A6 (C7) High Beam Assist retrofit
nully
C?ID=145156
I've been trying to retrofit HBA to my US '12 A6. As far as I can tell HBA was never offered on this platform in NA and no one else has tried it so as a beginner I would appreciate some help.
Things I've done:
1) Replaced my mirror with 8K0 857 511 E
2) Wired pins 3 and 8 to extended CAN bus HIGH and LOW (through the T46a junction).
3) Set the bit in 09-Cent. Electronics to enable HBA
4) Add Unit 20 the installation list under CAN Gateway
I can see the HBA module(J844) in VagCom now but it's throwing a few codes. The only other scan of a C7 A6 with HBA i've see is this one: http://forums.ross-tech.com/showthread.php?2444-Audi-A6-2012-high-beam-assist-adaption
My main suspicion is that my Can Gateway 4G0 907 468 G is not compatible; the scan above has a "E" version of the gateway, but I don't have access to ETKA to confirm if that's the case.
As mentioned any help would be appreciated.
Saturday,07,July,2018,11:14:21:19074
VCDS Version: 18.2.1.2 (x64)
Mileage: 50712km-31510mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 20 28 36 3B 3C 42 44
          46 47 52 53 55 56 5F 62 6C 72 82 85 8B 8E 8F 90
VIN: WAUHGCFC3CN079198   Mileage: 50712km-31510miles
20-High Beam Assist. -- Status: Not registered 0011
Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0010
   Revision: --H07---
   Coding: 0A2A0034056600060000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
   ROD: EV_ECM30TFS0214G0907551A_003.rod
   VCID: 2757E8745EA7967C46-8072
   Part No SW: 4G0 927 158 P    HW: 0BK 927 156 R
   Component: 0BK 30TFSIUSA H08 1006
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 3B7F2404B22F229C32-806E
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 44A70F0122E5F0804B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 38753B0883190984DF-806C
   Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 BR
   Component: BCM2 2.0      H31 0510
   Coding: 0D882006000000000000
   Shop #: WSC 22081 001 1048576
   VCID: 7CFDE718FFA1E5A47B-8028
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000236073009
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H12 0062
   Serial number: 05111100040469
   Coding: 668120B81C
   ASAM Dataset: EV_AirCondiComfoUDS 002033
0276 - Engine Off Timer Performance
          P150A 00 [009] - -
                    Reset counter: 98
                    Mileage: 50712 km
                    Date: 2018.07.07
                    Time: 00:12:48
                    Voltage terminal 30: 11.78 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001277080
   Coding: 09072097473C8FE281000087A0003800CF9CD308A20801218001085C3B00
   Shop #: WSC 34397 001 104857
   VCID: 6ED9DD50B9DD8734C5-803A
   Component: WWS57X 111008  H35 0051
   Serial number:         111011013116
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11752869
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 G    HW: 4G0 941 531 G
   Component: E1 - LDS  H07 0044
   Serial number: 26 10 2011  00000032
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R0RWC02
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000026101100010743
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000021101100010854
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103159000000547341
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: CC8885D5000000000001
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 C    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0490
   Revision: 00000007
   VCID: 2D5B1A5C745BBC2CBC-8078
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901129901103
   Coding: 282905
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Coding: 3601010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 2855EB4853B999044F-807C
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H31 0032
   Revision: --------    Serial number: 003D8001J4FK
   Coding: 30323437313130303036554A304C34473053
   VCID: 336F0C249A7FEADCEA-8066
   Serial number: 3575HRB40510SM2OFHH
   Serial number: 3585HRB40630Q4PG88CG
   Serial number: 3515JRB40670Q8K4E8MI
   Serial number: 3525JRB405R0OSD4F1G.
   Serial number: 3554VRB405B0ODISJOIZ
   Serial number: 3564VRB40530P4N0DGPX
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372KJM0011V
   Coding: 0004DC
   VCID: 38753B088B190984DF-806C
   Subsystem 1 - Part No SW: 4G0 951 528 F    HW: 4G0 951 528 F
   Component: E221 - MFL  H09 0009
   Serial number: 11 10 2011  33146213
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 931 P    HW: 4G8 920 931 P
   Component: TBenRdwAcc    H79 0416
   Revision: 25460175    Serial number: 658301011592022
   Coding: 0B8709044F010008020000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000283557
   Coding: 00C1033000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 346D0F389F71EDE4F3-8060
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790876665
0021 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 98
                    Mileage: 50712 km
                    Date: 2018.07.07
                    Time: 00:00:49
                    Voltage terminal 30: 11.8 V
                    Voltage terminal 15: 11.7 V
                    Control Module temperature: 34 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 E
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 040182646E6E645A5A253D3E
   VCID: 336F0C24927FEADCEA-8066
02001 - Data-Bus Automatic Distance Regulation
                    Fault Status: 00101110
                    Reset counter: 138
                    Reset counter: 127
                    Mileage: 72005 km
                    Date: 2014.10.06
                    Time: 09:33:23
00457 - Control Module for Network (J519)
                    Reset counter: 138
                    Mileage: 72005 km
                    Date: 2014.10.06
                    Time: 09:26:13
                    Reset counter: 138
                    Mileage: 72005 km
                    Date: 2014.10.06
                    Time: 09:26:11
03455 - Function Restriction due to Faults in Other Modules
            000 -  -  - Intermittent
                    Reset counter: 127
                    Mileage: 72005 km
                    Date: 2014.10.06
                    Time: 09:33:39
Address 28: HVAC, Rear (E265)       Labels:| 4G0-919-158.clb
   Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
   Component: KLIMA FOND    H07 0062
   Serial number: 31101100040602
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
   VCID: 306503286B69D1C497-8064
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000016655502
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77F7F834C687C6FC16-8022
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4202J4N50
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D5B1A5C7C5BBC2CBC-8078
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0020
   Revision: 00H02000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 30650328A369D1C497-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H02 0020
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F30.10.1100H020003CF20049ÿ
   Subsystem 4 - Serial number: F20049ÿ
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F17205E00628002000013
   Shop #: WSC 02312 785 00200
   VCID: 418356ECD8C3484C68-8014
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0021206979
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326109206565E3D4E1-8066
   Revision: 00002001    Serial number: 0161897612
   Coding: 0106063A00FA458583B00880020500000000000000000000000000000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000055185
   Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Serial number:     WOO13897327
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00000456196
   Revision: CJ007000    Serial number: 00000000032919
   Coding: 030000
   Shop #: WSC 40346 001 1048576
   VCID: 1D3BCA9C04FB4CAC2C-8048
   Part No SW: 4G8 959 792 D    HW: 4G8 959 792
   Component: TSG BF        H05 0212
   Coding: 011F17205E00628002000002
   Shop #: WSC 34397 001 1048576
   VCID: 408553E8D3C9414467-8014
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000173336
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A5111404DB5AB1459-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 111101-0004-106
   Coding: 1221A6601002A200
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C5D17584741B524AB-8078
   Component: Radio U SIRIU H53 0133
   Revision: AB001007    Serial number: 156J%0B7567413
   Coding: 020007010000000001
   VCID: 244DFF7827917D6463-8070
   Part No SW: 4G0 035 664 E    HW: 4G0 035 664
   Component: H-BN-NA       H48 0735
   Revision: --------    Serial number: 434J%0B7506449
   Coding: 050200000003EDEF7D128B0E00000003140001000000000000
   VCID: 2855EB485BB999044F-807C
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1301Z5V3
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349KK2000B7
   Component: CD-Database  3371
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F17204000628002000002
   VCID: 448D5FF8C7D15D6443-8010
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J1XG3ZD
   Coding: 1080004
   VCID: 2649E57091AD8F747D-8072
   Component: TSG HR        H04 0212
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 G    HW: 4G0 919 604 G
   Component: HeadUpDisplay 005 0106
   Coding: C60000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
   VCID: 2F6700547657CE3C8E-807A
Address 85: On Board Cam. (J852)       Labels:* None
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0036
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 65CBA27C642B446CB4-8030
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 3601010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   VCID: 2649E57059AD8F747D-8072
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000052009117
   Coding: 04C198180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3163062C6063D8CC98-8064
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 06:24)--------------------------
hadez16
C?ID=289891
Add unit 20 to the installation list of your gateway.
nully
C?ID=145156
Should have mentioned that already done that. After doing that the error on 19-CAN Gateway goes away but the 5x faults on 20-High Beam Assist. (J844) are still there.
hadez16
C?ID=289891
Which DTCs come back after deleting all?
Do you have a newer Auto-Scan with registered unit 20 to gateway?
wuplur
C?ID=247333
Get this all figured out? I’m interested in doing it too.
