VW Touran DSG problem
Kristian Hasa
Albania
C?ID=309376
Hello.
A 2011 touran came into the workshop the owner said when he was on road the car wasn't taking any gear so he stopped the car and then it didn't engage any gear (R,D) i diagnosed it with vcds and it shows a fault code .
Here is a autoscan
Saturday,30,June,2018,14:24:42:50280
VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
VIN: WVGZZZ1TZCW026349   License Plate:
Chassis Type: 1T-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 3D 42 44 46 52 56 61 62
          72
VIN: WVGZZZ1TZCW026349   Mileage: 123550km-76770miles
3D-Special Function -- Status: Malfunction 1010
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PJ    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9977
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00254014032400080000
   Shop #: WSC 30903 001 1048576
   ASAM Dataset: EV_ECM16TDI02103L906023PJ 003008
   ROD: EV_ECM16TDI02103L906023NB.rod
   VCID: FDB2A1AB6C3586ACCC-80A8
   Part No SW: 0AM 300 058 S    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 4540
   Revision: 00043014    Serial number: CU501512186815
   Coding: 0000000
   Shop #: WSC 80093 222 69422
   VCID: C1CA1D5B984D224CE8-8094
006300 - Function Restriction due to Insufficient Pressure Build-Up
               P189C - 000 -
                    Reset counter: 10
                    Mileage: 123559 km
                    Date: 2012.11.20
                    Time: 01:48:17
   Revision: 00H31001
   Coding: 323B401609240E004C0E02E890227041310000
   Shop #: WSC 01324 020 00200
   VCID: FBB6AFB37A21889CF2-80AE
                    Fault Status: 00101101
                    Reset counter: 93
                    Mileage: 123559 km
                    Date: 2012.11.19
                    Time: 00:43:14
                    Count: 3
                    Count: 12
                    Count: 13056
                    Count: 8196
                    Count: 50688
                    Count: 510
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0304
   Revision: 00001015
   Coding: 0000004002
   VCID: 804CD85F1BC7EB44A7-80D4
   Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
   Component: BCM PQ35 B    011 0048
   Revision: BA011001
   Coding: 40180A3880251AE0400000C0500000E4CB018E08F24DA560648042000040
   Shop #: WSC 03824 127 73028
   VCID: B522798B1C859EEC44-80E0
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 11081  26  0512
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 92
                    Mileage: 123559 km
                    Date: 2012.09.25
                    Time: 04:19:26
                        Term 15 On
                    Voltage: 12.55 V
                    Reset counter: 132
                    Mileage: 123559 km
                    Date: 2012.09.25
                    Time: 00:24:33
                        Term 15 On
                    Voltage: 14.20 V
01598 - Drive Battery Voltage
                    Fault Status: 00101011
                    Reset counter: 132
                    Mileage: 123559 km
                    Date: 2012.09.30
                    Time: 00:01:09
                        Term 15 On
                    Voltage: 13.95 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5N0 919 475 D    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0045
   Revision: --------    Serial number: 32901122100378
   Coding: 108101
   ASAM Dataset: EV_EPHVA14VW3680000 001005
   ROD: EV_EPHVA14VW3680000.rod
   VCID: BA386AB73D9B7194A9-80EE
1079316 - Center Rear Right Parking Aid Sensor
          B1078 14 [009] - Open or Short to Ground
                    Reset counter: 91
                    Mileage: 123559 km
                    Date: 2018.05.05
                    Time: 04:10:28
   Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
   Component: 02 AIRBAG VW8   022 0100
   Revision: 02022000    Serial number: 003K4D03W7SO
   Coding: 0012338
   VCID: B73E7383C6896CFC56-80E2
   Subsystem 1 - Serial number: 6332QSME2E5C3C5A
   Subsystem 2 - Serial number: 6342QSME7E5C1A62X
   Subsystem 3 - Serial number: 6352QSME525A094CO
   Subsystem 4 - Serial number: 6362QSME525A465AP
   Part No SW: 5K0 953 501 AQ    HW: 5K0 953 569 F
   Revision: FF010040    Serial number: 20110716100432
   Coding: 5980140000
   VCID: F9BAB5BB781DBA8CE0-80AC
0516 - Databus
                    Reset counter: 132
                    Mileage: 123559 km
                    Date: 2018.05.05
                    Time: 00:24:31
136194 - Supply voltage
                    Reset counter: 132
                    Mileage: 123559 km
                    Date: 2018.05.08
                    Time: 18:19:59
   Part No SW: 1T0 920 865 A    HW: 1T0 920 865 A
   Component: KOMBI         H04 0606
   Coding: 180F00
   VCID: B424448F1FFF87E473-80E0
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 C
   Component: Zuheizer        051 2730
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000011
   VCID: B424448FD7FF87E473-80E0
01444 - Under-Voltage Shut-Off (Automatic)
            000 -  -  - Intermittent
                    Reset counter: 182
                    Mileage: 165169 km
                    Date: 2015.01.31
                    Time: 05:29:00
01410 - Heater Over-Temp
            000 -  -
                    Reset counter: 178
                        After-Run
                    Temperature: 145.0°C
                    Temperature: -48.0°C
                    Voltage: 12.43 V
02251 - Heater Unit Locked
            000 -  -
                    Reset counter: 178
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 060811F1001204
   Coding: 358002
   VCID: B73E738306896CFC56-80E2
                    Fault Status: 00110100
                    Reset counter: 132
                    Mileage: 123559 km
                    Date: 2012.09.25
                    Time: 00:24:32
00380 - Special Vehicle Control Module (J608)
                    Reset counter: 132
                    Mileage: 123559 km
                    Date: 2012.09.25
                    Time: 00:00:02
   Component: IMMO          H04 0606
   VCID: EA989AF70DBB011419-80BE
Address 3D: Special Function (J608)       Labels: None
   Part No SW: 5K0 907 427 B    HW: 5K0 907 427 B
   Component: MFG II        005 0003
   Revision: S0005000    Serial number: 00000000006451
   Coding: 0101010001000000000000000000000000
   VCID: AF2E4BE3FED9A43C0E-80FA
                    Reset counter: 133
                    Mileage: 123559 km
                    Date: 2012.09.28
                    Time: 18:19:60
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2121
   Coding: 0000181
   VCID: C8DC007FBB7713042F-809C
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.293 1002
   Revision: 1AH03733    Serial number: 00112230008001
   Coding: 0000258
   VCID: BC346CAFFFAF4FA4BB-80E8
01288 - Terminal 30; Steering Assist
                    Fault Priority: 9
                    Fault Frequency: 8
                    Reset counter: 133
                        Term 15 On
                    (no units): 2.0
                    Voltage: 11.10 V
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000181
   VCID: C7DE0343B6691C7C26-8092
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  032 0079
   Revision: 01000001    Serial number: VWZ1Z2L3122455
   Coding: 05000400040009
   VCID: F2A882972D6BC9D4A1-80A6
03138 - Input AUX IN
                    Fault Status: 01101011
                    Reset counter: 93
                    Mileage: 123559 km
                    Date: 2012.11.19
                    Time: 00:41:39
   Component: Batt.regelung H43 1620
   Coding: E100185A
   VCID: F1AA8D9B286DF2CC58-80A4
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2104
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
   VCID: B22842972DEB89D461-80E6
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: B3264793D2F180DC6A-80E6
End----------(Elapsed Time: 01:30, VBatt start/end: 13.7V/13.7V)-----------
One thing i noticed that in the auto trans it said coding:0000000 does it mean the car "lost" the auto trans coding ?
Many thanks
*edit:forgot to mention when put to D the car can barely rev
Larry Manton
C?ID=112505
Kristian, I do not claim a lot of knowledge on DSG, but have one at present in my personal Jetta.
That said noted loss of pressure to the gear box, but is that from mechanical or other?, as noted loss of communications to it. Also some serious voltage anomalies in other areas and wondering if the two are not related??, just a thought.
LARIMORE
Kristian Hasa
Albania
C?ID=309376
eeh i dont have much knowledge with dsg too but i think it must be pressure built up by some sort of selenoids
That is a bit strange. The few others I've seen all have Coding: 0000020, but I've never heard of one just "losing" the coding either... :confused:
Golftwincharged
Guyana
C?ID=320847
Mechatronic failure are common on the 0AM dsg7 dry clutch system, fluid pressure drop can indicate many issues with the mech unit, probably low fluid in mech unit,1.) i would refill fluid with exact 1 litre of hydraulic oil and see if problem go away, 2.) also the hydraulic pump maybe failing , lastly software update, one last thing if clutch is worn on this DSG, it can cause a leaking valve body , hope this info helps.
Faulty relief valve in mech or pump & very common in 0AM garbage box from FOD frags getting past poor filtration process by design.
Been experimenting with fine screen pickup and extended sump to gain additional cooling with success outside USA in Dubai and South Africa.
Fredrick Awuor
Kenya
C?ID=309834
Hey Jack,seems your experiment can help us here....DSG's are failing here in droves and no solution apart from dealer exorbitant replacement rates......waiting to hear from you
No secret, add a cooler with lines and sump area to pump through trans externally, measure the volume dif and fill trans with correct level.
Add external filter membrane and catch area with magnets.
Some fun videos on the stupid accumulator.
Remember engines, transmissions and electrical components always almost fail due to heat or inadequate temperature regulation!
Mechanicals fail from inadequate lubrication when heat is created, sludge and FOD are vicarious result....game over!
NostraJackASS Has Spoken!
Kristian Hasa
Albania
C?ID=309376
Because i don't have to much knowledge on dsg actually i don't even normally work on them i gave the car to the owner and sent him to a transmission workshop thanks for the help guys :D
