Trying how to figure out why Intake Manifold Flap buzzes with key off and out
Da Tow'd
Canada
C?ID=217062
Hi Gang,
As the title states" Trying how to figure out why Intake Manifold Flap buzzes with key off and out"
some of the Scan shows
19557 (V157) open or short to ground intermittent
19558 (V157) no signal
checked the wires
2004 PD Jetta
any ideas appreciated
thanks
Hank
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum.
Please post a full Autoscan in between CODE tags [CODE] Full AutoScan [/CODE] .
Da Tow'd
Canada
C?ID=217062
dayum I can't find where I saved the scan on shop computer but have a paper copy I made.
Da Tow'd
Canada
C?ID=217062
Found it
Wednesday,27,August,2014,16:01:37:44816
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: 3VWSR69M54M024172   License Plate: HGT46
Mileage: 303190km-188393mi   Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
VIN: 3VWSR69M54M024172   Mileage: 303190km/188393miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 038 906 016 H    HW: 028 101 114 6
   Component: R4 1,9L EDC G000SG  6327
   Revision: 12345678    Serial number: VWZ7Z0C7560992
   Coding: 0150031
   Shop #: WSC 00066 000 00000
   VCID: 1939D9D1D336A2D67C9-5122
18996 - Turbocharger Boost Control Position Sensor Circuit
            P2564 - 000 - Signal too Low
                    Torque: 0.0 Nm
                    Lambda: -5.1 %
                    Absolute Pres.: 183.6 mbar
                    Absolute Pres.: 999.6 mbar
16502 - Engine Coolant Temp. Sensor (G62)
            P0118 - 000 - Signal too High - Intermittent
                    RPM: 1155 /min
                    Torque: 68.0 Nm
                    Speed: 9.0 km/h
                    Load: 17.3 %
                    Voltage: 14.36 V
                    Bin. Bits: 00001000
                    Temperature: 12.6°C
                    Temperature: 18.9°C
19558 - Motor for Intake Manifold Flap (V157)
            P3102 - 000 - No Signal
                    Torque: 240.0 Nm
                    Voltage: 12.24 V
                    Bin. Bits: 00001100
                    Torque: 0.0 Nm
                    Torque: 110.0 Nm
16791 - EGR Sensor 2
            P0407 - 000 - Signal too Low - Intermittent
                    Torque: 210.0 Nm
                    Lambda: 0.0 %
                    Mass Air / Rev.: 1000.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
                    Bin. Bits: 00000000
19557 - Motor for Intake Manifold Flap (V157)
            P3101 - 000 - Open or Short to Ground
                    Torque: 202.0 Nm
                    Voltage: 11.86 V
                    Bin. Bits: 00001100
                    Torque: 0.0 Nm
                    Torque: 110.0 Nm
18009 - Relay for Supply Voltage Terminal 30 (J317)
            P1601 - 000 - Implausible Signal
                    Torque: -98.0 Nm
                    Voltage: 11.48 V
                    Bin. Bits: 00000000
                    Bin. Bits:        0
                    (no units): 0.0
Readiness: 1 5 0 0 1
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0004097
   VCID: 33650B79519A7886565-5140
   Part No: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0003
   Coding: 12340
   Shop #: WSC 00066
   VCID: 275DEF29C5420426FAD-5104
00591 - Seat Belt Switch; Driver (E24)
            32-00 - Resistance Too High
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00066
   VCID: 2F6D0709EDB25C6632D-5122
01426 - Controls in Steering Wheel (E221)
            41-10 - Blocked or No Voltage - Intermittent
00926 - Terminal 30
   Part No: 1J5 920 806 Q
   Component: KOMBI+WEGFAHRSP VDO V52
   Coding: 15332
   Shop #: WSC 91444
   VCID: 3A7B265D26F089CE953-5104
   3VWSR69M54M024172     VWZ7Z0C7560992
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 91444
   VCID: F0EF4475B00C839EEB7-5104
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 377D3F6915E294A66AD-4AE4
   Component: 1H Tõrsteuer.FS KLO 0202
   Component: 1H Tõrsteuer.BF KLO 0202
   Component: 1H Tõrsteuer.HL KLO 0202
   Component: 1H Tõrsteuer.HR KLO 0202
9 Faults Found:
            37-00 - Faulty
01359 - Internal Central Locking Switch; Passenger Side (E198)
            37-00 - Faulty
00934 - Electric Window Motor; Rear Left (V26)
            62-10 - No or Incorrect Adjustment - Intermittent
            37-00 - Faulty
00935 - Electric Window Motor; Rear Right (V27)
            37-00 - Faulty
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 F
   Component:    Radio ZSW        0016
   Coding: 04401
   Shop #: WSC 00066
   VCID: 2345FB39B17AE806A65-5104
01336 - Data Bus for Comfort System
            37-10 - Faulty - Intermittent
My guess is you have a poor electrical connection somewhere. Check wiring diagrams to see of the stuff that you've got fault codes for has anything in common, either a common voltage supply or a common ground.
Gone But Not Forgotten
The reason for this noise.............
The ecu is saving data performing house cleaning to eeprom of last stored/learned adapted, DTC's, and wear limits of components for next start up.
This usually lasts up to about 20 seconds after key off and out............ then stops.
Considered normal.
In addition to what Uwe stated.
Look at codes and note data such as this one.
P3101 - 000 - Open or Short to Ground <<<<<<<<<<<<<<<<<<<<<< This one shows short to ground/open so check sensor for actual short in addition to harness.
Torque: 202.0 Nm
Voltage: 11.86 V <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Voltage appears to be an issue and there is additional DTC/code for it for terminal 30 B+
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 110.0 Nm
Check the battery/ plus connections and charging system as well as all grounds to chassis.
Da Tow'd
Canada
C?ID=217062
Thanks for the replies guys,
today I removed the battery and cleaned the 4 ground connections under it also the ground wire to the bolt on block between engine and trans.
the last one had a little "green" on it, cleaned them then put a little dielectric grease on.
Is there a easy way to get to the relay panel below fuse panel on left side of car?
Trying to locate the relay 106 or was it 901 due to
Torque: -98.0 Nm
Voltage: 11.48 V
Bin. Bits: 00000000
Bin. Bits: 0
(no units): 0.0
work done to car
removed and cleaned EGR and intake manifold --coked up less than 1/2 the original diameter
replaced IMF old one had black oil inside( where would the oil come from?)
freed up the vanes on turbo with easy off engine cleaner checked operation with vacuum pump
found and replaced the broken wires to the turbo control
replaced the water temperature sender green one in, black out
Battery will drain in two days -- door lock micro switch possible
Hank
