00654 - Seat Belt Tensioner Igniter; Driver Side (N153) - 001 - Upper Limit Exceeded
Pfaizulla
C?ID=322498
I need help with below airbag light on issue. The scan is below. I tried the connector under the seat but did not help. Can someone please tell me what ( 001 - Upper Limit Exceeded - MIL ON) exactly mean?
Tuesday,03,July,2018,22:26:38:15095
VCDS Version: 18.2.1.2 (x64)
VIN: 3VWRZ7AJXAM024654   License Plate: JETTA 2010
Mileage: 193070km-119968mi   Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 65 72
          77
VIN: 3VWRZ7AJXAM024654   Mileage: 193070km-119968miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 AG    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H03---    Serial number:
   Coding: 0000075
   Shop #: WSC 06103 444 999999
   VCID: 73CB3660128FDFDC2A-8026
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal - Intermittent
                    Mileage: 192519 km
                    Date: 2012.10.18
                    Time: 12:34:30
                    RPM: 1409 /min
                    Load: 24.7 %
                    Speed: 17.0 km/h
                    Temperature: 90.0°C
                    Temperature: 67.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
               P0300 - 000 -  - Intermittent
                    Mileage: 192771 km
                    Date: 2012.10.24
                    Time: 13:50:05
                    RPM: 878 /min
                    Load: 31.8 %
                    Temperature: 18.0°C
                    Temperature: 16.0°C
                    Voltage: 14.478 V
000773 - Cylinder 5
               P0305 - 000 - Misfire Detected - Intermittent
                    Mileage: 192771 km
                    Date: 2012.10.24
                    Time: 13:51:11
                    RPM: 820 /min
                    Load: 26.3 %
                    Temperature: 26.0°C
                    Temperature: 18.0°C
                    Voltage: 14.224 V
   Part No SW: 09G 927 750 HG    HW: 09G 927 750 HG
   Component: AQ 250 6F           1631
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 7DDF105824CB99AC4C-8028
                    Fault Status: 00101101
                    Fault Frequency: 13
                    Reset counter: 15
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 114B400C492400FE881102E9921D00413000
   VCID: 7EDD1754E9CD82B455-802A
                    Reset counter: 50
                    Mileage: 186837 km
                    Date: 2012.09.04
                    Time: 09:28:08
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 50262
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   Shop #: WSC 00066 000 00146
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3851C14C83697C84DF-806C
9481456 - Refrigerant Pressure
          B10AC F0 [008] - Too High
                    Reset counter: 27
                    Mileage: 188440 km
                    Date: 2018.04.26
                    Time: 15:32:43
          B10AB F0 [008] - Too Low
                    Reset counter: 27
                    Mileage: 190637 km
                    Date: 2018.05.09
                    Time: 16:29:49
   Part No SW: 5K0 937 085 C    HW: 5K0 937 085 C
   Component: BCM PQ35 B++  008 0019
   Revision: BI008001
   Coding: 6D200B1E902F3EE480080005400000000100008641008D605C8020000000
   VCID: 334BF660920F9FDCEA-8066
   Component: Wischer 13080  21  0501
   Coding: 009795
00955 - Key 1
                    Fault Status: 01100101
                    Reset counter: 168
                        Term 15 Off
                    Voltage: 12.55 V
                    Fault Status: 00101010
                    Fault Frequency: 67
                    Reset counter: 62
                    Mileage: 186356 km
                    Date: 2012.09.02
                    Time: 10:36:21
                    Voltage: 13.85 V
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 04 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM00WDE0
   Coding: 0012340
   VCID: 6EFD271479ADF234C5-803A
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME48204C3AE
   Subsystem 3 - Serial number: 6342MSME4852411A7
   Subsystem 4 - Serial number: 6351HSME1D0C1C3DM
   Subsystem 5 - Serial number: 6361HSME1C671C029
   Subsystem 6 - Serial number: 63727SME00112939S
   Subsystem 7 - Serial number: 63827SME00130B5C-
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           055 0111
   Coding: 0001731
   VCID: 76CD0F7401FDCAF40D-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5M0 920 970 AX    HW: 5M0 920 970 AX
   Component: KOMBI         H13 0021
   Revision: V0013012    Serial number: 00000000000000
   Coding: 271F00
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 062D7FB4B91DDA741D-8052
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 290609F1001803
   Coding: ED807F07400612001002
   VCID: 66ED5F34515D3A74BD-8032
   Component: IMMO          H13 0021
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667497830
   VCID: 266D1F3451DDFA747D-8072
   Part No SW: 3C0 035 684 A    HW: 3C0 035 684 A
   Component: RNS-MID       H02 0360
   Revision: AB001001    Serial number: VWZ6Z7J9181098
   Coding: 040004000400008600
   VCID: 21670C2838F31D4C08-8074
            000 -  -
                    Reset counter: 22
                    Mileage: 99056 km
                    Reset counter: 62
                    Mileage: 105418 km
                    Date: 2016.06.30
                    Time: 09:14:53
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000686098722
   Coding: 0001205
   VCID: 6FC33A107EA7FB3CCE-803A
                    Fault Status: 00101100
                    Fault Frequency: 49
                    Reset counter: 35
                    Mileage: 184902 km
                    Date: 2018.02.15
                    Time: 21:06:24
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2F43FA10BE27BB3C8E-807A
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 09051419471303
   Coding: 0001204
   VCID: 70C1396C6399E4C4D7-8024
                    Reset counter: 22
                    Mileage: 185763 km
                    Date: 2018.03.19
                    Time: 12:39:06
00110 - Right Mirror Turn Signal Lamp (L132)
                    Fault Status: 01101100
                    Reset counter: 22
                    Mileage: 193072 km
                    Date: 2012.11.23
                    Time: 21:53:11
            000 -  -
                    Reset counter: 22
                    Mileage: 99056 km
                    Reset counter: 62
                    Mileage: 105418 km
                    Date: 2016.06.30
                    Time: 09:14:53
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000004184084
   Coding: 0001168
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           008 0817
   Coding: 018705
02904 - Hard Warning 3
                    Fault Frequency: 18
                    Mileage: 120354 km
                    Date: 2016.12.26
                    Time: 11:57:30
                    Text: 3391172994
                    Pressure: 0.10 bar
                    Pressure: 2.30 bar
                    Temperature: 17.2°C
                    Text: A0
02801 - Hard Warning
                    Mileage: 178531 km
                    Date: 2017.09.28
                    Time: 08:41:56
                    Text: 3391172973
                    Pressure: 1.80 bar
                    Pressure: 2.30 bar
                    Temperature: 15.2°C
                    Text: 80
02903 - Hard Warning 2
                    Mileage: 178613 km
                    Date: 2017.09.30
                    Time: 07:34:02
                    Text: 3391172956
                    Pressure: 1.90 bar
                    Pressure: 2.30 bar
                    Temperature: 8.0°C
                    Text: 00
                    Speed: 26.0 km/h
                    Mileage: 179663 km
                    Date: 2017.10.24
                    Time: 19:58:19
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000004179924
   Coding: 0001168
   VCID: 77D3027006F7B3FC16-8022
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 C    HW: 1Z0 035 729 C
   Component: FSE_2P8x        H35 0170
   Revision: 00000000    Serial number: 00000005056368
   Coding: 0011070
   VCID: 3851C14C4B697C84DF-806C
End-------------------------(Elapsed Time: 02:08)--------------------------
Thanks,
Pkakaie
In this context, I imagine it means the resistance is too high, which might include a open circuit.
Have a look in Measuring Blocks, Group 001. The status of that tensioner should be in field 3.
Fredrick Awuor
Kenya
C?ID=309834
          77
   Coding: 0000075
                    Mileage: 192519 km
                    Date: 2012.10.18
                    Time: 12:34:30
                    RPM: 1409 /min
                    Load: 24.7 %
                    Speed: 17.0 km/h
                    Temperature: 90.0°C
                    Temperature: 67.0°C
                    Voltage: 13.716 V
                    Mileage: 192771 km
                    Date: 2012.10.24
                    Time: 13:50:05
                    RPM: 878 /min
                    Load: 31.8 %
                    Temperature: 18.0°C
                    Temperature: 16.0°C
                    Voltage: 14.478 V
000773 - Cylinder 5
                    Mileage: 192771 km
                    Date: 2012.10.24
                    Time: 13:51:11
                    RPM: 820 /min
                    Load: 26.3 %
                    Temperature: 26.0°C
                    Temperature: 18.0°C
                    Voltage: 14.224 V
   Coding: 0000840
                    Fault Frequency: 13
                    Reset counter: 15
   Revision: 00H45001
                    Reset counter: 50
                    Mileage: 186837 km
                    Date: 2012.09.04
                    Time: 09:28:08
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 50262
   Revision: 00006001
   Coding: 0000000000
                    Reset counter: 27
                    Mileage: 188440 km
                    Date: 2018.04.26
                    Time: 15:32:43
                    Reset counter: 27
                    Mileage: 190637 km
                    Date: 2018.05.09
                    Time: 16:29:49
   Revision: BI008001
   Coding: 009795
00955 - Key 1
                    Reset counter: 168
                        Term 15 Off
                    Voltage: 12.55 V
                    Fault Frequency: 67
                    Reset counter: 62
                    Mileage: 186356 km
                    Date: 2012.09.02
                    Time: 10:36:21
                    Voltage: 13.85 V
   Coding: 0012340
   Coding: 0001731
   Coding: 00000130
   Coding: 271F00
            000 -  -
                    Reset counter: 22
                    Mileage: 99056 km
                    Reset counter: 62
                    Mileage: 105418 km
                    Date: 2016.06.30
                    Time: 09:14:53
   Coding: 0001205
                    Fault Frequency: 49
                    Reset counter: 35
                    Mileage: 184902 km
                    Date: 2018.02.15
                    Time: 21:06:24
   Revision: 00H15000
   Coding: 0001204
                    Reset counter: 22
                    Mileage: 185763 km
                    Date: 2018.03.19
                    Time: 12:39:06
                    Reset counter: 22
                    Mileage: 193072 km
                    Date: 2012.11.23
                    Time: 21:53:11
            000 -  -
                    Reset counter: 22
                    Mileage: 99056 km
                    Reset counter: 62
                    Mileage: 105418 km
                    Date: 2016.06.30
                    Time: 09:14:53
   Coding: 0001168
   Coding: 018705
                    Fault Frequency: 18
                    Mileage: 120354 km
                    Date: 2016.12.26
                    Time: 11:57:30
                    Text: 3391172994
                    Pressure: 0.10 bar
                    Pressure: 2.30 bar
                    Temperature: 17.2°C
                    Text: A0
                    Mileage: 178531 km
                    Date: 2017.09.28
                    Time: 08:41:56
                    Text: 3391172973
                    Pressure: 1.80 bar
                    Pressure: 2.30 bar
                    Temperature: 15.2°C
                    Text: 80
                    Mileage: 178613 km
                    Date: 2017.09.30
                    Time: 07:34:02
                    Text: 3391172956
                    Pressure: 1.90 bar
                    Pressure: 2.30 bar
                    Temperature: 8.0°C
                    Text: 00
                    Speed: 26.0 km/h
                    Mileage: 179663 km
                    Date: 2017.10.24
                    Time: 19:58:19
   Coding: 0001168
   Coding: 0011070
Thanks,
Pkakaie
Hello,just as Uwe has said,it is about resistance...and a common airbag issue on VAG cars,take electronic contact cleaner, unplug connector,check for looseness, green corrosion deposits etc spray cleaner and remove deposits manually if any and plug back,light should go away after resetting memory
Pfaizulla
C?ID=322498
Thank you all for youy input.
Which part is causing this issue. The airbag inside the seat, the buckel tensioner, or the seatbelt tensioner inside the left side by the B Pilar?
Also, which connector I should check? The ones are attached to the bottom of the driver seat OR the one are under the floor carpet?
Sorry for asking too much questions.
Parez
iichel
Eindhoven, NB, NL
C?ID=284912
It is probably the connector that goes onto the driver seatbelt roller. It has some pyrotechnics in it to tighten it, in case of an accident. It's somewhere in the B pillar, probably somewhere near the bottom sill.
Always disconnect battery and wait a little while when working on the airbag system.
Avoid electrostatic charge, take precautions.
Number 5:
Pfaizulla
C?ID=322498
Thank you very much for your input. I noticed the seat belt is not rolling back when I release it. I think maybe the seat belt is bad! the car was in accident before , maybe they never changed the seatbelt.
Thanks again.,
I will check the cables and replace the seatbelt if needed.
Pfaizulla
C?ID=322498
Question: the driver side seatbelt has two connectors ( two stage retractor) is it possible to use a regular one stage seatbelt and disable the second one on this car? I found the one stage seatbelt for good price but very hard to get the two stage one.
Please advise
Parez
Pfaizulla
C?ID=322498
Hi Uwe,
Do you know by chance if I can replace the current retractor that has two cables with one cable retractor?
Parez
United States
We can't assist with used Airbag parts for liability reasons but I agree with Michel here. I'd either leave it broken with the warning light on -or- obtain the (new) proper part number from the VW dealer.
Pfaizulla
C?ID=322498
Thank you Dana and Michael, I will order a replacement seat belt for it.
