VW Transporter T6 TPMS Coding
exploria
C?ID=293062
i want to adjust the sensitivity of the TPMS on a 2016 VW Transporter T6
you can adjust it in adaptions on the abs control module but it requires a security code
the only security code in security access is for doing basic settings.
any help is appreciated
i have attached a scan of the vehicle
Wednesday,20,June,2018,14:08:36:64257
VCDS Version: 18.2.1.2 (x64)
VIN: WV1ZZZ7HZGH082091   License Plate: YG16VWP
Mileage: 23060km-14328mi   Repair Order: paul walton
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 55 5F 61 69 0B
VIN: WV1ZZZ7HZGH082091   Mileage: 23060km-14328miles
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 HJ    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 8378
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 01194012232401080000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20BTD01103L906019HJ 003005
   ROD: EV_ECM20BTD01103L906019HJ.rod
   VCID: 7AFC2B9BFD24589469-802E
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [032] - Malfunction
Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 43365000001458
   Coding: 347E4098656A84802C75027FA68321D3390000
   Shop #: WSC 02739 790 50316
   VCID: 3F8A9A8FA686BDBC1E-806A
   Serial number: 02121513471517
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF4278BE10C74B455-802A
   Part No SW: 7E0 907 047 S    HW: 7E0 907 047 S
   Component: Climatic-T5   H22 0607
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 3A7CEB9BBDA4989429-806E
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 342151077
   Coding: A0F4793A0A61349183284F606CEB8FF4C0A0738960CD79603204003F0820
   Shop #: WSC 60850 001 104857
   VCID: 68D861D39B88DA048F-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 081215 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 L    HW: 7E0 959 801 L  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU025111553297644
   Coding: 1400B1
   Subsystem 3 - Part No SW: 7E0 959 802 L    HW: 7E0 959 802 L  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU018111553222503
   Coding: 0400A1
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29150002156830035446
   Coding: A4FFFF
            000 -  -
                    Mileage: 23066 km
                    Date: 2018.06.20
                    Time: 13:17:44
   Part No SW: 7E0 919 475 R    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0210
   Revision: --------    Serial number: 32961530802594
   Coding: 210001
   Shop #: WSC 54321 321 68743
   ASAM Dataset: EV_VW75XParkAssis4K 001012
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 418E9C77D072CB4C68-8014
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00J 008 0016
   Revision: --------    Serial number: 003PH001ZEJS
   Coding: 00000000000000000000000000000000304A
   Shop #: WSC 02734 790 50316
   VCID: 377AF2AF8EB685FCD6-8062
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Component: KOMBI         H05 1008
   Coding: 470F010100
   VCID: 3362C6BF9ACE69DCEA-8066
13654544 - Databus
                    Fault Frequency: 248
                    Reset counter: 219
                    Mileage: 20086 km
                    Date: 2018.02.28
                    Time: 15:01:54
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042305
03158 - Control Module for Information Electronics 1 (J794)
                    Reset counter: 48
                    Mileage: 20086 km
                    Date: 2018.02.28
                    Time: 15:01:59
   Component: IMMO          H05 1008
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADC1BDB8D84E81499-803E
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Coding: 0FCE020001000000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC.rod
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 52327118031261123367
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 3068C9B363D852C497-8064
End-------------------------(Elapsed Time: 03:17)--------------------------
Issues with wheel speed sensors, wheel bearing pick-ups, and mismatched treads (i.e. 8/32" on one side and 7/32" on the other) are the most common causes of TPMS warnings when the tires are properly inflated and the same brand/model.
The indirect TPMS sensitivity shouldn't need to be modified in my opinion ... but I see the channel you spotted:
[*IDE04939-IDE09290*] Tire pressure monitoring display - Tire press monitor.display: warning sensitivity
Possible settings include values like:
Normal
Robust
Superrobust
Sensitive​
We don't have any official SA codes to offer aside from 40168 but you could try experimenting with codes such as the ones in post # 8:
http://forums.ross-tech.com/showthr...ssue-after-cluster-exchange&p=88737#post88737
Make sure you use a known good code (40168) after any are rejected to prevent lock-out. Advanced measuring value [*IDE00323*] Security Access: Number of invalid keys should be checked regularly.
Do let us know of any one of those happens to be accepted in this ABS module. Even if it doesn't allow you to change that particular channel we can note it in our files.
