CFFB camshaft and crankshaft sync
Bambur
Finland
is there a way to check the synchronization (torsion) of cam- and crankshaft on CFFB engine with VCDS? I mean the same parameter as given by Group 4 on PD VAG engines.
My VCDS current version is as follows
VCDS Version: 16.8.3.1
Thank you very much in advance!
Bambur
Finland
Uwe, thank you for the reply!
My questions is not about the auto-scan, but rather the measurement block(s). The parameter I am interested is not present in the scan.
I am wondering how I can see the synchronization of cam- and crankshaft on new VAG TDI CR engines like CFFB with VCDS. I used to check the torsion parameter in Group 4 on TDI PD engines. Is there a similar thing on VAG TDI CR's?
Westbury, UK
Maybe, just maybe, the parameter block will be present if you use the latest version of VCDS?
And maybe, just maybe, it would be helpful to know exactly what ECU he has, which would of course be shown in an Auto-Scan. ;)
Bambur
Finland
Uwe, sorry I did not figure out there are different ECU's. Here is mine
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 LE HW: 03L 907 309 AE
Component: R4 2,0L EDC H28 4571
Revision: 41H28--- Serial number: 00000000000000
Coding: 00190032042401080000
ASAM Dataset: EV_ECM20TDI01103L906018LE 003009
ROD: EV_ECM20TDI01103L906018LE.rod
VCID: 78FFE7AFC3A4718284-802C
How do I check cam- and crankshaft sync? :)
Fredrick Awuor
Kenya
C?ID=309834
Hello,follow instructions if you want help and aren't disclosing enough info surely....Heed UWE's advise and post a complete unedited AUTOSCAN period!
Bambur
Finland
Somehow I have a feeling I am not getting any help here. Anyway, here is a complete autoscan :)
 Chassis Type: 5N (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 53 56 61 62 72
VIN: WVGZZZ5NZEW123456   Mileage: 39510km-24550miles
2E-Media Player 3 -- Status: Malfunction 1010
Would somebody now get to my question please?
We kicked this around at the office a bit yesterday and none of us found an answer.
One question that was asked is: "What makes him his cam and crank are out of sync?
Another one in my mind is: Why do you think data like that, which was important on a PD engine (with cam actuated injectors) is going to be available on a CR engine (with completely computer-actuated injectors)?
Also, what you posted there is is still not a complete Auto-Scan. ;)
golfi_vend
Tartu, Estonia
C?ID=195131
If You have bad timing a fault code will tell.
Bambur
Finland
Uwe, thank you for the reply! I find this kind of measurement useful for monitoring the tooth-belt (aka timing belt) condition. With time belt gets stetched out and I could see that with my 1.9 PD TDI. I am hoping to find a way to inspect that on modern VAG CR TDI's as well.
Changing the timing tooth belt on PD TDI's, it was very easy to install it 1-2 degrees off, and many people complained about rough idle and fuel economy. It is not just the injection timing, but also the physical intake and exhaust valves' timing, which cannot be compensated by the ECU, except for the actual PD injection timing.
Btw, what is ENG106252 Synchronous angle for?
Good question. Unfortunately, VW does not bother to tell us these things.
Henrick
Lithuania
LP/IP
PD injectors are also electronically controlled.
Valve timing in these TDIs (be it either PD or CR) is VERY important (as well as CR pump timing, opposed to what most people think/say).
CR belt is very long (160 teeth) as opposed to PD belt (120 teeth).
Besides in the TB path there are much more rollers and idlers (1 tensioner + 3 idlers on CR vs 1 tensioner + 1 idler on PD). Over time/miles they get worn (actually by 140k km all idlers except the large one have play and bearing noise) so free play is introduced. This impactis timing as well.
The belt is prone to stretching, more or less, too. It's 25 mm wide, as opposed to PD which is 30 mm.
And finally CRs have almost twice as long TB replacement intervals as PD had (120k km for early PDs and 210k km for some CRs).
Removing TB cover to inspect the TB system is not that straight forward on CR as it's on PD - much more components will need to be removed.
So monitoring the cam/crank sync angle makes sense.
Answering OP's original question:
try to find a measuring block with something as "start of synchronization" in it's name. I believe the engine must be running for that. However, if I remember correctly, the reading is a bit different than what you were used to see in PD engines (degrees between crank and cam).
Mu81n
Hello All. I’ve got the same engine, but I cannot find ENG106252 Synchronous angle in advanced measuring blocks? I seen on other various posts, engine codes like CAGA for e.g. allow this channel to be viewed, is their an alternative IDE I can view? Oh how I wish I was back on CAN, alas, efficiency allows it not.
Please post an Auto-Scan so we can see exactly what ECU you have and what ASAM data it uses.
Mu81n
Apologies for the late reply. Please see below:
Wednesday,06,March,2019,18:03:08:60391
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ1KZAW419147   License Plate: SB10VEK
Mileage: 217150km-134930mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAW419147   Mileage: 217150km-134930miles
   Part No SW: 03L 906 018     HW: 03L 907 309 R
   Component: R4 2.0l TDI   H21 9978
   Revision: 42H21---    Serial number: 00000000000000
   Coding: 00190012042500080000
   Shop #: WSC 52856 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018 003014
   ROD: EV_ECM20TDI01103L906018D.rod
   VCID: 67D82FEE9E8633727C-8032
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 163B400D09230003680C02E890200082340000
   VCID: 78FA7C92CB38AC8AE5-802C
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6DD45DC6BC7A192206-8038
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0575
   Revision: 00103 AG
   Coding: 48180A3A9025F1C044080080000081E443010088524D8160648000200000
   VCID: 306A84B263C8B4CA6D-8064
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 27041  21  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K8 951 171
   Subsystem 3 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA79E0J
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B70A39EB28E4792C8-806E
   Serial number: 3572MSME04670252ZZZJ
   Serial number: 3582MSME0C037452ZZZR
   Serial number: 3512QSME06125D17ZZZQ
   Serial number: 3522QSME22145D16ZZZQ
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78FA7C920B38AC8AE5-802C
   Subsystem 1 - Part No: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6   H06 0022
   Coding: 00000226
   Part No SW: 5K0 920 970 N    HW: 5K0 920 970 N
   Component: KOMBI         H03 0305
   Coding: 470B00
   VCID: 397CB996B8B27582DA-806C
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 020510F1011493
   Coding: E9807F06000212000003
   VCID: 69DC29D6409205026A-803C
   Component: IMMO          H03 0305
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADE56DA8D940E1A63-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667994532
   VCID: 264662EA510CEA7A87-8072
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2114
   Coding: 0000692
   VCID: 316C81B6A8C2BDC262-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0000692
   VCID: 326E8EBAADC486DA1B-8066
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: RCD310 EU     H11 5032
   Revision: -----01S    Serial number: VWZ4Z2K1207605
   Coding: 0100040004
   VCID: 65C425E66C8A21624E-8030
00856 - Radio Antenna
                    Fault Status: 00100111
                    Reset counter: 30
                    Mileage: 202480 km
                    Date: 2013.03.03
                    Time: 07:52:28
                    Fault Status: 00101011
                    Fault Frequency: 13
                    Reset counter: 13
                    Mileage: 215435 km
                    Date: 2013.07.09
                    Time: 14:05:47
                    Fault Frequency: 14
                    Reset counter: 13
                    Reset counter: 10
                    Mileage: 215996 km
                    Date: 2013.07.15
                    Time: 14:25:38
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 346288A257D088EA09-8060
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 3564B5A65CAA91E23E-8060
End-------------------------(Elapsed Time: 02:16)--------------------------
Wednesday,06,March,2019,18:24:06:60391
Mu81n
I wonder if the below is of any use for monitoring, especially the camshaft position, start less end = sum of angle? Or along those line:
IDE00021 Engine speed 777 /min
IDE00351 Main injection: start of activation -4.00 °
IDE00365 Injection amount deviation cylinder 1 -0.36 mg/stroke
IDE00366 Injection amount deviation cylinder 2 0.23 mg/stroke
IDE00367 Injection amount deviation cylinder 3 0.50 mg/stroke
IDE00368 Injection amount deviation cylinder 4 -0.37 mg/stroke
IDE00394 Camshaft position: start of phase window 122.78 °
IDE00395 Camshaft position: end of phase window 250.84 °
I don't see it in the data for that ECU either, sorry.
Mu81n
Thank you for the swift response. Tis seems I am doomed. I don’t see why VAG can’t do this across the board, where timing/crank-cam correlation can be seen via VCDS. Unfortunately, the garage that did the initial work failed epically (wrong crank locking pin!) Although rectified, I suspect my fuel pump & cam isn’t as per spec (good enough to run & not flag any faults-is that even possible?), to elaborate, as one of the posters mentioned on this site (https://forums.ross-tech.com/showthread.php?7889-Help-please-2-0TDI-CR-Cambelt/page2), when the pin is locked for the fuel pump, this is the optimum level for the pump to operate. Which I assume will also lead to better fuel efficiency.
