Headlight Out Error When Using LEDs
dudadiesel
C?ID=271165
I have a 2003 VW Jetta wagon with LED headlights. This is the MK4/ALH model/engine. The dash throws an error of headlights not working with the symbol blinking. This prevents me from setting a speed on cruise control. I have to turn off the lights to set cruise control. Is there a way to disable this headlamp check/error with VCDS? Or is my only option to try and find a different way to wire my lights?
I've thought about installing load resistors hooked up to a relay so I can flick them on to correct the error when I want to set cruise control instead of turning off the lights, which probably freaks out other nearby drivers every time I do it. But this is a last resort tactic if I can't find a better solution.
I don't think there's any way to change that on an Mk.4, but please post an Auto-Scan so people can see exactly what modules are installed in your car.
dudadiesel
C?ID=271165
Sunday,08,July,2018,15:18:33:45815
VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4411.4
Data version: 20180518 DS287.2
VIN: WVWSP61J23W493678   License Plate: DUDA
Mileage: 196170km-121894mi   Repair Order:
          76
VIN: WVWSP61J23W493678   Mileage: 196170km-121894miles
Address 01: Engine        Labels: 038-906-012-AGR.clb
   Part No: 038 906 012 GN
   Component: RCS4MP  EDC G520SG  4308
   Coding: 00002
   Shop #: WSC 00777
   VCID: E288D35B6CFDC654D2-4B3C
19561 - Valve for Intake Manifold Flap (N239)
            P3105 - 35-10 - Open or Short to Ground - Intermittent
16955 - Brake Switch (F)
            P0571 - 35-10 - Implausible Signal - Intermittent
17911 - Load Signal from Alternator Term. DF
            P1503 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019458
   Shop #: WSC 01266 785 00200
   VCID: B4246503D68918E470-5184
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
   Part No: 1C0 909 605 F
   Component: 03 AIRBAG VW61 0202 0003
   Coding: 12339
   Shop #: WSC 01266
   VCID: A71E824F475F637CC5-5160
   Part No: 1J0 920 906 L
   Component: KOMBI+WEGFAHRSP VDO V11
   Coding: 07232
   VCID: B12A6C17799B2DCC1B-5160
   WVWSP61J23W493678     VWZ7Z0C6820513
7 Faults Found:
01176 - Key
01177 - Engine Control Unit
            64-10 - Not Currently Testable - Intermittent
            49-00 - No Communications
            80-10 - Single-Wire Operation - Intermittent
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01266
   VCID: F0ACA913B21164C454-5160
01304 - Radio
   Part No: 1C0 959 799 C
   Component: 8A Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 01266
   VCID: B73E520F97FFF3FC55-4B1E
   Component: 8A Tõrsteuer.FS KLO 0009
   Component: 8A Tõrsteuer.BF KLO 0009
   Component: 8A Tõrsteuer.HL KLO 0009
   Component: 8A Tõrsteuer.HR KLO 0009
00913 - Window Regulator Switch; Front Right Driver (E81)
End----(Elapsed Time: 05:12, VBatt start/end: 12.0V/11.8V. VIgn 11.8V)-----
Yeah.... The lights in that car are not computer-controlled. I'm not sure how it does bulb-out checks...
dudadiesel
C?ID=271165
I'll ask around on some other forums and see. I'm sure there's a non-resistor solution. Thanks for checking!
shwagondawheels
C?ID=146532
Dang MK4s can't do cool stuff...
