Changing the map update count on the navigation
o33err
C?ID=317589
All new Audis are sold with 5 free map updates from the version installed at the factory. Where is this update count stored? Is it possible to reset it?
MasterTommy
Amsterdam
C?ID=295586
Probably stored on a server, not local.
o33err
C?ID=317589
But how will the car access this server with no data connection? You are able to perform a completely Offline Update using a USB or SD card with the update on it. Online Update is an option but not the only one.
golfi_vend
Tartu, Estonia
C?ID=195131
Isn't it 5 map updates from date of purchase. Meaning even if You don't update, the number still counts.
DJAlix
London, United Kingdom
C?ID=238277
When you update via the vehicle data connection the server side counter records this. If you choose to download and create a USB / SD card via myAudi then said creation communicates with the server side in order to update the counter, even if you don't apply the update.
o33err
C?ID=317589
Correct. So somewhere there must be a data field that stores what the original version loaded was? Otherwise how can the car determine if the update is within 5 versions or not
o33err
C?ID=317589
But there are people who claim that they share a USB drive between cars and the updates work as long as they are within 5 versions. So an account that has not downloaded any map update and that car has only used 'other' USB, and yet is able to determine that its had its quota of 5 updates. How is that done?
