Hello.
A 2011 touran came into the workshop the owner said when he was on road the car wasn't taking any gear so he stopped the car and then it didn't engage any gear (R,D) i diagnosed it with vcds and it shows a fault code .
Here is a autoscan
One thing i noticed that in the auto trans it said coding:0000000 does it mean the car "lost" the auto trans coding ?
Many thanks
*edit:forgot to mention when put to D the car can barely rev
Here is a autoscan
Saturday,30,June,2018,14:24:42:50280
VCDS Version: 18.2.1.2 HEX-NET CB: 0.4411.4
VIN: WVGZZZ1TZCW026349 License Plate:
Chassis Type: 1T-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 3D 42 44 46 52 56 61 62
72
VIN: WVGZZZ1TZCW026349 Mileage: 123550km-76770miles
02-Auto Trans -- Status: Malfunction 1010
3D-Special Function -- Status: Malfunction 1010
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PJ HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9977
Revision: --H43--- Serial number: 00000000000000
Coding: 00254014032400080000
Shop #: WSC 30903 001 1048576
ASAM Dataset: EV_ECM16TDI02103L906023PJ 003008
ROD: EV_ECM16TDI02103L906023NB.rod
VCID: FDB2A1AB6C3586ACCC-80A8
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 058 S HW: 0AM 927 769 D
Component: GSG DSG AG7 431 4540
Revision: 00043014 Serial number: CU501512186815
Coding: 0000000
Shop #: WSC 80093 222 69422
VCID: C1CA1D5B984D224CE8-8094
006300 - Function Restriction due to Insufficient Pressure Build-Up
P189C - 000 -
Reset counter: 10
Mileage: 123559 km
Date: 2012.11.20
Time: 01:48:17
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 323B401609240E004C0E02E890227041310000
Shop #: WSC 01324 020 00200
VCID: FBB6AFB37A21889CF2-80AE
Fault Status: 00101101
Reset counter: 93
Mileage: 123559 km
Date: 2012.11.19
Time: 00:43:14
Count: 3
Count: 12
Count: 13056
Count: 8196
Count: 50688
Count: 510
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004002
VCID: 804CD85F1BC7EB44A7-80D4
Part No SW: 5K0 937 084 F HW: 5K0 937 084 F
Component: BCM PQ35 B 011 0048
Revision: BA011001
Coding: 40180A3880251AE0400000C0500000E4CB018E08F24DA560648042000040
Shop #: WSC 03824 127 73028
VCID: B522798B1C859EEC44-80E0
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 11081 26 0512
Coding: 009795
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 92
Mileage: 123559 km
Date: 2012.09.25
Time: 04:19:26
Voltage: 12.55 V
Reset counter: 132
Mileage: 123559 km
Date: 2012.09.25
Time: 00:24:33
Voltage: 14.20 V
01598 - Drive Battery Voltage
Fault Status: 00101011
Reset counter: 132
Mileage: 123559 km
Date: 2012.09.30
Time: 00:01:09
Voltage: 13.95 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5N0 919 475 D HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0045
Revision: -------- Serial number: 32901122100378
Coding: 108101
ASAM Dataset: EV_EPHVA14VW3680000 001005
ROD: EV_EPHVA14VW3680000.rod
VCID: BA386AB73D9B7194A9-80EE
1079316 - Center Rear Right Parking Aid Sensor
B1078 14 [009] - Open or Short to Ground
Reset counter: 91
Mileage: 123559 km
Date: 2018.05.05
Time: 04:10:28
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D03W7SO
Coding: 0012338
VCID: B73E7383C6896CFC56-80E2
Subsystem 1 - Serial number: 6332QSME2E5C3C5A
Subsystem 2 - Serial number: 6342QSME7E5C1A62X
Subsystem 3 - Serial number: 6352QSME525A094CO
Subsystem 4 - Serial number: 6362QSME525A465AP
Part No SW: 5K0 953 501 AQ HW: 5K0 953 569 F
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110716100432
Coding: 5980140000
VCID: F9BAB5BB781DBA8CE0-80AC
0516 - Databus
Reset counter: 132
Mileage: 123559 km
Date: 2018.05.05
Time: 00:24:31
136194 - Supply voltage
Reset counter: 132
Mileage: 123559 km
Date: 2018.05.08
Time: 18:19:59
Part No SW: 1T0 920 865 A HW: 1T0 920 865 A
Component: KOMBI H04 0606
Coding: 180F00
VCID: B424448F1FFF87E473-80E0
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 C
Component: Zuheizer 051 2730
Revision: 00051000 Serial number: 09022126000000
Coding: 0000011
VCID: B424448FD7FF87E473-80E0
01444 - Under-Voltage Shut-Off (Automatic)
Reset counter: 182
Mileage: 165169 km
Date: 2015.01.31
Time: 05:29:00
01410 - Heater Over-Temp
Reset counter: 178
After-Run
Temperature: 145.0°C
Temperature: -48.0°C
Voltage: 12.43 V
02251 - Heater Unit Locked
Reset counter: 178
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 060811F1001204
Coding: 358002
VCID: B73E738306896CFC56-80E2
Fault Status: 00110100
Reset counter: 132
Mileage: 123559 km
Date: 2012.09.25
Time: 00:24:32
00380 - Special Vehicle Control Module (J608)
Reset counter: 132
Mileage: 123559 km
Date: 2012.09.25
Time: 00:00:02
Component: IMMO H04 0606
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: EA989AF70DBB011419-80BE
Address 3D: Special Function (J608) Labels: None
Part No SW: 5K0 907 427 B HW: 5K0 907 427 B
Component: MFG II 005 0003
Revision: S0005000 Serial number: 00000000006451
Coding: 0101010001000000000000000000000000
VCID: AF2E4BE3FED9A43C0E-80FA
Reset counter: 133
Mileage: 123559 km
Date: 2012.09.28
Time: 18:19:60
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2121
Coding: 0000181
VCID: C8DC007FBB7713042F-809C
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.293 1002
Revision: 1AH03733 Serial number: 00112230008001
Coding: 0000258
VCID: BC346CAFFFAF4FA4BB-80E8
01288 - Terminal 30; Steering Assist
Fault Priority: 9
Fault Frequency: 8
Reset counter: 133
(no units): 2.0
Voltage: 11.10 V
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000181
VCID: C7DE0343B6691C7C26-8092
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 032 0079
Revision: 01000001 Serial number: VWZ1Z2L3122455
Coding: 05000400040009
VCID: F2A882972D6BC9D4A1-80A6
03138 - Input AUX IN
Reset counter: 93
Mileage: 123559 km
Date: 2012.11.19
Time: 00:41:39
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: E100185A
VCID: F1AA8D9B286DF2CC58-80A4
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0000144
Shop #: WSC 01324 020 1012552
VCID: B22842972DEB89D461-80E6
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: B3264793D2F180DC6A-80E6
End----------(Elapsed Time: 01:30, VBatt start/end: 13.7V/13.7V)-----------
Many thanks
