Sunday,08,July,2018,15:18:33:45815
VCDS Version: 18.2.1.5 (x64) HEX-NET CB: 0.4411.4
VIN: WVWSP61J23W493678 License Plate: DUDA
Mileage: 196170km-121894mi Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
76
VIN: WVWSP61J23W493678 Mileage: 196170km-121894miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 GN
Component: RCS4MP EDC G520SG 4308
Coding: 00002
Shop #: WSC 00777
VCID: E288D35B6CFDC654D2-4B3C
19561 - Valve for Intake Manifold Flap (N239)
P3105 - 35-10 - Open or Short to Ground - Intermittent
16955 - Brake Switch (F)
P0571 - 35-10 - Implausible Signal - Intermittent
17911 - Load Signal from Alternator Term. DF
P1503 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 01266 785 00200
VCID: B4246503D68918E470-5184
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Part No: 1C0 909 605 F
Component: 03 AIRBAG VW61 0202 0003
Coding: 12339
Shop #: WSC 01266
VCID: A71E824F475F637CC5-5160
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 07232
VCID: B12A6C17799B2DCC1B-5160
WVWSP61J23W493678 VWZ7Z0C6820513
7 Faults Found:
01176 - Key
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01316 - ABS Control Module
49-00 - No Communications
80-10 - Single-Wire Operation - Intermittent
01304 - Radio
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: F0ACA913B21164C454-5160
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8A Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 01266
VCID: B73E520F97FFF3FC55-4B1E
Component: 8A Tõrsteuer.FS KLO 0009
Component: 8A Tõrsteuer.BF KLO 0009
Component: 8A Tõrsteuer.HL KLO 0009
Component: 8A Tõrsteuer.HR KLO 0009
00913 - Window Regulator Switch; Front Right Driver (E81)
End----(Elapsed Time: 05:12, VBatt start/end: 12.0V/11.8V. VIgn 11.8V)-----
