Hello a audi a3 came into the shop and the owner said it has the abs light on i diagnosed it and it said the abs speed sensor has electrical fault in the circuit, i tried clearing the problem but it showd it again.I putted a new sensor in it and now it still shows the code after clearing the fault codes.
here a autoscan
looking at the steering assist it shows steering limit stop does it affect the speed sensor ?
here a autoscan
Friday,22,June,2018,12:14:04:50280
VCDS Version: 18.2.1.2 HEX-NET CB: 0.4411.4
VIN: WAUZZZ8P85A069407 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P85A069407 Mileage: 229820km-142803miles
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 7364
Revision: 12345678 Serial number: AUX7Z0D9FNE03Q
Coding: 0000072
Shop #: WSC 01455 264 89190
VCID: EC949CEFCF4F1F246B-80B8
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: BA386AB7F59B7194A9-80EE
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 105816 Serial number: 8P0820043D
Shop #: WSC 06314 000 00000
VCID: AD1251EB34D5D62C3C-80F8
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001125484
Coding: 05884F029214100000160000160000000000FE0F5C
VCID: BD3261ABE4B546AC8C-80E8
Subsystem 1 - Component: Fehler Lin-Slave 01
10 Faults Found:
02071 - Local Databus
00153 - Windshield Wiper Motor; Driver Side (V216)
01800 - Light Switch (E1)
009 - Open or Short to Ground
010 - Open or Short to Plus
01495 - Bulb for High-Beams; Left (M30)
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 2620
Revision: 91H10262 Serial number: 00362000PJU%
Coding: 0033622
VCID: C2C812579D4B3954F1-8096
Subsystem 1 - Serial number: 6332DRB400DC0E96.
Subsystem 2 - Serial number: 6342DRB400DC469B$
Subsystem 3 - Serial number: 63528RB4002B166BH
Subsystem 4 - Serial number: 63628RB4002B119FK
Subsystem 5 - Serial number: 63729RB4002BA85BU
Subsystem 6 - Serial number: 63829RB4002BA788U
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
VCID: B02C489F23E7BBC417-80E4
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 K HW: 8P0 920 930 K
Component: KOMBIINSTR. VDO H71 0210
Revision: D03 Serial number: 2249DD03035907
Coding: 0004148
Shop #: WSC 80093 222 69422
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104928044E
Coding: 3D3F0B42072102
VCID: A81CA0FF1B37F304CF-80FC
Revision: D03 Serial number: AUX7Z0D9FNE03Q
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8P0 959 801 F
Component: Tuersteuerger. H10 0030
Coding: 0000120
VCID: BE3066A7E9B35DB495-80EA
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.10 1401
VCID: AF2E4BE33ED9A43C0E-80FA
02546 - Steering Limit Stop
Mileage: 9800 km
Temperature: 29.0°C
Voltage: 12.30 V
Voltage: 12.00 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 E
Component: KSG H04 0050
Coding: 188000186D088505488F016000
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH02 0160
Revision: 00001 Serial number: 10000001189632
VCID: F1AA8D9BE86DF2CC58-80A4
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8P0 959 802 F
Coding: 0000120
VCID: BFCE1BA3EEB954BC9E-80EA
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H51 0100
Revision: 01S Serial number: AUZ2Z3D1532145
Coding: 0001001
VCID: B22842972DEB89D461-80E6
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG H10 0010
Coding: 0000216
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 B
Coding: 0000216
Component: PTC-Element 0404
End----------(Elapsed Time: 01:18, VBatt start/end: 12.3V/12.3V)-----------
