Finally got my replacement warning light from Audi, rushed home to fit it and....same error codes (short to positive/open circuit) plus a new one U004700.
The new code seems to relate to an intermittent CAN bus issue.
I’ll attach the scan below.
I checked both the warning lights to see if all four LEDs in both lights were working - they are.
I checked to see if the lights were connected the right way - they are.
I checked to see if constant 12v was being supplied to the light – it is.
I checked continuity from the other light terminal back to the module.
Voltage on the permanent live is 12v and on the other terminal is 5.72v.
I checked continuity both wires from the Gateway back to the bumper module – all OK.
I checked continuity both wires to another point on the same Canbus circuit - all OK.
I had to extend the loom canbus wiring owing to the change from LHD to RHD(see earlier post). I got some wire slightly thicker than the original, twisted together, soldered connections and heat shrink and checked continuity.
This evening my wife, the usual driver of the SQ5, caually mentioned that she had seen the warning lights illuminate from time to time! This despite dash message the side assist not available!
To be honest I’m completely stumped so any ideas of what to check next would be very welcome..
Friday,17,August,2018,20:23:17:63302
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
VIN: WAUZZZ8R8FA079650 License Plate: CJ55RDJ
Address 3C: Lane Change Labels: 5Q0-907-566.clb
Control Module Part Number: 8T0 907 566 B HW: 8T0 907 566 B
Component and/or Version: Master H05 0071
Software Coding: 010312
Work Shop Code: 06334 123 12345
Dataset: EV_LaneChangAssis 001020 (AU48)
VCID: 3F8CC8ECA68AFABC1D-806A
512260 - Extended CAN Bus (SAE Bus C)
U0047 00 [008] - Performance
[New feature! Extended fault detail is only supported by current gen. interfaces]
Reset counter: 221
Mileage: 34319 km
Date: 2018.08.03
Time: 23:27:04
730378 - Warning Lamp for Lane Change Assistance in Driver-Side Ext. Mirror
C1116 15 [009] - Open or Short to Plus
Reset counter: 181
Mileage: 34319 km
Date: 2018.08.03
Time: 23:26:57
730634 - Warning Lamp for Lane Change Assistance in Passenger-Side Ext. Mirror
C1117 15 [009] - Open or Short to Plus
Reset counter: 181
Mileage: 34319 km
Date: 2018.08.03
Time: 23:26:57
