2013 Golf GTI MK6 -- Problems with fueling/misfires.
sama13
Guatemala
C?ID=1044
Hello everybody,
Need some help here, I have been suffering for 2 months with this car, I attach Auto-scan. Car apparently was tampered by previous owner and new owner came to me, first faults where O2 sensor heater and misfire on 4 cylinders, I thought plugs and coils to do a fresh start so I could check what was going on from there, 3 wees or so later the problem appears again no more O2 sensor issue but misfires on 1 and 4. Decided to change fuel filter, check for leaks (with pressurizing the system), remove intake manifold to do carbon clean up and nothing, a few weeks later the issues come back.
I attach some pictures of measuring blocks with strange data. Today I checked cyl #1 misfires and went up to 130 non stop, turns back to zero and restarts counting. I have never ever seen this strange behavior. I forgot to add, I drove it a while and after driving it starts to adapt but after you accelerate and lift gas pedal and reaches about 1800 rpm a big explosion thru the exhaust system, accelerated 5 times 4 of it popped a bang.
I tried to paste the pics but no luck again! (Uwe help me....)
https://imgur.com/a/bZ5XLo4
https://imgur.com/a/GR02eIf
sama13
Guatemala
C?ID=1044
Thursday,05,July,2018,18:32:14:51947
VCDS Version: 18.2.0.3 (x64)
VIN: WVWZZZ1KZDW095264   License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4C 52 55 56 77
VIN: WVWZZZ1KZDW095264   Mileage: 68960km-42849miles
2E-Media Player 3 -- Status: Not registered 0001
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115 A    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH18---    Serial number:
   Coding: 040300101C070060
   Shop #: WSC 00642 210 45725
   VCID: 285585789B39F00470-807C
               P0300 - 000 -
                    Mileage: 68968 km
                    Date: 2012.11.25
                    Time: 18:18:55
                    RPM: 753 /min
                    Load: 23.5 %
                    Temperature: 102.0°C
                    Temperature: 58.0°C
                    Absolute Pres.: 840.0 mbar
                    Voltage: 13.589 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected
                    Mileage: 68968 km
                    Date: 2012.11.25
                    Time: 18:18:55
                    RPM: 753 /min
                    Load: 23.5 %
                    Temperature: 58.0°C
                    Voltage: 13.589 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected
                    Mileage: 68968 km
                    Date: 2012.11.25
                    Time: 18:18:55
                    RPM: 753 /min
                    Load: 23.5 %
                    Temperature: 58.0°C
                    Voltage: 13.589 V
001092 - EVAP Purge Control Valve (N80)
               P0444 - 000 - Circuit Open
                    Mileage: 68968 km
                    Date: 2012.11.25
                    Time: 18:24:56
                    RPM: 620 /min
                    Load: 33.3 %
                    Temperature: 101.0°C
                    Temperature: 60.0°C
                    Voltage: 11.430 V
Readiness: 1110 0101
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3514
   Revision: 05551213    Serial number: 00001208151501
   VCID: 275786449627FF7C79-8072
   Revision: 00H31001
   Coding: 143B600D092B80FF280D06EA901D0141350D50
   VCID: 7DFB842CE43B85AC73-8028
                    Fault Status: 00101101
                    Reset counter: 149
                    Mileage: 68387 km
                    Date: 2012.11.12
                    Time: 00:55:22
                    Count: 12
                    Count: 29184
                    Count: 8193
                    Count: 44288
                    Count: 65280
                    Count: 255
   Part No SW: 5K0 907 044 GK    HW: 5K0 907 044 GK
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004002
   VCID: 7AF18F30FD15B29456-802E
   Part No SW: 1K0 937 086 R    HW: 1K0 937 086 R
   Component: BCM PQ35  M   111 0709
   Revision: AC111709
   Coding: 40180A3BE825F300408800C0340089EC4FD54088737D8D20E48400240040
   VCID: 3F873E24AEB757BC21-806A
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 06091  26  0512
   Coding: 009F95
   Component: RLS 140912 05  54  0403
   Coding: 0630AD
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 13
                    Mileage: 66616 km
                    Date: 2018.04.11
                    Time: 11:08:35
                    Voltage: 12.30 V
                        Term 50 Off
                    Reset counter: 167
                    Mileage: 68474 km
                    Date: 2012.11.16
                    Time: 15:06:04
                    Voltage: 13.55 V
                        Term 50 Off
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56231203401265
   Coding: 348103
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000.rod
   VCID: 448D31C8CF5134647C-8010
12658720 - Databus
                    Reset counter: 13
                    Mileage: 66616 km
                    Date: 2018.04.11
                    Time: 11:08:35
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RANTBE9
   Coding: 00003957
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3163681C60E3B1CCA7-8064
   Serial number: 3572MSME1D5A5274ZZZ/
   Serial number: 3582MSME37616074ZZZS
   Serial number: 3512QSME74221B13ZZZM
   Serial number: 3522QSME66471730ZZZQ
   Part No SW: 5K0 953 507 AF    HW: 5K0 953 549 A
   Revision: --------    Serial number:  90440LIF000HS
   Coding: 189A040000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 74EDA108DF71C4E40C-8020
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0068085
   Coding: 830000
   Part No SW: 5K6 920 873     HW: 5K6 920 873
   Component: KOMBI         H05 0705
   Coding: 170E01
   VCID: 73EFA214DA7FC3DC15-8026
   Part No SW: 7N0 907 530 AB    HW: 7N0 907 530 AB
   Component: J533  Gateway H47 1633
   Revision:   H47       Serial number: 030912F1001490
   Coding: 350000
   Shop #: WSC 12345 528 03869
   VCID: 70E5AD18A369F8C4E8-8024
            000 -  -
                    Mileage: 66616 km
                    Date: 2018.04.11
                    Time: 11:08:36
   Component: IMMO          H05 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1BF708DB50214A6-803E
   Revision: A1001003    Serial number: 7660899436
   VCID: 2953807C4033C90C6F-807C
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2117
   Coding: 0004150
   VCID: 32616710ADE58AD4DE-8066
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   VCID: 3777560446876FFCE9-8062
   Part No SW: 5K0 959 702 J    HW: 5K0 959 702 J
   Component: Tuer-SG         009 2103
   Coding: 0004406
   VCID: 3A714F307595729416-806E
   Coding: 1442908
   VCID: 346D610857F184E4CC-8060
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000022
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0236
   Revision: 00000001    Serial number: VWZ1Z3M7282520
   Coding: 05000410040005
   VCID: 244D9148271114645C-8070
03138 - Input AUX IN
                    Reset counter: 13
                    Mileage: 66616 km
                    Date: 2018.04.11
                    Time: 11:08:52
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663415370
   Coding: 0A00000000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A714F30BD95729416-806E
End-------------------------(Elapsed Time: 02:56)--------------------------
sama13
Guatemala
C?ID=1044
This is how i got the car first day
Saturday,07,April,2018,10:07:04:51947
VIN: WVWZZZ1KZDW095264   Mileage: 66610km-41389miles
9 Faults Found:
008801 - Boost Pressure Control Valve (N249)
               P2261 - 000 - Mechanical Malfunction - Intermittent
                    Fault Frequency: 34
                    Mileage: 65269 km
                    Date: 2018.02.19
                    Time: 19:42:55
                    RPM: 1564 /min
                    Load: 9.0 %
                    Speed: 53.0 km/h
                    Temperature: 98.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 850.0 mbar
                    Voltage: 13.843 V
000370 - Fuel Trim; Bank 1
               P0172 - 000 - System Too Rich - Intermittent
                    Fault Frequency: 34
                    Mileage: 64983 km
                    Date: 2018.02.09
                    Time: 22:51:14
                    RPM: 753 /min
                    Load: 17.6 %
                    Temperature: 99.0°C
                    Temperature: 37.0°C
                    Voltage: 13.843 V
008759 - Oxygen (Lambda) Sensor B1 S1
               P2237 - 000 - Pump Current Open Circuit - Intermittent
                    Mileage: 66514 km
                    Date: 2018.04.05
                    Time: 07:04:52
                    RPM: 1260 /min
                    Load: 11.0 %
                    Speed: 23.0 km/h
                    Temperature: 96.0°C
                    Temperature: 29.0°C
                    Voltage: 14.097 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
                    Fault Frequency: 8
                    Mileage: 66537 km
                    Date: 2018.04.05
                    Time: 16:50:03
                    RPM: 751 /min
                    Load: 25.5 %
                    Temperature: 98.0°C
                    Temperature: 42.0°C
                    Voltage: 13.843 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent
                    Mileage: 66445 km
                    Date: 2018.04.03
                    Time: 07:13:54
                    RPM: 1042 /min
                    Load: 36.1 %
                    Speed: 6.0 km/h
                    Temperature: 99.0°C
                    Temperature: 33.0°C
                    Voltage: 13.970 V
               P0172 - 000 - System Too Rich - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 66483 km
                    Date: 2018.04.04
                    Time: 07:09:39
                    RPM: 1321 /min
                    Load: 25.5 %
                    Speed: 35.0 km/h
                    Temperature: 98.0°C
                    Temperature: 27.0°C
                    Voltage: 14.097 V
000136 - Fuel Rail/System Pressure
               P0088 - 000 - Too High - Intermittent
                    Fault Frequency: 9
                    Mileage: 66504 km
                    Date: 2018.04.04
                    Time: 19:08:18
                    RPM: 751 /min
                    Load: 17.2 %
                    Speed: 9.0 km/h
                    Temperature: 60.0°C
                    Voltage: 13.462 V
008825 - Leak in Air Intake System
               P2279 - 000 -
                    Mileage: 66616 km
                    Date: 2018.04.07
                    Time: 09:55:03
                    RPM: 755 /min
                    Load: 17.6 %
                    Temperature: 104.0°C
                    Temperature: 54.0°C
                    Voltage: 13.462 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - Intermittent
                    Mileage: 66445 km
                    Date: 2018.04.03
                    Time: 07:13:54
                    RPM: 1042 /min
                    Load: 36.1 %
                    Speed: 6.0 km/h
                    Temperature: 99.0°C
                    Temperature: 33.0°C
                    Voltage: 13.970 V
Readiness: 0010 0000
   Revision: 00H31001
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 211
                    Mileage: 65590 km
                    Date: 2018.03.10
                    Time: 13:03:47
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 49153
                    Count: 1
                    Count: 2
   Revision: 00001004
   Coding: 0010004002
   Revision: AC111709
   Coding: 009F95
   Coding: 0630AD
                    Fault Frequency: 27
                    Reset counter: 7
                    Mileage: 64538 km
                    Date: 2018.01.28
                    Time: 12:18:10
                    Voltage: 12.25 V
                        Term 50 Off
                    Reset counter: 30
                    Mileage: 65829 km
                    Date: 2018.03.15
                    Time: 17:15:14
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
   Coding: 348103
12658720 - Databus
                    Reset counter: 145
                    Mileage: 64450 km
                    Date: 2018.01.19
                    Time: 10:40:56
   Coding: 00003957
   Coding: 189A040000
   Coding: 830000
   Coding: 170E01
   Coding: 350000
            000 -  -
                    Mileage: 64450 km
                    Date: 2018.01.19
                    Time: 10:41:44
   Coding: 0004150
   Revision: 00H22000
   Coding: 0004406
   Coding: 1442908
   Coding: 00000022
   Coding: 00000022
                    Reset counter: 148
                    Mileage: 64538 km
                    Date: 2018.01.28
                    Time: 12:19:29
End-------------------------(Elapsed Time: 03:00)--------------------------
sama13
Guatemala
C?ID=1044
I have been able to track down that it's an injector failure, I will change and let know the outcome.
sama13
Guatemala
C?ID=1044
WOW talk about a good read, very very interesting Jack.
We tested the obvious, the cars behavior is pretty bad when cold, we found out the catalytic converter was blocked but the 2nd O2 sensor didn't say so, changed downpipe to a good one, we pre-charged the system with 15 psi after the maf to the TB, blocking PCV and it hold the boost, checked PCV with the trick we where taught (don't know if it's 100% correct) when engine is hot on idle open up the oil top cap and if the engine accelerates the PCV is bad, if it seems it goes to 3 cylinders the PCV is good, so it went to 3 cylinders. Then we noticed the MAF was reading pretty bad, got another one to test and the value is a lot better and the car behaves a lot better now, still rich and now we can hear a little explosion when you are cruising and lift the gas pedal so that is why it seems injector fault.
it takes so much time sometimes to nail something down.
NostraJackAss
Your firmware is of the most up to date version too.
Yeah........I suspect that air leak thread and the JPPSG will become most visited...........
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
I don't like engines making a fool of me and I certainly don't like when the OBD doesn't lead me where I should be making a turn & instead on the road to the abyss!
Mechanical's never lie, especially when cross checking to the block values and the diagnostic flash programming stack, the JPPSG is going to get you back on the map.
NostraJackASS Has Spoken!
Saving the Ball Earth is everyone's responsibility, even Cobra Commander agrees.
NostraJackAss
5K0-907-115A_0040 EU2 PR-0GV+G0K+G1A
[TABLE="class: vinInfoTable, width: 550"]
[TR]
[TH="align: left"]Vehicle Identification No.[/TH]
[TD="colspan: 2"]WVWZZZ1KZDW095264[/TD]
[/TR]
[TR]
[TH="align: left"]Model[/TH]
[TD="colspan: 2"]Golf GTI
GOLF[/TD]
[/TR]
[TR]
[TH="align: left"]Date of production[/TH]
[TD="colspan: 2"]27.09.2012[/TD]
[/TR]
[TR]
[TH="align: left"]Year[/TH]
[TD="colspan: 2"]2013[/TD]
[/TR]
[TR]
[TH="align: left"]Sales type[/TH]
[TD="colspan: 2"]5K19V3[/TD]
[/TR]
[TR]
[TH="align: left"]Engine Code[/TH]
[TD="colspan: 2"]CCZB[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission Code[/TH]
[TD="colspan: 2"]PBH[/TD]
[/TR]
[TR]
[TH="align: left"]Axle drive[/TH]
[TD="colspan: 2"]6A[/TD]
[/TR]
[TR]
[TH="align: left"]Equipment[/TH]
[TD="colspan: 2"]QW[/TD]
[/TR]
[TR]
[TH="align: left"]Roof color[/TH]
[TD="colspan: 2"]B4[/TD]
[/TR]
[/TABLE]
[TABLE="class: vinInfoTable, width: 533"]
[TR]
[TH="align: left"]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PE[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]0HA[/TD]
[TD]Vehicle class differentiation -1K0/5K0-[/TD]
[/TR]
[TR]
[TH="align: left"]tail pipe[/TH]
[TD="class: prCode"]0P1[/TD]
[TD]Rear side exhaust tailpipe[/TD]
[/TR]
[TR]
[TH="align: left"]drive-off assistance[/TH]
[TD="class: prCode"]UG4[/TD]
[TD]Hill hold assist + comfort driving assist[/TD]
[/TR]
[TR]
[TH="align: left"]Emission standard[/TH]
[TD="class: prCode"]0GV[/TD]
[TD]Emission standard EU2
(critical vapor pressure)[/TD]
[/TR]
[TR]
[TH="align: left"]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH="align: left"]airbag[/TH]
[TD="class: prCode"]4UP[/TD]
[TD]Airbag for driver and front passenger
with knee airbag and front passenger
airbag deactivation[/TD]
[/TR]
[TR]
[TH="align: left"]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E1[/TD]
[TD]Activated carbon canister[/TD]
[/TR]
[TR]
[TH="align: left"]Aerials[/TH]
[TD="class: prCode"]8L6[/TD]
[TD]"diversity" window antenna[/TD]
[/TR]
[TR]
[TH="align: left"]Exterior mirror setting[/TH]
[TD="class: prCode"]6XQ[/TD]
[TD]Exterior mirrors with memory feature,
power-folding/adjustable, separately
heated[/TD]
[/TR]
[TR]
[TH="align: left"]Follow-on warranty[/TH]
[TD="class: prCode"]EA0[/TD]
[TD]Without subsequent warranty[/TD]
[/TR]
[TR]
[TH="align: left"]Left exterior mirror[/TH]
[TD="class: prCode"]5SL[/TD]
[TD]Left exterior mirror, aspherical[/TD]
[/TR]
[TR]
[TH="align: left"]Right exterior mirror[/TH]
[TD="class: prCode"]5RQ[/TD]
[TD]Right exterior mirror: convex[/TD]
[/TR]
[TR]
[TH="align: left"]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH="align: left"]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WL[/TD]
[TD]Jack for external audio source[/TD]
[/TR]
[TR]
[TH="align: left"]Equipment levels[/TH]
[TD="class: prCode"]A8H[/TD]
[TD]Top sports equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type in rear[/TH]
[TD="class: prCode"]1KT[/TD]
[TD]Disc brakes in rear (Geomet D)[/TD]
[/TR]
[TR]
[TH="align: left"]batteries[/TH]
[TD="class: prCode"]J1L[/TD]
[TD]Battery 280 A (60 Ah)[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type, front[/TH]
[TD="class: prCode"]1ZB[/TD]
[TD]Disc brake in front[/TD]
[/TR]
[TR]
[TH="align: left"]Components with special surface[/TH]
[TD="class: prCode"]6FF[/TD]
[TD]Exterior mirror housing and various attachments
colour coded to vehicle[/TD]
[/TR]
[TR]
[TH="align: left"]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH="align: left"]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B2L[/TD]
[TD]Component parts set, complying with
vehicle type for Ecuador, various parts[/TD]
[/TR]
[TR]
[TH="align: left"]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH="align: left"]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)
[/TD]
[/TR]
[TR]
[TH="align: left"]Owner's manuals[/TH]
[TD="class: prCode"]0VD[/TD]
[TD]Information kit in Spanish[/TD]
[/TR]
[TR]
[TH="align: left"]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH="align: left"]brake wear indicator[/TH]
[TD="class: prCode"]9U0[/TD]
[TD]Without brake pad wear indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Heated washer nozzles[/TH]
[TD="class: prCode"]9T0[/TD]
[TD]Without heated washer nozzles[/TD]
[/TR]
[TR]
[TH="align: left"]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH="align: left"]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH="align: left"]"Charism"[/TH]
[TD="class: prCode"]2H0[/TD]
[TD]Without "drive select"[/TD]
[/TR]
[TR]
[TH="align: left"]Chrome package[/TH]
[TD="class: prCode"]QJ3[/TD]
[TD]Chrome package (version 2)[/TD]
[/TR]
[TR]
[TH="align: left"]General operating permit, alterations[/TH]
[TD="class: prCode"]C44[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH="align: left"]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FE[/TD]
[TD]Tilting and sliding glass sunroof with
sunbshade[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in rear[/TH]
[TD="class: prCode"]1JH[/TD]
[TD]Rear shock absorption[/TD]
[/TR]
[TR]
[TH="align: left"]Suspension system in front[/TH]
[TD="class: prCode"]G11[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH="align: left"]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X0[/TD]
[TD]without load through system[/TD]
[/TR]
[TR]
[TH="align: left"]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G7[/TD]
[TD]Filler neck module 1 with insert[/TD]
[/TR]
[TR]
[TH="align: left"]Installation differentiation for components[/TH]
[TD="class: prCode"]0ES[/TD]
[TD]Installation differentiation for
transmission DQ250
-- vehicle components --[/TD]
[/TR]
[TR]
[TH="align: left"]Theft protection system[/TH]
[TD="class: prCode"]7AS[/TD]
[TD]Anti-theft alarm system, interior
monitoring, backup horn and towing
protection[/TD]
[/TR]
[TR]
[TH="align: left"]Inserts[/TH]
[TD="class: prCode"]5MD[/TD]
[TD]Decorative aluminum inserts[/TD]
[/TR]
[TR]
[TH="align: left"]Scuff plates[/TH]
[TD="class: prCode"]7M5[/TD]
[TD]Without impact protection film for door sill[/TD]
[/TR]
[TR]
[TH="align: left"]Park distance control[/TH]
[TD="class: prCode"]7X2[/TD]
[TD]Park distance control in front and rear[/TD]
[/TR]
[TR]
[TH="align: left"]Electric interface for external use
[/TH]
[TD="class: prCode"]UF0[/TD]
[TD]Without electric interface[/TD]
[/TR]
[TR]
[TH="align: left"]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[TH="align: left"]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH="align: left"]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH="align: left"]Pedestrian protection[/TH]
[TD="class: prCode"]VL1[/TD]
[TD]Extended pedestrian protection measures[/TD]
[/TR]
[TR]
[TH="align: left"]Pedal cluster[/TH]
[TD="class: prCode"]VF1[/TD]
[TD]pedal cluster[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight activation[/TH]
[TD="class: prCode"]8K3[/TD]
[TD]Daytime headlights with automatic headlight control
and coming home function[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category rear axle[/TH]
[TD="class: prCode"]0YC[/TD]
[TD]Weight range 3
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category front axle[/TH]
[TD="class: prCode"]L35[/TD]
[TD]Suspension range 35
[/TR]
[TR]
[TH="align: left"]Base engine[/TH]
[TD="class: prCode"]TD6[/TD]
[TD]4-cyl. petrol engine 2.0 l assembly 06J.D[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage netting/pocket on backrest(s)[/TH]
[TD="class: prCode"]4U5[/TD]
[TD]Luggage pockets on backrest[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment cover[/TH]
[TD="class: prCode"]3U4[/TD]
[TD]Luggage compartment cover[/TD]
[/TR]
[TR]
[TH="align: left"]cruise control system[/TH]
[TD="class: prCode"]8T0[/TD]
[TD]Without cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment trim[/TH]
[TD="class: prCode"]5A7[/TD]
[TD]Comfort luggage compartment trim with
service lid/snap-on cover[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission specifications[/TH]
[TD="class: prCode"]G1A[/TD]
[TD]6-speed automatic transmission[/TD]
[/TR]
[TR]
[TH="align: left"]handle for hand brake lever[/TH]
[TD="class: prCode"]6PC[/TD]
[TD]handbrake lever grip (leather)[/TD]
[/TR]
[TR]
[TH="align: left"]Rear spoiler[/TH]
[TD="class: prCode"]5J4[/TD]
[TD]Body-colored rear spoiler[/TD]
[/TR]
[TR]
[TH="align: left"]Rear window wiper and washer system[/TH]
[TD="class: prCode"]8M1[/TD]
[TD]Rear window wiper washer system with
intermittent wipe[/TD]
[/TR]
[TR]
[TH="align: left"]Molded headliner[/TH]
[TD="class: prCode"]6NW[/TD]
[TD]Unsplit molding roof liner[/TD]
[/TR]
[TR]
[TH="align: left"]Rear seats[/TH]
[TD="class: prCode"]3NU[/TD]
[TD]Rear bench seat, not split, split backrest, folding
centre armrest[/TD]
[/TR]
[TR]
[TH="align: left"]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AK[/TD]
[TD]Climatronic with impact pressure
control, CFC-free[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamps[/TH]
[TD="class: prCode"]8BI[/TD]
[TD]Twin headlight for driving on the right
(gas discharge) w/ integrated high beam[/TD]
[/TR]
[TR]
[TH="align: left"]Customized installation[/TH]
[TD="class: prCode"]FC0[/TD]
[TD]Without individual installation[/TD]
[/TR]
[TR]
[TH="align: left"]Interior light in footwell[/TH]
[TD="class: prCode"]6T1[/TD]
[TD]Interior light in footwell[/TD]
[/TR]
[TR]
[TH="align: left"]Instrument clusters[/TH]
[TD="class: prCode"]U5A[/TD]
[TD]Instrument insert, km/h speedometer[/TD]
[/TR]
[TR]
[TH="align: left"]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L6[/TD]
[TD]Breakaway interior rearview mirror,
auto-dimming[/TD]
[/TR]
[TR]
[TH="align: left"]Sticker (customized or special edition)[/TH]
[TD="class: prCode"]0KA[/TD]
[TD]Without decals and emblems[/TD]
[/TR]
[TR]
[TH="align: left"]Body style[/TH]
[TD="class: prCode"]K8G[/TD]
[TD]Hatchback[/TD]
[/TR]
[TR]
[TH="align: left"]coolbox[/TH]
[TD="class: prCode"]1W2[/TD]
[TD]Glove compartment cooling system[/TD]
[/TR]
[TR]
[TH="align: left"]Climatic zones[/TH]
[TD="class: prCode"]0Y7[/TD]
[TD]Tropical zones and high-water country[/TD]
[/TR]
[TR]
[TH="align: left"]Compass/road sign display[/TH]
[TD="class: prCode"]QR0[/TD]
[TD]Without compass/road sign display/
dynamic road sign display[/TD]
[/TR]
[TR]
[TH="align: left"]headrest for seat, rear[/TH]
[TD="class: prCode"]3Q6[/TD]
[TD]Three rear head restraints[/TD]
[/TR]
[TR]
[TH="align: left"]Head restraints[/TH]
[TD="class: prCode"]5ZF[/TD]
[TD]Front head restraints[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel tank treatment[/TH]
[TD="class: prCode"]2LD[/TD]
[TD]Fuel tank without differentiation of
special material treatment
(fluorination/co-extrusion)[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z2[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel systems[/TH]
[TD="class: prCode"]1A5[/TD]
[TD]Fuel system for SI engine[/TD]
[/TR]
[TR]
[TH="align: left"]Body measures[/TH]
[TD="class: prCode"]5C0[/TD]
[TD]Without special body measures[/TD]
[/TR]
[TR]
[TH="align: left"]Radiator grille[/TH]
[TD="class: prCode"]6KA[/TD]
[TD]Radiator grille[/TD]
[/TR]
[TR]
[TH="align: left"]License plate lighting[/TH]
[TD="class: prCode"]KL1[/TD]
[TD]LED license plate lighting[/TD]
[/TR]
[TR]
[TH="align: left"]Rear license plate bracket[/TH]
[TD="class: prCode"]6P1[/TD]
[TD]Rear license plate carrier (ECE)[/TD]
[/TR]
[TR]
[TH="align: left"]Front license plate bracket[/TH]
[TD="class: prCode"]6W1[/TD]
[TD]Front license plate carrier (large)[/TD]
[/TR]
[TR]
[TH="align: left"]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K7[/TD]
[TD]Transport protection film (minimum
protection) with additional transport
[/TR]
[TR]
[TH="align: left"]Paint coating[/TH]
[TD="class: prCode"]FB0[/TD]
[TD]standard paint coating[/TD]
[/TR]
[TR]
[TH="align: left"]Steering system arrangement[/TH]
[TD="class: prCode"]L0L[/TD]
[TD]Left-hand drive[/TD]
[/TR]
[TR]
[TH="align: left"]Reading lamp[/TH]
[TD="class: prCode"]8S4[/TD]
[TD]Two reading lights front, two rear[/TD]
[/TR]
[TR]
[TH="align: left"]steering[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH="align: left"]Backrest release[/TH]
[TD="class: prCode"]3H9[/TD]
[TD]Backrest release for front seats with
Easy Entry feature[/TD]
[/TR]
[TR]
[TH="align: left"]Air duct, front area[/TH]
[TD="class: prCode"]VK1[/TD]
[TD]Air duct, type 1[/TD]
[/TR]
[TR]
[TH="align: left"]Light control systems[/TH]
[TD="class: prCode"]8G0[/TD]
[TD]Without Light Assist[/TD]
[/TR]
[TR]
[TH="align: left"]Lumbar support[/TH]
[TD="class: prCode"]7P1[/TD]
[TD]Power adjustable lumbar support in front
seats[/TD]
[/TR]
[TR]
[TH="align: left"]steering wheels[/TH]
[TD="class: prCode"]2FU[/TD]
[TD]Leather-wrapped multi-function sports
steering wheel with tiptronic[/TD]
[/TR]
[TR]
[TH="align: left"]Speaker installation[/TH]
[TD="class: prCode"]8RM[/TD]
[TD]8 speakers (passive)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight range control[/TH]
[TD="class: prCode"]8Q5[/TD]
[TD]Dynamic headlight range control,
with cornering light (AFS 1)[/TD]
[/TR]
[TR]
[TH="align: left"]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Front center armrest[/TD]
[/TR]
[TR]
[TH="align: left"]Marten repeller[/TH]
[TD="class: prCode"]UM0[/TD]
[TD]Without marten repeller[/TD]
[/TR]
[TR]
[TH="align: left"]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q5[/TD]
[TD]Multi-function display with control[/TD]
[/TR]
[TR]
[TH="align: left"]Engine cooling[/TH]
[TD="class: prCode"]8Z4[/TD]
[TD]moderately hot country[/TD]
[/TR]
[TR]
[TH="align: left"]Engine specifications[/TH]
[TD="class: prCode"]D2D[/TD]
[TD]4-cylinder SI engine 2.0 l/155 kW 16V
turbo FSI, homogeneous; base engine is
TM2/TV2/TG6/TJ6/TD6/TP6/TL5/TL6/TI6[/TD]
[/TR]
[TR]
[TH="align: left"]Left vanity mirror[/TH]
[TD="class: prCode"]4SD[/TD]
[TD]Vanity mirror, left, illuminated[/TD]
[/TR]
[TR]
[TH="align: left"]Right vanity mirror[/TH]
[TD="class: prCode"]4TD[/TD]
[TD]Vanity mirror, right, illuminated[/TD]
[/TR]
[TR]
[TH="align: left"]Navigation device[/TH]
[TD="class: prCode"]7Q0[/TD]
[TD]without navigation system[/TD]
[/TR]
[TR]
[TH="align: left"]rear fog lamp[/TH]
[TD="class: prCode"]8TC[/TD]
[TD]Rear fog light for driving on the right[/TD]
[/TR]
[TR]
[TH="align: left"]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WD[/TD]
[TD]Integrated front fog light[/TD]
[/TR]
[TR]
[TH="align: left"]Upgrading measures[/TH]
[TD="class: prCode"]GP1[/TD]
[TD]Vehicles with special upgrade measures
[/TD]
[/TR]
[TR]
[TH="align: left"]Rear of platform module base[/TH]
[TD="class: prCode"]4P0[/TD]
[TD]Rear floor panel module, type 1[/TD]
[/TR]
[TR]
[TH="align: left"]Platform group class[/TH]
[TD="class: prCode"]7PA[/TD]
[TD]Platform group class 1[/TD]
[/TR]
[TR]
[TH="align: left"]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH="align: left"]Wheels[/TH]
[TD="class: prCode"]CG6[/TD]
[TD]Alloy wheels 7.5J x 17[/TD]
[/TR]
[TR]
[TH="align: left"]Radios[/TH]
[TD="class: prCode"]8DD[/TD]
[TD]Radio "RCD510 World Variant"[/TD]
[/TR]
[TR]
[TH="align: left"]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JB[/TD]
[TD]Smoker's package, ashtrays in front and
rear[/TD]
[/TR]
[TR]
[TH="align: left"]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K0[/TD]
[TD]Without tyre pressure monitor[/TD]
[/TR]
[TR]
[TH="align: left"]tire[/TH]
[TD="class: prCode"]H6L[/TD]
[TD]Tires 225/45 R17 91W[/TD]
[/TR]
[TR]
[TH="align: left"]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH="align: left"]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G9[/TD]
[TD]Space-saving spare wheel for temporary
use, radial tire
(5-hole)[/TD]
[/TR]
[TR]
[TH="align: left"]Restraint systems, front[/TH]
[TD="class: prCode"]3QT[/TD]
[TD]3-point seat belts in front, with
tensioner and height adjustment[/TD]
[/TR]
[TR]
[TH="align: left"] [/TH]
[TD="class: prCode"]PAA[/TD]
[TD]Tray areas package[/TD]
[/TR]
[TR]
[TD="class: prCode"]PH2[/TD]
[TD]Air conditioning system Climatronic[/TD]
[/TR]
[TR]
[TD="class: prCode"]PLB[/TD]
[TD]Mirror package[/TD]
[/TR]
[TR]
[TD="class: prCode"]PS5[/TD]
[TD]Electric tilt/slide glass sunroof[/TD]
[/TR]
[TR]
[TD="class: prCode"]PXG[/TD]
[TD]Xenon headlamps with bending light and
LED separate daytime running lights[/TD]
[/TR]
[TR]
[TD="class: prCode"]RK5[/TD]
[TD]"RCD 510" mercados especiales con antena
Diversity para luna[/TD]
[/TR]
[TR]
[TD="class: prCode"]WD6[/TD]
[TD]Anti-theft alarm system "Plus"[/TD]
[/TR]
[TR]
[TD="class: prCode"]WDA[/TD]
[TD]Park distance control[/TD]
[/TR]
[TR]
[TD="class: prCode"]WL2[/TD]
[TD]Leather trim "Vienna" with top sports
seats in front[/TD]
[/TR]
[TR]
[TH="align: left"]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH="align: left"]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q6[/TD]
[TD]Gearshift knob/handle in aluminum[/TD]
[/TR]
[TR]
[TH="align: left"]Special labels/plates[/TH]
[TD="class: prCode"]2KY[/TD]
[TD]Labels in Italian, Spanish and
Portuguese[/TD]
[/TR]
[TR]
[TH="align: left"]Tail lamp assemblies[/TH]
[TD="class: prCode"]8SD[/TD]
[TD]Taillight assembly w/ red colored lens[/TD]
[/TR]
[TR]
[TH="align: left"]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E0[/TD]
[TD]Tailgate/trunk lid unlocking
from outside[/TD]
[/TR]
[TR]
[TH="align: left"]Service indicator[/TH]
[TD="class: prCode"]QI4[/TD]
[TD]Service indicator 15 000 km or 1 year
( fix )[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, left[/TH]
[TD="class: prCode"]3TU[/TD]
[TD]Sports seat, front left[/TD]
[/TR]
[TR]
[TH="align: left"]Front seat, right[/TH]
[TD="class: prCode"]3SU[/TD]
[TD]Sports seat in front, right[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplates for sales name[/TH]
[TD="class: prCode"]QD0[/TD]
[TD]Without lettering for sales name[/TD]
[/TR]
[TR]
[TH="align: left"]Seat belt check[/TH]
[TD="class: prCode"]9P3[/TD]
[TD]Seat belt reminder, electric contact in
buckle[/TD]
[/TR]
[TR]
[TH="align: left"]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZB[/TD]
[TD]3-point seat belts, outer rear with ECE
label[/TD]
[/TR]
[TR]
[TH="align: left"]Center rear seat belts[/TH]
[TD="class: prCode"]3C7[/TD]
[TD]3-point seat belt for center rear seat[/TD]
[/TR]
[TR]
[TH="align: left"]seat covers[/TH]
[TD="class: prCode"]N7F[/TD]
[TD]Seat trim covers in part-leather,
embossed leather[/TD]
[/TR]
[TR]
[TH="align: left"]Seat adjustment[/TH]
[TD="class: prCode"]3L3[/TD]
[TD]Manual height adjustment for front seats[/TD]
[/TR]
[TR]
[TH="align: left"]seat heater[/TH]
[TD="class: prCode"]4A3[/TD]
[TD]seat heating for front seats separat controlable[/TD]
[/TR]
[TR]
[TH="align: left"]Safety head restraint system[/TH]
[TD="class: prCode"]3K0[/TD]
[TD]w/o safety head restraint system[/TD]
[/TR]
[TR]
[TH="align: left"]Side lights[/TH]
[TD="class: prCode"]7R3[/TD]
[TD]Side turn signal lights (white)[/TD]
[/TR]
[TR]
[TH="align: left"]Start-stop system/regenerative braking[/TH]
[TD="class: prCode"]7L3[/TD]
[TD]Without start/stop system without
regenerative braking[/TD]
[/TR]
[TR]
[TH="align: left"]Horns[/TH]
[TD="class: prCode"]8Y1[/TD]
[TD]Two-tone horn[/TD]
[/TR]
[TR]
[TH="align: left"]Control number (no PR family)[/TH]
[TD="class: prCode"]S1X[/TD]
[TD]Special built-in parts (w/o police) in
After-Sales Serv. Worksh. contr. distr.
type 02, with separate AS invoice[/TD]
[/TR]
[TR]
[TH="align: left"]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH="align: left"]power outlet[/TH]
[TD="class: prCode"]7B2[/TD]
[TD]12 volt socket in luggage compartment[/TD]
[/TR]
[TR]
[TH="align: left"]Bumper[/TH]
[TD="class: prCode"]2JG[/TD]
[TD]bumper in color of vehicle[/TD]
[/TR]
[TR]
[TH="align: left"]Rear stabilizer[/TH]
[TD="class: prCode"]0BF[/TD]
[TD]Rear stabilizer[/TD]
[/TR]
[TR]
[TH="align: left"]Front stabilizer bar[/TH]
[TD="class: prCode"]0AE[/TD]
[TD]Front stabilizer bar[/TD]
[/TR]
[TR]
[TH="align: left"]Drawers under front seats[/TH]
[TD="class: prCode"]QN3[/TD]
[TD]Drawers under front seats[/TD]
[/TR]
[TR]
[TH="align: left"]Heavy-duty/sports version[/TH]
[TD="class: prCode"]2UC[/TD]
[TD]Sports version[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamp washer system[/TH]
[TD="class: prCode"]8X1[/TD]
[TD]Headlamp washer system[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N3[/TD]
[TD]intermittent windscreen wiper with rain sensor[/TD]
[/TR]
[TR]
[TH="align: left"]Special approval measures[/TH]
[TD="class: prCode"]3M0[/TD]
[TD]Without special measures[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplate set[/TH]
[TD="class: prCode"]0NH[/TD]
[TD]Nameplate set "GTI"[/TD]
[/TR]
[TR]
[TH="align: left"]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q1[/TD]
[TD]Mass damper for steering wheel, 26.5Hz[/TD]
[/TR]
[TR]
[TH="align: left"]Door and lid locking system[/TH]
[TD="class: prCode"]4K3[/TD]
[TD]Central locking w/ radio remote control,
interior controls and SAFELOCK[/TD]
[/TR]
[TR]
[TH="align: left"]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]BG9[/TD]
[TD]Special requirements for Guatemala[/TD]
[/TR]
[TR]
[TH="align: left"]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D1[/TD]
[TD]Carrier frequency 433.92 to 434.42 Mhz[/TD]
[/TR]
[TR]
[TH="align: left"]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH="align: left"]Door and side trim panels[/TH]
[TD="class: prCode"]3LJ[/TD]
[TD]Door and side trim panel in foam film,
insert in leatherette[/TD]
[/TR]
[TR]
[TH="align: left"]doors[/TH]
[TD="class: prCode"]0A1[/TD]
[TD]2 doors[/TD]
[/TR]
[TR]
[TH="align: left"]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV0[/TD]
[TD]without TV/digital radio reception[/TD]
[/TR]
[TR]
[TH="align: left"]Front underbody guard[/TH]
[TD="class: prCode"]1SB[/TD]
[TD]Additional front underbody guard[/TD]
[/TR]
[TR]
[TH="align: left"]Identification plates[/TH]
[TD="class: prCode"]1EY[/TD]
[TD]Special identification label
with weight data, but without general
operating permit (ROW)[/TD]
[/TR]
[TR]
[TH="align: left"]Delivery equipment[/TH]
[TD="class: prCode"]2A8[/TD]
[TD]Delivery equipment, water border[/TD]
[/TR]
[TR]
[TH="align: left"]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T2[/TD]
[TD]warning triangle[/TD]
[/TR]
[TR]
[TH="align: left"]Two-way radio installation preparation[/TH]
[TD="class: prCode"]9D0[/TD]
[TD]without prepared for two way radio system[/TD]
[/TR]
[TR]
[TH="align: left"]Telephone / telematics[/TH]
[TD="class: prCode"]9W7[/TD]
[TD]Mobile phone interface (NAR)
[/TD]
[/TR]
[TR]
[TH="align: left"]Additional warning lights[/TH]
[TD="class: prCode"]9TC[/TD]
[TD]Additional retro-reflectors (door area)[/TD]
[/TR]
[TR]
[TH="align: left"]LongLife Service Regime[/TH]
[TD="class: prCode"]QG2[/TD]
[TD]LongLife Service Regime cannot be
activated[/TD]
[/TR]
[TR]
[TH="align: left"]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E0[/TD]
[TD]W/o heat accumulator/auxiliary heating[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH="align: left"]Washer fluid level indicator[/TH]
[TD="class: prCode"]8W1[/TD]
[TD]Washer fluid level indicator[/TD]
[/TR]
[TR]
[TH="align: left"]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH="align: left"]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH="align: left"]Additional body panels,
side[/TH]
[TD="class: prCode"]6EA[/TD]
[TD]Without additional side body covers
(stone guard)[/TD]
[/TR]
[TR]
[TH="align: left"]Additional child seat anchors[/TH]
[TD="class: prCode"]3B4[/TD]
[TD]Child seat anchors for
child seat system ISOFIX[/TD]
[/TR]
[TR]
[TH="align: left"]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
sama13
Guatemala
C?ID=1044
How do you all get all of this? pretty helpful info! We removed intake manifold did carbon build up service, changed o-rings on the injectors, will see what else we find.
