Just wondering, is there any way to get my car to memorize specific settings, like HVAC temperature, radio channel, drive select profile etc based on which key is used?
I tried searching and only thing I found was something called Personalization active or something like that, in module 09 long coding. Checked that bit, but saw no difference.
Any hints as to where else I should make changes? Or is this functionality simply not possible? Our other car (A4 8K) has this feature and it is quite nice, since my wife likes quite different settings than I do...
Most recent auto-scan, without that personalization bit checked in module 09. Also G247 has already been replaced (real PITA to do!), so no worries about that...
Monday,28,May,2018,14:43:25:26429
VCDS Version: 18.2.0.3 HEX-V2 CB: 0.4411.4
VIN: WAUZZZ8V0EA015968 License Plate:
Mileage: 121257km-75345mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 22 42 44 52 55 5F 69 BB BC
VIN: WAUZZZ8V0EA015968 Mileage: 121257km-75345miles
Address 01: Engine (J623-CJSB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 B HW: 06K 907 425 A
Component: 1.8l R4 TFSI H09 0003
Revision: --H09---
Coding: 0A9D00322436010B2000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
ROD: EV_ECM18TFS0218V0906264B.rod
VCID: 3B23CA2E33E3D30F67A-806E
15042 - Fuel Pressure Sensor (G247)
P119A 00 [096] - Malfunction
Mileage: 119929 km
Date: 2018.05.04
Time: 06:20:26
Engine speed: 3079.25 /min
Normed load value: 56.9 %
Vehicle speed: 121 km/h
Coolant temperature: 80 °C
Intake air temperature: 10 °C
Voltage terminal 30: 14.765 V
Unlearning counter according OBD: 9
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 853 s
MAP_MES_SAE: 157 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.168 V
FAC_LAM_LIM[1]: -27.089 %
FUP_H_SAE: 20130.0 kPa
Part No SW: 0D9 300 011 L HW: 02E 927 770 AN
Component: DQ250-6A MQB H52 4006
Revision: 05652104 Serial number: TFK01305220004
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1E6523BA8031A627604-804A
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 616130000001AF
Coding: 12F16AA234212A710180070641CB2948562C5480E08294F4024100388508
Shop #: WSC 09892 123 104857
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 7BA30A2E7363130F27A-802E
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[IPB: Supply Voltage below undervoltage threshold]
Reset counter: 22
Mileage: 12989 km
Date: 2013.11.25
Time: 06:39:17
Part No SW: 8V0 820 043 A HW: 8V0 820 043 A
Component: AC Automat H13 0031
Revision: 20021000 Serial number: 00000000099176
Coding: 03000004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
VCID: 3039ED02EAA52057C28-8064
263682 - Exterior Air Quality/Humidity Sensor
B137A 31 [009] - No Signal
Reset counter: 246
Mileage: 109501 km
Date: 2017.10.24
Time: 14:40:02
Outside air temperature: 19.5 °C
Voltage terminal 30: 14.7 V
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011316201758
Coding: 04021B46C2C122FD43844004001807A8000C000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77AB161E4F4B376F432-8022
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130531 041 0580
Serial number: 130605022756
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 21404519
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Serial number: 15 05 2013 00000326
395521 - Function Limitation due to Active Protection Function
B2023 00 [008] - -
[Störschutzzählerüberlauf]
Reset counter: 17
Mileage: 120695 km
Date: 2018.05.15
Time: 14:22:43
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831316301318
Coding: 0000050111
Shop #: WSC 58799 001 104857
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_002_AU37.rod
VCID: 3829D52202D5F8178A8-806C
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R01XNWE
Coding: 98CCC0000C0000005C5400CA004800000065
VCID: 4BC39AEE6343638FD7A-801E
Subsystem 1 - Part No SW: ----------- HW: 480 002 905 13
Serial number: 35767000000E846C1D00
Subsystem 2 - Part No SW: ----------- HW: 480 002 905 13
Serial number: 358670000005E46C1D0+
Subsystem 3 - Part No SW: ----------- HW: 480 401 306 13
Serial number: 3516502C9107446432E2
Subsystem 4 - Part No SW: ----------- HW: 480 401 306 13
Serial number: 3526502C91074465F303
Subsystem 5 - Part No SW: ----------- HW: 480 402 604 13
Serial number: 3556502B7105065592B2
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 506 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502BB105066582C6
Subsystem 7 - Part No SW: ----------- HW: 480 400 506 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502BB1050661521W
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 606 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502AD10CBDF4A37V
Part No SW: 8V0 953 521 B HW: 5Q0 953 549 A
Revision: -------- Serial number: 11061308490398
Coding: A418
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 392FD02639DFE11F756-806C
Part No SW: 8V0 920 870 G HW: 8V0 920 870 G
Component: KOMBI H03 2210
Coding: 07AD08082B8000080100AA00000000
VCID: 3FDBBE3E27FBCF2F4B2-806A
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000647351
Coding: 030100042B085A005B0002481C0B00000001000000000000000000000000
ROD: EV_GatewLear_009_VW37.rod
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 02 06 2013 C0272476
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051468196
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 8V0 857 511 HW: 8V0 857 511
Component: FLA H03 0002
Revision: AA001001
Coding: 02018764747464545425363E00
Shop #: WSC 15420 000 1048576
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 79AF1026795F211F356-802C
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00017.04.13
Coding: 0001
VCID: 46D5ABDA78219EE7084-8012
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 07061306070553
Coding: 001C8E204000040000001002
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D27C4362DF7DD3F59E-8068
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 25051306070222
Coding: 001C86204000040000001002
VCID: 3E25C33A20F1C627404-806A
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Coding: 01AA000001000000
VCID: 75B71C165547457F51E-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 840 A HW: 8V0 035 840
Component: MU-S--ER 039 0370
Serial number: A3E01106131184
Coding: 01730300FF00000011110001000A00002F0001040100010002
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 3333E20E1BB31B4FBFA-8066
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9DG601AN1
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000031051300021226
6179 - Display Module 1 for Multimedia System
B1297 F6 [008] - Cable for Video Signal; Open Circuit
Fault Frequency: 68
Reset counter: 30
Mileage: 110584 km
Date: 2017.11.08
Time: 15:42:08
Voltage terminal 30: 12.0 V
Part No SW: 5Q0 907 383 HW: 5Q0 907 383
Component: Anhaenger H11 0030
Revision: 6A001003 Serial number: 00000193727355
Coding: 0101000200000000
ASAM Dataset: EV_TrailFunctDemouHella 001001
ROD: EV_TrailFunctDemouHella.rod
VCID: 74B121125E3D5C77660-8020
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 21051302090272
Coding: 000C86204000040000001002
VCID: 41DFB8C6510FB9DF3D6-8014
Component: TSG HBFS 010 0006
Serial number: 21051304080272
End----------(Elapsed Time: 02:55, VBatt start/end: 12.0V/12.0V)-----------
