
   Serial number: 29 06 2011  11148824
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 934 H    HW: 4G8 920 934 H
   Component: TDieRdwAcc    H11 0104
   Revision: 07001088    Serial number: 658131015596041
   Coding: 038612001F550008080000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K.rod
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002019450
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 4304577903
   Voltage stabilizer:
   Serial number: 15072900000000000376
5046 - Control Module for Multi-Contour Seat; Driver Side
          U1083 00 [009] - No Communications
                    Reset counter: 169
                    Mileage: 80891 km
                    Date: 2018.07.25
                    Time: 00:59:32
                    Voltage terminal 30: 14.0 V
                    Voltage terminal 15: 13.9 V
                    Control Module temperature: 41 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
5047 - Control Module for Multi-Contour Seat; Passenger Side
          U1085 00 [009] - No Communications
                    Reset counter: 169
                    Mileage: 80891 km
                    Date: 2018.07.25
                    Time: 00:59:32
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 X299
   Serial number: 17051300040785
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 37794DED8EC8FEFCE9-8062
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F69758D7698363CB1-807A
   Component: MEM-FS        H04 0154
   Revision: AA000000    Serial number: 00000016110514
   Coding: C0183B0085016201010001010101112030303333203333
03657 - Control Module for Multicontour Seat; Front Passenger-Side
                    Reset counter: 169
                    Mileage: 80891 km
                    Date: 2018.07.25
                    Time: 00:59:33
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820ADWCS
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H07 0060
   Serial number: 0383839204
   Coding: 040311
   VCID: 397D4BD5B8DCE88C1F-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H07 0060
   Serial number: 0384004426
   Coding: 040311
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F16205E00628002080013
   VCID: 45853725CC249C6C6B-8010
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000308997
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A7F54D9BDDAE39416-806E
   Revision: 00002001    Serial number: 0382776124
   Coding: 01000E3820B93081C32009840C030F4F0000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00016043045
   Subsystem 2 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93656352
   Component: TSG BF        H03 0511
   Coding: 011F16205E00628002080002
   VCID: 46873029F122977462-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001621928
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D556F857C94442C83-8078
   Coding: 04FA02202A170200
   VCID: 34637AE19FBE15E4CC-8060
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 044 E    HW: 4G1 035 044
   Component: MU-H-LN-EU    042 0335
   Serial number: A589J0F7540746
   Coding: 01750201FF0A000013110001000A00102F0006E5F1700100BF
   VCID: 214D83B5304C904C37-8074
   Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
   Component: ECE 2018  --- 0166
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9FY8037VG
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349OJD0000G
   Compact Disc Database:
   Component: Gracenote  --- 1010
   Component: TSG HL        H03 0511
   Coding: 010F15004000628002080002
   VCID: 499D3B15E03C780C8F-801C
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H08 0361
   Revision: 11001001    Serial number: 82330JG0121226
   Coding: 0213000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 280501070
   Coding: 093205C030
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0511
Address 85: On Board Cam. (J852)       Labels:* None
   Component: DPC-SG        H27 0081
   Coding: EA160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C536281478E4D2494-8078
Address 88: Multicont. Seat Driver
Address 89: Multicont. Seat Pass.
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 27599DAD5E686E7C79-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000622610157
   Coding: 04C0BB181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Component: RGS-VL        H14 0080
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 316D73F560AC20CCA7-8064
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 326F7CF965AA1BD4DE-8066
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 152741199
   ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 06:15)--------------------------
Are you sure that these seats are really the "Multi-Contour" seats that have their own control modules?
XPepino
Czech Republic
C?ID=91614
Ups hope yes :-)
My seats looks the same like these: (massage and ventilated - it is picture from internet)
0f8ddb39-6592-4fd7-9013-e658cdcf5fb5_audi-a6-iv-c7-3-0-tdi-272km-s-tronic-salon-polska-wentylacja-masaz-fv23.jpg
Question is, if can be massage and ventilated and cannot be Multi-Contour
I will try to check, if there are modules from bottom...
T.
XPepino
Czech Republic
C?ID=91614
So i found the error, why this unit is not on CAN :-)
Simply - it has no power :-)
My electrician connect 12V+ - what was in 17pin red connector under the seat to green connector heating 12V+ what is connected to central electric :-)
And this PIN uses Multicountour unit for power... So it can work only if heating was on.
Ok, with Multi countour seats it seems on the good way!!!
But i still have no working cooling :-(
Any advise ? Can be it in coding ?
I ordered today better HEX-NET multi VIN interface in upgrade program from CZ.
Notice:
So for them, who want to switch from Electric seats to Multi-contour seats, they should add in RED connector PIN 17 and connect it to Fuse Carrier ST2/SB3 (from MY2014 facelift) or ST3/SB6 (from 2011 to 2014)!
XPepino
Czech Republic
C?ID=91614
So what do you think ?
Can i use Prefacelift Clima panel 4G0 to Facelift Audi A6 C7.5 ?
I cannot find facelift one with code CE :-(
First it seems if i compare both of them the lenght of coding is different.
Old one - massage seats with ventilation prefacelift
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H11 0070
   Serial number: 17051100040315
   Coding: 3602007E20
   Shop #: WSC 45343 001 1048576
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 285B9E9153766102C8-807C
And facelift massage seats with ventilation: (not my)
   Part No SW: 4G0 820 043 CE    HW: 4G0 820 043 CE
   Serial number: 06021500041506
   Coding: 3601317A590000
   VCID: 64CDD1486F91546615-8030
XPepino
Czech Republic
C?ID=91614
After i used also facelift Klima 4G0 820 043 BM, there was an error and cooling does not worked: (there is BM successor - CE, what is not available on the market :-( )
0556 - A/C clutch
          B1488 11 [009] - Short to Ground
                    Reset counter: 170
                    Mileage: 80891 km
                    Date: 2018.07.26
                    Time: 23:34:22
                    Voltage terminal 30: 14.05 V
                    A/C clutch-Remaining run time for play protection: 0.0 s
                    A/C clutch-Status: OFF
                    A/C clutch-Supply voltage: 6.5 V
                    A/C clutch-Current power consumption: 5.000 A
XPepino
Czech Republic
C?ID=91614
Hello, so what do you think ?
Will work prefacelift Clima panel in Facelift ?
siLc
Tallinn, Estonia
C?ID=330192
Mind posting a new autoscan with Multicontour seats visible on the CAN ?
Do the seat cooling modules show up as slave modules to the J519? Buy a hourly access et ErWin and get the appropriate wiring diagrams.
XPepino
Czech Republic
C?ID=91614
Hello
yes here is:
Tuesday,30,October,2018,01:06:27:12448
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
VIN: WAUZZZ4G4GN100931   License Plate:
Mileage: 83449km-51852mi   Repair Order:
VIN: WAUZZZ4G4GNxxxxx   Mileage: 83449km-51852miles
Address 01: Engine (J623-CRTE)       Labels: Redir Fail!
   Component: 3.0TDI EDC17  H34 0003
   Revision: 92H34---
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM30TDI0114G2907311C 001003
   VCID: 2502051A24D1A66286-8070
   Revision: --H03---
   Coding: 100001
   VCID: 2B16F3224235901250-807E
   VCID: 41CAB18AD0B96A429A-8014
   VCID: 7DB20D7AE4C1CEA2BE-8028
   VCID: 3A38C666B56F399ADB-806E
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 19101500040623
   Coding: 368211BE250000
   VCID: 63865B026A651852A8-8036
Address 09: Cent. Elect. (J519)       Labels:. User\4H0-907-063-V2.clb
   VCID: 70AC244EA393B3CA25-8024
   Coding: 0045F7
   Coding: 02006D
   Coding: 020300
   Coding: B82B16
   VCID: 3620D2568977DDFA3F-8062
   Coding: 7E04010202
   VCID: 291A092A48C98202A2-807C
   VCID: 3B36C362B2550092C0-806E
   Coding: 0004FD
   VCID: 383CDC6E8B632B8A2D-806C
   ROD: EV_RBD4K.rod
   Coding: C0CD078118
   Voltage stabilizer:
   Coding: 20
   VCID: 373EDF528E7D24F224-8062
   Coding: 008002
   VCID: 2F2EE732762DEC327C-807A
   ROD: EV_SARA2.rod
   Coding: 040311
   VCID: 393AD96AB8693282D2-806C
   Coding: 040311
   Coding: 011F17015E00628002080013
   VCID: 45C2A59ACC914662A6-8010
   VCID: 3A38C666BD6F399ADB-806E
   Coding: 011F17015E00628002080002
   VCID: 46C0A296F1974D7AAF-8012
   VCID: 2D12FD3A7C219E224E-8078
   VCID: 3424E85E9F0BCFEA01-8060
   Coding: E01F00
   Coding: E01F00
   Coding: E01F00
   Coding: E01F00
   Part No SW: 4G1 035 044 H    HW: 4G1 035 044
   Component: MU-H-LN-EU    042 0924
   Coding: 01750201FF0A000013110001000A00102F0006E5F17001009F
   Shop #: WSC 41834 002 1048576
   VCID: 2404181E2FEB5F6A91-8070
   Component: DU8 C7 SV  H63 0007
   Component: Gracenote2  --- 1012
   VCID: 49DAA9AAE089A20242-801C
   Coding: 093205C030
   Coding: FA160000
   VCID: 2C14F03E473B972A59-8078
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00002607222501
   Coding: 766FF0
   Shop #: WSC 06745 128 28888
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00002607253001
   Coding: 366FF0
   Coding: 7E04010202
   VCID: 271E0F125EDDB472B4-8072
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   VCID: 312AE14A6019FAC26A-8064
   ROD: EV_RGS_R.rod
   VCID: 3228EE46651FC1DA13-8066
End----(Elapsed Time: 02:18, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
