Friday,15,June,2018,19:20:01:12112
-- Windows Based VAG/VAS Emulator Running on Windows 7 x64
Version: 18.2.1.2 (x64)
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 52 55 5F 6C
BB BC
VIN: Mileage:
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0005
Revision: --H13---
Coding: 0A1D00324426000F3000
Shop #: 06385 790 00016
Dataset: EV_ECM20TFS0205G0906259A 001007
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C5DEA2047246724AB-8078
15271 - EVAP System
P0456 00 [096] - Very Small Leak Detected
Part No SW: 0D9 300 012 K HW: 02E 927 770 AQ
Component: DQ250-6A H53 4515
Revision: 05853104 Serial number: TFK01412010104
Shop #: 04742 780 00200
Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1E3930E8019885B435-804A
Address 03: Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 63404000000625
Coding: 13FF6A9234290A70017C030981C929C8562C5080C08194B4024100588208
Dataset: EV_Brake1UDSContiMK100IPB 034036
VCID: 4895B6B0F39CAB04AF-801C
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Revision: 00021000 Serial number: 0355051571
Coding: 030C0C
Shop #: 00000 000 00000
Dataset: EV_KessyHellaMQBAB 002011
VCID: 3A71DC78BD70C99429-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000521595
Coding: 03000014010000000000000000001400
Dataset: EV_AirCondiFrontVaAU37X 008020
VCID: 336FF15C9A1A38DCEA-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 59B88167000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: MQBAB MNA H18 0137
Serial number: 01011433500648
Coding: 04151A46C04122F541C04004511007A00800000000000000000000000000
Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 79F30374F8F6028C60-802C
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 141127 042 0585
Serial number: 141204043259
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23535289
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Component: E1 - H05 0032
Serial number: 14 11 2014 00000602
Serial number: 00000000000031370026
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H02 0003
Serial number: 0000FST00025LWO00000
Coding: 101F00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39391433101129
Coding: 0030150011
Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000_002_AU37.rod
VCID: 4281A498D5A0815471-8016
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR0120EW
Dataset: EV_AirbaVW20SMEVW37X 002138
VCID: 4797B58CFE82A47CA6-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34178311B11121441280
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34178312B11121471496
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y1400019HJC0U
Coding: 303230
Subsystem 4 - Part No SW: ----------- HW: 480 000 212 14
Serial number: 35700000000EC905021F
Subsystem 5 - Part No SW: ----------- HW: 480 000 212 14
Serial number: 358000000007A9050217
Subsystem 6 - Part No SW: ----------- HW: 480 400 412 14
Serial number: 3510002B118B3AB4308$
Subsystem 7 - Part No SW: ----------- HW: 480 400 412 14
Serial number: 3520002AF18B3AB63228
Subsystem 8 - Part No SW: ----------- HW: 480 400 109 14
Serial number: 3550002B5175A8E3A0BE
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 109 14
Component: FrontSensor_P 001 6149
Serial number: 3560002BB175A8E2E3AQ
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 10121408490809
Coding: A018
Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 0A114CB8AD10191479-805E
Part No SW: 8V0 920 971 D HW: 8V0 920 971 D
Component: KOMBI H02 4291
Coding: 03E418192B88D7050200E8001800000000000000
Dataset: EV_DashBoardVDDMQBAB 009040
VCID: 3E79D068A158E5B415-806A
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW High 212 2203
Revision: -------- Serial number: 29111410803436
Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_011_VW37.rod
VCID: 72E13458A58071D421-8026
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 28 11 2014 A0095290
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00010.11.14
Coding: 0001
Dataset: EV_AllWheelContrHA1VW37X 002013
VCID: 4689B888F988BD745D-8012
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000341144004
Coding: 5D00000000000000
Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 346DF2409F143FE4F3-8060
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: Master H05 0071
Serial number: 0352513607
Coding: 030211
Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3875C670837CDB84DF-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: Slave H05 0071
Serial number: 0352878377
Coding: 030211
Part No SW: 5Q0 959 393 D HW: 5Q0 959 393 B
Component: FS 020 0028
Serial number: 251114BKO12286
Coding: 00101F204000048000000002
Dataset: EV_DCUDriveSideEWMINKLO 006003
VCID: 4085AE90DBAC934467-8014
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 8102
Dataset: EV_SteerAssisMQB 012140
VCID: 438FA19CCABA885C7A-8016
Part No SW: 5Q0 959 392 D HW: 5Q0 959 392 B
Component: BFS 020 0028
Serial number: 261114BKP10195
Coding: 001017204000048000000002
Dataset: EV_DCUPasseSideEWMINKLO 006003
VCID: 3F87AD6CA652ECBC1E-806A
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR- 005 0080
Coding: 012A000101000000
Dataset: EV_HeadlRegulVWLWRMQB 001110
VCID: 75EB0F44D4EE66EC04-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035--HGH1.clb
Part No SW: 8V0 035 038 B HW: 8V0 035 038 B
Component: MU-H-LNS-US H43 0394
Serial number: A302L0EB007857
Coding: 01730102FF0A000021220001041A00102F000105010001047E
Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: 2015 --- 0035
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9EY2028UJ
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000017111400030187
Compact Disc Database:
Component: Gracenote --- 3006
1564 - Microphone 1
B129B 13 [008] - Open Circuit
Reset counter: 80
Mileage: 33243 km
Date: 2018.04.03
Time: 09:51:30
Voltage terminal 30: 12.6 V
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: RVC Mid H07 0140
Coding: 027300010201000300
Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
VCID: 3065FE506B0C03C497-8064
Part No SW: 5Q0 959 395 D HW: 5Q0 959 395 B
Component: HFS 020 0028
Serial number: 011214BKU00507
Coding: 000017204000048000000002
Dataset: EV_DCURearDriveMINKLO 006003
Component: HBFS 020 0028
Serial number: 011214BKU0050A
Dataset: EV_DCURearPasseMINKLO 006003
End-------------------------(Elapsed Time: 04:51)--------------------------
