A couple months ago I experienced the pleasure of my timing belt disintegrating, which of course destroyed my top end. Due to funds instead of putting in a TSI or 2.5 I swapped for the same motor with only 22k. The only mods were intake and DP. Ran great until my DP broke at the turbo flange (looked like a weak thin weld), company sent me a new one which i change out and about a week after started throwing a p2177 code "Bank 1 system too lean off idle". After hours of research and diagnosing i cannot for the life of me find the culprit giving me the trouble code.
The car is an '07 A3 2.0t FSI, BPY Engine code...
Here is what I have tried and where I am at up to this point:
I have since switched back to stock intake and DP.
Replaced MAF, upstream O2 sensor, DV, Coil Packs, Plugs, PCV (new version) & Fuel Filter.
Had it tested for vacuum leaks.
Checked Fuel pressures via Vag-com, all seems to be normal.
Block 003 shows MAF reading air values in normal range. Blocks 15-16 are not showing any misfires. My LTFT in block 32 keeps rising to @ 20% within 10 - 15 miles of highway driving only under about 20% - 30% engine load at @ 2500 - 2900 rpms. The STFT in block 32 stays perfect between -0.5 and 0.8%. Block 33 Lambda fluctuates from 4% to 14% randomly which is indicative of a vacuum leak but cant find one to save my life.
I am stumped and virtually at my wits end. Does anyone have any ideas or experience with this type of situation. I am trying to keep from taking it to the stealership or other service center in my area simply because I don't want a second ***hole, plus the addition of a newborn is diverting the money I could pay them anyway.
Any help or possible theorems would be appreciated!!
Tuesday,07,October,2014,13:50:00:57138
VCDS Version: 12.12.3.0
Data version: 20140822
VIN: WAUHF78P87A065742 License Plate: YSK-6990
Mileage: 229380km-142530mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUHF78P87A065742 Mileage: 229380km/142530miles
01-Engine -- Status: Malfunction 0100
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8P0 907 115 P HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0010
Software Coding: 0103010A1C070160
Work Shop Code: WSC 09223 444 84432
VCID: 3F874F2B6EA28EE6A2D-806A
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 -
Fault Status: 01100001
Mileage: 229380 km
Date: 2014.10.07
Time: 13:50:25
RPM: 1865 /min
Load: 38.4 %
Speed: 74.0 km/h
Temperature: 90.0°C
Temperature: 28.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
Readiness: 0000 0100
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 C HW: 02E 927 770 AE
Component: GSG DSG 070 1125
Revision: 04507000 Serial number: 00000608090419
Shop #: WSC 06314 000 00000
VCID: 142DB08737A4BDBE2F5-8041
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-F.lbl
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H13001
Coding: 0053890
VCID: 68D5B4775BACE95E33D-803D
Part No SW: 8P0 820 043 M HW: 8P0 820 043 M
Component: KlimavollautomatH18 0300
Revision: 373905 Serial number: 8P0820043M
Shop #: WSC 02130 213 02130
VCID: 36692A0F41984FAE711-8063
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006111129
Coding: 018C4F01C0141019000F0064190032640009FE1F641200
VCID: 40854CD7135CF11EDBD-8015
Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 02130
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 A HW: 8P0 959 655 A
Component: Airbag 9.41 H12 3890
Revision: 91H12389 Serial number: 0035W0G01T77
Coding: 0032605
Subsystem 1 - Part No: 8P0 910 339
Component: BF-Gewichtsens. 001 0020
Subsystem 2 - Serial number: 3BF5H
Subsystem 3 - Serial number: 0001.01.000000100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB403C352B0Jÿ†63
Subsystem 5 - Serial number: 352B0Jÿ†6342DRB403C48B8B+ÿ†63
Subsystem 6 - Serial number: 48B8B+ÿ†63528RB40175925BKÿ†63
Subsystem 7 - Serial number: 5925BKÿ†63628RB4017589D3Rÿ†63
Subsystem 8 - Serial number: 589D3Rÿ†63729RB4018C11DEXÿ†63
Subsystem 9 - Serial number: C11DEXÿ†63829RB4018C117BPÿ
Subsystem 10 - Serial number: C117BPÿ
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H34 0070
Coding: 0012142
VCID: 418349D31856F816D43-8014
Component: E0221 H07 0090
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 H HW: 8P0 920 981 H
Component: KOMBIINSTR. VDO H18 0560
Revision: D0H18002 Serial number: 2247F002003015
Coding: 0000259
VCID: 3D7B352364AE9CF6B0B-8068
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 J HW: 1K0 907 951
Component: J533__Gateway H12 0160
Revision: H12 Serial number: 32001068028483
Coding: 3F3F034207002102
VCID: 2E59026FB9C8776E391-807B
Revision: D0H18002 Serial number: AUX7Z0F7FNS08M
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0001177
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346D100757E45DBE4F5-8061
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 D
Component: 02 KSG H04 0050
Coding: DBC003403F7F870FC04F047301
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674696594863
VCID: F1E35913E876A896E43-80A4
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0001176
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 K HW: 8P0 035 186 K
Component: concert II US H52 0460
Revision: 04S Serial number: AUZ5Z6F6031790
Coding: 0402004
VCID: 3A713E3F7580ABCE959-806F
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0001176
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0001176
End ---------------------------------------------------------------------
