2012 Jetta S - "No ROD file found" "... please send an Autoscan ... to Ross-Tech"
normhill
C?ID=299555
Got same error with 18.2.
"No ROD file found
Unable to find a ROD file for:
EV_Kombi_cy _VCC_RM09 A04114 (VW36*)
Please make sue uou are using the latest version (including BETA).
If you are using the lates version,
please send an Autoscan from this car to Ross_Tech."
Sunday,15,July,2018,18:33:23:59981
VCDS Version: 18.5.4.2  HEX-NET CB: 0.4427.4
Data version: 20180518 DS291.0
VIN: 3VW2K7AJ5CM342254   License Plate: 2012 JETTA
Mileage: 99424   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
   Part No SW: 06G 906 055 AE    HW: 06G 906 055 B
   Component: 2.0l 85 KW       01 1302
   Revision: T5H06---    Serial number:
   Coding: 0001015
   Shop #: WSC 33562 001 1048576
   VCID: 6C9410B24F61BA2BA1-8038
               U0155 - 000 -  - Intermittent
                    Mileage: 159828 km
                    Date: 2007.14.09
                    Time: 17:06:18
                    Temperature: 46.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.319 V
001121 - Fuel Level Sensor Circuit
               P0461 - 000 - Implausible Signal - Intermittent
                    Mileage: 159828 km
                    Date: 2007.14.09
                    Time: 17:06:19
                    Temperature: 45.0°C
                    Temperature: 21.0°C
                    Voltage: 12.192 V
000801 - Engine Speed Sensor (G28)
               P0321 - 000 - Implausible Signal - Intermittent
                    Mileage: 159833 km
                    Date: 2007.14.10
                    Time: 16:46:39
                    RPM: 88 /min
                    Load: 75.3 %
                    Temperature: 58.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.557 V
   Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
   Component: AQ 250 6F           2618
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 7F4ED7FE2E1731B314-802A
                    Reset counter: 5
                    Mileage: 53694 km
                    Date: 2035.14.19
                    Time: 23:15:45
   Revision: 00H31001
   Coding: B14B240C512608FC8D0D24E98A1D1061A70000
   Shop #: WSC 00066 000 00000
   VCID: 7BB623EEFA0F2D9338-802E
                    Reset counter: 210
                    Mileage: 159833 km
                    Date: 2007.14.10
                    Time: 17:28:29
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 16390
                    Count: 43264
                    Count: 63745
                    Count: 252
                    Count: 121
                    Reset counter: 210
                    Mileage: 159833 km
                    Date: 2007.14.10
                    Time: 17:28:29
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 8194
                    Count: 43264
                    Count: 63745
                    Count: 252
                    Count: 121
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 170
                    Mileage: 159833 km
                    Date: 2007.14.10
                    Time: 17:32:49
                    Count: 2
                    Count: 12
                    Count: 28672
                    Count: 16401
                    Count: 43264
                    Count: 63745
                    Count: 252
                    Count: 121
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AM    HW: 5C0 820 047 AM
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000603299
   VCID: 6B9613AE4A6FBD13A8-803E
                    Reset counter: 210
                    Mileage: 159833 km
                    Date: 2007.14.10
                    Time: 17:28:36
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0251
   Revision: B2066001    Serial number: 04371281110159
   Coding: 7B994B9A08AB0B0008302000240884D400C2502E60000000300000000000
   VCID: 2F2EC7BE7EF70133C4-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H09 0007
   Serial number:     WRH000372TB
   Coding: 180000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
            000 -  -
                    Reset counter: 205
                    Mileage: 160012 km
                    Date: 2012.14.21
                    Time: 23:41:36
03444 - Ignition Starter Switch
                    Reset counter: 210
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTM02CDHS
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3424C8D29FD122EBB9-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y11000086GM0L
   Coding: 303148
   Serial number: 3572MSME2D542163ZZZT
   Serial number: 3582MSME18213262ZZZJ
   Serial number: 3516KSME5B070914ZZZQ
   Serial number: 3526KSME2E167211ZZZO
   Serial number: 3556LSME36051D13ZZZQ
   Serial number: 3566LSME3C051D13ZZZX
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 5C6 920 951     HW: 5C6 920 951
   Component: KOMBI         H04 0604
   Coding: 270201
   Shop #: WSC 00066 000 00123
   ASAM Dataset: EV_Kombi_cÿ_VDD_RM09 A04114
   ROD: N/A
   VCID: 689C6CA29399960BC5-803C
No ASAM data for: "EV_Kombi_cÿ_VDD_RM09" (VW36 *)
12648448 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 210
                    Mileage: 159833 km
                    Date: 2071.14.10
                    Time: 17:28:53
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0251
   Revision: B2066001
   Coding: 102200
   VCID: 70AC04C2A3495ECB9D-8024
                    Reset counter: 210
                    Mileage: 159833 km
                    Date: 2007.14.10
                    Time: 17:28:59
   Component: IMMO          H04 0604
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9816AA8D95A41BD3-803E
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0004
   Revision: -----03S    Serial number: VWZ4Z6L3199396
   Coding: 05000400010006
   VCID: 23063B8E223FB55350-8076
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 170
                    Mileage: 159833 km
                    Date: 2007.14.10
                    Time: 17:29:07
End----(Elapsed Time: 01:12, VBatt start/end: 11.3V/11.3V. VIgn 11.2V)-----
normhill
C?ID=299555
Just purchased.
Just purchased.
Well, that's a problem. I believe someone was into your instrument cluster with a "back door" tool. There are two reasons why people use tools like that; either to roll back the odometer, or to match new keys to the immobilizer. Obviously there's no excuse at all for the former, and for the latter, there's a right way (using the proper tools) and plenty of questionable ways...
normhill
C?ID=299555
The current mileage is consistent with the progression of service records throughout the time that the previous owner had the car. So I believe the mileage is correct. I received one remote key and one manual key, both of which seem to match the age of the car, but I realize it's really hard to tell. It just seems a little too coincidental that the first link you sent me has the exact same defective ASAM ID: as mine, and just like mine it is a 2012 Jetta S. Mine was made in Mexico. Didn't notice if origin was mentioned in the other post. Is it possible VW created a variation to the code for these, that even their factory supplied scanners don't recognize?
No, I don't think so. They would either have had a campaign to re-flash them to something that their own diagnostic software recognizes or they would have made an accommodation for that ID in their own diagnostic software.
Eric
HC800000
Not to mention that the ASAM ID is supposed to be human-readable, not something with a 0xFF in the middle of it ;)
