Coding for passat abs bosch 5.7
hamod_00
Middle East
HN1-013096 (2nd hand?)
hi for all
can any one help please to coding abs bosch 5.7 for passat
itry many coding and login code without successful
thanks
this log file
Monday,25,June,2018,09:21:45:50475
VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
VIN: WVWZZZ3BZ2P222992   License Plate:
Chassis Type: 3B (3A - VW Passat B4 (1994 > 1997))
Scan: 01 02 03 08 15 25 41
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 EP
   Component: 1,9l R4 EDC 0000AG  1464
   Coding: 00001
   Shop #: WSC 00028
   VCID: 699A4BCF11BCC90C90-4B1E
   WVWZZZ3BZ2P222992     VWZ7Z0A4196145
18261 - Powertrain Data Bus
            P1853 - 35-10 - Implausible Message from ABS Controller - Intermittent
18027 - Glow Plug Relay (J52)
            P1619 - 35-10 - Open or Short to Ground - Intermittent
18044 - Powertrain Data Bus
            P1636 - 35-00 - Missing Message from Airbag Controller
18057 - Powertrain Data Bus
            P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0 0 X X X
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 3B0 927 156 S
   Component: AG5 01V 1.9l-PD RdW 2224
   Coding: 00103
   Shop #: WSC 00028
   VCID: 3620D0B3108256F4CD-5160
18265 - Load Signal
            P1857 - 35-10 - Error Message from ECU - Intermittent
17087 - Brake Switch (F)
            P0703 - 35-10 - Electrical Malfunction - Intermittent
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 00000
   VCID: 250207FFBD242D6C74-51F2
            66-10 - Not Matched - Intermittent
            35-00 -  -
   Part No: 3B1 907 044 K
   Component: CLIMATRONIC B5GP    0010
   Coding: 17000
   Shop #: WSC 00028
   VCID: 291A0BCFD13C090C50-5184
00818 - Sensor for Evaporator Outlet Temperature (G263)
            30-00 - Open or Short to Plus
00797 - Sunlight Photo Sensor (G107)
01271 - Positioning Motor for Temperature Flap (V68)
            35-10 -  -  - Intermittent
            35-00 -  -
01273 - Fresh Air Blower (V2)
            79-00 - Please Check Fault Codes
End----(Elapsed Time: 01:17, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
NostraJackAss
Vehicle Identification No.WVWZZZ3BZ2P222992
Modelpassat sedan
PA
Date of production27.09.2001
Year2002
Sales type3B3165
Engine CodeAVF
Transmission CodeEYF
x
[COLOR=#222222][FONT=Arial]
[LIST]
[/LIST]
[FONT=Arial][TABLE="class: vinInfoTable, width: 533"]
[TR]
[TH="align: left"]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PA[/TD]
[TD]Standard wheel bolts[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]0DE[/TD]
[TD]Installation differentiation for build
status of vehicle class B5 (VW Passat)[/TD]
[/TR]
[TR]
[TH="align: left"]Emission standard[/TH]
[TD="class: prCode"]0GE[/TD]
[TD]Emission standard EU3[/TD]
[/TR]
[TR]
[TH="align: left"]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH="align: left"]airbag[/TH]
[TD="class: prCode"]4UE[/TD]
[TD]driver and front passanger airbags[/TD]
[/TR]
[TR]
[TH="align: left"]Automatic transmission indicator light[/TH]
[TD="class: prCode"]9FB[/TD]
[TD]Automatic transmission indicator light[/TD]
[/TR]
[TR]
[TH="align: left"]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E0[/TD]
[TD]Without activated charcoal canister[/TD]
[/TR]
[TR]
[TH="align: left"]Storage compartment[/TH]
[TD="class: prCode"]7N0[/TD]
[TD]Without overhead storage compartment[/TD]
[/TR]
[TR]
[TH="align: left"]Aerials[/TH]
[TD="class: prCode"]8L3[/TD]
[TD]roof antenna[/TD]
[/TR]
[TR]
[TH="align: left"]Exterior mirror setting[/TH]
[TD="class: prCode"]6XN[/TD]
[TD]Exterior mirrors, power-adjustable/
separately heated[/TD]
[/TR]
[TR]
[TH="align: left"]Left exterior mirror[/TH]
[TD="class: prCode"]5SL[/TD]
[TD]Left exterior mirror, aspherical[/TD]
[/TR]
[TR]
[TH="align: left"]Right exterior mirror[/TH]
[TD="class: prCode"]5RQ[/TD]
[TD]Right exterior mirror: convex[/TD]
[/TR]
[TR]
[TH="align: left"]Alternative drive system[/TH]
[TD="class: prCode"]0K0[/TD]
[TD]Without alternative drive system[/TD]
[/TR]
[TR]
[TH="align: left"]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH="align: left"]Outside temperature display[/TH]
[TD="class: prCode"]9Y0[/TD]
[TD]Without outdoor temperature gage[/TD]
[/TR]
[TR]
[TH="align: left"]Equipment levels[/TH]
[TD="class: prCode"]A8S[/TD]
[TD]Standard equipment[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type in rear[/TH]
[TD="class: prCode"]1KD[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH="align: left"]batteries[/TH]
[TD="class: prCode"]J0R[/TD]
[TD]Battery 380 A (80 Ah)[/TD]
[/TR]
[TR]
[TH="align: left"]Brake type, front[/TH]
[TD="class: prCode"]1ZC[/TD]
[TD]Disc brakes in front (Geomet D)[/TD]
[/TR]
[TR]
[TH="align: left"]Controls (steering wheel/steering column)[/TH]
[TD="class: prCode"]4LA[/TD]
[TD]Without control element[/TD]
[/TR]
[TR]
[TH="align: left"]Beverage holders[/TH]
[TD="class: prCode"]4M6[/TD]
[TD]Beverage holders[/TD]
[/TR]
[TR]
[TH="align: left"]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0A[/TD]
[TD]build parts set without county specific documentatio[/TD]
[/TR]
[TR]
[TH="align: left"]floor covering[/TH]
[TD="class: prCode"]3MQ[/TD]
[TD]Ibolours floor covering[/TD]
[/TR]
[TR]
[TH="align: left"]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]electronic satbility programme -ESP-[/TD]
[/TR]
[TR]
[TH="align: left"]Owner's manuals[/TH]
[TD="class: prCode"]0VF[/TD]
[TD]Information kit in English[/TD]
[/TR]
[TR]
[TH="align: left"]Heated washer nozzles[/TH]
[TD="class: prCode"]9T0[/TD]
[TD]Without heated washer nozzles[/TD]
[/TR]
[TR]
[TH="align: left"]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH="align: left"]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH="align: left"]Chrome package[/TH]
[TD="class: prCode"]QJ0[/TD]
[TD]Without aluminum/chrome work package[/TD]
[/TR]
[TR]
[TH="align: left"]General operating permit, alterations[/TH]
[TD="class: prCode"]C04[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH="align: left"]Shock absorption/suspension, chassis[/TH]
[TD="class: prCode"]1BA[/TD]
[TD]Federung/Daempfung, standard[/TD]
[/TR]
[TR]
[TH="align: left"]Roof rails/roof load rack[/TH]
[TD="class: prCode"]3S0[/TD]
[TD]Without roof rails/roof load rack[/TD]
[/TR]
[TR]
[TH="align: left"]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FA[/TD]
[TD]roof without cut out[/TD]
[/TR]
[TR]
[TH="align: left"]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X0[/TD]
[TD]without load through system[/TD]
[/TR]
[TR]
[TH="align: left"]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G0[/TD]
[TD]Without insert for the filling up of
fuel[/TD]
[/TR]
[TR]
[TH="align: left"]Theft protection system[/TH]
[TD="class: prCode"]7AA[/TD]
[TD]Electronic immobilizer[/TD]
[/TR]
[TR]
[TH="align: left"]Inserts[/TH]
[TD="class: prCode"]5MA[/TD]
[TD]Decorative inserts[/TD]
[/TR]
[TR]
[TH="align: left"]Interference suppression[/TH]
[TD="class: prCode"]8E2[/TD]
[TD]Local interference suppression for FM/AM
radio reception[/TD]
[/TR]
[TR]
[TH="align: left"]Park distance control[/TH]
[TD="class: prCode"]7X0[/TD]
[TD]Without park distance control[/TD]
[/TR]
[TR]
[TH="align: left"]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FG[/TD]
[TD]Mosel manufacturing sequence[/TD]
[/TR]
[TR]
[TH="align: left"]window regulator[/TH]
[TD="class: prCode"]4R3[/TD]
[TD]Power windows with comfort operation[/TD]
[/TR]
[TR]
[TH="align: left"]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH="align: left"]Malfunction display[/TH]
[TD="class: prCode"]9HA[/TD]
[TD]Without additional malfunction display[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight activation[/TH]
[TD="class: prCode"]8K0[/TD]
[TD]Without special driving light switching[/TD]
[/TR]
[TR]
[TH="align: left"]Antifreeze[/TH]
[TD="class: prCode"]1C1[/TD]
[TD]Antifreeze up to -25 degree Celsius
tolerance up to -30 degree C[/TD]
[/TR]
[TR]
[TH="align: left"]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH="align: left"]throttle control[/TH]
[TD="class: prCode"]0L2[/TD]
[TD]accelerator pedal with electronic modul[/TD]
[/TR]
[TR]
[TH="align: left"]Alternators[/TH]
[TD="class: prCode"]8GL[/TD]
[TD]Alternator 120 A[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission types/gearshift mechanisms[/TH]
[TD="class: prCode"]0G7[/TD]
[TD]tiptronic[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission shafts, rear axle[/TH]
[TD="class: prCode"]1YA[/TD]
[TD]Without transmission shafts f. rear axle[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission shafts[/TH]
[TD="class: prCode"]1WD[/TD]
[TD]Transmission shaft for tripod joints[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category rear axle[/TH]
[TD="class: prCode"]0YD[/TD]
[TD]Weight range 4
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH="align: left"]Weight category front axle[/TH]
[TD="class: prCode"]0JK[/TD]
[TD]Weight category front axle
weight range 10[/TD]
[/TR]
[TR]
[TH="align: left"]Base engine[/TH]
[TD="class: prCode"]T9J[/TD]
[TD]4-cylinder diesel engine 1.9 l
unit 038.K[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage netting/pocket on backrest(s)[/TH]
[TD="class: prCode"]4U5[/TD]
[TD]Luggage pockets on backrest[/TD]
[/TR]
[TR]
[TH="align: left"]cruise control system[/TH]
[TD="class: prCode"]8T0[/TD]
[TD]Without cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH="align: left"]Exterior noise suppression measures[/TH]
[TD="class: prCode"]2B1[/TD]
[TD]additional noise dampener[/TD]
[/TR]
[TR]
[TH="align: left"]Garage door opener[/TH]
[TD="class: prCode"]VC0[/TD]
[TD]without Garage door opener[/TD]
[/TR]
[TR]
[TH="align: left"]Transmission specifications[/TH]
[TD="class: prCode"]G0F[/TD]
[TD]Five-speed automatic transmission[/TD]
[/TR]
[TR]
[TH="align: left"]Cruise control system and speed limiter[/TH]
[TD="class: prCode"]6Y0[/TD]
[TD]without speed warning system[/TD]
[/TR]
[TR]
[TH="align: left"]glove box[/TH]
[TD="class: prCode"]4Z2[/TD]
[TD]glove box, lockable[/TD]
[/TR]
[TR]
[TH="align: left"]Center high-mounted stop light[/TH]
[TD="class: prCode"]8R1[/TD]
[TD]Center high-mounted stop lamp[/TD]
[/TR]
[TR]
[TH="align: left"]handle for hand brake lever[/TH]
[TD="class: prCode"]6PA[/TD]
[TD]Hand brake lever handle in plastic[/TD]
[/TR]
[TR]
[TH="align: left"]Rear seats[/TH]
[TD="class: prCode"]3NZ[/TD]
[TD]Rear bench seat, not split, split backrest, folding[/TD]
[/TR]
[TR]
[TH="align: left"]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AK[/TD]
[TD]Climatronic with impact pressure
control, CFC-free[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamps[/TH]
[TD="class: prCode"]8BG[/TD]
[TD]Twin-headlamps for driving on the
right, with integrated high beam[/TD]
[/TR]
[TR]
[TH="align: left"]Instrument clusters[/TH]
[TD="class: prCode"]U0C[/TD]
[TD]Instrument cluster with tachometer,
clock and km/h speedometer[/TD]
[/TR]
[TR]
[TH="align: left"]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L2[/TD]
[TD]Breakaway interior rearview mirror,
dimming[/TD]
[/TR]
[TR]
[TH="align: left"]Sticker (customized or special edition)[/TH]
[TD="class: prCode"]0KA[/TD]
[TD]Without decals and emblems[/TD]
[/TR]
[TR]
[TH="align: left"]Body style[/TH]
[TD="class: prCode"]K8B[/TD]
[TD]Notchback[/TD]
[/TR]
[TR]
[TH="align: left"]Luggage compartment floor covering[/TH]
[TD="class: prCode"]6SD[/TD]
[TD]Luggage compartment floor covering in
needle-punched nonwoven (dimensionally
stable)[/TD]
[/TR]
[TR]
[TH="align: left"]Cassette and CD storage unit[/TH]
[TD="class: prCode"]4W0[/TD]
[TD]without cassette / CD tray[/TD]
[/TR]
[TR]
[TH="align: left"]Child seats[/TH]
[TD="class: prCode"]QA0[/TD]
[TD]without child seat[/TD]
[/TR]
[TR]
[TH="align: left"]Climatic zones[/TH]
[TD="class: prCode"]0Y1[/TD]
[TD]Standard climatic zones[/TD]
[/TR]
[TR]
[TH="align: left"]headrest for seat, rear[/TH]
[TD="class: prCode"]3Q1[/TD]
[TD]headrest for seat, rear[/TD]
[/TR]
[TR]
[TH="align: left"]Head restraints[/TH]
[TD="class: prCode"]3J7[/TD]
[TD]Tilt- and height-adjustable head
restraints for front seats[/TD]
[/TR]
[TR]
[TH="align: left"]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z0[/TD]
[TD]Initial standard fuel filling[/TD]
[/TR]
[TR]
[TH="align: left"]Body measures[/TH]
[TD="class: prCode"]5C0[/TD]
[TD]Without special body measures[/TD]
[/TR]
[TR]
[TH="align: left"]Catalytic converter control[/TH]
[TD="class: prCode"]8KA[/TD]
[TD]without catalyst control[/TD]
[/TR]
[TR]
[TH="align: left"]Front license plate bracket[/TH]
[TD="class: prCode"]6W1[/TD]
[TD]Front license plate carrier (large)[/TD]
[/TR]
[TR]
[TH="align: left"]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K1[/TD]
[TD]Transit coating (wax)[/TD]
[/TR]
[TR]
[TH="align: left"]Paint coating[/TH]
[TD="class: prCode"]FB3[/TD]
[TD]Surface, interior trim, soft-touch paint[/TD]
[/TR]
[TR]
[TH="align: left"]Rear cargo area[/TH]
[TD="class: prCode"]3GK[/TD]
[TD]Without add. lower section for luggage comp. floor[/TD]
[/TR]
[TR]
[TH="align: left"]Steering system arrangement[/TH]
[TD="class: prCode"]L0L[/TD]
[TD]Left-hand drive[/TD]
[/TR]
[TR]
[TH="align: left"]Reading lamp[/TH]
[TD="class: prCode"]8S4[/TD]
[TD]Two reading lights front, two rear[/TD]
[/TR]
[TR]
[TH="align: left"]steering[/TH]
[TD="class: prCode"]1N1[/TD]
[TD]Power steering[/TD]
[/TR]
[TR]
[TH="align: left"]Lumbar support[/TH]
[TD="class: prCode"]7P4[/TD]
[TD]Manually adjustable lumbar support in
front seats[/TD]
[/TR]
[TR]
[TH="align: left"]steering wheels[/TH]
[TD="class: prCode"]2PQ[/TD]
[TD]Steering wheel for airbag system[/TD]
[/TR]
[TR]
[TH="align: left"]Speaker installation[/TH]
[TD="class: prCode"]8RE[/TD]
[TD]4 speakers (passive)[/TD]
[/TR]
[TR]
[TH="align: left"]Headlight range control[/TH]
[TD="class: prCode"]8Q1[/TD]
[TD]Headlight range control[/TD]
[/TR]
[TR]
[TH="align: left"]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Front center armrest[/TD]
[/TR]
[TR]
[TH="align: left"]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q0[/TD]
[TD]Without multi-function display/
trip computer[/TD]
[/TR]
[TR]
[TH="align: left"]Engine cooling[/TH]
[TD="class: prCode"]8Z6[/TD]
[TD]Engine cooling, version 2[/TD]
[/TR]
[TR]
[TH="align: left"]Engine specifications[/TH]
[TD="class: prCode"]D3E[/TD]
[TD]4-cyl. turbo diesel engine 1.9 L/96 KW TDI
Unit injector, EU3
Basic engine is: T9J[/TD]
[/TR]
[TR]
[TH="align: left"]Left vanity mirror[/TH]
[TD="class: prCode"]4SD[/TD]
[TD]Vanity mirror, left, illuminated[/TD]
[/TR]
[TR]
[TH="align: left"]Right vanity mirror[/TH]
[TD="class: prCode"]4TD[/TD]
[TD]Vanity mirror, right, illuminated[/TD]
[/TR]
[TR]
[TH="align: left"]Navigation device[/TH]
[TD="class: prCode"]7Q0[/TD]
[TD]without navigation system[/TD]
[/TR]
[TR]
[TH="align: left"]rear fog lamp[/TH]
[TD="class: prCode"]8TC[/TD]
[TD]Rear fog light for driving on the right[/TD]
[/TR]
[TR]
[TH="align: left"]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WA[/TD]
[TD]Without fog lights[/TD]
[/TR]
[TR]
[TH="align: left"]Rear of platform module base[/TH]
[TD="class: prCode"]4P1[/TD]
[TD]Rear floor panel module, type 2[/TD]
[/TR]
[TR]
[TH="align: left"]Hubcaps[/TH]
[TD="class: prCode"]1NC[/TD]
[TD]Full wheel covers[/TD]
[/TR]
[TR]
[TH="align: left"]Wheels[/TH]
[TD="class: prCode"]C5E[/TD]
[TD]Steel wheels 6J x 15
ET 37[/TD]
[/TR]
[TR]
[TH="align: left"]Radios[/TH]
[TD="class: prCode"]8AA[/TD]
[TD]without radio[/TD]
[/TR]
[TR]
[TH="align: left"]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JB[/TD]
[TD]Smoker's package, ashtrays in front and
rear[/TD]
[/TR]
[TR]
[TH="align: left"]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K0[/TD]
[TD]Without tyre pressure monitor[/TD]
[/TR]
[TR]
[TH="align: left"]tire[/TH]
[TD="class: prCode"]H6S[/TD]
[TD]195/65 R15 V tyres[/TD]
[/TR]
[TR]
[TH="align: left"]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH="align: left"]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G2[/TD]
[TD]Spare wheel with full tyre, steel[/TD]
[/TR]
[TR]
[TH="align: left"]Restraint systems, front[/TH]
[TD="class: prCode"]3QT[/TD]
[TD]3-point seat belts in front, with
tensioner and height adjustment[/TD]
[/TR]
[TR]
[TH="align: left"][/TH]
[TD="class: prCode"]PH2[/TD]
[TD]air con "Climatronic", free of cfc[/TD]
[/TR]
[TR]
[TD="class: prCode"]SQ5[/TD]
[TD][/TD]
[/TR]
[TR]
[TH="align: left"]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH="align: left"]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q1[/TD]
[TD]Gearshift knob/handle in plastic[/TD]
[/TR]
[TR]
[TH="align: left"]Special labels/plates[/TH]
[TD="class: prCode"]0SC[/TD]
[TD]Labels in English[/TD]
[/TR]
[TR]
[TH="align: left"]Tail lamp assemblies[/TH]
[TD="class: prCode"]8SA[/TD]
[TD]Rear combination lamp, standard design[/TD]
[/TR]
[TR]
[TH="align: left"]Materials of low flammability[/TH]
[TD="class: prCode"]4Q1[/TD]
[TD]Materials of low flammability[/TD]
[/TR]
[TR]
[TH="align: left"]Seat belt check[/TH]
[TD="class: prCode"]9P0[/TD]
[TD]without press button buckle with warning contact[/TD]
[/TR]
[TR]
[TH="align: left"]Center rear seat belts[/TH]
[TD="class: prCode"]3C3[/TD]
[TD]Lap belt with retractor
for the center rear seat[/TD]
[/TR]
[TR]
[TH="align: left"]Gearshift boot/cover[/TH]
[TD="class: prCode"]6R0[/TD]
[TD]Gearshift boot for automatic
transmission[/TD]
[/TR]
[TR]
[TH="align: left"]seat covers[/TH]
[TD="class: prCode"]N0U[/TD]
[TD]Cut pile seat covering[/TD]
[/TR]
[TR]
[TH="align: left"]Seat adjustment[/TH]
[TD="class: prCode"]3L3[/TD]
[TD]Manual height adjustment for front seats[/TD]
[/TR]
[TR]
[TH="align: left"]seat heater[/TH]
[TD="class: prCode"]4A0[/TD]
[TD]without seat heater[/TD]
[/TR]
[TR]
[TH="align: left"]Safety certificate[/TH]
[TD="class: prCode"]0LA[/TD]
[TD]Without special labels
safety certificates[/TD]
[/TR]
[TR]
[TH="align: left"]Side lights[/TH]
[TD="class: prCode"]8F2[/TD]
[TD]side-mounted turn signals[/TD]
[/TR]
[TR]
[TH="align: left"]Voice enhancer[/TH]
[TD="class: prCode"]VX0[/TD]
[TD]Without voice enhancer[/TD]
[/TR]
[TR]
[TH="align: left"]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH="align: left"]Protective side molding[/TH]
[TD="class: prCode"]4B1[/TD]
[TD]Protective side molding[/TD]
[/TR]
[TR]
[TH="align: left"]Sunroof roller blind for rear/side windows[/TH]
[TD="class: prCode"]3Y0[/TD]
[TD]without roller blind[/TD]
[/TR]
[TR]
[TH="align: left"]Supertone system and tone sequence
control[/TH]
[TD="class: prCode"]9J0[/TD]
[TD]Without supertone system and tone
sequence control[/TD]
[/TR]
[TR]
[TH="align: left"]power outlet[/TH]
[TD="class: prCode"]7B6[/TD]
[TD]12-volt socket(s)[/TD]
[/TR]
[TR]
[TH="align: left"]Bumper[/TH]
[TD="class: prCode"]2JB[/TD]
[TD]Standard bumpers[/TD]
[/TR]
[TR]
[TH="align: left"]parking light warning lamp[/TH]
[TD="class: prCode"]8NA[/TD]
[TD]without parking light warning lamp[/TD]
[/TR]
[TR]
[TH="align: left"]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N4[/TD]
[TD]Windshield wiper intermittent control
with potentiometer (four speeds)[/TD]
[/TR]
[TR]
[TH="align: left"]Nameplate set[/TH]
[TD="class: prCode"]1DG[/TD]
[TD]"TDI" (PD) lettering set[/TD]
[/TR]
[TR]
[TH="align: left"]Special alarm systems[/TH]
[TD="class: prCode"]9A0[/TD]
[TD]Without taxi alarm system[/TD]
[/TR]
[TR]
[TH="align: left"]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q1[/TD]
[TD]Mass damper for steering wheel, 26.5Hz[/TD]
[/TR]
[TR]
[TH="align: left"]Door and lid locking system[/TH]
[TD="class: prCode"]4K3[/TD]
[TD]Central locking w/ radio remote control,
interior controls and SAFELOCK[/TD]
[/TR]
[TR]
[TH="align: left"]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]B22[/TD]
[TD]Type approval country Israel[/TD]
[/TR]
[TR]
[TH="align: left"]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D1[/TD]
[TD]Carrier frequency 433.92 MHz[/TD]
[/TR]
[TR]
[TH="align: left"]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH="align: left"]Door and side trim panels[/TH]
[TD="class: prCode"]3LD[/TD]
[TD]door and side trim panels[/TD]
[/TR]
[TR]
[TH="align: left"]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV0[/TD]
[TD]without TV/digital radio reception[/TD]
[/TR]
[TR]
[TH="align: left"]Assembly parts for engine (drive bearing)[/TH]
[TD="class: prCode"]1VG[/TD]
[TD]Assembly part for 4-cyl. engine[/TD]
[/TR]
[TR]
[TH="align: left"]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH="align: left"]Identification plates[/TH]
[TD="class: prCode"]1EY[/TD]
[TD]Special identification label
with weight data, but without general
operating permit (ROW)[/TD]
[/TR]
[TR]
[TH="align: left"]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T2[/TD]
[TD]warning triangle[/TD]
[/TR]
[TR]
[TH="align: left"]Two-way radio installation preparation[/TH]
[TD="class: prCode"]9D0[/TD]
[TD]without prepared for two way radio system[/TD]
[/TR]
[TR]
[TH="align: left"]Front seats[/TH]
[TD="class: prCode"]Q2J[/TD]
[TD]convenience seat[/TD]
[/TR]
[TR]
[TH="align: left"]Preparation for rotating beacon/siren
combination[/TH]
[TD="class: prCode"]9F0[/TD]
[TD]Without preparation for rotating
beacon/siren combination[/TD]
[/TR]
[TR]
[TH="align: left"]Telephone / telematics[/TH]
[TD="class: prCode"]9W0[/TD]
[TD]Without car phone preparation/
installation[/TD]
[/TR]
[TR]
[TH="align: left"]LongLife Service Regime[/TH]
[TD="class: prCode"]QG2[/TD]
[TD]LongLife Service Regime cannot be
activated[/TD]
[/TR]
[TR]
[TH="align: left"]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E0[/TD]
[TD]W/o heat accumulator/auxiliary heating[/TD]
[/TR]
[TR]
[TH="align: left"]Windshield Glass[/TH]
[TD="class: prCode"]4GH[/TD]
[TD]Windshield in heat-insulating glass
with sunshield[/TD]
[/TR]
[TR]
[TH="align: left"]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH="align: left"]floor mats[/TH]
[TD="class: prCode"]0TA[/TD]
[TD]without floor mats[/TD]
[/TR]
[TR]
[TH="align: left"]Decorative trims[/TH]
[TD="class: prCode"]4ZB[/TD]
[TD]Bright decorative trims[/TD]
[/TR]
[TR]
[TH="align: left"]Additional body panels,
side[/TH]
[TD="class: prCode"]6EP[/TD]
[TD]Additional stone guard body covers[/TD]
[/TR]
[TR]
[TH="align: left"]Additional child seat anchors[/TH]
[TD="class: prCode"]3B4[/TD]
[TD]Child seat anchors for
child seat system ISOFIX[/TD]
[/TR]
[TR]
[TH="align: left"]Duty-free tires[/TH]
[TD="class: prCode"]1V0[/TD]
[TD]Without duty-free and cost-free tires[/TD]
[/TR]
[TR]
[TH="align: left"]Additional dust seals[/TH]
[TD="class: prCode"]6U0[/TD]
[TD]Without additional seals outside[/TD]
[/TR]
[TR]
[TH="align: left"]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
[/FONT]
[/FONT][/COLOR]
With the PR Codes data, we can refer to this Wiki Page and deduce the following:
Login:
0?xxx: Chassis - 9 = VW Passat
0x?xx: Brakes - 5 = (PR-1LB/1LE/1ZC)
0xx?x: Engine - 5 = (PR-T5X/T4N/T9J*/T6T/T1K/T1E/T7F*) (*with Brakes: PR-1LB/1LE/1ZC)
0xxx?: Transmission - 7 = Automatic (PR-G0E/G0F/G0Q)
So the Login is 09557
Coding:
0?xxx: Chassis - 4 = VW Passat
0x?xx: Brakes - 2 = (PR-1LB/1LE/1ZC)
0xx?x: Engine - 5 = (PR-T5X/T4N/T9J*/T6T/T1K/T1E/T7F*) (* with Brakes: PR-1LB/1LE/1ZC)
So the Coding is 04257
Now watch this video:
hamod_00
Middle East
ok thanks its work my freind
