English label files? When, if ever?
Henrick
Lithuania
LP/IP
Hello everyone.
Just wanted to ask, when, if ever, will English translation be done for some very popular cars here in Europe? Been waiting for the labels for ages and in 18.2 version they are still not there. :( These come here almost every day
Thanks..
Friday,22,June,2018,13:03:28:40776
VCDS Version: 18.2.1.2
VIN: WV1ZZZ7HZ4H0xxxxx   License Plate: GHZ575
Mileage: 541970km-336764mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ4H0xxxxx   Mileage: 541970km-336764miles
   Part No SW: 038 906 016 A    HW: 028 101 073 5
   Component: R4 1,9L EDC 0000SG  5226
   Revision: 12345678    Serial number: VWZ7Z0D8870694
   Coding: 0000031
   Shop #: WSC 02737 785 00200
   VCID: 1220789D0EF0C9D481-513C
16486 - Mass Air Flow Sensor (G70)
            P0102 - 000 - Signal too Low
                    RPM: 1092 /min
                    Torque: 38.0 Nm
                    Voltage: 12.46 V
                    Bin. Bits: 00000100
                    Mass Air / Rev.: 635.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
17978 - Engine Start Blocked by Immobilizer
            P1570 - 000 -
                    Torque: 0.0 Nm
                    Voltage: 13.22 V
                    Bin. Bits: 00000000
                    Bin. Bits: 11100000
                    (no units): 0.0
16705 - Engine Speed Sensor (G28)
            P0321 - 000 - Implausible Signal
                    RPM: 420 /min
                    Torque: 116.0 Nm
                    Speed: 6.0 km/h
                    Load: 66.7 %
                    Voltage: 12.39 V
                    Bin. Bits: 00000100
                    Idle Stabilization: 0.0°KW
                    RPM: 126 /min
16619 - Boost Pressure
            P0235 - 000 - Regulation Range not Reached
                    RPM: 2205 /min
                    Torque: 192.0 Nm
                    Speed: 96.0 km/h
                    Load: 70.6 %
                    Voltage: 14.36 V
                    Bin. Bits: 00000000
                    Absolute Pres.: 1876.8 mbar
                    Absolute Pres.: 1397.4 mbar
16567 - Fuel Temp. Sensor A (G81)
            P0183 - 000 - Open or Short to Plus - Intermittent
                    RPM: 2037 /min
                    Torque: 184.0 Nm
                    Speed: 89.0 km/h
                    Load: 60.8 %
                    Voltage: 14.29 V
                    Temperature: 93.6°C
                    Temperature: -22.5°C
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 000 -
                    RPM: 840 /min
                    Torque: 40.0 Nm
                    Voltage: 12.24 V
                    Temperature: 18.0°C
                    Temperature: 18.9°C
                    Temperature: 18.9°C
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 7H0-907-37x-ASR-F.lbl
   Part No: 7H0 907 379 E
   Component: ASR FRONT MK25      0103
   Coding: 0007206
   VCID: 3776E90945D2CCFCD6-513C
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 K
   Component: BORDNETZ SGVER 1.0  1901
   Coding: 0000100
   VCID: 3A70F03D76C0D19429-513C
00077 - Windshield Wiper Stop Switch (F229)
01598 - Drive Battery Voltage
            002 - Lower Limit Exceeded
00538 - Reference Voltage
            014 - Defective
01117 - Generator Terminal DF Load Signal
   Part No: 1C0 909 605 A
   Component: 3B AIRBAG VW51      0008
   Coding: 13122
   Shop #: WSC 02756
   VCID: 2240285DAE50B95411-5120
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 850 L
   Component: KOMBI+WEGFAHRSP VDO V01
   Coding: 02111
   Shop #: WSC 00222
   VCID: 336EDD1901AA20DCEA-5120
   WV1ZZZ7HZ4H080948     VWZ7Z0D8870694
            30-00 - Open or Short to Plus
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02737
   VCID: 70E41215303C5BC4D7-513C
            49-00 - No Communications
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component:    Komfortgerįt     0004
   Coding: 00079
   Shop #: WSC 02737
   VCID: 3260D81DFEB029D4E1-4B18
   Subsystem 1 - Part No: 7H1959801
   Component: Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: Steuerger
   Component: t Beif. antwortet nicht
00912 - Window Regulator Switch; Front Left (E40)
End-------------------------(Elapsed Time: 06:19)--------------------------
_Val
Latvia
C?ID=356659
Mexico, South Africa and Europe's market is too far from USA. They all speak German in here :D
