Audi A5 DPF regeneration timeout
Kristian Hasa
Albania
C?ID=309376
Hello i did a cleaning of the dpf and need to do diesel particle filter regeneration on a 2009 audi a5 but there is a problem. When select Service regeneration of particle filter i press go and i do what the software says (press brake and accelerator) and relase them when it says on the screen but after doing that it says timeout what is that and why is it not letting me do the regen here is a autoscan
VIN: WAUZZZ8T69A054553   License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 3C 42 46 52 53 55 56
          5C 5F 69
VIN: WAUZZZ8T69A054553   Mileage: 189520km-117762miles
13-Auto Dist. Reg -- Status: Cannot be reached 1100
20-High Beam Assist. -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: Malfunction 0010
Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K2 907 401     HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H01 0006
   Revision: 15H01---
   Coding: 0114002C190F0A28
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TDI0118K2907401 001006
   ROD: EV_ECM30TDI0118K2907401.rod
   VCID: EA989AF70DBB011419-80BE
4528 - Coolant Fan Control Circuit 2
          P0481 00 [039] - Electrical Malfunction
                    Mileage: 189522 km
                    Date: 2018.07.17
                    Time: 09:45:04
                    Engine speed: 640.00 /min
                    Normed load value: 21.6 %
                    Coolant temperature: 72 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 13.840 V
                    Crankshaft speed (RPM): 640.0 /min
                    Vehicle speed: 0.00 km/h
                    Intake air temperature: 40.4 °C
                    Air mass: specified value: 200.0 mg/stroke
                    C Thmst r: 0.00 %
                    Field regeneration status-Bits 0-7: 00000000
                    Field regeneration status-Bits 0-7: 00010000
                    Exhaust gas temp.bef.turbocharger: -273.1 °C
5188 - Diesel Particle Filter
          P2463 00 [167] - Excessive Soot Accumulation
                    Mileage: 189522 km
                    Date: 2018.07.17
                    Time: 09:45:06
                    Engine speed: 2472.00 /min
                    Normed load value: 26.7 %
                    Crankshaft speed (RPM): 2472.0 /min
                    Particle filter: soot mass measured: 33.70 g
                    Particle filter: soot mass calculated: 51.43 g
                    Particle filter: kilometers since last regeneration: 895358 m
                    P Flt Rgn st Intr-Bits 0-7: 00000001
                    P Flt Rgn st Intr-Bits 0-7: 00001000
                    Particle filter: time since last regeneration: 0 s
5308 - Throttle Body Actuator Bank 1 (J338)
          P0638 00 [039] - Implausible Signal
                    Mileage: 189522 km
                    Date: 2018.07.17
                    Time: 09:45:05
                    Engine speed: 1395.50 /min
                    Normed load value: 99.6 %
                    Voltage terminal 30: 13.880 V
                    Crankshaft speed (RPM): 1395.5 /min
                    Thr Vlv r: 100.00 %
                    Ambient temperature: 28.5 °C
                    Throttle valve output stage: 5.00 %
                    Vehicle voltage terminal 30: 13880 mV
9491 - Oile Pressure Regulating Valve
          P164E 00 [039] - Electrical Malfunction
                    Mileage: 189522 km
                    Date: 2018.07.17
                    Time: 09:45:04
                    Engine speed: 642.00 /min
                    Normed load value: 21.2 %
                    Voltage terminal 30: 13.800 V
                    Crankshaft speed (RPM): 642.0 /min
                    Vehicle voltage terminal 30: 13800 mV
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 189522 km
                    Date: 2018.07.17
                    Time: 09:45:04
                    Engine speed: 641.50 /min
                    Voltage terminal 30: 13.860 V
                    Crankshaft speed (RPM): 641.5 /min
                    Accelerator position: 0.00 %
                    Vehicle voltage terminal 30: 13860 mV
                    Bus Diag st Node 0-Bits 0-7: 00000000
                    Com ct Rx TO ACC-Bits 0-7: 00001000
                    Cr C st Key 0-Bits 0-7: 00000000
5189 - Particulate Trap Bank 1
          P2002 00 [039] - Efficiency Below Threshold
                    Mileage: 189522 km
                    Date: 2018.07.17
                    Time: 09:45:06
                    Particle filter: difference pressure: 60 hPa
                    Exh t Adap T Oxi Cat Ds: 115.7 °C
                    Exhaust gas temperature before particulate filter: 83.6 °C
                    Exhaust gas vol.flow particulate filter: 260.9 m³/h
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 A    HW: 0B6 927 156
   Component: 0B6 30 TDIRdW H04 0050
   Revision: --H04---
   Coding: 001001
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: B424448F1FFF87E473-80E0
4765 - Functionality limited due to Engine Control Module
          P1719 00 [047] - -
          [Text noch nicht vorhanden - KFC_GBMOT-KFA_KSM]
                    Mileage: 189522 km
                    Date: 2018.07.17
                    Time: 09:45:04
                    Transmission input speed: 618 /min
                    Engine torque: -12 Nm
                    Transmission fluid temperature: 57 °C
                    Accelerator position: 0.0 %
                    Clutch status: 0
   Part No SW: 8K0 907 379 AH    HW: 8K0 907 379 AH
   Component: ESP8 quattro  H04 0230
   Coding: 14CD00
   VCID: FF4E5BA36E3994BCDE-80AA
01319 - Control Module for Distance Control (J428)
                    Fault Frequency: 74
                    Reset counter: 13
                    Mileage: 189195 km
                    Date: 2018.04.16
                    Time: 16:13:10
                    Hex Value: 0x0000
                    Hex Value: 0x4082
                    Hex Value: 0x0024
                    Hex Value: 0xB48F
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 48
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:05:19
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x0031
                    Hex Value: 0x029B
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 CQ    HW: 8K0 907 064 CQ
   Component: BCM2 2.0      H07 0437
   Coding: 050000
   Shop #: WSC 49816 002 1048576
   VCID: 814ADD5B18CDE24CA8-80D4
   Subsystem 1 - Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K
   Serial number: 0509000013725003
   Component: J764 ELV MLB  H38 0042
   Serial number: 3216000122698016
03285 - Sensor for Contact with Door Handle; Front Left
                    Reset counter: 4
                    Mileage: 189195 km
                    Date: 2018.04.16
                    Time: 16:13:15
                    Fault Frequency: 37
                    Reset counter: 48
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:27:29
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Fault Frequency: 53
                    Reset counter: 48
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:27:30
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:00:58
                    Reset counter: 48
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Fault Status: 00100001
                    Fault Frequency: 8
                    Reset counter: 48
                    Mileage: 189244 km
                    Date: 2018.07.11
                    Time: 10:35:23
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01210420091108
   Coding: 36120000
   VCID: F2A882972D6BC9D4A1-80A6
01230 - Left Footwell Vent Temperature Sensor (G261)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 4
                    Mileage: 189195 km
                    Date: 2018.04.16
                    Time: 10:13:35
                    Temperature: 21.0°C
                    Voltage: 13.70 V
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:31:52
            000 -  -  - Intermittent
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:28:45
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:11:53
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:31:52
   Component: BCM1 1.0      H26 0253
   Revision: 05026001    Serial number: 00000000249005
   Coding: 260050914074AF010009000300005D5D0F1C638800010141000000
   VCID: B02C489FE3E7BBC417-80E4
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 250708  H13 0040
   Serial number: SWFBIE 0005198
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10445598
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
   Serial number: 00000000001504091280
                    Fault Frequency: 8
                    Reset counter: 45
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:27:00
01800 - Light Switch (E1)
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2018.06.29
                    Time: 19:49:00
   Part No SW: 8K0 919 475 G    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0040
   Revision: 11001001    Serial number: 40040911300092
   Coding: 110101
   VCID: BD3261AB24B546AC8C-80E8
                    Reset counter: 47
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:28:40
                    Temperature: 26.0°C
00457 - Control Module for Network (J519)
                    Reset counter: 48
                    Mileage: 1048574 km
                    Date: 2018.07.09
                    Time: 11:57:21
                    Temperature: 77.0°C
Address 13: Auto Dist. Reg
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EFD0231U
   Coding: 30313433363030303030554A304C38543053
   VCID: C1CA1D5B504D224CE8-8094
   Serial number: 6334MSME46662F77Q
   Serial number: 6344MSME472206386
   Serial number: 6352QSME712804188
   Serial number: 6362QSME7423323EG
   Serial number: 63732SME2F240717.
   Serial number: 63832SME2D230E0F6
13697280 - Component Protection
          U1101 00 [008] - Active
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:32:05
13635840 - Supply voltage
          [Powersupply  lower threshold fall short of]
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:12:02
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Revision: --------    Serial number: 90319IDF00046
   Coding: 00009E
   VCID: BE3066A729B35DB495-80EA
02795 - Steering Wheel Vibration Motor (V331)
                    Fault Status: 00100111
                    Reset counter: 45
                    Mileage: 189195 km
                    Date: 2018.04.16
                    Time: 16:13:05
                    Fault Status: 00100011
                    Reset counter: 44
                    Mileage: 189196 km
                    Date: 2018.04.17
                    Time: 12:58:26
                    Reset counter: 44
01426 - Controls in Steering Wheel (E221)
                    Reset counter: 47
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:00:46
   Part No SW: 8T0 920 930 S    HW: 8T0 920 930 S
   Component: KOMBIINSTR.   H16 0224
   Revision: 00200000    Serial number: 9DD21U949
   Coding: 0F0701004F000008000000
   VCID: C6C00E4771630574DD-8092
                    Reset counter: 4
                    Mileage: 189195 km
                    Date: 2018.04.16
                    Time: 10:13:43
01298 - Instrument Cluster Lamp Test
                    Reset counter: 47
                    Mileage: 189212 km
                    Date: 2018.07.10
                    Time: 08:48:18
   Part No SW: 8T0 907 468 Q    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0095
   Revision: FB600048    Serial number: 4800F094040162
   Coding: 000303
   VCID: CFEE2B639E19C43C6E-809A
   Component: J367-BDM  H06 0160
   Serial number: 190725BC250309
                    Reset counter: 4
                    Mileage: 189195 km
                    Date: 2018.04.16
                    Time: 10:13:41
                    Fault Frequency: 16
                    Reset counter: 49
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:05:00
   Part No SW: 8K0 857 511 C    HW: 8K0 857 511 A
   Component: FLA           H04 0003
   Revision: AA001002
   Coding: 02019864747464545425363E
   VCID: B12A4D9BE8EDB2CC18-80E4
                    Fault Frequency: 14
                    Reset counter: 45
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0010104
   VCID: B6207E87C18395F44D-80E2
   Subsystem 1 - Part No: 8K0 907 568 B
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F02.04.0900H010003C910486ÿ
   Subsystem 4 - Serial number: 910486ÿ
02857 - Supply Voltage for Lane Change Assistance Control Module 2
                    Fault Frequency: 17
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2009.01.01
                    Fault Frequency: 26
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2009.01.01
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008797294
   Coding: 011C12224000120102
   VCID: C1CA1D5B584D224CE8-8094
                    Fault Frequency: 19
                    Reset counter: 45
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:27:34
                    Reset counter: 48
   Revision: 00002001    Serial number: 0444392079
   Coding: 011A0E80003904010120000000000000
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 4
                    Mileage: 189195 km
                    Date: 2018.04.17
                    Time: 12:42:04
02738 - Bulb for Tail/Brake Light; Left
                    Fault Status: 11101100
                    Fault Frequency: 56
                    Reset counter: 13
                    Mileage: 189195 km
                    Date: 2018.04.17
                    Time: 12:43:41
02741 - Bulb for Tail Light 2; Right
                    Fault Frequency: 88
                    Reset counter: 13
                    Mileage: 189195 km
                    Date: 2018.04.17
                    Time: 12:44:13
02615 - Fuel Tank Cap; Lock
                    Reset counter: 4
                    Mileage: 189195 km
                    Date: 2018.04.17
                    Time: 12:47:15
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Reset counter: 48
                    Mileage: 189244 km
                    Date: 2018.07.11
                    Time: 10:39:38
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008801971
   VCID: C0CC185F53472B44E7-8094
                    Fault Status: 01101000
                    Fault Frequency: 23
                    Reset counter: 13
                    Mileage: 189195 km
                    Date: 2018.04.17
                    Time: 12:42:04
                    Fault Frequency: 22
                    Reset counter: 45
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:27:34
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:29:30
                    Reset counter: 48
                    Mileage: 189244 km
                    Date: 2018.07.11
                    Time: 10:37:18
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000349352
   VCID: B326479312F180DC6A-80E6
02432 - Supply Voltage for Left Parking Brake Motor (V282)
                    Fault Status: 00101011
                    Reset counter: 48
                    Mileage: 189244 km
                    Date: 2018.07.11
                    Time: 10:29:41
                    Voltage: 15.30 V
                    Count: 28
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02434 - Supply Voltage for Control Module for Left Channel
                    Fault Status: 00101001
                    Reset counter: 48
                    Mileage: 189244 km
                    Date: 2018.07.11
                    Time: 10:29:41
                    Voltage: 15.30 V
                    Count: 14
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02435 - Supply Voltage for Control Module for Right Channel
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:05:19
                    Voltage: 14.80 V
                    Count: 15
                    Hex Value: 0x02E3
                    Hex Value: 0x0001
                    Hex Value: 0x1010
02433 - Supply Voltage for Right Parking Brake Motor (V283)
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:05:19
                    Voltage: 14.80 V
                    Count: 29
                    Hex Value: 0x02E3
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000017
   Shop #: WSC 06324 000 00000
   VCID: B02C489F23E7BBC417-80E4
   Subsystem 1 - Part No: 7L6 941 329 C
   Component: AFS-Modul links H01 0004
   Subsystem 2 - Part No: -----------
   Component: AFS-Modul rechts
02631 - Voltage Supply for Swivel Module Position Sensor; Left
            007 - Short to Ground - MIL ON
                    Fault Status: 11100111
                    Reset counter: 4
                    Mileage: 189195 km
                    Date: 2018.04.17
                    Time: 12:42:14
                    Reset counter: 4
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:28:44
02234 - Right Headlight Power Output Stage (J668)
                    Fault Status: 11100100
                    Fault Frequency: 49
                    Reset counter: 8
                    Mileage: 189210 km
                    Date: 2018.07.06
                    Time: 19:26:02
                    Reset counter: 45
                    Mileage: 189212 km
                    Date: 2018.07.09
                    Time: 08:58:56
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0020
   Revision: AB001007    Serial number: 342D$097596366
   Coding: 010003020100000001
   VCID: 9F0EBB238E7934BCBE-80CA
03029 - Subwoofer (R157)
                    Reset counter: 4
                    Mileage: 189195 km
                    Date: 2018.04.16
                    Time: 10:13:36
                    Voltage: 13.50 V
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8K0 907 217 A    HW: 4E0 907 217 C
   Component: J759  LDW           0070
   Revision: 00H07012    Serial number: 2002093120001B
   Coding: 0002003
   VCID: AE1056E739D3AD3405-80FA
                    Reset counter: 48
                    Mileage: 189196 km
                    Date: 2018.04.17
                    Time: 12:58:27
                    Fault Frequency: 65
                    Reset counter: 11
                    Mileage: 189195 km
                    Date: 2018.04.16
                    Time: 10:13:41
                    Fault Frequency: 23
                    Reset counter: 47
                    Mileage: 189210 km
                    Date: 2018.06.04
                    Time: 17:28:41
02858 - Windshield Heater for Directional Stabilization Assistance (Z67)
                    Fault Frequency: 12
                    Reset counter: 48
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:03:46
   Part No SW: 8T1 035 670 D    HW: 8T1 035 670
   Component: H-BNT-EU      H65 0047
   Revision: --------    Serial number: 320DG097531052
   Coding: 010100020006A9ED39000B1E000000030000
   VCID: B6207E87018395F44D-80E2
   Subsystem 1 - Part No: 8R0 060 884 C
   Component: EUROPE 2008  5608
   Component: DU7 High  H43 0306
   Serial number: 9356DR091090627
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000271219
            000 -  -
                    Reset counter: 4
                    Mileage: 189195 km
                    Date: 2018.04.16
                    Time: 10:13:38
                    Voltage: 13.60 V
            000 -  -
                    Reset counter: 47
                    Mileage: 189213 km
                    Date: 2018.07.10
                    Time: 14:41:51
                    Bin. Bits: 00010010 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
01043 - Control Module; Incorrect Software Version
                    Reset counter: 44
                    Mileage: 189210 km
                    Date: 2008.05.27
                    Time: 00:04:44
                    Bin. Bits: 00000000 00100000
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 B    HW: 8K0 907 383 B
   Component: Anhaenger     H08 0080
   Revision: 1A002002    Serial number: 00000118152079
   Coding: 0100000000000000
any help would be appreciated
Kristian Hasa
Albania
C?ID=309376
forgot to mention the Particle Filter Soot Mass (calculated) is around 50 mg
I think you might have to fix some of the other fault codes, such as the Cooling Fans and Throttle Body Actuator first.
Kristian Hasa
Albania
C?ID=309376
ok thanks will try
