Missing adaptation channel in BCM after changes
kamold
Australia
C?ID=241363
Hi All,
Was doing a few tweaks in a mk7.5 Golf.
I tried to enabled Dynamic Light Assist initially. I realised that the led light module did no support it so tried instead to enable high beam assist.
I was still getting a fault when pushing on the high beam stalk so I decided to revert the coding and adaptation changes to BCM, A5 and 4B.
I noticed that one of the adaptation channels in 09 BCM that I had previously changed, is now missing, so I can't fully revert the changes:
channel ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung
I need to change this back to 'AFS: Fernlicht ueber AFS'
But no matter how many times I go into and out of the BCM and enter the security code, this channel is no longer available.
Does anyone have some thoughts as to how I might regain access to this channel in order to change it?
Unfortunately the owner had to leave so the ideas I have had since I have not tried- namely trying with the release version of VCDS, or trying other diagnostic tools.
My feeling is that its just a display issue with the beta...
It seems this is the likely cause of the faults I now have:
Saturday,07,July,2018,14:52:20:58930
VCDS Version: 18.5.4.2 (x64)  HEX-V2 CB: 0.4427.4
Data version: 20180518 DS291.0
VIN: WVWZZZAUZJW0   License Plate: AFS_FAULT
Mileage: 10249km-6368mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 3C 42 44 47 4B 52
          5F A5 D6 D7
VIN: WVWZZZAUZJW00   Mileage: 10249km-6368miles
Address 01: Engine (J623-DCYA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 RJ    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H24 4381
   Revision: B5H24---
   Coding: 01250032046405083000
   ASAM Dataset: EV_ECM20TDI01104L906026RJ 004001
   ROD: EV_ECM20TDI01104L906026RH.rod
   VCID: 035371C78B9B7B3F98F-8056
   Part No SW: 0GC 300 042 G    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1404
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 2A0DFC634C714A77FB9-807E
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 61227000001120
   Coding: 01FA8AA12420096F4778060240C72980512490E26002947338625038C2A2430000000012121212B835351919323200
   VCID: 79AF132FF95731EFC23-802C
16401 - Tire Pressure Warning
          C102D 00 [137] -  -
                    Reset counter: 31
                    Mileage: 10249 km
                    Date: 2018.07.07
                    Time: 14:41:11
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0439808698
   Coding: 032C0C
   VCID: 3C21CA3BB6E5C4C7995-8068
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012010420010000110500001210142A
   VCID: 6D87377FBD1F9D4F5EB-8038
   Air quality sensor:
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001712401208
   ROD: EV_BCMBOSCH_018.rod
   VCID: 084966EBB2BD5867CDD-805C
   Component: WWS    170425  042 0551
   Serial number:         170511022702
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617126
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50F98E8B0A6D50A755D-8004
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330067C159FFC428949C810580300600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E25C033A0F9D6D7B71-806A
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 31
                    Mileage: 10249 km
                    Date: 2018.07.07
                    Time: 14:45:19
                    Control Module temperature: 54 °C
                    Voltage terminal 15: 11.6 V
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR2Z9ZAC
   Coding: 98CCC000000000005C000000008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 094F63EFA9B7216FD23-805C
   Belt Pretensioner left:
   Serial number: 34169677E16051750601
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E17051750340
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 905 17
   Serial number: 357000000003AB98042J
   Subsystem 4 - Part No SW: -----------    HW: 480 001 905 17
   Serial number: 35800000000526680426
   Subsystem 5 - Part No SW: -----------    HW: 480 401 305 17
   Serial number: 3510001A1253734575CV
   Subsystem 6 - Part No SW: -----------    HW: 480 401 305 17
   Serial number: 3520001C125C67A5222Y
   Subsystem 7 - Part No SW: -----------    HW: 480 401 705 17
   Serial number: 3550001BB2507FD5A32C
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 15051708491185
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         407 3193
   Coding: 27A401186F8C000801886B0B5401000080000000
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006305325
   Coding: 030100345F086800FB00025C1C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3333E1079BBB0BBF48F-8066
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 39170001222760057187
   Coding: 2DFFFF
   Serial number: 9790543904
   Revision: 00000000    Serial number: 17000120476009
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E21B9EB50C87515-8060
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QDU14504
   Coding: 0014000000000500018280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   Component: HRE_Master    H12 0080
   Serial number: 0440830483
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C73FADFFCDCFAEB-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0440980726
   Coding: 020112
   Serial number: 060417ED603446
   Coding: 003B1320D201048000001000
   VCID: 43D3B1C7CB1BBB3FD8F-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000014702068
   Coding: 0D0000
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCC23BCD1FAF78B9-806E
   Revision: 00000001    Serial number: VWZ8Z1HBA03LYG$
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   Component: FCM MQB Low   002 0285
   Serial number: 08051710522007
   Coding: 000000070100164E01000101020000000000000000000000000000000000
   VCID: 72BD2403A42142B7839-8026
13705478 - Databus
          [RLS_01 data bus missing message]
                    Reset counter: 31
                    Mileage: 10249 km
                    Date: 2018.07.07
                    Time: 14:43:33
   Serial number: 280417EDS01055
   Coding: 003B1120DE01048000801000
   VCID: 42DDB4C3D401B237D39-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000014474051
   Coding: 150000
   Part No SW: 5NA 035 045 A    HW: 5NA 035 045
   Component: MU-H-N-RW     H54 1121
   Serial number: A849E0HS001874
   Coding: 027310080000000051510002000808001F0106F601200402DF
   VCID: 3635D81388C91E976F1-8062
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9120
   Serial number: VWZ6ZHT1411541
   Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
   Component: ROW 2017  --- 0062
   Compact Disc Database:
   Component: Gracenote2  --- 4012
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 05051712K20110
   Coding: 000307000000010100022354C150A90094000E200000
   ROD: EV_MFKBoschMQBB_VW27.rod
1122632 - Databus
          [TIMEOUT_RLS_01]
                    Reset counter: 31
                    Mileage: 10249 km
                    Date: 2018.07.07
                    Time: 14:43:15
                    Control Module temperature: 43 °C
                    Outside air temperature: 16.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 773.3 s
                    mid: 02 08
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 7EA50033E07916D7F71-802A
   ROD: EV_LED_PLUS_R_KEBODAVW416.rod
End----(Elapsed Time: 01:59, VBatt start/end: 11.7V/11.6V. VIgn 11.5V)-----
shwagondawheels
C?ID=146532
What others did you change before this?
Maybe if you swap the others back to inactive or the previous setting you might find the one you are looking for?
Just a though... Not saying it will work
kamold
Australia
C?ID=241363
Yeah I reverted all the coding and adaptation changes that I had performed, except for the one I mentioned, as it is no longer found in the BCM channels.
I checked back over the coding and adap logs in case I had missed anything from my notes but this seems to be the only thing I haven't reverted...
^^^ Kamold: Yes, your suggestion is worth tying - I've found that subsequent release versions of VCDS do "strange things" to the channel count of previous admaps. Invariably, new channels are discovered (which is a good thing) and existing channels get lost (which is a bad thing). I have no idea why this happens and I have raised this matter in the past - I now retain the installer.exe files of obsolete VCDS versions on my laptop exactly for this purpose.
Are you sure that you are using the exact VCDS version program (release versus Beta) with which you made the original changes for the repatriation work ?
PS: are you aware that VCDS reports 2 x different "tag-numbers" for the descriptor for your illusive adaptation channel depending on the SW version in the BCM?
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung (SW:5Q0-937-084-CF reported by VCDS Version: Beta 17.6.0 Data version: 20170602 DS274 ), and
ENG10578-ENG10901-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung (SW:5Q0-937-084-CG reported by VCDS Version: Beta 17.2.4 (x64) Data version: 20170220 DS267.3)
kamold
Australia
C?ID=241363
All changes were done in the same session with the same beta version.
I did note that initially the BCM was identified but subsequently I was having to identify the ASAM file for VCDS...looking back this seems important.
Tomorrow I'll first try the release version, then failing that I will try some other diagnostic tools.
I was searching in the adaptation channels for 'fern' so it should have been able to find it, as it was finding the other similarly named channels.
Was a bit embarrassing as it's left the owner's car in a worse state than when he brought it to me as now the driver assist features aren't working....had I had a bit more time I would hopefully have gotten to my current thought process but as is usual when under time pressure the lateral thinking process tends to 'go sideways' a bit ... ;)
shwagondawheels
C?ID=146532
That's how things go sometime. I'd like to see what you figure out...
The channel "ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung" is definitely defined in EV_BCMBOSCH_018.rod in DS291, so I'm scratching my head as to why kamold can't find it.
Maybe run a map just to prove that it's there?
I have seen one other message recently that might be indicative of a problem with the search/filter function though...
kamold
Australia
C?ID=241363
So I got this fixed today.
Tried the beta 18.5.2 again however the channel was still not listed.
I went back to the release 18.2 version and the channel was correctly listed.
Still had some other issues but with the assistance of Don found the missing messages were being caused by the A5 coding incorrectly having RLS enabled.
Can you run maps using both please? It makes no sense that it's not there in 18.5...
kamold
Australia
C?ID=241363
I'm sorry Uwe I only had access to the car for a short time :(
The beta was still not automatically identifying the BCM, and perhaps I was selecting the wrong choice (VW37)?
The release 18.2 version auto identified the BCM and then found the channel as normal.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
This topic was of interest to me, since I have a similar car (Mk7.5 Golf platform, 2018 Golf R) and I have also engaged in a failed attempt to enable DLA. :D
Your BCM is not quite identical, but ought to be close enough for me to see the same problem, or so I would think. Your chassis IDs correctly in your Auto-Scan (AU-VW37) and the BCM asks for the same dataset (EV_BCMMQB 018001). I just checked, and I can't repeat your issue. The channel shows up for me identically in both Release 18.2.1 and Beta 18.5.4.2. I had no problems with the standard auto-lookup of ASAM/ROD data for 09; I wasn't prompted to choose anything manually.
Results below. Yes I have been fingerpoken. Don't judge me. :p
Release 18.2.1.5 / HNU:
Sunday,08,July,2018,12:23:40:21122
VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4429.4
Data version: 20180518 DS287.2
VIN: WVWVF7AU2JW177386   License Plate: 2018GOLFR
Mileage: 9909km-6157mi   Repair Order: REL1821-HNU
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          47 4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVF7AU2JW177386   Mileage: 9909km-6157miles
Address 01: Engine (J623-DJJA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 P    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 092500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
   ROD: EV_ECM20TFS0208V0906259P.rod
   VCID: 4DD2A85C1C839C2C9F-8018
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1403
   Revision: 00H06V07
   VCID: 210A24EC309B684C0B-8074
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 63627000001098
   Coding: 01FA6BA154272173457A030860C96980D62A84A2C0069677384250D8C2A8430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW27.rod
   VCID: 03464E648A479A5C39-8056
   Revision: 00021000    Serial number: 0464858592
   Coding: 032C0C
   VCID: 3C34F598B73925A438-8068
   Revision: 00001K08
   Coding: 0002000420010200110501401211140A
   Shop #: WSC 08607 444 00001
   VCID: 6D9208DCBCC37C2CFF-8038
   Air quality sensor:
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001735200577
   ROD: EV_BCMCONTI.rod
   VCID: 06405770B975AF741E-8052
   Component: WWS    171209  043 0551
   Serial number:         171213061443
   Component: RLHS  047 0105
   Serial number: S4Y18M01D10H22M47S41
   Coding: 00A8DD
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418918005
   Coding: 0471155811
   VCID: 4BD6A644E297921C81-801E
   Coding: 330000C159FFC728949C810580401600000000000000000000
   VCID: 3E30FF90A12537B416-806A
   Serial number: 24111741350693
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 383CE98883010984DC-806C
   Serial number: 003GCR09SK3W
   VCID: 47DE9A74FEFF767CA5-8012
   Occupant Detection:
   Serial number: IBH000000000008EZ3AU
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 000 501 18
   Serial number: 35700000000198194A2G
   Subsystem 3 - Part No SW: -----------    HW: 480 000 201 18
   Serial number: 358000000007D82D1A2T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 312 17
   Serial number: 3510001C9284E2D6869H
   Subsystem 5 - Part No SW: -----------    HW: 480 402 712 17
   Serial number: 3520001AB288D0F4E33G
   Subsystem 6 - Part No SW: -----------    HW: 480 402 212 17
   Serial number: 3550001C7284E2D3A79J
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 212 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001C7284E2D20755
   Revision: --------    Serial number: 28121704221561
   Coding: 0C10
   VCID: 095A5C4CA86BC00C73-805C
   Part No SW: 5G1 920 891 A    HW: 5G1 920 891 A
   Component: KOMBI         408 3195
   Coding: 03AD301A7F88CF0502886F0B54010000A0000000
   VCID: 2B16C6C44257B21CA1-807E
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007198325
   Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW27.rod
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29170002448880057427
   Coding: 35FFFF
   Serial number: 3640416404
   Serial number: HA1-00003.11.17
   Coding: 0001
   VCID: 4CD4A558E799952488-8018
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Revision: 00000000    Serial number: 17000376691003
   VCID: 3424DDB89F69EDE4F0-8060
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0464678659
   Coding: 02011103
   VCID: 3D32F89CAC232CAC0F-8068
   Serial number: 0465504023
   Coding: 020111
   Serial number: 021217EL138903
   Coding: 003E13208000040000000000
   VCID: 43C68E64CAC75A5C79-8016
   Serial number: 00000000000018361075
   Coding: 111000
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B36F684B237229C31-806E
24320 - Steering
          C10AC 07 [009] - Mechanical Failure
          [Belastungszähler hat 99% überschritten Belastungszähler hat 100% erreicht]
                    Reset counter: 151
                    Mileage: 8084 km
                    Date: 2018.06.07
                    Time: 20:43:46
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 11.75 V
                    Temperature: 53.0 °C
                    KFC: 5F
                    KFA: 00 00
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 12.00 V
                    uAdSensI_SwitchedKl30_xdu16: 11.91 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD01KBFQ
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E10CFD07145C73486-807A
   Serial number: 21121710521279
   Coding: 00000005010016520771CFC7020000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X.rod
   VCID: 72A81BA0A5FDA3D422-8026
   Serial number: 101217ELA06139
   Coding: 003E13208000040000800000
   VCID: 42C88B60D5DD535472-8016
   Serial number: 00000000000018233831
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Coding: 027310020000000051220002001808009F0507F40120040586
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 3326DEA49A67EADCE9-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJT3480215
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
7204 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Tilt-angle indicator (0x24) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 151
                    Mileage: 8084 km
                    Date: 2018.06.07
                    Time: 20:41:28
                    Voltage terminal 30: 12.3 V
                    BAP-BAP_Function_ID: 02
7226 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Pedestrian assist (0x3A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 151
                    Mileage: 8084 km
                    Date: 2018.06.07
                    Time: 20:41:28
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Serial number: 22121712P20035
   Coding: 0003070000000201002213548150890084000E300140
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 171206201656
   VCID: 2F2ED2D4764FCE3C8D-807A
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393AEC8CB80B108C23-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 02:00, VBatt start/end: 13.3V/12.8V)-----------
Beta 18.5.4.2 / HNU:
Sunday,08,July,2018,12:20:21:21122
VCDS Version: 18.5.4.2 (x64)  HEX-NET CB: 0.4429.4
Dealer/Shop Name: Southwest Ohio Luxobarge Rescue
Workshop Code: 444 08607 000001
Mileage: 9909km-6157mi   Repair Order: BETA1854-HNU
   Revision: --H13---
   ROD: EV_ECM20TFS0208V0906259P_VW37.rod
   VCID: 4DD2A85C1C839C23D6-8018
   Revision: 00H06V07
   VCID: 210A24EC309B684342-8074
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 03464E648A479A5370-8056
   Coding: 032C0C
   VCID: 3C34F598B73925AB71-8068
   Revision: 00001K08
   VCID: 6D9208DCBCC37C23B6-8038
   Air quality sensor:
   VCID: 06405770B975AF7B57-8052
   Coding: 00A8DD
   Coding: 0471155811
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 4BD6A644E2979213C8-801E
   VCID: 3E30FF90A12537BB5F-806A
   VCID: 383CE9888301098B95-806C
   VCID: 47DE9A74FEFF7673EC-8012
   Occupant Detection:
   Coding: 303344
   Coding: 0C10
   VCID: 095A5C4CA86BC0033A-805C
   VCID: 2B16C6C44257B213E8-807E
   ROD: EV_GatewNF.rod
   Coding: 35FFFF
   Coding: 0001
   VCID: 4CD4A558E799952BC1-8018
   VCID: 3424DDB89F69EDEBB9-8060
   Coding: 02011103
   VCID: 3D32F89CAC232CA346-8068
   Coding: 020111
   VCID: 43C68E64CAC75A5330-8016
   Coding: 111000
   Coding: 911F0000
   VCID: 3B36F684B237229378-806E
24320 - Steering
                    Reset counter: 151
                    Mileage: 8084 km
                    Date: 2018.06.07
                    Time: 20:43:46
                    Motor status: 01
                    KFC: 5F
                    KFA: 00 00
   VCID: 2E10CFD07145C73BCF-807A
   VCID: 72A81BA0A5FDA3DB6B-8026
   VCID: 42C88B60D5DD535B3B-8016
   Coding: 091000
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3326DEA49A67EAD3A0-8066
          U1111 00 [009] - -
                    Reset counter: 151
                    Mileage: 8084 km
                    Date: 2018.06.07
                    Time: 20:41:28
          U1111 00 [009] - -
                    Reset counter: 151
                    Mileage: 8084 km
                    Date: 2018.06.07
                    Time: 20:41:28
   VCID: 2F2ED2D4764FCE33C4-807A
   VCID: 393AEC8CB80B10836A-806C
End----------(Elapsed Time: 02:02, VBatt start/end: 13.2V/13.2V)-----------
kamold
Australia
C?ID=241363
If I had ready access to the vehicle I would be able to perform some more testing.
If I come across another similar case I will certainly try some other basic troubleshooting like reinstalling the beta version, turning on debug etc.
For the time being I'm happy to have the issue at hand resolved though I wish I had been able to provide some more useful feedback to assist with isolating the cause of the module id failure and subsequent channel ID issue.
